[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, aber die Relation zu den schwächeren Karten muss nvidia auch weiterhin betrachten. Wenn mal angenommen eine 6090 3000€ kostet, darf eine 6080 ja nicht "nur" 1500€ kosten. Die 6090 würden ja dann nur ganz wenige kaufen.
Das stimmt, aber dafür steigt ja auch wieder die Leistung. Sprich wenn bisher der Kunde eher die xx80 gekauft hat, wird er halt in Zukunft eher die xx70 kaufen dann. Steigen werden die Preise vermutlich sowieso immer weiter.
CableMod hat das mit den extra Kablen für die Sense-Pins ganz gut gelöst, finde ich.
Anhang anzeigen 815829 Anhang anzeigen 815830 Anhang anzeigen 815831
Ja ich wart ja auf CableMod.
Die Bestellung ist ja angeblich fertig und die Versandmarke gedruckt aber es passiert seit nun zwei Wochen nichts.
Kein Fortschritt.
Das Fasgear Kabel ja es fühlt sich an wie ein dickerer Schweißdraht überspitzt ausgedrückt aber es scheint sehr massiv auch am Stecker. Auf jeden Fall wertiger als der Nvidia Adapter aber ich hoffe trotzdem das die CableMod Lieferung bald da ist.
Das Ding liegt auf dem Schiff glaub ich. Das wurde zumindest hier einige male behauptet. Deshalb tut sich da nichts.
Ja, aber die Relation zu den schwächeren Karten muss nvidia auch weiterhin betrachten. Wenn mal angenommen eine 6090 3000€ kostet, darf eine 6080 ja nicht "nur" 1500€ kosten. Die 6090 würden ja dann nur ganz wenige kaufen. Wenn sie jedoch den Preis der 80er auch stetig steigen lassen, werden sie evtl auch dort die potentielle Kundschaft verlieren.
Zumindest muss das am Anfang gegeben sein. Wenn man kurz nach Markteinführung auf die Konkurrenz reagieren muss, so wie das jetzt bei den 4080 passieren könnte, dann ist das Faust zweiter Teil. Wenn man aber die Markteinführung so macht wie bisher, dass ganz am Anfang die teuersten und schnellsten Exemplare gebracht werden, so muss die zweite Wahl hoch genug eingepreist sein damit der der die schnellste kaufen kann, auch zur schnellsten greift.
Das Spielchen kannst du aber maximal 2x machen. Dann begreifen es die Kunden und bleiben etwas zurückhaltender. Ausnahme: du nutzt als Deckung andere Effekte (wie z.B. Kryptomining Hype oder eine Pandemie) die die reine Preisplatzierungstaktik verschleiern können. Der Käufer der das Produkt will, möchte eben gerne noch eine Bestätigung dass sein Handeln nicht völlig irrational ist. Ist ein bisschen so wie beim Porsche: der gilt als "Geldanlage" obwohl das sicher nicht alle Porsche sind (einige natürlich schon).
@***** Sylwester hat sich nochmal gemeldet und zugegeben, dass er gar keine Ahnung von den Specs. des Steckers hatte. 🙂
Bevor ich meinen nvidia-Adapter mit den 150V Kabeln benutze, setze ich auch lieber auf gecrimpte 16AWG Kabel in Steckern, die auch spür- und hörbar einrasten.
Wenn die Ursache für schmelzende nvidia-Adapter(!) eindeutig benannt werden kann, können wir nochmal weiter darüber reden.
Mein Nvidia Adapter rastet spürbar und hörbar ein! Weil ich es schlicht aber selber mal wissen wollte, habe ich an einem der Stränge meines Adapters mal das Slave zurückgezogen - ach was kommt den da zum vorschein, da sind ja gar keine 150V Kabel dran, sondern 300V, so wie es auch Gamers Nexus beschrieben hat - einzig dieser wichtigtuer Clickbait Igor hat das bis jetzt gezeigt, das an seinem 150V wären! So wie bisher eben nirgends ein Adapter aufgetaucht ist, mit Nvidia Logo drauf und das einer 4090 beiliegt, mit 150V Kabeln, das sind dann schlicht andere Adapter, nachbauten anderer was auch immer. Und noch mal, das Schmelzen passiert nur dann, wenn ein Pin nicht richtig mittig im Stecker sitzt, beim Einstecken zur Seite gebogen wurde, was einfach nicht aufgefallen ist oder wenn der Stecker oder die Buche einen Fertigungsfehler hat, was bei Massenprodukten eben einfach immer passieren kann, es ist schlicht immer ein Kontaktproblem. Aber jeder kann stecken und kaufen, was er will, dennoch ändert es nichts an dem Umstand, dass es auch damit passieren kann.
Die 4090 bietet die Perspektive, in 4k mind. die nächste Generation überspringen zu können, da die Leistung mit aktuellen und auf absehbare Zeit kommenden Szenarien noch sehr gut reichen sollte.
Hoffe mal, dass du recht behälst. Wenn Frame Generation gut implementiert wird, könnte es, je nach Anspruch, wirklich klappen. Ansonsten bin ich mal gespannt, wie die 4090 mit den ersten UE5 Games performt😅
Niemand sagt übrigens das jeder Adapter nun die 150v Kabel hat sondern das manche Adapter diese Kabel verwenden das scheint dir wohl entgangen zu sein
das hat also nix mit Clickbait zu tun sondern is halt fakt
Na dann frag ich mich aber warum Nvidia solange brauch um das herrauszufinden wenn du das mal eben auf die Schnelle geklärt hast ?
Auch passend dazu nochmal den Text von vorhin ... PCI-Sig arbeitet auch schon an einer revision sowie Nvidia wohl schon laut gerüchten am Power Adapter V2
Es muss sich noch zeigen wie groß der Abstand zur 4080 und 7900XTX sein wird.
Wenn die 4080 wirklich nur 15% schneller als eine 3090 Ti ist und 25-30% gegenüber einer 3090 ist die 4090 schon ein Monster dagegen .
Damit könnte ich mir schon vorstellen das man mal ne Gen. überspringen kann .
Denke der Sprung zur nächsten Gen. wird wahrscheinlich kleiner ausfallen und Nvidia macht Werbung für DP 2.x :d
Der Sprung von der 3090 hat sich definitv gelohnt was sie sich natürlich gut bezahlen lassen , aber ist jetzt schon deutlich und DLSS 3 ist noch kaum in Games implementiert.
Dazu kommen über die nächsten Monate noch einige optimierungen beim Treiber.
Da ich neu hier bin erstmal ein Hallo an Alle.
@Trill Ich habe mir die ZOTAC GAMING GeForce RTX 4090 AMP Extreme AIRO gekauft und da liegt der 150V Adapter bei.
Habe mir bis das Kabel von Be Quiet lieferbar ist von Amazon das hier geholt https://www.amazon.de/ummantelt-Ver...&qid=1668345945&sprefix=sirlyr,aps,109&sr=8-1
Hoffe es war kein Fehlkauf.
mfg Thronmir
Bei diesen 130 sind bestimmt auch Adapter bei, die kein Nvidia Logo haben, ich sprach explizit von Adaptern mit Nvidia Logo! Und wenn es nach diesem Artikel geht, den du hier als Maßstab heranziehst, darf man gar nichts mehr einstecken bzw. verwenden - und auch mit einem Adapter V2 wird es weiter passieren, versprochen!
Bei diesen 130 sind auch Adapter bei, die kein Nvidia Logo haben, lesen, ich sprach explizit von Adaptern mit Nvidia Logo!
Mag sein das da "auch" Adapter bei waren wo kein Logo drauf war aber es gibt eben auch 150v kabel bei Nvidia Adaptern .. aber is doch super das DEIN Adpater 300v Kabel hat
bei anderen is das aber eben nich der Fall zb eben bei den Zotac Karten wie GamersNexus zb geschrieben hat
Auch sagt er das nur weil da nun 150v Kabel verbaut sind muss das noch nix heissen
Ich nehme hier 0 als Maßstab was ich mache is einfach nur eine Berichterstattung von Dingen die so passieren aber ich vertrette natürlich auch meine Meinung dazu
Die die hier im thread nen Maßstab nehmen sind andere Leute die nehmen zb die Geringe Zahl an Fällen als Maßstab dafür dass das alles ja nich so schlimm sei sind ja erst 30 Fälle von denen wir wissen
seit dem 28.10 passiert
Ja, und seit Wochen drehen sich alle im Kreis und die Lösung ist für die, die dem Adapter nicht trauen, sie nehmen andere Kabel und fühlen sich dann sicher, passt doch dann. Und wenn Zotac aus der Reihe tanzt, nun, wer weiß, was die Gründe sind, bei den FE könnte ich wetten, du findest keinen Adpater mit 150V Kabeln.
Jup weil Nvidia seit Wochen keine Offizielle Stellung dazu bisher bezogen hat sondern erstmal mit der Untersuchung weitermachen will währendessen immer mehr Fälle passieren
wo hoffentlich nie etwas schlimmes passieren wird wo jemand in Lebensgefahr kommt
Wenn Nvidia dafür dann die Garantie nich fallen lässt passt das vielleicht ja aber da Nvidia die Sache so schwammig formuliert hat wissen wir nich ob Nvidia dann die Garantie übernimmt
bei einem Fall wo es mit nem Anderem Kabel / Adapter passiert ( siehe zb Jays letztes Video ) ... da ja auch mit anderen Kabeln die Nativ sind schon Fälle bekannt sind ( MSI ATX 3.0 Netzteil )
Wenn der Adapater per se ein Problem wäre, wäre der Verkauf gestoppt worden und jetzt kann sich jeder weiter seinen eigenen Film fahren.
Nochmal ... Nvidia untersucht immernoch ... es dauert halt .. noch is da keine Entscheidung seitens Nvidia gefallen weil die untersuchung noch andauert und sie nich ausm Quark kommen
war bei vielen anderen Dingen ( wie eben das NZXT Riser Kabel was zu brennen anfing ) die ich nun schon mehrfach hier im Thread benannt habe nich anders
In der Zwischenzeit steigen die Fallzahlen halt weiter an und eine FE is ja nun auch schon betroffen
Jup is interessant was hier so für 2-3 Leute so für Filme fahren .. manche laufen halt mit Scheuklappen durchs leben
hm?
Lag meiner Inno3d X3 OC bei. Ist eine Referenzkarte! Kann leider keine Bilder machen vom Stecker selbst, da das Handy schlecht ist. Stecker ist aber intakt nach 3 Wochen Nutzung.
Und manche springen voll auf den Zug auf. Sind zwar auch nur 2 bis 3 aber immerhin. Jeder wie er mag
Klar ist aber beim Adapter das Problem , dass dieses mit 8 Leitungen für die 12 Pins mal angelötet sind.
Das ist schon misst. Da sind die nativen von Bequiet oder Corsair wo die Leitungen jeweils gecrimpt sind schon besser .
Wie soll man ohne an den Adapter dran zu gehen prüfen ob die Kabel noch ordentlich verlötet sind?
Bei dem einen Kabel von Bequiet was nicht ordentlich verarbeitet war konnte man es halt direkt sehen und der User konnte das Kabel dann reklamieren.
Das ist für mich persönlich das Hauptproblem am Adapter. Ich habe meinen Nvidia Adapter entsorgt und würde es Wünschenswert finden , wenn die jeweiligen
Boardpartner demnächst bessere Adapter Kabel an die Kunden schicken bzw. man sich dafür anmelden kann eines kostenfrei zu erhalten.
Ja das hab ich schon bei diversen Themen immer gesagt aber in der Vergangenheit wurd ich dafür nur belächelt und die Leute suchten für den Preisanstieg dann rechtfertigungen wie "ja wir bekommen diesmal ja auch mehr fürs Geld" "Das wird nächstemal anders sein weil das liegt momentan nur an den Minern" "Ist zwar viel Geld aber schau dir an wie Effizient diese Generation ist da kann man mal etwas mehr ausgeben" "Das liegt an dem Krieg und der Inflation da kann der Hersteller nichts für wird bald wieder besser werden".
Solange es gekauft wird wird diese Spirale nur stetig steigen. Besonders das auch die "normaleren" Karte wie die 4080 jetzt schon zu Preisen von 1700-2000euro liegen ist doch schon verrückt. 2015 zum Release hab ich eine 980 TI Strix für 699euro kaufen können. Sooolange ist das auch nicht her.
Ja und selbst das alte Ding, was natürlich neu und krass war zu damaligen Zeiten, schon ziemlich teuer war und nur eine verdammte Komponente vom ganzen System... so gesehen dürfte eine Grafikkarte niemals mehr als 500 € Kosten selbst das ist für jemanden, der nichts damit zu tun hat, einfach nur verdammt viel Geld. Ein Ottonormalverbraucher muss auch oft tief in die Tasche greifen für eine Playstation 5 oder Xbox SX. Die Preise für Grafikkarten waren schon immer irgendwie umstritten. Aber "haben wollen" ist halt oft übermächtig als "nein mach ich aus Prinzip nicht" 😁
Genau, soll jeder machen, wie er es für richtig hält, für mich gibt es keinen Grund dem Adapter nicht zu trauen! Ich habe diesen mit der FE eine Woche lang bis 550 Watt Dauerlast gequält, jetzt die TUF quäle ich seit einer Woche auch bis 550 Watt, der Adapater ist wie neu, der Stecker auf der Karte ebenfalls.
das wird sicher von allen akzeptiert. Und jetzt akzeptierst du vielleicht noch das nicht jeder mit dir einer Meinung ist was den Adapter angeht und alles ist super. :)
Witzig dass grade du forderst andere Meinungen und Positionen zu akzeptieren
:popcorn:
Absolut aktzeptiere ich das ... jeder hat seine Meinung ( was wichtig is ) und sollte dem gegenüber seine Meinung lassen und sich nich darüber lustig machen was hier aber leider passiert hin und wieder von bestimmten Personen ... aber man kann natürlich auch normal über Dinge Diskutieren und sollte dabei aber Sachlich argumentieren mit den Fakten die auf dem Tisch liegen
:popcorn:
ja, manche verstehen halt was man schreibt und wie Aussagen gemeint sind und andere sehen eben Angriffe darin. Liegt an der Person selbst. Ein müdes lächeln hast du mir zumindest entlockt.
Darf man fragen welches genau Du hast, ich hab so auf die Schnelle kein gescheites gefunden.
Hab gleich zu Beginn das Corsair Kabel abgegriffen und das bevor ich noch wusste, dass ich eine 4090 kaufen werde. Mittlerweile weiß ich, dass es eine goldrichtige Entscheidung war. Glaub das Kabel ist bis heute vergriffen...
Ähnliche Themen
Antworten
7K
Aufrufe
540K
