[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab nochmal beobachtet wie sich die Werte bei anderen Games verhält gegenüber CP 2077
CP2077 4K max. RT Ultra , DLSS Qualität GPU = 64°C Hotspot = 81°C GPU Verbauch 420 Watt GPU NVVDD = 560 Watt @ Stock (Alles max. Werte)
BF2042 4K max. RT aus , DLSS Qualität GPU = 60°C Hotspot = 71 °C Verbrauch 326 Watt GPU NVVDD = 538 Watt @ Stock (Alles max. Werte)
So wie in BF2042 verhält sich das auch in den meisten anderen Games die ich bisher gezockt habe , aber CP 2077 haut schon richtig rein :d
Kann mir gut vorstellen , dass die Lastspitzen bei GPU NVVDD sicher auch mehr als 600 Watt sein können , wenn man das PL auf 600 Watt und auf 1,1 V erhöht wird.
Puh, Adapterrevision ist ja sehr wahrscheinlich aber eine Steckerrevision wäre ja aber wohl der worst case für Nvidia, das kann ich mir erst zur nächsten Generation vorstellen. Dann dürften sie die 4080 nächste Woche eigentlich nicht rausbringen und auch der 4090 Verkauf müsste gestoppt werden, weil sie damit ja quasi eingestehen, dass alle bisher verkauften Karten mit diesem Stecker ein Risiko sein können.
einzig dieser wichtigtuer Clickbait Igor hat das bis jetzt gezeigt, das an seinem 150V wären! So wie bisher eben nirgends ein Adapter aufgetaucht ist, mit Nvidia Logo drauf und das einer 4090 beiliegt, mit 150V Kabeln, das sind dann schlicht andere Adapter, nachbauten anderer was auch immer.
Willst Du dich nicht gerade wichtig tun? Ich habe sehr wohl meiner Zotac Karte beiliegend einen 4-fach Adapter mit 150V und natürlich mit nvidia-Aufdruck!
Was Du nun hier behauptest, lässt mich an Deinem vorgeblichen Wissen zweifeln. Auch GN hat schon festgestellt, dass nvidia-Adapter mit 150V im Umlauf sind.
Momentan is alles noch möglich .. sollte der Stecker ansich also der auf der Karte das Prob sein müssen sie sich was überlegen aber ich glaub am Stecker liegt es nich ( aber wer weiss )
sondern an der Qualitätskontrolle der 16 Pin Kabel / Adapter aufgrund der Unterschiedlichen bauweisen sowie verlötungen der Adapter obwohl eigentlich bei einem Serien Produkt immer die gleiche
Bauweise vorherschen sollte ... aber auch das is eben einfach nur eine Vermutung von mir bevor mir wieder jemand "Panikmache" Vorwirft sag ich das lieber nochmal extra dazu.
Um das zu entscheiden müsste Nvidia ja erstmal zu einem Ergebniss der Untersuchung kommen aber die lassen sich Zeit ... was aber auch teils gut so ist den Übereile is bei sowas auch nich gut
aber zuminndest ein Offizielles Statement zu den Fälle sollte Nvidia rausgeben sowie eine White List von Kabeln / Adaptern von 3t Anbietern die ok sind wo dann Nvidia da auch die Garantie übernimmt
aber momentan besteht weiterhin die Möglichkeit das wenn einem sowas passiert und man nen anderen Adapter oder Nativ Kabel nutzt Nvidia die Garantie verweigert dazu sollte sich Nvidia
nun möglichst schnell äussern und sagen das sie auch die Garantie geben wenn man andere Kabel nutzt
gibt neue bilder zur 4080 FE
4090 links, 4080 rechts
wird wohl die mit Abstand langsamste 80 (im Vergleich zum Vollausbau) - und teuerste - aller Zeiten
Ich bin mir sicher, dass Nvidia schon weiß was das Problem ist. Sie sind die einzigen, die Zugriff auf die geschmolzenen Adapter und Karten haben und haben sicherlich eine Armee an Spezialisten dran gesetzt. Ich denke die Entscheidung, wie Nvidia jetzt offiziell damit umgeht kostet mehr Zeit als die Analyse selbst. Daher gehe ich davon aus, dass Nvidia den Stecker an sich weiterhin als unproblematisch ansieht NACH der Analyse, denn sonst wäre ein Launch solcher Geräte ja grob fahrlässig. Lass da mal wirklich eine Bude deswegen abfackeln weil der PC unbeaufsichtigt ist und ggf. Menschen zu Schaden kommen. Ich erinnere mich noch an das Samsung Note 7 damals und wie schnell da reagiert wurde nachdem einige Geräte abgefackelt sind. Und ich glaube das waren weniger Fälle auf mehr Verkäufe als bei der 4090 jetzt.
Ach du meine Güte, ich dachte nicht das es noch Menschen gibt die sowas tatsächlich nochmal erwähnen. Wird wieder wíld und lustig hier. Hauptsache wir haben Spaß :)
Wie viel Zeit hast du schon mit relativierenden Posts zu dem Thema hier verschwendet? Reagier doch einfach nicht darauf wenn es für dich kein Thema ist. Danke
Habe ich keinen Grund zu, mich wichtig zu machen - wenn es Adapter gibt mit Nvidia Logo drauf und die dann 150V Kabel verwenden kann ich mir vorstellen, dass das diese nicht den Nvidia Vorgaben entsprechen, wobei 150V Kabel per se auch nicht problematisch sind. Hier ist ja nicht bekannt, ob die Adapter Nvidia selber an die Hersteller liefert oder die verschiedenen Hersteller die in Eigenregie fertigen lassen und hier dann evtl. Fehler entstehen bzw. dann eben einfach andere Kabel benutzt werden. Es ist auch denkbar, dass der Auftragsfertiger von Nvidia hier Bockmist baut und lustig verbaut, was er will. Und gerne noch mal, das Problem sind ja nicht die Kabel und auch nicht die aufgelöteten Kabel innerhalb des Adapters, dieses Schmelzen passiert innerhalb des Steckers/Buchse und ist eben ein Kontaktproblem, mehr sage ich jetzt auch nicht mehr!
Und mein anderer Freund, @ssj3rd, hatte Recht - beim Wechsel der GraKa wird rBar im Bios des Mainboards deaktiviert (bezogen auf ASUS AM4).
Vielleicht auch für eure Boards mal schauen für mein Taichi X570 gab es auch ein neues BIOS .
Verbesserte GPU-Kompatibilität für die GeForce RTX 40-Serie.
Jedoch muss ich sagen bei mir war ohne das Bios auch rBar aktiv mit der Master.
Hoffe die kommenden Tage habe ich mehr Glück mit der Strix.
Bedenke der erste Fall is "erst" seit dem 24.10 bekannt also seit 3 Wochen .. in dieser Zeit kamm es nun zu 30 Fällen ( nich alle davon waren schmorschäden )
die bekannt geworden sind ... dann brauch es Zeit bis Nvidia die entscheidung trifft das die betroffenenn Kunden die Karten zur Untersuchung zu Nvidia schicken soll dann müssen die Karten sowie Adapter erstmal wieder vom Kunden zu Nvidia zurück sind wieder ein paar Tage weg ... also grob Arbeitet Nvidia seit vielleicht 15 Tagen daran .. also ich kann es nun nich einschätzen wie lange sowas dauert aber
schnell geht das sicher nich und sie sollten das alles auch nun nich übereillen sodass etwas übersehen wird. ... aber wie gesagt zumindest ein Statement sowie ne Ansage welche Kabel und Adapter von
3t Anbietern ok für Nvidia sind sollte Nvidia nun bekannt geben und eventuell ne Ansage wie es nun weitergeht
Einige bisher. Viele davon sind sehr beliebt und gefallen sogar den Menschen. Danke der Nachfrage.
Also mir isses egal ob meine Posts beliebt sind und Leuten gefallen das is ja hier kein Wettbewerb wer nun hier der beliebteste is
aber wenn das dein Ziel is möglichst beliebt zu sein und gefeiert zu werden nunja
Fall Nr. 31 und 32 :
Ja WilliWonka ist wahsinnig beliebt hier im Forum :ROFLMAO: Deswegen streitet er sich auch alle 5 Seiten hier im Thread mit irgendjemanden und wurde sogar schon von Mods verwarnt. Naja, wenn man sonst nichts zu tun hat.
Das Thema mit dem Stecker sollte man nicht unterschätzen und hat ja auch inzwischen einen knapp 20 Seiten langen thread !
Wen man mehr da zu wissen will sind die Infos da zu dort ja auch gut aufgehoben !
So bleibt das ganze hier übersichtlicher.
Falls noch nicht geschehen sollte man das hier auf der ersten Seite hervorheben das es zu Problemen kommen könnte und den Hinweis auf den separaten thread hier im Forum platzieren.
Das sollte dann auch etwas strukturierter sein.
Ich tue mir hier inzwischen echt schwer für mich wichtige Infos zu bekommen .
Da kommt man von einer fast 5 stündigen Session bei der die 4090 bis an die kotzgrenze ausgelastet war und findet so eine Shitshow vor.
Wann gab es hier den letzten interessanten Beitrag zur 4090 ? Immer diese Abschweife.
Erzähl Mal wie ist die Lautstärke im Silent Mode wie ist die Anlaufdrehzahl der Lüfter nach Zerofan bei welcher Temps laufen sie an.
Temps /GPU /RAM Vram /Hotspot /undervolting ohne Takt zu senken bitte ohne Fenster Mod !
So was halt ein schönes 24/7 Setting sein könnte :-)
Geh ruhig ins Detail.
Vielen Dank !
Freue mich für dich
Grüße
Ich hoffe du hast den Post gestern hier lesen können @ssj3rd
würde gerne etwas mehr Infos zur Strix aus erster Hand bekommen.
Vielen Dank!
Was soll das bringen? Jeder, der an dem Thema noch interessiert ist, kann den Reddit Thread verfolgen. Du brauchst hier nicht tagtäglich jede Wasserstandsmeldung crossposten. Hast du nichts besseres zu tun?
Ach du ich denke bei 670 Seiten übers Undervolting und Lüfter rattern und Spulenfiepen hier fallen nun so diese Paar Posts zu den Power Adapter Fällen nich sonderlich ins gewicht.
Solange es für die Mods ok is das ich hier über die Fälle berichte werde ich das weiterhin tun schadet ja niemanden informiert zu werden und ist weiterhin ein "Brand" Aktuelles Thema
ausserdem scheinen ja manche immernoch nich auf dem aktuellsten Stand zu sein sah man ja zb Heute wieder
wer wollte noch gleich spiele die die karte fordern?
endlich kann man skyrim zocken. wurde auch zeit :bigok:
Temperatur, Lautstärke?
Ähnliche Themen
Antworten
7K
Aufrufe
540K
