[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist es irgendwie möglich 4080 und 4090 im Telegram channel / Verfügbarkeitsthread zu trennen oder wäre das zu umständlich?
Grüße
Sicherlich mit dem offenen Aufbau der Worst-Case. Allerdings mit immer derselben Smartphone-Kamera und nur 2 unterschiedlichen Aufbauszenarien (z.B. Thema Raum-Akustik) hoffentlich halbwegs vergleichbar.
Zum Hochladen auf Youtube fehlt mir gerade die Zeit, daher nun auf diesem Wege (läuft morgen ab, ca 650Mbyte):
PW: Luxx
Hier und da hat mir das Spiel die Aktivierung/Deaktivierung von DLSS nicht korrekt übernommen (habe ich leider erst später entdeckt).
Aber man sieht die Fps und die Auslastung der Karte ja trotzdem.
@postmymind
Wie warm genau wird deine TUF unter Wasser?
Hier noch mal ein Ergebnis von gestern: 10er Loop Port Royal mit 120 l/h flow und 27,3 Wasser. Setup im Silent betrieb. Gekühlt wird mit 3x360er Rads + einen Mo-Ra3 420 Pro extern. Lüfterdrehzahl entsprechend angepasst. (Allerdings kein OC Bios auf der normalen TUF)
Diskussion dazu im Parallelthread: https://www.hardwareluxx.de/community/threads/nvidia-ada-lovelace-40xx-wasserkühler.1323682/page-16
Seit dem aktuellen Treiber 562.98 kann ich den Vram Takt höher fahren, kann das hier jmd. bestätigen?
Juhu,,, der Thread ist wieder offen. Und ich melde: FE ist verbaut. Man ist die schön. Fun fact: offiziell die einzige die in meinen Jonsbo U4 Plus passt aber ich hab auch die Zotac Airo und die Gainward rein gebracht - nur ohne Netzteil :devilish:
Jetzt wo ich etwas OC Erfahrung habe. Welche Taktraten (GPU, 1.05V und 1.1V) habt ihr denn stabil anliegen? Bzw. welches OffSet? Ich mein nicht Fester auf, benchsetting etc... sondern was geht gerade noch so im Alltag?
Finde die Wassertemp etwas niedrig bzw. GPU-Temp etwas zu hoch
Wieviel "Board Power Draw" waren das? War mit dem EK nicht mehr rauszuholen? Für 240€ bzw. 400€ inkl. ABP erwartet man schon was, ja
Ich würde einfach das Powerlimit auf 70% setzen. GPU Takt auf +150mhz und Speicher auf +750mhz.
Ca. 4-5% weniger FPS, aber nur knapp 300W. Den Performanceunterschied wirst du nicht merken. Aber die bessere Stromrechnung schon :)
Anders, wie bei meinen 3x 3090 habe ich mit meiner bescheidenen 4090 in den letzten Wochen mehr gezockt, als gebencht :fresse:
Alleine 200h mit "Kingdom Come" - traumhaft, dass das so schön flüssig läuft :)
„Schatten“ musste ich jedoch auf „Hoch“ reduzieren, da diese sehr an der CPU (5950X) zerren, wie @HisN schrieb
Settings sind...
70% PL +180/1.200 (GPU/RAM)
(nur grob eingestellt)
Waren 507W Board power Draw. Bitte beachten, dass es sich hier um die Variante ohne ABP handelt. Mit ABP hätte ich keine zwei 4090 nebeneinander bekommen aber ja, ich hätte auch gedacht die Temps wären etwas besser. Letztendlich funktioniert es auch so aber schade ist es. Ich gebe ein Statusupdate pro Karte, wenn das zweite GPU/Block-Set ebenfalls im Loop hängt.
Hey zusammen,
kann es sein, dass das Firmware-Update (Leerer Startbildschirm), die 4090 FE langsamer macht?
Ich hatte nach dem BIOS Flash/Update reproduzierbar 5% weniger Leistung bei EZ Benchmark (90% Powertarget sowie 100% Powertarget).
Alle Parameter gleich.
PS: Ich habe das BIOS nicht auf CSM umgestellt (ASUS B550 ROG STrix), habe einfach die .exe gestartet und es hat wunderbar geklappt.
Aber ich möchte doch einfach nur wissen, was die Chips im Schitt so schaffen und wo meine liegt :rolleyes2:
Wieviel mm fehlen geschätzt, damit ABP passen würde?
Hey zusammen,
Müsste man mit älteren Karten gegentesten...
Was das Booten auf jeden Fall langsamer macht ist "CSM on"
War bei dir aber "off" wie du schreibst
Ich meine nicht das booten, sondern Benchmarks.
GraKa neu eingebaut Treiber installiert und dann Benchmarks.
Dann dieses Bios update und plötzlich waren die Benchmark-Ergebnisse schlechter.
Könnte aber auch ein Win-Update gewesen sein...
Achso :)
Alles was unter +1200 Speicher ist, ist unterdurchschnittlich.
GPU Takt liegt so bei 3050 - 3075 mhz in Benchmarks bei Timespy Extreme durchschnittlich.
Du wirst dich wundern, ich habe jetzt eine FE, eine PNY und meine TUF persönlich gehört, überall sind die Spulegeräusche deutlich hörbar, vor allen bei den 600 Watt Karten - für diese 450 Watt Dinger mit ihren Billig-VRMs mit 14 Spulen würde ich keine 2000,- legen, vor allem weil mir die 150 Watt fehlen würden, wenn man mal ne 600 Watt Karte hatte, den vor allem die Raytracing Games ziehen Watt ohne Ende. ;)
Welche Karten haben für dich "Billig-VRMs"?
Jene Karten, die vergleichbare Spulen besitzen, die man auch auf 150€ Mainboards findet.
Ob die Karten jetzt schlechter sind, sei mal dahingestellt.
:coffee2:
Naja irgendwas scheint bei den "hochwertigeren" Spulen nicht zu stimmen, da gerade die Asus und MSI Karten zumeist unerträgliche Spulengeräusche haben (können) und ich meine nicht etwas, sondern unerträglich. Hatte selbst eine Suprim X hier, da ich ein riesen MSI Fan bin aber die Karte war absolute katastrophe, was Spulenfiepen und Lüfterrattern anging. Die inno3d dagegen ist flüsterleise, minimales zirpen, was man bei 800rpm drehenden Lüftern und der CPU AIO Pumpe nur hört, wenn man bei offenem Gehäuse 5cm vor der Karte hängt!
Es ist klar, dass Trill seine TUF verteidigt, denn wer würde schon gern sagen, dass die Karte super verarbeitet ist aber die Spulengeräusche unerträglich sind (außer man ist schwerhörig). Wenn man es im Forum schreibt, glaubt man es am Ende vll. noch oder man ist vll. einen Moment zufrieden mit den Geräuschen der Karte und redet sie sich weg!
Was diese Generation der Nvidia Karten deutlich gezeigt hat ist, dass es wirklich egal ist, wie das PCB Layout designed ist oder welchen Hersteller man favorisiert. Selbst die "Einstiegskarten" können top Chips verbaut haben und die Karten à la Strix etc. können trotz perfektem PCB Layout keine 3000Mhz halten. Am Ende kommt es auf die Geräuschkulisse und die Temperaturen an, auf mehr nicht! Die Karte hat selbst mit Stock Takt mehr als genug Leistung und viele undervolten ihre Karte sowieso!
Welche Karte idlet denn bein 53C°?
Endlich dabei:bigok:, zum Glück super leise die Karte, Gehäuse bleibt erstmal offen, wegen Stecker...
Die Strix liegt so bei 30 Grad im Idle.
Beste Grüße
Ähnliche Themen
Antworten
7K
Aufrufe
467K
