[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
gut investierte 2000€ würde ich sagen. Fürs Forum reicht es allemal.
Strix vs. TUF vs. Suprim X
Bei Lüfter 100% blieb bei mir die Suprim X am kühlsten. TUF hatte das angenehmste Geräusch. Lag aber nicht an den Lüftern sondern am Spulenfiepen. Kühlleistung ist natürlich schwer zu beurteilen weil die Chipgüte und das Powerlimit eine Rolle spielen. Die von mir getesteten Karten war allerdings die MSI auch die schnellste.
@Trill
Bei mir ändert sich nix.
Ich hab 5% TDP in beiden Fällen. Nur beim Bewegen der Maus (egal in welche Richtung) ändert sich das nach oben hin :-)
1,5% TDP hätte ich auch gerne :-)
Und die Luxxer hier so:
Verfolge die Beiträge hier schon seit vielen 100 Seiten und muss leider feststellen das es hier hauptsächlich um Adapter geht die 99,99% der Besitzer nicht betrifft und wie schön die 4090 fe ist die genauso aussieht wie die 3090 fe
Aber alle anderen Themen interessieren mich sehr :)
Wo es für die Brandgefahr sogar nen eigenen Thread gibt…
Aber hier ist die Aufmerksamkeit halt größer…
Nachricht gelöscht
^^Ich habe zwei an der 4090 bzw. drei, einen 144Hz WQHD und einen 60HZ UHD. Ich meine im Einzelbildschirmbetrieb, es ist dann egal ob WQHD oder UHD Auflösung, die Watt sind bei mir gleich, nur wenn beide an sind es natürlich mehr, so um die 18 - 22 Watt. Dann steckt noch ein 55 Zoll LG Oled C9 über HDMI dran, auch hier der gleiche Verbrauch, wenn alleine.
Hmm... was läuft bei mir dann verkehrt? Hab einen C1 (UHD/120Hz) und in Idle Desktopbetrieb so um die 30 Watt.
Gibt es für Undervolting und Overclocking und Spulenfiepen auch aber dennoch wird auch hier in diesem Thread viel dazu geschrieben und zwar um einiges mehr als zu den Power Adaptern
dessen Posts nur ein Bruchteil dessen ausmacht im vergleich zu den anderen Themen in diesem Thread aber selbst das is ja schon für diese kleine Gruppe zuviel
Ja undervolting und oc betrifft 99% der user und der Adapter ca 0,001%
mag sein aber warum schreiben die 99 % dann nich auch in den jeweiligenn Sammlern und stellen das schreiben hier ein wie es von den Power Adapter Diskussionen und Berichterstattungen gefodert wird
von einer kleinen Gruppe ? Merkste selber nech ?
Entweder alle oder keiner .. wenn dann sollte man dann diesen Thread dicht machen da wir ja für alles nun Sammler haben oder man lässt diesen Thread weiter offen für alles
Entweder alle
Die Mehrheit interessiert sich hier für oc/uv und das Thema mit den Adapter Liebhabern zählt leider nicht dazu
Die Mehrheit interessiert sich hier für oc/uv sind und das Thema mit den paranoiden Adapter Liebhabern zählt leider nicht dazu
Dafür gibts wie gesagt eigene Sammler .. kann ja nich angehen das User hier bestimmen über was geredet werde darf und über was nicht
wie gesagt entweder gilt das für alle oder für keinen .. wenn hier über Undervolting und Co. geschrieben werden darf obwohl es dazu eigene Sammler gibt dann darf hier
auch über Power Adapter gelabert werden obwohls dafür nen Sammler gibt
@AzRa-eL
Habe UHD 144HZ am Deskop und 18,9 Watt Verbrauch im Idle mit dem neusten Treiber .
Bei den letzten beiden Treiber waren es 28,5 Watt .
Schreiben kannst du natürlich über was du möchtest aber es sollte jeder selber entscheiden ob er möchte das dieser Beitrag hier mit Adapter Geschichten anstatt interessanten Themen überschattet wird. Mühsam für die Mehrheit:(
Du verdirbst damit manchen die Freude an der Karte . Manchen bereitest du damit sogar sorgen und innere Unruhe .Mir persönlich macht es nichts , dass du darüber berichtest.
Spart mir das googlen danach.
Finde das Thema durchaus interessant .
Oh das is aber lieb das du das Gestattest
aber es sollte jeder selber entscheiden ob er möchte das dieser Beitrag hier mit Adapter Geschichten alle interessanten Themen überschattet
Die können sich jja dann die Wichtigen Infos aus den Sammlern holen. ... und ich bezweifel stärkstens das die Adapter Posts auch nur annähernd an die Menge an Posts der anderen Themen rankommen
Denk drann das sind nun 680 Seiten.
Ich bleib dabei ... entweder alle oder keiner .. entweder verbietet man dann hier alles wo es schon Sammler zu gibt oder man lässt offen Diskutieren
Warum verbieten / ich appelliere nur daran vorher zu überlegen ob das Thema die Mehrheit interessiert oder eher ärgert
Für oc/uv Themen hat sich hier doch noch niemand beschwert oder ?
Spart mir das googlen danach... Finde das Thema durchaus interessant .
Das is nich meine Absicht als auch das es keine Absicht ist Panilk zu verbreiten als auch nicht gegen Nvidia zu Shooten ( hatte die letzten etwa 20 Jahre bisher immer ne Nvidia Karte drinn )
... wie schon gesagt bin ich ja selbst auf der Suche nach einer neuen 4090 Strix für nen fairen Preis aus nem Shop ... es is halt ein Thema das Polarisiert das is klar
aber es ist ein Thema das immernoch Aktuell ist und wo noch viele Fragen offen sind und wo nun die Leute auf eine Reaktion seitens Nvidia warten.... News Seiten Schreiben darüber
es gibt ne Liste auf Reddit wo Fälle gesammelt werden
Wir sind alle hier weil wir die 4090 gut finden aber man muss halt auch über die nich so guten Dinge sprechen und nich nur alles mit der Rosa Roten Brille sehen
Ich find es ehrlich gesagt mittlerweile viel nerviger, dass User sich hier gegenseitig angehen, wegen den Inhalten, die ihnen nicht passen.
Wenn mich OC/UV nicht interessiert, dann überlese ich es. Wenn mich die Brandkabel Sache stört, dann ignoriere ich es.
Aber wenn User sich Seitenlang darüber streiten, welche Themen hier am Platz sind oder nicht, dann nervt es irgendwann.
Dafür gibt es doch Mods und wenn die nicht eingreifen, dann ist doch alles im Rahmen.
Für oc/uv Themen hat sich hier noch niemand beschwert oder ?
Fordere Mich nich auf damit nun anzufangen :ROFLMAO:
Ich bin da halt für gerichtigkeit ... wenn die schreiben dürfen dann dürfen es auch die anderen und wenn die nich schreiben dürfen dann dürfen es die anderen auch nich
Und genau das passiert ja und daher wird eigentlich mehr darüber geschrieben als die Leute eigentlich vorhaten .... aber ich hab dieses verhalten auch schon in andere Threads bei anderen Themen erlebt
manche wollen halt auch einfach nur einen Streit Provozieren und eigentlich sollte ich auf solche Leute garnicht erst eingehen weil das eh zu nix führt
Exakt und genau so mache ich das auch wenn es zb um Undervolting und Lüfter Klackern usw geht .. klappt bei mir immer wunderbar aber manche scheinen nich in lage zu sein Dinge zzu überlesen
die sie nich interessieren
Jup sollten die Mods was dagegen haben das ich weiter darüber berichte dann werde ich damit aufhören würde es dann aber unfair finden
wenn es dann weiterhin erlaubt wäre über die anderen Dinge ( UV , OC , Fiepen , klackern , fiepen , rasseln ) hier zu schreiben wo es aber auch Sammler zu gibt
So und zum ende hin nochmal :
Wir sind alle hier weil wir die 4090 gut finden aber man muss halt auch über die nich so guten Dinge sprechen und nich nur alles mit der Rosa Roten Brille sehen und so tun als wär nix passiert
Und genau das passiert ja und daher wird eigentlich mehr darüber geschrieben als die Leute eigentlich vorhaten .... aber ich hab dieses verhalte auch schon in andere Threads erlebt
Ja ist alles in Ordnung :) schönen abend und einen guten Wochenstart morgen an alle :)
Ja, ist mir leider auch bei der Garantie Sache aufgefallen, als ein User eine Frage diesbezüglich hier gestellt hat und auf mehr oder weniger schroffe Art fast schon aus dem Thread geekelt wurde.
Danke dir auch! Wollte mal was "sinnvolles"beitragen 😂👋
Wo bleibt der lvl up Thread?!😂
Wurde geschlossen, da du dich doch nicht getraut hast das pic zu posten 🙄kaum hab ich "besser als zu koksen" gesagt wurde es geschlossen... Auf jeden Fall verdächtig 🤔
Hö? Welches Pic? Was hab ich verpasst?!
Warst du das nicht, mit dem Bild von vielen verschiedenen Level Up Dosen übereinander?
Sorry dann hab ich dich verwechselt, wenn du es nicht warst))
Hatte dich im Thread aber erwähnt doch von dir kam nichts... 😒
@Trill
Was?
Wird hier etwa die Leistungsaufnahme im Leerlauf in Prozent von der TDP angegeben?
Wie lange hab ich hier in den thread nicht reingeschaut, 10 Jahre oder doch nur 3 Tage?
Was kommt als Nächstes? Angabe in Euro, wenn man örtlichen Tarif zu Grunde legt?
@HisN soll kein Front sein. Finde es nur kurios wie schnell sich manche Diskussionen weiterentwickeln.
Ähnliche Themen
Antworten
7K
Aufrufe
541K
