[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Man man man, wer immernoch denkt seine 4090 an der Kotzgrenze laufen zu lassen statt UV zu nutzen oder das PT zu verringern, der hats langsam echt nichtmehr anders verdient. Ich wette da ist kein einziger Fall dabei von Leuten die normal mit Ihren Karten umgehen und vernünftig die Kabel legen sowie UV oder PT verringern.
Blöderweise erfährt man sowas halt nicht. Das gibt ja keiner zu.
So viel besser wie das Spulenfiepen der KFA2 auch ist, der Kühler kommt an die Asus TUF Non-OC bei weitem nicht ran. Die Karte will auf über 70c und die Lüfter drehen sehr gut hörbar auf. Man kann die Lüfterkurve anpassen, aber dann steigen die Temps auf weit über 70. Die TUF-Lüfter waren fast nicht hörbar bei Temps im niedrigen 60er-Bereich. Zero-RPM funktioniert bei mir auch nicht richtig. Die Karte hängt idle gerne bei 30% und gerade bei dieser Lüftergeschwindigkeit höre ich auch einiges an Resonanzgeräuschen.
Die TUF ist dieses Jahr ein überdimensioniertes Kühlwunder für den Preis. Insbesondere als die zu Release zu UVP (~ 1950) verkauft wurde. Hier ist der Aufpreis zur Strix (300 € oder mehr) kaum sinnvoll.
Abgesehen vom Spulenfiepen sehe ich hier keinerlei Nachteil zu höherpreisigen Karten. Wer preisbewusst einkauft, sollte sich am besten zu einer TUF oder einer FE zu UVP umschauen, sofern derjenige die Geduld hat.
  • Danke
Reaktionen: THK
Dazu sollte man aber folgendes nicht vergessen:
Zitat CB:
„ Noch eine große Stufe darüber ist die UHD-Auflösung angesiedelt, die Grafikkarte entscheidet nun de facto allein.
Hier bleibt die alte Erkenntnis, dass sich mit jeder modernen CPU gepaart mit den besten Grafikkarten in dieser Auflösung quasi gleich gut spielen lässt.
Quelle:
Regler!
settings runter und man kann auch in 4k höhere fps erzielen und die muss die cpu, natürlich wie in jeder anderen auflösung auch, stemmen
deswegen hab ich vorhin den borderlands screenshot gepostet. 1 regler von 124 auf 192fps!
Regler!
Was heißt bei Dir "settings runter" und "regler"?
Redest Du von UV? Oder in einem Game die Grafikanforderungen runterschrauben?
alles fein :d
ingame settings natürlich,. ich will ja mehr fps
Regler!
Einspruch!
Maximale Bildqualität!
Alle Regler sollten auf Max stehen bei 4K (am besten natürlich mit RT und ohne DLSS), dafür ist die 4090 schließlich da! 😏
das ist aber dein bier :d
wenn du mit weniger fps klarkommst ist das super. aber jemand der mehr fps will dreht die regler zurück und dann wird auch in 4k eine größere cpu notwendig
alles fein :d
Dann reduzierst Du also die Grafikqualität für mehr FPS?
Macht für mich überhaupt keinen Sinn, ich kaufe ja grade eine 4090, damit ich auf meinem OLED in 4K die absolut überragenste Bildpracht habe. Wenn mir Bildqualität egal ist, kann ich auch einfach eine 3070 nehmen , mache DLSS performance an und kaufe mir stattdessen irgendwas schönes.
Aber jeder wie er mag.
von be quiet gibt es noch kein atx 3.0 netzteil.
das von seasonic kommt auch erst noch... bisher gibt es von seasonic nur ein passendes kabel was direkt ans netzteil angeschlossen werden kann.
offiziell nur für 1.000 und 1.300 watt modelle.
Die offiziell genannten NT sind die einzigen für die Seasonic erstmal Kablel rausgibt. Ich hatte bei Seasonic am 14.10 angefragt wie es aussieht für ältere NT wenn man das Kabel kaufen will.
Da solte man definitv nicht drauf warten.
feierabend, geht nach hause
alles ausverkauft :d
jay hat cablemod leerräumen lassen mit seinem aufruf :d
EDIT: US STORE
im EU STORE GEHTS NOCH
Glück gehabt :d
alles fein :d
Dann würde ich eher einen Monitor mit einer niedrigen Auflösung nehmen um höhere FPS zu erzielen statt auf Grafikpracht zu verzichtn. Schau dir doch mal bei deinen sreenshots die wiesen an! eine sieht aus wie von 2001 und die andere wie ein modernes game.
Macht für mich überhaupt keinen Sinn, ich kaufe ja grade eine 4090, damit ich auf meinem OLED in 4K die absolut überragenste Bildpracht habe. Wenn mir Bildqualität egal ist, kann ich auf einfach eine 3070 nehmen , mache DLSS performance an und kaufe mir stattdessen irgendwas schönes.
die bildpracht ergibt sich bei mir aus nativer auflösung + gute kantenglättung und den FPS die mein monitor anzeigen kann. effekte kommen bei mir ganz hinten.
Vielleicht gibt es ja bei der 5090 endlich mal ein Modell, welches geringes Spulenfiepen und gute Kühlung kombiniert. :d
das ist ein GPU setting und auflösung ist 100% gpu workload. ein niedriger monitor bringt mir in einem cpu limit gar nichts. darum gehts doch gerade.
joa mir ist das wurscht wie die wiese aussieht wenn ich nur 120fps bekomme ist das eben zu wenig ;)
Das sind alles Fake-Benchmarks. Der einzige seriöse "Benchmark-Youtuber , den man eventuell mal als Anhaltspunkt nehmen kann, ist "Bang4Buck Gamer".
Also der Kerl der über 2100 mhz auf seiner 3090 Master bei knapp unter 60 Grad laufen hat, ich bitte dich... seine bechmark Videos nimmt er Nachts auf, bei geöffneten Fenster oder im Winter. Rechner stellt er direkt dahin um schön seine kühlen Temps zu präsentieren. Wenn man ihn frägt wie er seine Karte mit Luft so kühl bekommt, gibt's keine Antwort. Absoluter Spast der Typ.
OK. Bei CPU Limit hast du natürlich recht.
kollege. wie oft soll man es dir eigentlich noch eklären. das oc hat damit nix zu tun. Wäre dem so, hätten das deutlich mehr leute, vor allem hier im luxx die ihre karten für jeden punkt im 3d mark todprügeln.
wenn der adapter heile ist, geht alles, sobald das ding aber eine schwachstelle hat weil das ding jämmerlich konstruiert wurde, dann kommt es mit pech zu diesem problem so wie es aktuell den anschein macht
jeder hier im thread mit ausnahme von ein paar wenigen schließt die karte an und knallt im afterburner direkt alles richtung 3ghz. und knallt das ding durch timespy und speedway. hier passiert gar nichts.
es passiert einzelnen usern die die karte selbst mit uv und niedrigem PT laufen lassen.
muess es erst konsumentenklagen geben bevor Nvidia nen offizielles wort gibt?
Der wohnt in England und hat nen MORA direkt am Fenster stehen. Logisch trägt das mit dazu bei. Zumindest zeigt er seine Setups im Video (sowohl den Aufbau als auch das Equipment und seine Settings) und das finde ich okay. Mit nem Custom Loop am richtigen Wohnort definitiv so machbar.
Musst nichts erklären. Ändert nichts daran das man es beeinflussen kann. Wenn man UV betreibt oder das PT verringert geht weniger Strom durch den Adapter und somit ist die Gefahr auch geringer. Da man nie weis welcher Adapter halt schlecht verarbeitet ist und welcher nicht. Keine Ahnung wie oft man dir sowas erklären muss.
Ich hab vorhin auch mal schnell den Stecker an der Strix kontrolliert, alles gut… 😅
Cablemod dauert allerdings noch etwas…
und wie tief soll man das pt denn stellen? ab wie viel watt ist man safe?
beim optimal PT von ca 70% gehen bei full load trotzdem 300w+ durch die karte. ich glaube nicht dass das tief genug ist
lol. muss schon sagen der aftermath nach den neuen hardware releases ist schon geiler als die hardware selbst :d
Ähnliche Themen
Antworten
6K
Aufrufe
392K
