[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So, da ist es nun das seasonic kabel, das ist so steif dass ich offen gesagt keine Ahnung hab wie man das verwenden soll. Wenn man genau hinsieht dann sind die pins nicht gleichweit drinnen, genau das ist gefährlich oder?
@RaptorOne
Hoffe habe mit der Gigabyte Gaming OC Glück gehabt mit dem "besseren" Adapter. Bisher ist alles gut und hoffentlich bleibt das auch so! 🙏
Laut Reddit sind beide Hersteller-Adapter von Problemen betroffen.
Hier auch nochmal eine Übersicht von Igor
Das dürfte gewollt sein, damit am Kabel vorne nicht abgeknickt werden kann (scheint eine der möglichen Ursachen für die Probleme zu sein).
Ist wahrscheinlich auch gewollt, dass man jetzt keine herkömmlichen PC-Cases sondern IKEA-Umzugskartons mit Löchern als Baurahmen für die Hardware nutzt. Die Ausrichtung vom 12+4 ist die nächste komplett unnachvollziehbare Entscheidung dieser Generation, warum nicht seitlich gewinkelt wie bei Ampere FE...Seit 4 Wochen ist mein Case offen, es nervt mich optisch massiv.
"Nee, haben wir im Gegensatz zum Erfolgskonzept des Vorgängers schon absichtlich beschissen angebracht, grundsätzlich wollen wir ja, dass die Kunden möglichst unzufrieden nach dem Einbau unserer Produkte sind"
"What is interesting to note is that NVIDIA reportedly will use dual 8-pin to 16-pin power adapter for its upcoming GeForce RTX 3070 Ti"
Oder die ganzen Gehäusehersteller bringen jetzt Seitenteile mit einer Ausbuchtung wie früher an den Corvette Modellen.
Hat doch auch was - die Steckerhutze. So wird das Gehäuse auch Ready für PCIe 5.0. Lässt sich vermarkten und verkaufen.
Sehe ich andres. Ich feiere es schon ein wenig das mein GTA 5 mit NVE Mod inzwischen auf 4k bei 90 FPS mit gradmal 240 Watt Verbrauch läuft. Dabei wird die Karte nichtmal 45 Grad heiß nach Stunden. Das wäre mit der 3090 anders gewesen.
Musst du ja Gott sei Dank auch nicht. Die Karte verkauft sich gut genug bisher. Noch besteht hier nicht die Not das man die Karte empfehlen müsste um den Abverkauf zu pushen. Aktuell kann man eher froh um jeden sein der keine 4090 will. Bleibt mehr für andere.
Noch jemand mit GTA 5 und NVE! Benutzt du Alt:V? Oder nur Singleplayer? Mit Alt:V hab ich absolut schlechte performance... meistens so 60 fps aber ständig Drops auch öfter mal auf 40 FPS. GPU scheint auf Limit zu laufen... ich hab trotzdem Hoffnung, dass ne neue CPU helfen könnte.
Wie ich vermutete, verschiedene Adapter bzw. Hersteller mit Nvidia Logo und die backen die Dinger wie sie es wollen. Und auch diese neuen Erkenntnisse helfen erneut keinem weiter, denn man besitzt ja nun mal nur den Adapter, der der Karte beiliegt. Und die sich dann ein anderes Kabel kaufen, weil sie dem Adapter nicht trauen, weil sie Version A oder B haben, stehen genauso da und wissen im Endeffekt auch nicht genau, was sie da eigentlich bekommen - also nur ein weiterer Tag wo sich alle im Kreis drehen ohne echte Lösung.
Überwiegend ragemp. Da geht die Performance. Habe meist um die 85 bis 95 fps in 4k.
so bei mir ist jetzt auch alles fertig, aus einen Graka Kauf bei Release und nicht passendem Gehäuse wurde am Ende ein komplett neuer Build. Verbaut suprim mit 5800x3d und atx 3.0 nt mit nativen Kabel und 1 schlitz :) leider nur 450 w Kabel aber sollte kein Problem darstellen hoffe ich
@RaptorOne
Warte auch noch auf meins und hoffe es kommt bald. Wie lange hat es denn bei dir gedauert?
Habe heute mein Asus 16 PIN Kabel erhalten. Dummerweise hat man dort wo ich biegen müsste einen Kabelbinder rein der mit einem extrasteifen Schrumpfschlauch überzogen worden ist.
Hancock mode: "Gut gemacht"
/edit: trotzdem nicht überreagieren.
@RaptorOne
Hmm, das sieht nicht so schön aus! Kannst du die "Kabel" am Stecker etwas mehr rein drücken? Oder sind die starr?
Wurde am 11.11 verschickt aus Taipan und kam heute an
Ok, dann haben die bescheid gegeben. Hab es ende Oktober bestellt, hoffe dauert nicht mehr lange. Aber ob es damit die ultimative Lösung ist, keinen Ahnung. Zweifel bleiben bei der ganzen Sache bestehen.
Woher bzw wie und wo bestellt ?
@RaptorOne
Das hätte ich auch gern...passt ja auch bei Asus.
Ich frage mich immer was Ihr mit den ganzen Lüftern macht?
Habe ein Define R6. Hinten ist ein 140er und vorne 2 140er.
Wenn ich zocke geht der hinten auf 1000rpm und vorne die beiden auf 600rpm.
Nichts überhitzt und ist beim zocken auch nicht zu hören...
Ich bin mehr so der Purist. Manchmal ist weniger mehr... :-) Dennoch... hübches Set hast Du.
Vom ASUS Kundendienst. Wurde hier auch schon bestimmt 2x beschrieben. Denn das ASUS ROG Thor P2 1000W hatte nur einen 12 PIN und keinen 16 PIN Adapter in der Schachtel. Auf der ASUS Homepage wird aber damit geworben dass sie über einen 16 PIN Ready für PCIe 5.0 sein wollen und man sich beim Support melden soll wenn im eigenen Karton noch kein 16 PIN drin ist. Genau das habe ich gemacht. Ob sie das Kabel jetzt auch in anderen Fällen rausrücken weiß ich aber nicht. Da müsstest du selbst nachfragen. Vorher anrufen ist einfach und schafft Klarheit.
Das Fractal define R6 ist aber auch einfach ein wahnsinnig gutes Gehäuse. Ich hatte da schon ein 280er+420er radi verbaut samt Pumpe etc und es passt ohne Probleme jede Grafikkarte. Auch zur Seitenwand ist genug platz für eine 4090 TUF samt 16 pol Stecker ohne biegen und brechen. Klare Empfehlung, dazu ist es sogar noch gedämmt. Bin aber auch eher der purist 😅
Welche 4090er-Karten mit vorinstalliertem Wasserblock gibt es (kein AIO)? Bisher ist mir nur ein Modell von Inno3D bekannt.
Kupplung bei der GPU auslöten und das NT Kabel direkt an die GPU löten ... besser gehts nicht :lol:
Herrlich, 2-2,5k€ für GPU und es "scheitert"
an Cent Artikeln :wall:
Damit bist du auch schom am Ende. Mehr gibt es nicht. Das Modell von Gigabyte gibt es wohl nur für die 4080.
Das Thema sollten sich manche tatsächlich etwas näher anschauen. Es gibt hier viele Bilder von cases mit absolut katrastrophalem Airflow, schlichtweg weil zuviele Fans am Werke sind, die sich ständig gegenseitig die Luft zuschieben, ohne dass ein vernünftiger "Kanal" entstehen kann (kalte Luft rein, hat Zeit sich aufzuheizen d.h. Wärme aufzunehmen und wird dann "abgepumpt"). Da gibt es genug vernünftige Tests, die zeigen, dass zuviele Fans genauso schädlich sind wie zu wenige.
Drei Lüfter würde ich - in Deinem Beispiel - jetzt nicht als optimal bezeichnen, schlechter als solche "überfüllten" wird es vermutlich aber nicht sein.
LF hatte da mal einen interessanten Artikel zu geschrieben
"Just because case fans help to keep your gaming PC cool, you don’t need to stack your system with fans. The biggest mistake rookie gamers make is installing too many case fans.
When you use multiple case fans in your system, it has a negative effect. Stacking doesn’t improve the airflow but hinders it. If there are many fans on the PC, the first fan will interfere with the other, and less air will be circulated inside the system.
Too many intake fans create negative airflow. The fan will pull too much air in the PC, and the exhaust will not be able to remove it. Because of this, hot air will remain in the PC for a long time, and more dust will build up.
Similarly, if there are many exhaust fans, it will end up removing air too quickly from the system. In order to manage proper airflow, you don’t need more fans. Instead, you need to create a proper balance between intake and exhaust fan [sic]."
Gibt doch bereits praktikable Lösungsansätze
Ich habe das Kabel noch vor dem Schlauch + Kabelbinder gebogen. Also da wo die einzelnen Adern sind.
Aber die drei reichen doch.
Habe auch höhere Drehzahlen probiert. Die Kühlung wird nicht besser.
Also warum sollte ich jetzt mehr nehmen???
Alles im grünen BEreich.
Junge, Junge war die TUF schnell weg :oops:
Ja ich weiß weniger dies das aber es ist eher ein persönliches Ding bei mir. Soll auch als showcase dienen für Fotos, daher ist neben der Leistung auch die Optik wichtig.
Wie hast du die LEDs auf der Grafikkarte so bunt gemacht?
MSi center
Ähnliche Themen
Antworten
7K
Aufrufe
541K
