[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So läuft meine Gamerock auch. Entspannt bei 320-350W je nach Auslastung. Ist für mich das beste Verhältnis aus Verbrauch und Leistung.
Beste Grüße
Ich hab ne FE. Power Limit 600W aber da meine ja nicht Werksübertaktet ist kann/muss ich mehr offset geben.
3045 bei 55 Grad in Time Spy Extreme packt meine auch. Kannst ja mal Unigine Heaven laden und mit den höchsten Settings laufen lassen. Würde mich mal interessieren was dann geht.
Das macht natürlich Sinn.
Das schau ich mir mal an, wenn ich später daheim bin. Ich dachte, dass meine Strix non-OC nicht werksübertaktet ist.
Bei mir fiept und rasselt die 4090FE auch... die Bananen-GameRock war da vieeeel leiser. Ich find meine Lösung immer noch am Besten und kann das auf alle Fälle empfehlen. Loch durch die Wand, Rechner in den Nebenraum, Kabel durch die Wand und schon ist es flüsterleise im Gaming-Raum.. Dafür stört dann der zweite Monitor, der bei weisser Fläche etwas fiept.. :d.
Vorteile:
  • Es ist egal wie laut er ist
  • Wen juckt RGB im Nebenraum
  • Es muss Dunkel sein für den OLED Monitor..
Nachteile:
  • Die Lebensmittel im Vorratsraum werden bei höheren Temperaturen gelagert.. keine Ahnung wieso..... :d
  • bei nem neuen Zubehör muss nen neues Kabel durch das Loch in der Wand..
Jetzt kommt mir nicht mit, "wenn ich das machen würde" steht der Rechner auf der Straße... :). Es gibt immer Möglichkeiten.. :d
Dieses extreme Spulenfiepen hatte ich bei meiner 2080 Ti von Aorus, 3080 Ti FE und nun bei der 4090 FE, bei der 4090 is es allerdings wirklich nur bei großer Last, also erträglich. Bins vermutlich schon gewohnt :(
Sollte rein vom PCB Design das beste auf dem Markt sein nach der HOF .
Die hat 26 Phasen mit 70A pro Phase wie bei den anderen Custom auch , aber eben auch flachere Spulen .
Aber die teile von Monolithic soll wohl das allerbeste sein derzeit.
Hat die Strix wohl auch und die TUF hat wohl von Infineon bzw alles bisschen gemischt^^ , aber kenne mich da garnicht so krass aus.
Hier mal die Strix als vergleich https://www.techpowerup.com/review/asus-geforce-rtx-4090-strix-oc/4.html
Hier noch der Teardown der TUF https://www.kitguru.net/components/graphic-cards/dominic-moass/asus-rtx-4090-tuf-gaming-oc-review/2/
Die Zotac mit den 24 Phasen wäre mal was komplett anderes von den Komponenten her und ist deutlich besser ausgestattet von
PCB Design als die ganzen 14 Phasen Dinger die es derzeit noch zu kaufen gibt.
Meine die 3090 Gainward GS die ich hatte war besser ausgestattet als manche 4090er derzeit auf dem Markt .
Glaube 16 oder 18 Phasen mit dem selben Komponenten , aber 365 Watt PL und plötzlich reichen davon ein 14 Phasen Design für 450 Watt aus ?
Kann sein , aber man will ja schon bisschen was für sein Geld und da darf es schon ein bisschen mehr sein.
Frag mal 2080 Ti Besitzer, da waren etliche Karten auf Kante genäht was VRM Design angeht, da sind einige mit durchgebrannten Mosfets über den Jordan gegangen.
Habe hier zwei 4090 FE.
Eine Karte bleibt und LuKü (auf 450 Watt begrenzt.
Eine Karte kommt unter WaKü (mit drei MoRa 3 420).
Was sind den so typische Taktraten (GPU/VRam) die man mit OC erreicht bei 450 Watt LuKü (Fractal Torrent) und 600 Watt WaKü?
Und welche Temperaturen sind denn ein vorsichtiges Limit für GPU/Hotspot und VRam?
Danke und Gruß
so es geht ja nun hier weiter ;D in der zeit hat sich ein wenig was getan , bin weg von der strix was ich schade finde und bin auf die tuf gewechselt ............ war auch kein großer fehler auch wenn sie optisch mir nicht ganz zusagt , ja auch die tuf hat spuhlenrasseln aber das finde ich nicht so schlimm da das rasseln erst unter last anfängt und im idle nicht ............
weiter ist das kabel von seasonic angekommen , es gab nach der uhrsprünglichen anerkennung seitens seasonic keine mail mehr , einzig da ich beim angeben der daten meine handynummer hinterlassen habe hat mir fedex vorab eine sms geschickt und ich konnte den versand aus asien tracken ......... ging recht fix letzte woche mittwoch auf reisen und war am wochenende dann in deutschland und heute zugestellt
tja da muss man mal cabelmod dissen , 2 einzelbestellungen , beide seperat , das erste was angeblich am 8 raus ist hat sich immer noch nichts getan (via dhl die haben aber das paket noch nicht sonder nur ankündigung) zweites paket wurde irgendwann letzte woche "rausgeschickt" (cabelmod ist auf dpd gewechselt ) tracking kommt aus asien , angeblich wurde es da am 17. in chenzen eingesammelt hat sich aber auch noch nicht weiter bewegt
cabelmod is leider ein sehr fragwürdiger laden ..... kann man sich auch gleich die kabel in china bestellen ohne umwege über cabelmod us oder gar cabelmod-eu .........war das letztemal das ich da bestellt habe
noch ein paar bilder vom seasonic kabel das auf nachweis eines netzteil der entsprechenden klasse sowie graka verschickt wird ............ das was native bei ist bei entsprechenden netzteilen sieht glaub ein wenig anders aus , das ist mir aber lieber da besser biegbar nicht so ein riesen fropf am graka ende
Meine geht schon bei +180 auf 3045. Dann ist aber Schluss. Was für ein PL hast du?
Ach ja und 55 Grad Core.
Auf +xxxMHz-Angaben kann man nicht viel geben
Flasht man ein OC-BIOS oder das der Strix auf eine Non-OC-GPU, muss man weniger angeben, weil der Defaulttakt ja höher ist bzw. am max. Takt
Ich habe heute in der Pause mal mein System auf Default, OC und Undervolting getestet mit Stromanzeige in W mit voller Gaminglast in 4K mit RT.
Same here. PUBG in 1680x1000 (low Details) erst ohne FPS CAP mit 5.7GHZ CPU und 3.0GHZ GPU gezockt. Bei 500FPS+ zieht er da richtig aus der Dose, obwohl nur low Settings, dafür aber halt FPS des Todes. 150W CPU und 300W GPU teilweise.
Jetzt mit 5.5G CPU und 2.7G GPU mit einem FPS CAP bei 237 FPS (240 Hz Monitor) habe ich teilweise nur 70W CPU und 60W GPU... GPU taktet teilweise nur 800-1200Mhz und die FANs der FE laufen bei 0 RPM mit nur 40-60W.
Strompreis hat sich hier von 29 Cent auf 61 Cent verdoppelt. Da macht so ein Setting schon Sinn. 200W statt 500W auf Dauer, bei ca 5-6h / Day PUBG, macht am Ende schon was aus.
Mit einer 4090 für PUBG in den Settings sich über Strompreise aufregen ist auf der anderen Seite auch irgendwie paradox ;) zumal direkt neben dem PC ein 550l Aquarium steht, das auf 26c Wassertemperatur gehalten werden will mit einer Beleuchtung oben drüber, die wohl aktuell den Verbrauch des PCs übersteigt... :ROFLMAO:
Danke und Gruß
Und was mir noch auffällt. Egal ob ich 90% oder 100% PowerLimit mache. Die Karte hängt immer bei 2700 MHz fest.
Ja das Ding ist schon durch war bei meinem Saturn vor Ort .. Der Verkäufer sagte auch das er die Karte mit Spulen fiepen als defekt deklariert.
Er meint sowas darf einfach nicht sein bei so einem teuren Produkt versteht er meine Rückgabe !
Dann wieder Willkommen zurück bei den 4090 Suchenden
Nach deiner Gigabyte Master und der TUF was kommt da nun als nächstes bei dir ?
Kabel-Alarm!!! (mom. verfügbar)
Mach mal Furmark @ 4K ohne AA (max. 2x AA) :fire::d
An alle mit "Speedway"...
Ist das neuerdings im 3DMark-Paket mit drin oder konnte man das kurzzeitig mal umsonst ziehen?
Kostet mom. genauso viel, wie das gesamte "Advanced-Paket" als Aktion
Ja das ist so eine Frage die Master für 2100 und Wasserkühler wäre top gewesen aber nich für 2400€+ 260€Wasserkühler .
Die Strix soll ja auch oft mächtig Spulen Stress machen !
Danke und Gruß
Das versuche ich auch zu erfahren. Gestaltet sich schwierig, wenig resonanz und meist unpräzise. Was ich Dir sagen kann, das Power Limit drosselt selten bzw. bei 600W gar nicht. Entscheidend ist dann, wie viel OC der Chip verträgt.
Ich versuchs mal mit nem neuen Thread um da mehr Feedback zu bekommen.
Ja das ist so eine Frage die Master für 2100 und Wasserkühler wäre top gewesen aber nich für 2400€+ 260€Wasserkühler . ... Die Strix soll ja auch oft mächtig Spulen Stress machen !
Jup ich werde dann berichten wie und ob meine zukünfttige 4090 Strix dann bei max 117 FPS fiept oder nich fiept sollte ich die mal irgendwann im Asus Shop erwischen.
Also wird es bei dir dann wieder ne Master wenn es die dann mal für 2100 Euro geben sollte ?
Also wird es bei dir dann wieder ne Master wenn es die dann für 2100 Euro mal geben sollte ?
Ich weiß es noch nicht !
Die hat zumindest fast gar nicht gefiept da musste man auf Paar Zentimeter mit dem Ohr ran um was zu hören !
Bei der TUF waren 3m noch nicht weit weg genug um sie nicht mehr zu hören!
Wie angedroht ;) Hier ist die kleine 4090 daily OC Umfrage.
Ich wäre für ein bissl feedback dankbar. Der verlinkte Test (Heaven 4.0) ist ganz gut zum ausloten geeignet, da klein & unkompliziert, kein unsinniger Power-Virus aber gnadenlos um Fehler aufzudecken.
Auf gehts!
Strix und Tuf verhalten sich sehr ähnlich bzgl. Spulenfiepen. Würde da aktuell wenn man empfindlich ist nicht drauf setzen.
Beste Grüße
Bei welchem Game/Bench war sie so laut?
FPS, PL, Takt etc nicht vergessen
Bei allen Spielen!
Spiderman ,Cyberpunk,Red Dead ,Dark Tide egal ob 65 /80 /90/ 115 FPS egal ob UV oder original V ob 280 W 350 W 415W
Hab meinem Bruder gerade Sprach Nachricht geschickt mit einer Aufnahme er meinte was ist das ein Elektro Motor 🤣
Die Surrte echt in jedem Spiel
Wie läuft das genau? Einfach den Support anschreiben und Rechnungen von NT und GraKa als Screen hochladen?
Selbes Verhalten wie bei der Strix die ich hier hab. Kollege kauf jetzt meine Gamerock OC. Hab zur Zeit keine Aufträge also brauch ich so viel Render/Spieleleistung nicht. Der Dümpelt noch mit ner 2060 rum und hat sich einen 4k Monitor geholt. Bin da mit 2x 1920x1080 genügsam. Da reicht die 3080 FTW3 locker bis die Preise wieder okay sind. Übern Winter ist es da eh entspannter mit den Renderaufträgen.
Beste Grüße
Meine TUF...
Case ist aktuell schlecht durchlüftet. Momentan 48°C GPU bei 0% Lüfter
Was habt ihr so bei 0% Lüfter?
kann eig net sein. meine tuf idlet
1 youtube video läuft im hintergrund
ich sollte eventuell erwähnen dass alle lüfter @ 800 rpm laufen
3x120mm front
2x 140mm top
1x 140mm back
@LtSnoopy , wollte es eben für dich raussuchen aber leider ist das mit dem kabel seitens seasonic schon rum und muss käuflich erworben werden ...... (nicht seasonic dissen) promotion ist rum und muss wie bei anderen herstellern nun gekauft werden
Sehe gerade mein AX 1000 wäre eh nicht beigewesen. Das ungesleevte hab ich schon bestellt und verbaut, das funktioniert gut.
Aber wenn man noch eines umsonst hätte abgreifen können, nimmt man das gerne mit :d
So jetzt hat auch nach Supportanfrage der Prio Invite Link von GE geklappt. Konnte zwischen 4080 FE und 4090 FE wählen. Da fiel die Entscheidung ziemlich leicht. Bin mal gespannt ob die 4090 FE was taugt. Bin wegen Fiepen und Lüftergeräusche gespannt. NBB bietet ja auch bis zum 31.01 verlängerte Rückgabe an. Kann man dann ja entspannt schauen ob die AMD doch was taugt.
Ich schrieb ja, dass das bei mir versch. Ursachen haben kann...
Hatte noch keine Zeit und Lust danach zu gucken, denn die Zeit, die ich hatte, wollte ich seit Langem mal wieder mit zocken verbringen ;)
Welches OS und Treiber-Version?
Und was hast du bei "Power Comsumption %"
win 11, aktueller treiber
zimmertemp ca 20grad würd ich schätzen
der airflow hilft natürlich etwas. wenn ich die balkon tür aufmache hat die karte nach ein paar minuten 19grad :d
Ähnliche Themen
Antworten
7K
Aufrufe
540K
