[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
+ Undervolting
Spulenfiepen bei der GTX 280 war damals der Grund, warum ich mir gesagt habe, dass ein PC unter und nicht auf dem Tisch gehört.
Hab meine 3090 Strix damals extra mit einem Plexi Würfel gedämmt, war für mich sonst nicht auszuhalten😩
Aber mag das wenn man alles im Sichtbereich hat - dafür hat man die schicke Hardware ja 😁
Hab auch so meine 3090 Strix Erfahrung. Man hatte gedacht es könnte nicht schlimmer kommen bis ich dann die 4090 Strix eingebaut hatte. Ist echt Körperverletzung sich das anhören zu müssen.
Irgendwie schwer nachvollziehbar, dass einige hier so krasses Spulenfiepen haben. Ich hatte noch keine Karte, welche unter normalen Bedingungen (Spiele < 300 fps) fiepte. Klar in Furmark bei 600+ Fps oder im Menü bei Doom mit 1000 fps hab ich das auch, aber wer braucht so hohe Frames?
Ich brauch hohe frames
Wundert mich auch. Ich hatte damit noch nie Probleme.
Scheinbar kennen hier auch welche alle Strix Besitzer.
Dann halt doch mal alle Lüfter an bei dir bzw. Regel sie auf Silent und mach ein Video nahe der Karte mit Timespy Bench 1 . Ich wette ich höre das Ding fiepen. Genau so wette ich, hören andere es nicht. So ist das halt mit fiepen.
Mach mal ein Experiment. Bewege dich bzw. deinen Kopf / Ohren im Raum (auch mal die Höhe verändern). Das Blöde bei diesen hohen Frequenzen ist, dass die Schallsegel recht schmal sind. Das heißt allein schon wenn du mit deiner Sitzposition oder mit der Position deines Gehäuses eine Veränderung um wenige Zentimeter vornimmst, kann das erträglich oder komplett vollgas da sein.
Ich habe das mit meiner TUF damals versucht. Wenn ich das Gehäuse in einen anderen Winkel gedreht habe war der Löwenanteil des hörbaren Tons weg. Es blieb aber der "Druck" auf dem Ohr. Es kann also sein dass bei dir einfach nur alles günstig steht. Bei mir steht der PC 40 cm neben mir direkt auf Kniehöhe. Da ist auch keine Tischplatte dazwischen. Und links daneben ist eine Wand und ein bodentiefes Fenster (beides also schallhart).
Gibt es ein Spiel und/oder Benchmark wo ich die FPS am besten per Tastendruck regulieren kann?
Ich habe hier bei meiner Strix leichtes/leises Spulenfiepen, aber ich möchte gerne herausfinden ab welcher FPS Zahl dieses hier genau beginnt.
In Quake 2 RTX kannst du die Target FPS in den Optionen einstellen. Der reguliert dann die Auflösung automatisch runter.
Das Problem ist nicht alle Strix Besitzer zu kennen. Das Problem ist, dass alle Ohren unterschiedlich sind. Manche sind sehr empfindlich und nehmen es extrem deutlich wahr, manche hören es gar nicht und dann gibts natürlich noch alles dazwischen.
Die G-sync Pendulum Demo von Nvidia kann das. Da gibt es direkt in der Demo am unteren Rand einen FPS-Slider, mit dem du sowohl min- als auch max FPS festlegen kannst. und da wäre noch der FPS-Limiter im RTSS. Dort kannst du im Hotkey-Plugin eine Taste für das ein- und ausschalten des Limiters festlegen und auch Tasten für das verringern/erhöhen des Limits um einen von dir festgelegten Wert.
Das geht dann alles on-the-fly direkt im Spiel.
Keine Ahnung was diese Antwort mit meiner Aussage zutun haben soll.
Hallo Gemeinde,
eigentlich hatte ich mir zum Release-Tag der RTX 4090 geschworen, keine Karte zu kaufen, weil ich zum einen die Preispolitik von Nvidia nicht unterstützen wollte und ich zum anderen schlicht und ergreifend keinen wirklichen Bedarf gesehen habe, mir ein GPU-Flaggschiff anzuschaffen. Mit meiner ASUS Strix 3080 OC war ich eigentlich sehr zufrieden. Aber wie so oft im Leben (und je länger man hier in diesem Thread mitgelesen hat) kam ich an den Punkt, an dem die anfängliche Vernunft vom Gefühl des „Habenwollens“ verdrängt wurde.
Seit letzter Woche bin ich nun stolzer Besitzer einer Gigabyte RTX 4090 Windforce 24G. Und was soll ich sagen: ich bin von der Karte mehr als begeistert!
Klar ist sie nicht die Stärkste 4090 (siehe Benchmark-Ergebnis). Aber für mich und meine Zwecke ist sie mehr als ausreichend. Und da ich mir erst Anfang letzten Jahres ein neues System (AM4-Sockel) zusammengestellt hatte, wollte ich nicht schon wieder auf eine neuere Plattform setzen, um das Potenzial einer 4090 vollends entfachen zu können. Etwaige Flaschenhälse nehme ich also in Kauf. Ich habe mir aufgrund der Empfehlungen hier im Forum lediglich eine etwas stärkere CPU (Wechsel von AMD Ryzen 5800X auf einen 5800X3D) sowie ein stärkeres Netzteil (750W --> 1.000W) geholt.
Hier mal ein paar Eindrücke von der Karte:
Die Karte hat unter Last (10 Minuten FurMark, Time Spy, Cyberpunk 2077, Battlefield 2042) nach meinem Empfinden kein wahrnehmbares Spulenfiepen und ist an sich wirklich leise. Jedenfalls kann ich die Karte nicht aus meinem System heraushören. Gerade im Hinblick auf die Temperaturen und im Vergleich zu meiner alten Strix 3080 OC bleibt die Karte angenehm kühl, was ich auch an der Raumtemperatur nach einer halben Stunde BF2042 gemerkt habe. Die Temperatur des GPU Hot Spots lag lt. Logfile von GPU-Z nach ca. 30 Minuten BF2042 auf Ultra-Settings bei maximal 74,9 Grad.
Idle:Last (BF2042, Ultra-Einstellungen):
Anhang anzeigen 816417Anhang anzeigen 816418
Anhang anzeigen 816430Anhang anzeigen 816425
Bezüglich der Adapter-Problematik kann ich nur sagen, dass der mitgelieferte Adapter ohne Probleme hörbar eingerastet ist. Vom Biegeradius sollte es in meinem Gehäuse (Define 7) auch passen. Mit dem Glasseitenteil, welches ich auch besitze, ist minimal mehr Platz vorhanden als mit dem Seitenteil aus Metall plus Dämmmatte. Ich werde allerdings noch das Adapterkabel von be quiet! (12VHPWR) verbauen, sofern es denn jemals geliefert wird.
Was mir optisch an der Karte gut gefällt, ist, dass sie ohne viel Bling-Bling auskommt und relativ nüchtern ist - auch wenn ein Metallgehäuse á la ASUS TUF einen bestimmt noch wertigeren Eindruck vermittelt hätte. Ich denke, dass ich die Gigabyte Windforce behalten werde und mit ihr erst einmal eine Zeit lang alles flüssig spielen kann. Und wie gesagt ist die Karte angenehm leise und auch preislich (UVP) eine Empfehlung wert, sofern man denn eine bekommt.
Ich habe zwar noch eine ungeöffnete ASUS TUF 4090 OC hier bei mir liegen, aber die wenigen Prozent an Mehrleistung benötige ich nicht. Oder doch? Und schon fange ich wieder an zu grübeln… :haha:
Was hast du denn für die TUF 4090 bezahlt?
Am Ende würde ich wohl bei der Gigabyte bleiben, wenn du die für 1949€ bekommen hast, vergiss nicht das Gigabyte auch nochmal Cashback gibt.
Bezüglich OC und Spulenfiepen kannst du mit allen Karten Pech und Glück haben.... die TUF muss nicht schneller als deine Gigabyte sein und kann zudem mehr fiepen.
Besser ein Spatz in der Hand als eine Taube auf dem Dach :)
Würde meine PNY nicht fiepen und hätte ich nicht bei Jeff dafür 2130€ bezahlt würde ich nicht mal mehr nachdenken die auszutauschen:
Der Score ist absolut solide, klar wird man mit 450W Bios keine Rekorde brechen.... aber was erreicht man denn am Ende bei den Karten? 3% mehr Leistung bei 100-150W mehr Leistungsaufnahme ^^
Die PNY ist super leise und kühl, Lüfter drehen auch wie bei der TUF mit max 1000rpm und kühler bleibt sie auch, da der Speicher keine super dicken Pads hat. Das Fiepen ist besser geworden, aber leider immer noch da.
Wie kommt es eigentlich, dass du so eine geringe Leistungsaufnahme bei BF hast?
Proshop ist echt das Allerletzte! - Angeblich neun Karten "auf Lager", aber bestellen darf man nicht, sondern sich gnädigerweise nur benachrichtigen lassen^^
"Der Verkauf von vorrätigen Karten öffnet täglich (Montag bis Freitag) um 14.00 Uhr."
Du musst dafür nicht alle Strix Besitzer kennen, wenn das fiepen selbst mit kleinen Stichproben bei 9 von 10 Karten vorhanden ist. Statistisch gesehen ist also die Chance deutlich höher eine zu haben die fiept, als eine zu haben die nicht fiept. Wenn du aber die Komponente "unbekannte Ohren" mit in die Erhebung einbeziehst, fiepen plötzlich nur noch 5/10 Karten. Daher sind Aussagen von Besitzern die scheinbar "immun" gegen fiepen sind, ohne Proof nichts Wert.
Wir hatten hier zu dem Thema schon alles. Halbtaube Leute mit Hörgeräten die ihre "leisen Karten" ewig verteidigt hatten aber nach Video Beweis ein echten Schreihals offenbarten, bis zu Leute mit 3 D5 Pumpen auf Anschlag im PC die alles übertönt haben und auch Leute mit 30 Jahren Rockkonzert in der ersten Reihe. Schwieriges Thema.
Ich hab dir erklärt warum du sehr wahrscheinlich bis jetzt keine Probleme damit hattest, es liegt vermutlich nicht an der GPU.
Ich besitze keine Strix. Ich besitze eine TUF. Wenn die Karte im normalen FPS Bereich fiepen würde, würde ich das mit meinen Ohren hören. Ich höre sehr gut und sehr viel :) Ich hatte schlichtweg bisher Glück und Karten erwischt die erst in Bereichen fiepen die ich nicht erreiche.
Stimmt halt nicht. Ich kann hier keine Aussage tätigen das alle Karten fiepen nur weil man ein paar Leute kennt bei der die Karte fiept. Man kann nicht von sich auf die Allgemeinheit schließen. Und viel lustiger wird es wenn man sogar behauptet das einfach die die kein Fiepen haben oder hören halt schlechte Ohren haben. Gerüchte besagen es gibt auch Karten die Fiepen erst dann wenn man in unüblichen FPS Bereichen ist.
Das durfte sich der Käufer vor Ort selbst anhören, aber ich bin Fan deiner passiv-aggressiven Zwischen-den-Zeilen-Unterstellung, ich hätte es nicht gemacht:d
Ja die meisten gpus die zurück gehen und privat verkauft werden sind sicher alle sehr laut. Finde es klasse das du dem Käufer die chance gibst die gpu mit 500 fps zu hören:)
In Unigine Heaven sinds im Menü glaube 7700:d
Mein Phanteks-Kühler ist heute gekommen und steckt schon im System.
Wirklich "kleiner" wird das ganze dadurch nicht. Weniger als 100mm auf jeden Fall. Und was sich Phanteks bei den Schrauben für die Backplate gedacht hat ... das wird auch niemand jemals verstehen.
Zur Standard-Ausrüstung eines Hobby-Bastlers gehört das bestimmt nicht. Ein Glück hatte ich was passendes. Ist Mini-Torx oder so ähnlich.
Karte macht gerade den Dichtungs-Test-Run.
Im Idle nix auffälliges.
Ach ja, das Corsair-Kabel macht übrigens sehr sehr deutlich "klick" und geht relativ einfach in die Buchse. Hab mal drauf geachtet. Hab meine 10 Zyklen jetzt bestimmt "voll" :-)
Sorry aber da muss ich dir ganz klar widersprechen. Wahrscheinlichkeitsrechnung lügt nicht ab einer gewissen Dimension. Bei Ampere zuletzt, wurde da grade bei Strix und FE Karten Daten in einer Menge gesammelt die durchaus Hochrechnungen zulassen. Alleine ich hab >50 3090 FE Karten Kommerziell im Einsatz. Von Zufall oder sporadisch ist selbst da schon keine Rede mehr. Es wurde auch nirgends gesagt, dass automatisch jede Karte fiept. Die die nicht fiepen sind prozentual trotzdem Unicorns.
So leid es mir tut, aus welchen Umständen auch immer, viele hören es nicht und manche weigern sich auch es hören zu wollen. Da kannst du einfach nichts drauf geben.
Übrigens der Grund warum besonders die hochpreisigen Karten unverhältnismäßig öfter betroffen sind, ist ein ganz einfacher. Grade die Karten haben idR auch deutlich mehr Spulen verbaut. Je mehr Spulen verbaut sind, desto höher ist das Risiko das welche davon Geräusche von sich geben. Auch werden bei solchen Karten gerne Spulen verbaut die besonders Kompakt gebaut sind. Wenn man solche Spulen auseinander nimmt und sich den Aufbau als auch den Guss des Harzes/Kleber anschaut, erkennt man das dort viel einfacher Resonanzen entstehen können, oft nicht mal nur durch Eigenvibration, sondern die oszillieren auch gerne gegen die Gehäusewand.
Hast du eine Miningfarm, oder was machst du kommerziell mit 50 3090ern?^^
Die Lüfter drehen immer nur bei ~800 rpm.
Habe mal Testweise Furmark angeschmissen und ich höre kein Fiepen aus dem geschlossenen Case bei 650 fps. Wenn ich mit dem Ohr direkt an die Karte gehe, mag das anders sein, aber wer spielt so?
@FR4GGL3 ich kann dir gern mal eine Aufnahme machen.
Deep Learning.
Furmark ist nicht wirklich gut dafür geeignet. Die Last/FPS ist zu konstant.
@cHio @FR4GGL3
Idle: https://filehorst.de/d/ewawhbfm
TS GPU Bench 1: https://filehorst.de/d/ehcwwtJD
Ja der Ton verändert sich, aber das ist wirklich so marignal, dass ich dafür das Ohr ans Case halten muss und selbst dann ist es alles andere als störend. Wenn ich normal vor dem Monitor sitze, dann ist kein Spulenfiepen zu vernehmen und beim Zocken wird man das garantiert nicht raushören können.
Das verstehe ich unter Spulenfiepen:
Und so ein kreischendes Geräusch macht meine Karte definitiv nicht.
Die TUF OC gab es letzte Woche im ASUS-Shop für 2.169,90 Euro. Habe glücklicherweise eine abstauben können. Das mit dem Spatz (Gigabyte Windforce) würde ich so unterstreichen. Mir würde die TUF auch gut gefallen. Aber da die Windforce kein Spulenfiepen oder andere auffällige Eigenschaften hat, werde ich vermutlich auch bei dieser bleiben.
Ich habe das noch gar nicht so mitbekommen. Habe auf der Map "Gestrandet" (das ist die Karte mit dem aufgelaufenen Containerschiff) gespielt. Du meinst schon den Board Power Draw? Habe das Logfile von GPU-Z noch einmal überflogen. So wie ich das auf die Schnelle gesehen habe, war da der Wert nicht einmal bei 300.
Ist das fiepen der Strix um soviel schlimmer als bei den anderen Karten ?
Ich mein die Kochen alle nur mit Wasser.
Ja, hab jetzt schon verschiedene Karten selber hören können und da gibt es schon deutliche unterschiede je nach art der verbauten Spulen. Blöderweise verhält es sich bei der Qualität der Lüfter genau umgekehrt. Bin jetzt bei einer ZOTAC AMP Extreme AIRO gelandet, da sie die leisesten Spulen hatte. Sogar leiser als die ZOTAC Trinity welche die gleichen Spulen hat, könnte eventuell an der größeren Spannung der AMP liegen, aber das ist auch nur eine Vermutung.
Thx, damit konnte ich es perfekt ausloten, ab 170 FPS fängt bei mir dann gaaanz leise Spulenfiepen an, aber selbst mit 500FPS ist es immer noch ein wirklich leises Geräusch, da war meine 3090FE um das 10 fache lauter. Da ich eh auf 116FPS limitiere habe ich somit nie Spulenfiepen und die Karte wird definitiv behalten.
Meine Phantom wurde vor 5 Minuten von einem EKA Käufer abgeholt, die Lüfter waren echt ein absoluter Graus.
PS:
Es gibt sie also doch: :bigok: Eine Leise 4090 Strix OC, ohne Spulenfiepen!* :bigok:
*bis 170FPS jedenfalls :sneaky:
PPS:
Mein süßes 700 Watt Netzteil macht selbst bei der Strix und 133% PT Limit keinerlei zicken :banana:
Extremtest:
Im PUBG Hauptmenü ist das aber alles echt am Limit:
Ähnliche Themen
Antworten
7K
Aufrufe
540K
