[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wääh ... nix für mich dabei -.-
Wollte eine ASUS TUF non OC
kann ich dir auch Empfehlen.
hatte die TUF und TUF OC hier, beide einmal getestet - und die "normale" TUF hat in allen Benchmarks und Games, die ich getestet hatte, bessere Werte und mehr fps bei weniger Verbrauch, trotz des niedrigeren Taktes - ganz merkwürdig
Ich weiß nicht, ob das eventuell ein Montagsmodell der TUF OC war, aber ich war dennoch überrascht.
Die Termine schieben sich alle paar Tage weiter. War einer der ersten hab am 14.10 bestellt.
Ich auch. Bei CU. Aber dann kam auch eine Verschiebung.
Naja. Läuft ja auch mit Adapter. Ist halt nur unordentlich im PC mit der Krake.
Die Karten sind baugleich. Bei der OC kommen nur cqa. 50mhz mehr aufs bios drauf.
Wenn aber die non oc einen besseren chip hat geht der trotz 50mhz weniger höher.
Bin mir auch gar nicht sicher ob die überhaupt andere Basistaktraten in den Biosen haben???
Naja. Hätte auch lieber die Non OC. 300 Euro für nix war schon ein Scalperaufschlag.
Wenn die wenigstens bei den OC Modellen die Chips testen würden oder sowas. Nein einfach bisschen höheren Takt eingestellt und fertig, 300€ teurer :d Schon heftige Abzocke.
Was für ein Prügel oO
Oben 3090 Strix mit WB, 3090FE und 4090 Strix.
Adapter ging ziemlich schwer rein ist aber bündig:
Wenn ich nicht stark gedrückt hätte, wäre er nicht bündig!
Außerdem weiß ich nun, was LianLi meint, dass die Karte mit Adapter nicht ins O11XL passt:
Dann würde ich mit „Ich bin mir nicht sicher“ anfangen.
Aber nicht pauschal darauf verweisen, dass eine OC Variante ca. 50 MHz schneller sei - vor allem nicht hier - wo die Hersteller den treuen Kunden melken.
Also lügt Asus in ihren Produktbeschreibungen oder wie kann man das verstehen? Wurde das verifiziert das sie lügen? Hab ich gar nicht mitbekommen.
Jo ist reine Produktvermarktung. Irgendein User hier, ich meine es war @***** (korrigier mich wenn es nicht stimmt) hat beide Biose der Tuf (also Oc und Non Oc) hintereinander geflasht und es ist zwei mal das gleiche Bios mit anderem Namen.
Sprich: Nix da Oc. Gleiche VF-Curve
Weiß hier jemand was das soll, wenn eine 4090 bei NBB "Sofort ab Lager" verfügbar ist, der "In den Warenkorb"-Button aber einfach nicht funktioniert?
Ja, sie lügen nach meiner Betrachtung und „darf man nicht aussprechen“.
Aber nicht nur ASUS…
Ich hatte eine TUF und habe das TUF OC Bios drauf geflasht.
Boost-Verhalten bei 1.05v bei
2715 bis 2685 MHz unangetastet.
Es gibt Leute, die haben eine TUF non OC, die höher Boostet als eine TUF OC.
@MS1988 's TUF OC hat das gleiche Boostverhalten wie diese TUF non OC.
Meine jetzige TUF OC hat 2775 bis 2745 MHz… ok, würde ich den Balkon aufmachen oder den Lüfter auf 100% stellen, hätte sie auch 2790 MHz.
Mit einem STRIX / STRIX OC Bios haben TUF / TUF OC Karten einen offset von +45 MHz (im Bios hinterlegt).
ASUS war schlau und will nicht, dass die STRIX Karten so schnell als „Verlierer“ darstehen - ich nenne es mal schummeln.
Jetzt ist aber fraglich, welcher Hersteller ebenfalls mit einem Bios (Offset Erhöhung) schummelt.
(Offset verändert die komplette Curve = MSI Afterburner: STRG + F)
Hast du ein Link zu den beiden Bios Varianten dann kann ich nachschauen ob es das selbe ist oder was geändert wurde.
Neuer NVidia Treiber: 526.86 WHQL oder über GeForce Experience
Die Gigabyte Gaming OC wird ja heute sehr oft bei Mediamarkt und Saturn angeboten. Ich hatte evtl. heute morgen bei Saturn Erfolg. Mal schauen, wollte eigentlich ne KFA2 oder lieber TUF haben.
Wenn du die Gigabyte Gaming OC meinst, da kommt das zurück {"successful":false,"cartCount":0,"isBuyable":false,"maxAmountReached":0} und der Button ist auch Grau.
Ja die. Ich weiß nicht warum man es einem so schwer bzw. unmöglich macht eine GPU zu kaufen... Ich möchte eine Gigabyte-Karte und es scheint nicht machbar. Wenn mal verfügbar dann binnen Sekunden weg oder mit abartigen Preisaufschlägen. So kann man einem das Hobby auch madig machen.
Also die Gigabyte Gaming OC war heute mehrmals kaufbar bei MM. Eh fragwürdig es ob die extra 200€ gegenüber der Windforce wert ist...
Naja hübsch ist was anderes und wieso hat man zwei 3090 rumliegen?!
Doch war sie, sogar über die normale Produktseite in den Warenkorb legbar
Ja, soweit war ich auch. Sofern denn der "Fortfahren und Bezahlen"-Button mal sichtbar war, war sofort Ende und der Einkaufsvorgang wurde mit einem Fehler abgebrochen. Ich hab es wirklich mehrfach heute probiert und es war mir mehrfach nicht möglich eine zu bestellen. Browser & Cookies schließe ich aus, die Probe mit anderen Artikeln funktioniert einwandfrei.
Habs auch mal durchlaufen lassen mit dem 5800X3D.
4090@950mV 2715MHZ
Interessant 5900 vs 5800X3D.
Ach was Forza 5 hatte ein Raytracing Update!?
Krasse Info, wird direkt mal wieder installiert und ausprobiert. Bin aber noch viel mit GT7 beschäftigt. Hatte mir das Game bei Release knapp für 80€ besorgt und bisher extrem wenig bis gar nicht gespielt. Dass muss sich echt noch ändern!
TUF und TUF OC ist auf jedenfall verarsche , weil beide Varianten über den Stock Boost Clock von 2520 oder OC Variante 2565 MHZ takten.
***** seine non OC und meine OC hat bei 1,05 V beide 2700 MHZ getaktet und ist jeweils auch in der Curve bei AB so hinterlegt .
Die GPU´s gehen hier eh teilweise stark auseinander . Manche Karten gehen sogar @ 1,05 V out of the Box 2835+ MHZ so lange die Temps stimmen.
Meine hier haben sogar manche mit REF. Design GPU´s die 2800 + takten out of the box.
Die meisten Leute die ne TUF oder TUF OC hier haben hatten GPU´s die im Bereich 2700-2790 getaktet haben.
Also das zusätzliche Geld für eine OC Variante zumindest bei den Asus Karten kann man sich wohl schenken sofern man die Auswahl hat,
weil da liegt aktuell oft das Problem. Die Asus Karten gehen sehr gut weg und sind bei Geizhals auch mit am teuersten.
Ähnliche Themen
Antworten
7K
Aufrufe
541K
