[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Cablemod hat ja nun ein FAQ hinzugefügt, aber kommt das hin?
“Once you’ve signed up, we will send you an email as soon as the adapters are available for purchase.
The email you receive will have the purchase link inside, and using the email you signed up with, you’ll be able to purchase the adapter(s) you want. We expect this to happen in roughly 4-6 weeks.
Heißt:
Ich kann die Bestellung erst in 4-6 Wochen tätigen und darf dann noch auf die Lieferung warten, die ja auch noch paar Wochen dauert…
Dann kommt das Teil ja frühestens 2023 in unsere Hände, Hach ja 😂
Genau....bis dahin sind schon alle 4090 abgebrannt...
Bzgl der Adapter-Geschichte: Laut Igors neustem Video scheint es wohl mindestens 4 Adapter Varianten im Umlauf zu geben
150V 4 löt pads (schlecht)
300V 4 löt pads (schlecht)
150V 2 löd pads combined (möglicherweise gut)
300V 2 löd pads combined (höchstwahrscheinlich gut)
Herausfinden kann man das von außen nicht. Nur durch Zerstörung des Adapters sieht man die Verlötung. Ist und bleibt also Rätselraten, welche Karten einen "vernünftigen" Adapter dabei hat.
Hier sieht man den Unterschied bei den zwei Löt-Arten (links: scheiße, rechts: stabil)
Ich habe keine Ahnung warum du meinst das die links "sch…e" sein soll. Selbst bei die Darstellung ist erkennbar, dass die benetze Fläche links vermutlich sogar größer ist pro Litze als rechts. Was ist daran also besser? Um es ganz klar zu sagen, die Aufgabe einer Lötstelle ist eine elektrische Verbindung zwischen Z. B Kabel, Bauteil und PCB oder in diesem Fall dem Stecker sicher zu stellen.
Die Aufgabe einer Lötstelle ist es in keinen Fall für mechanische Stabilität o. ä. zu sorgen. Eine Lötstelle ist immer frei von mechanischen Spannungen zu halten - Stichwort Zugentlastung. Crimpen wäre sicherlich die deutlich bessere Methode. Übrigens können auch die einzelnen Drähte/Litzen unterhalb der Ummantelung brechen, auch hier gibt es deutlich hochwertigere Ausführungen. Die Stückzahlen können überhaupt nicht so groß sein, das ein Fertiger da nicht hinterher kommt. Wenige 1000 Stück jede Woche ist lächerlich. Kein Mensch sagt das so etwas noch von Hand gelötet wird. Oder gerade auf Grund der geringen Stückzahl wird von Hand gelötet. Für mich ist hier ganz klar NV in der Verantwortung. Nur die kennen den Einsatz und die Strombelastung. Nicht der Fertiger, der bekommt idR nur Fertigungsunterlagen und produziert gemäß Zeichnung. Trotzdem darf dieser natürlich nicht so miese Qualität abliefern. Stichwort QS von NV. Gerade bei den AMIS muss man als Zulieferer jedes Mistdokument bzgl. Konfliktmaterialien … usw. ausfüllen, so dass dieses hier um so trauriger ist.
Das Design ist Mist! Hatte man 90 Grad abgewinkelt etwas designed und das Kabel nach unten oder oben weggeführt wäre dazu vermutlich nicht gekommen. Warum man jedoch 2 oder 3 Ausführungen des Kabel in den Markt bringt ist schon sehr verwunderlich.
Basierend auf dem Feedback der letzten Seiten/Tage habe ich den MMS Monitor mal beschleunigt. Er holt jetzt tagsüber 5-6 pro Minute neue Daten (statt bisher 1-2 mal pro Minute). Vielleicht hilft das ja.
Eigentlich kam die Meldung aber eh immer schon 30-60 Sekunde vor Verfügbarwerden des Warenkorb Buttons auf der Artikelseite (da komisch gecached => Umweg via Merkliste ist immer noch viable).
Danke dir für deine Mühen!
Aber ich denke da kannst du mit dem "Erkennen" Bot nicht viel machen. Ich bin der Meinung dass das Checkout Bots aktiv sind. Und so schnell wie die die Elemente auf der Homepage bedienen kann man das als Mensch einfach nicht.
MM und Saturn müssten ihre Shops härten, damit man zumindest in der Zeit bis die Bots angepasst sind eine kleine Chance hat.
Und das alles nur, damit die einen vermeintlich ein paar Hunderter Gewinn machen können (da sind wieder die dran schuld die dort kaufen) und die anderen parallel x Karten wollen damit sie sich die besten aussuchen können. Tja. Ist dann halt so.
Meine Austausch Gamingrock OC ist auch unterwegs, mal schauen wie lang die halten wird :d
Beste Grüße
Denn empfehle ich denjenigen aber auch ein Gewerbe anzumelden und direkt alles weiterzuhökern. Von Grafikkarten bis zum Klopapier.
Weißt, lieber schmeiß ich die paar Hunderter mehr einem echten Händler in den Rachen als so einem Privathökerer
Vereinzelt schon, aber nicht bei allen Karten und nicht immer. Kann ich mir echt nicht vorstellen, die Karten bringen im Re-Sell kaum Gewinn, besonders nicht für Botter die das im großen Stil machen (mit Gewerbe, ggf. USt).
Ich hab bei den <= 2000 Karten oft selbst mitgemacht und dann bei der Paypal Zahlung doch wieder abgebrochen weil ich nur die FE haben will. Ging zwar nicht immer (manchmal war man per Hand zu lahm), aber einige male bin ich schon durchgekommen.
Inzwischen gibt es die Karten auch beim Händler teurer. Brauchst keine Scalper mehr.
Was für ein quatsch. Hoffentlich glaubt diesen Panikmachern niemand.
Wenn der 90° Winkel Stecker von Seasonic nach unten verläuft, also Richtung der Lüfter, dann wird er nicht passen.
Bei Cablemod passt der 180° Stecker B mit Sicherheit (bei mir ist aber ne AIO im Weg :d ). Der 90° Stecker ist aber anscheinend nur dazu gedacht um das Kabel Richtung Lüfter zu verlegen und nicht nach oben. Hier passt der Stecker B aber nicht.
Habe die Suprim bei NBB bestellt für 2450€...brauche endlich mal ne 4090 und will nicht ewig auf eine FE warten...wobei die Suprim passt vielleicht gar nicht :d
Zur Not schicke ich sie zurück oder verkaufe die weiter zum €inkaufspreis.
Denkst du es gibt noch eine reale Chance auf eine FE? Die hab ich von meiner Liste eigentlich schon gestrichen, weil als Einhorn abgestempelt
Ihm geht's um den Adapter von nvidia. Er glaubt nicht an den defekt
Mag sein das manche falsch gefertigt wurden oder es ist ein Benutzerfehler...
Sowas gab es schon immer...nur wird alles heutzutage alles Clickbaity breitgetreten...
Man darf auch nicht den Fakt vergessen, das es vorher gar keine Adapter bei Karten dabei gab. Bisher war es nur die 3000FEs und die 3090Ti...
Schmorende Stecker gab es schon vorher, nur war nicht einer Schuld, sondern verschiedene...
Wenn man also JETZT den Adapter falsch reinsteckt ist Nvidia Schuld...wenn man das mit alten Karten ohne Adapter gemacht hat, war man selber Schuld... jaja >_>
Nur zur Anmerkung: Ich habe mir ein Adapterkabel bestellt, weil ich ein kleines Gehäuse habe und mit einem neuen Kabel deutlich weniger Platz brauche.
Der 90° B Winkel ist interessant, weil das kleine Gehäuse nur knapp 2,3-2,5cm cm bis zum Seitenpanel hat. Der Nvidia Adapter ist so lang, das es schlicht nicht passt.
Kann aber sein, das das neue Kabel ausreicht. Mit einem starken Knick :d
Naja, Polkappen sinds nun auch nicht die von der Klimaerwärmung schmelzen. Scheint eine Lotterie zu sein ob es einen trifft oder nicht.
Nur fürs Protokoll. Scrush liegt falsch. Mir ging es nicht um den Nvidia Adapter.
Schade Marmelade.
Naja aber cablemod sagt ja dass die an
anderen karten folgen werden. Ob der Adapter da angepasst werden muss, ka
Aber ich finds toll das es hier soviele gibt die Beta Tester spielen.
Ich warte ganz entspannt bis das alles gefixt ist und ohne Probleme läuft
Bis nvidia was macht war der Weihnachtsmann 2 mal da😅
Das glaube ich nicht, ich glaube das es genau ein Hersteller ist der in der ersten Charge eben Mist gebaut hat. Und ich denke sogar das Nvidia genau das gleiche glaubt, deshalb agieren die so wie sie agieren.
Das ganze wird jetzt erstmal geprüft und dann wird wahrscheinlich rauskommen Hersteller X hat bei Charge Y Mist gebaut weil ... Und dann gibt es halt verschiedene Schritte wie das ganze weiter geht
Option 1: Der Hersteller wird nochmal gebrieft und bei den neuen Kabeln wird ganz genau drauf geschaut.
Option 2: Der Hersteller fliegt aus der Produktion und muss ich neue Kunden suchen.
Wenn dann die Rückverfolgbarkeit passt und man genau vermerkt hat welcher Hersteller bei welcher Karte welches Kabel beilegt und an welche Händler die Karten gingen, wird man rausfinden können welche Kunden ein Kabel erhalten haben das Defekt sein kann und kann direkt ein neues Kabel kostenfrei zusenden.
Außerdem braucht man so viele Anläufe um die Karte zu kriegen die man will, dass man ruhig schon einmal anfangen kann. Lieber dann nach einem Funktionstest hinlegen und warten bis der Adapter Fix da ist.
Ich hoffe nur, dass es eine Lösung ohne gelötete Verbindung gibt. Selbst wenn sie nicht zu den defekten Adaptern gehören, alt werden die nicht. Im KFZ ist sowas z.B. verboten soweit ich weiß, weil man sich einfach nicht drauf verlassen kann. Crimpen hieß da seit Jahren schon das Mittel der Wahl und damit hatte ich nie Probleme.
Dann sind wir schon 2. Ich kaufe nur neu.
oder wenn man es übersetzt: "Bis ich endlich die Karte bekomme die ich will ohne dauerhaft am PC zu aktualisieren"
Ahja. Also mein System rennt ohne Probleme und ich wüsste aktuell kein Game das unbedingt ne 4090 brauch, aber gut du scheinst es ja besser zu wissen :lol:
Was an der Gamerock gammelig sein soll wüsste ich gern mal. Hatte die mal eine Zeit lang und war top.
Wenn sie so Top war wieso hast du sie dann abgegeben? Geht mir einfach nur darum das es ein Outlet Modell ist und die Karte unter UVP angeboten werden müsste, also unter 1999€ für die OC.
Ähnliche Themen
