[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
der Link der FE bei NBB kann sich durchaus bei neuen Drops ändern, aber dort ab und an zu schauen kann natürlich wie in diesem Fall ein Lucky shot sein.
verwendet eigentlich irgendwer den kleinen Ständer der zu den Karten mitgeliefert wird?
glaub der ist viel zu klein für mein Gehäuse^^ der kommt nie am Boden an
Hast du mal die Kompatibilitätsliste für dein PSU geprüft? Wenn aus zweimal 8 Pin jeweils 300W rauskommen, kannst auch zweimal 8 Pin nehmen. Wäre da in jedem Fall vorsichtig und würde mir das via Emal bestätigen lassen.
Sollte gehen. Das Original Corsair Kabel nimmt auch 300 Watt aus einer Buchse. Ich schreib das hier aber Mal hin falls jemand mitliest.
Solange mein cablemod Kabel aber nicht da ist mache ich eh keine 600 Watt Späße.. nur will ich keine Wackelkontakt-widerstandsheizung in der Nähe meiner VGA haben XD
Ja hätte mir auch nicht gedacht mal das Glück zu haben ein Einhorn zu schießen. Hatte bei Ampere nicht geklappt und am Releasetag von Ada auch nicht... die zweite Chance ging aufgrund Job durch die Lappen und GFE pfff ein Witz. Das wird umgehend wieder deinstalliert! :haha:
Ja und er reicht obwohl ich ein WP100 hab
ich melde mich auch mal zurück. Ich habe eine Gainward RTX 4090 Phantom GS 2-3 Tage nach release bei Alternate gekauft. Hier schreiben einige von unerträglichen Geräuschen, das kann ich so gar nicht bestätigen. Die Karte surrt ein wenig aber extrem unauffällig. Sobald ich die Scheibe wieder dran habe hört man so gut wie nichts mehr. Gehäuse ist eine Fractal Meshify 2 Air Flow.
Die Seriennummer der Karte habe ich leider nicht parat... Karton ist schon im Keller.
2. Punkt: Ich habe den Connector nach ca. 2 Std. Dauerbetrieb (mit 450W) mal mit einer Temperaturpistole gemessen und kam auf maximal 51c bei 100% PT. Bei 111% waren es 53c.
Hier nochmal das Video zum Geräusch bei Volllast:
Weiß jemand wie viel Watt diese Karte zulässt?
Wie könnt ihr die KFA2 bestellen? Ich habe die im Warenkorb, aber dort ist bei mir der kaufen button immer ausgegraut..
Achja bei der strix war so ein ausziehbarer arretierbarer mininschraubendreher dabei. Für was? Der ist für ganz kleine schräubchen gedacht also nicht die Brocken am case slot...
GPU Stütze...
Reicht ein 750W Netzteil (Be Quiet Dark Power Pro 11) erstmal für die 4090 mit einem i9 9900k? Steht eh bald ein Wechsel auf einen 7950X an, dann gibts auch ein neues NT, aber hab mich gefragt ob das wohl auch noch mit dem alten NT gehen würde
Gerade hätt ich können, aber dann hab ich mich blöd angestellt. Hätte es einfach nur in meinen Markt liefern lassen sollen. Aber heute hab ich zuviel parallel...
Interessant. Kann da jemand ein Foto machen bitte? Muss man den umdrehen und als teleskopstütze zwischen Karte und PSU shroud klemmen?
Ach und dieser ahem Pappe Ständer für Handys, soll das zum Einbau die Taschenlampe schräg fixieren?
So habe ich es.
Umdrehen und mit der Gummiseite nach oben.
Der Pappkartonhandyständer ist bestimmt nur Gimmick.
Habe mal den beiliegenden 3-Zack Adapter durchgemessen. Auch bei dem sind die Kontakte mit diesen Plättchen miteinander am Stecker verbunden und nicht wie bei der 3090 Serie, wo jedes einzelne Kabel noch extra auf den Pin gecrimpt war. Also auch dieser Adapter ist Schrott und gefährlich.
Hat jemand schon an Gigabyte Cashback Aktion teilgenommen und bei Media Markt bestellt?
Gigabyte will da die Kundennummer des Shops, irgendwie finde ich nur leider keine.😂 Verglichen mit alten Rechnungen ändern sich da alle Nummern immer und online sah ich da auch keine. Jemand ne Ahnung wo man die findet?
Hast du nicht eine Clubkarte? Steht da nicht ne Nummer drauf?
Ich denke wenn du kein OC betreibst auf jeden Fall aber gewährleisten kann dir das keiner. Ich hab ja auch "nur" 750W und werde erstmal stock bzw. dann UV damit fahren. Mein 5900X braucht etwas mehr als so manch andere aber heute Nacht/Früh gegen 1 Uhr wurde ich sehr schwach und... ja X3D incoming.
am 19.10. habe ich vorbestellt, in der Auftragsbestätigung stand als Liefertermin der 21.11.
hatte mich heute früh auch gewundert / gefreut das EK nun schon versendet hat.
Welche Version davon Nickel Plexi oder Nickel Acetal mit ABP oder ohne ABP?
Also wenn man eine GPU haben will...von denen scheint es genug zu geben:
ja... hatte sie im Warenkorb... aber dann kam mir der Lüfter ins Gedächtnis... heute ist ein blöder Tag bei mir ^^
Ähnliche Themen
Antworten
6K
Aufrufe
389K
