[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die TUF OC gab es letzte Woche im ASUS-Shop für 2.169,90 Euro. Habe glücklicherweise eine abstauben können. Das mit dem Spatz (Gigabyte Windforce) würde ich so unterstreichen. Mir würde die TUF auch gut gefallen. Aber da die Windforce kein Spulenfiepen oder andere auffällige Eigenschaften hat, werde ich vermutlich auch bei dieser bleiben.
Ich habe das noch gar nicht so mitbekommen. Habe auf der Map "Gestrandet" (das ist die Karte mit dem aufgelaufenen Containerschiff) gespielt. Du meinst schon den Board Power Draw? Habe das Logfile von GPU-Z noch einmal überflogen. So wie ich das auf die Schnelle gesehen habe, war da der Wert nicht einmal bei 300.
Dann gibt es da dch eigentlich nicht viel zu überlegen :)
Die Windforce hast du -30€ Cashback für 1919€ bekommen, die TUF würde also 250,90€ teurer sein. Dafür bekommst du ne Karte die in jedem Fall schicker ist, einen besseren VRM hat und ein 600W Bios und potenziell bis zu 3% schneller ist. Dafür wird sie eben sehr wahrscheinlich auch noch fiepen....
Also meine Entscheidung würde feststehen bei dem Preisunterschied und auch wenn du die Karte in 2-3 Jahren wieder verkaufst wirst du die 250€ nicht wieder rein bekommen. Der fette VRM hilft am Ende des Tages eben auch nicht wirklich, weil UV/Powerlimit bei der 4090 einfach Sinn macht.
Ich glaube man lässt sich bei der 4090 einfach unnötig verrückt machen. Klar, es ist sehr viel Geld und jeder will das beste für sein Geld... Am Ende des Tages kostet es aber eben auch einfach Zeit auf die Karten zu campen und dann muss man eben auch noch den Kauf durch bekommen... auch Zeit ist Geld (wenn man Überstunden bezahlt bekommt) und ich vermute mal wer eine 4090 hat, der wird nicht unbedingt einen unterdurschnittlichen Stundenlohn haben.
Alle Karten funktionieren prima und bei der 4090 gibt es realisitisch und alltagsrelevant einfach nur feine Unterschiede. Es gibt Modelle die man meiden sollte wegen Lüftergeräuschen zB, aber technisch funktional sind die alle vergleichbar und auch ein "schlechter" VRM wird sicher 4 Jahre überleben, sonst wäre alleine die RMA Quote in den 3 Jahren Garantiezeitraum zu hoch.
Gibts hier eigentlich jemanden der so mutig war eine 4090 FE in ein Meshlicious einzubauen? Mich würde vor allem interessieren wie es mit dem Stromanschluss aussieht. Theoretisch sollte sie reinpassen, die 3090FE ging auch rein aber die Geschichte mit dem berüchtigiten Adapter zur Seite macht mir da Sorgen.
Sollte gerade so passen, aber dann mit Sicherheit nur ohne Radi vorne, damit genügend Platz für den 16pin Stecker wäre (ohne Radi würde nochmal 2,6cm bringen, so dass man dann knapp 3,5 bis 4cm hätte)
3080TI Strix: 318.5x140.1x57.78mm
4090 FE: 304x137x61mm
Wenn der laute Luftkühler weg ist, hört man erst mal wie laut die Karte eigentlich ist.
Meine 4090 TUF bei F@H
Wasser im Moment des Screenshots etwa 30° .. also die üblichen 16k Delta
Gesundheit ;)
Hast du nicht gesehen, welchen Zeitstempel mein Beitrag hat, oder wohnst du in den USA??
Also ich komme aus Deutschland und dein Beitrag war bei mit nach 16 Uhr. Wenn der Verkauf ab 14 Uhr startet bedeutet das nicht, dass 16 Uhr ein Kauf möglich sein muss... Wann sollte denn sonst ein Kauf unmöglich sein? 13:59-14 Uhr? Man kann auch freundlich sein ;)
Also so Hustgeräusche hatte ich noch nie bei einer GPU, ob da nicht was kaputt ist? :P
Danke, das habe ich befürchtet. Mit Winkel-Adapter würde es vermutlich ganz gut gehen aber die sind aktuell ja nicht wirklich zubekommen.
Glaube deine Karte hat eine Erkältung. Und das bei 30 Grad.
ab 170 FPS fängt bei mir dann gaaanz leise Spulenfiepen an, aber selbst mit 500FPS ist es immer noch ein wirklich leises Geräusch. Da ich eh auf 116FPS limitiere habe ich somit nie Spulenfiepen und die Karte wird definitiv behalten. Es gibt sie also doch: :bigok: Eine Leise 4090 Strix OC, ohne Spulenfiepen!* :bigok: *bis 170FPS jedenfalls :sneaky:
Deckt sich mit meinen erfahrungen der letzten 10 Jahre die ich vorhin ja auch schon hier niedergeschrieben hab.... für Leute mit nem 120hz Monitor und somit nem FPS Cap von so 117 FPS is
Spulenfiepen absolut kein Thema ... das mag bei Leuten mit 240 Hz + Monitoren dann aber schon anders aussehen aber für die 120hz Fraktion zu der ich gehöre kein Problem
Aber kann natürlich auch sein das es empfindliche Menschen gibt die schon bei 120 FPS das fiepen hören das will ich garnich ausschliesen nur sollte man die Sache nich verallgemeinern
und sagen diese Karte fiept bei jeden also kauft die nich sondern da gibt es noch andere Faktoren die man da mitbedenken sollte Menschen sind unterschiedlich bzw haben unterschiedliche Empfindungen
und nutzen Unterschiedliche Monitore bzw FPS und haben eine unterschiedliche Geräuschkulisse ( Bei mir zb 7 x 140mm Lüfter mit 1200 -1500 Umdrehungen beim zocken + ne Fiepende D5 Next Pumpe )
Puhhh, Danke für das Video mit F@H Geräuschkulisse ... da ich eine 4090 ausschließlich zum Falten mit Wakü möchte, fällt die Asus so leider völlig raus.
Also dann wohl doch auch Zotac, schade eigentlich ... ick war mit Asus bisher immer happy :(
Ich muss alle 2 Jahre einen Hörtest machen und meine Ohren sind soweit Top .
Thx, damit konnte ich es perfekt ausloten, ab 170 FPS fängt bei mir dann gaaanz leise Spulenfiepen an, aber selbst mit 500FPS ist es immer noch ein wirklich leises Geräusch, da war meine 3090FE um das 10 fache lauter. Da ich eh auf 116FPS limitiere habe ich somit nie Spulenfiepen und die Karte wird definitiv behalten.
Meine Phantom wurde vor 5 Minuten von einem EKA Käufer abgeholt, die Lüfter waren echt ein absoluter Graus.
PS:
PPS:
Mein süßes 700 Watt Netzteil macht selbst bei der Strix und 133% PT Limit keinerlei zicken :banana:
Extremtest:
Im PUBG Hauptmenü ist das aber alles echt am Limit:
Anhang anzeigen 816523Anhang anzeigen 816524
Wie ist die Lautstärke der Lüfter im allgemeinen nutzt du den OC Mod oder das Silent Bios.
Wie sind die Vram Temps bei hoher last .
Kannst du ja über HW INFO mit einbinden die Infos im AB.
Würde dir die KFA2 ans Herz legen, hat 22 Phasen und die hohen fast lautlosen Spulen, zumal mit 1999 Euro günstiger als die Zotac, Powerlimit max ist bei 510 Watt, aber das reicht ja vollkommen und wenn nicht Strixbios drauf. Layout ist auch Ref
Ist man bei der KFA2 lärmtechnisch auch auf der sicheren Seite? Im Wakü-Sammelthread benutzt die KFA2 die gleichen VRMs wie Karten, die Lärm machen (Gainward).
Ich nutze den Quiet Modus und es ist wirklich schön ruhig.
Hier die Temps nach Cyberpunk:
...was hat denn das mit Unfreundlichkeit zu tun?
Ich zitier mal den Shop:
"Der Verkauf von vorrätigen Karten öffnet täglich (Montag bis Freitag) um 14.00 Uhr."
Also worin liegt dann das Problem, dass ich kurz vor 16 Uhr keine Karte kaufen/bestellen kann, obwohl der Status auf "sofort Lieferbar" steht (inkl. der Vorrätigen Karten -> 9 Stück)?
Wenn man mich aber mit dem Hinweis zitiert, dass der Verkauf erst "ab 14 Uhr" startet, unterstellt man mir, dass ich evtl. zu früh bestellen wollte oder ich evtl. nicht lesen kann. Und es heisst auch nicht "Verkauf nur zwischen 14Uhr - 14:30Uhr oder so, dann kann ich wohl davon ausgehen, dass ich 15:45 Uhr bestellen kann, wenn 9 Karten ab Lager lieferbar sind.
Das ergibt irgendwie kein Sinn, die Lüfter der TUF sind so leise dass man bereits minimales Fiepen heraushören kann.
Dass die Karte nach Wakü Umbau lauter fiept basiert eher auf den Umständen dass sich Anpressdruck auf die Spulen, Kühler als Resonanzkörper und Dämmung verändert.
Die Karten gehen jeden Tag "ab 14 Uhr" in den Verkauf, du kannst dich auch auf die Benachrichtigungsliste setzen lassen, dann bekommst du etwa 30 Minuten vorher eine Info per Mail, wenn die jeweilige Karte verfügbar wird.
Dann geht die Karte zu der Zeit in den verkauf und du hast vielleicht 2-3s die Transaktion abzuschließen und die Karte vorher in den Warenkorb zu legen ;)
Dass die Karte nach Wakü Umbau lauter fiept basiert eher den Umständen dass sich Anpressdruck auf die Spulen, Resonanzkörper und Dämmung verändert.
Du findest die TUF "leise"?
Sorry. Ich fand die Geräuschkulisse mit Luftkühler unerträglich. Und ja, es war schon vorher zu hören. Das hat ja auch niemand gesagt, dass es vorher nicht da war.
Jap die KFA ist leise, sagen auch diverse Tests
Du weisst schon, was du gerade für nen Käse schreibst?
Die Benachrichtigung per Mail habe ich längst aktiviert, aber bis heute noch keine Mail von dem Saftladen bekommen.
Aber hey, wer weiss, vielleicht bekomme ich dann in 14 Tagen eine Mail, dass die Karten, die seit zwei Wochen im Lager rumgammeln nun in den nächsten 5 Minuten "verkauft" werden ;)
...egal, mit diesem sogenannten "Online-Shop" habe ich jetzt persönlich abgeschlossen.
Ich kann warten, ist ja nicht gerade so, als meine 3090er ne lahme Krücke ist^^
Ich hab mir den Kühler für die 4090 nicht der Temperatur der Karte unter Luft wegen gekauft, die sind ja echt Bombe. Aber die Abluft heizt mein Gehäuse übel auf, was mich nervt.
Aber was da beim Zocken rum kommt, wenn man nicht gleich "all in" geht. Das ist ja der Hammer.
8K Delta zum Wasser.
Sieht ungefähr aus wie ein PS3-Game :ROFLMAO:
Mein Kabel wurde am 1.11. verschickt, bisher null Updates beim DHL-Tracking. Naja, habe das Corsair-Kabel als Übergangslösung.
Bei mir Bestellung am 31.10 und Versand am 3.11. Tut sich ebenfalls nichts. Verstehe nicht warum die überhaupt einen "EU Store" haben wenn das eh mit der anscheinend langsamsten Versandmethode aus China kommt. Habe schon mal was bei Wish bestellt und das war schneller da :LOL: Zumal mein Kabel jetzt auch kein Custom ist
Hast du sie vielleicht im OC Modus laufen gehabt weil da dreht sie auf jeden Fall auf laut Tests.
Ich hab sie im Auto und mit angepasster Kurve arbeiten lassen. War mir alles nix. Vor allem weil die Umwälzpumpe ja das ganze Gehäuse aufheizt plus aller Komponenten drinne, und die übrigen Gehäuselüfter ja auch zu "Mehrarbeit" zwingt.
Jetzt ist Chic.
Hier das gleiche bestellt am 28.10. Verschickt am 3.11. Da müssen wir uns anscheinend noch bissl gedulden bis der Dampfer da ist :LOL:
Ähnliche Themen
Antworten
7K
Aufrufe
541K
