[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Falscher Thread :
Aber damit dieser Post hier nich umsonst war .... das dürfte "Pixel Shift" sein sofern es sich um etwa 1cm handelt um welches sich das Bild verschiebt... Pixel Shift kannst du im TV Menu ausschalten.
Ist aber eine Burn In Schutz Funktion .... muss jeder selber wissen ob er das ausschaltet oder nich
Joh - LG kann auslesen, wann, wie oft, wie lange es deaktiviert wurde
Hier ein Bild:
Liegt das eventuell auch an randloser Fenstermodus ? Früher hatte ich das damit nicht. Das kommt auch wenn ich die Taskleiste öffne im Spiel über die WIndowstaste.
Eine FE Hats doch zu mir geschafft
TUF : -------------------------------------------------------------------------------------------------- Strix :
Anhang anzeigen 809133--- Anhang anzeigen 809134
Macht nicht die Welt aus, aber die Strix hat ein "paar" Sachen mehr drauf
Die Elkos scheinen komplett andere (hochwertigere?) zu sein
btw:
Fein, dass die TUF das hier hat... :-)
das ist schonmal kein pixelshift
window mode?
alt + enter?
Schaut danach aus :d
wozu willst den randlosen fenstermodus?
Ob die Elkos ( weis noch nichmal was das nun sein soll :d ) andere sind weiss ich nich
Aber ob nun 2150 für ne TUF OC oder 2350 für ne Strix OC is nun auch nich mehr so der große unterschied bei der Summe an sich... und ich brauch halt eher mehr HDMI Anschlüsse als Weniger daher TUF oder Strix
Daher werd ich dann .. sofern AMD am 3.11 nix besseres vorstellt ... zur 4090 Strix greifen wenn die Power Adapter Sache geklärt ist und die Verfügbarkeit Normal geworden ist sodas Menschliche Wesen
auch mal ne Chance haben eine zu kaufen.
Power Adapter verschmort :
Fall Nr. 10 ( 9 ohne unsern Luxxer )
Fall Nr. 11 ( 10 ohne unseren Luxxer )
Somit dann nun 11 bzw 10 Fälle ( zieht man unsern Luxxer ab ) in 16 tagen bisher von dennen wir bisher wissen
Assassins Creed Valhalla gespielt? Das baucht mit maximalen Settings in 4k nicht mal 200 Watt. Die Karte taktet ~1500mhz. Da gehen kaum die Lüfter an. Und das schmort die Kabel?
Ich weiss nich was diese Personen da gespielt haben ich berichte nur von den Fällen der verschmorten Adapter die ich so im Netz finde und bisher haben wir da nun 11 bzw 10 Fälle von
verschmorten Adaptern
Ich finde schon das es einen Preisunterschied zwischen der TUF für 1950€ und der Strix OC für 2350€ gibt. Leistung sollte bei beiden ziemlich identisch sein.
@SamLombardo
Sieht auch nicht danach aus, als hätte er das Kabel weit vorne am 12VHPWR-Stecker geknickt
Wenn das sein Setup, wie auf dem Bild ist, verstehe ich das Problem mit dem Stecker nicht
Wir wissen aber auch nicht, ob das Kabel mal scharf geknickt wurde (DAS SOLLTE MAN BESSER NICHT TUN)
Einzelne Adern könnten aus den gecrimpten Hülsen gerutscht sein und einen beschissenen Übergangswiderstand haben (<- da wirds gerne heiß)
Verstehe sowieso nicht, warum man "Millionen" Leiter braucht, um 600W zu befördern
Im Modellbau reichen genau 2 Leitungen (+/-) mit jeweils 6mm² und anständigen Steckern
Ok, mit dem billigen China-Dreck, mit ~30 An-/Absteckzyklen lässt sich mehr Geld machen :rolleyes2:
ich hab gedacht jo machste n Treiber Downgrade auf 522.25 damit das geflacker in MW2 vielleicht aufhört, jetzt freezed es random im Menü oder in der Runde oder nach der Runde :d, und dabei ist es egal ob neuer Treiber oder 522.25... hab auch schon mit DDU removed, fantastisch :d
nur das game? hab den neuen auch schon drauf^^
Was ist hier Kaputt :)
Das neue CyberPunk ja ?
SackBoy mit Ultra Settings und Raytracing OHNE DLSS :)
Sorry vor lauter testen vergessen zu reagieren. Ich hab das immer so gehabt in der Vergangenheit. War ganz geschickt um mal spontan was nebenbei zu öffnen. Aber gebraucht hab ich das nicht oft. Ich werde jetzt auf Vollbild bleiben denke ich. Habs einfach nie wieder geändert :d
das vollbild sofern gleiche auflösung wie desktop ist fast genauso fix beim alt tabben :)
Das is dann aber die TUF non OC ... die TUF OC kostet 2150 Euro und nich 1950 Euro ... ich hab aber eben TUF OC mit Strix OC verglichen : ( non OC is immer günstiger )
Und hier war sie sogar nochmal etwas günstiger gelistet .. das war Gestern oder Vorgestern : ( währen zur TUF OC dann "nur" 137 Euro unterschied )
Er meinte die TUF OC (aktuell im ASUS-webshop für 2.188€) ;)
Aber +238€ mehr für lasche +45MHz mehr, als die Non-OC ist die TUF OC nicht wert @Stagefire ;)
Zwischen der Strix und Strix OC liegen nur 13€ :rolleyes2:
Die RT-Effekte der UE4 sind von Haus aus leider nicht gut optimiert. Ich denke die Entwickler werden die hier in einfach nur forciert haben. Kannst auch mal Fortnite mit RT ausprobieren. Habe da selbst mit DLSS Drops auf 20fps mit der 4090 gesehen. :fresse:
@Stagefire Man könnte natürlich auch die TUF-OC und die STrix Non-OC vergleichen. Aber drauf will ich nicht hinaus.
Mir geht es um die Frage ob die günstigste 4090 (TUF non-oc) weniger Performance hat als die teuerste 4090 (Strix oc).
Ähnliche Themen
Antworten
7K
Aufrufe
477K
