[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Arbeiten auf einem OLED ist auch nicht gut, zumindest was Schrift angeht. Zocken macht natürlich Laune, besonders mit dem Kontrast, echtem Schwarz.
modmesh oder flex?
wie lang hats gedauert?
25-50€ rum kostet diese
eins über den configurator kostet 53€ mit aluminimum connector
ein fertiges 25-30.
strange :fresse:
scheint wohl der aufschlag für extrawurst zu sein
Schon geil was der 5800x3d mit den alten Boards und altem RAM reißen kann mit der 4090 :)
Ich hab mir das modDIY.com Kabel gekauft.
2x8 Pin (PSU) -> 12VHPWR
Gibts auch mit 3x8 PIN.
Ist aber bei meinem be quiet SP11 1200W nicht nötigt da sich der dritte PCIe Stromanschluss eh auf beide Rails aufteilt.
Versand ist gratis, dauert aber dann etwas länger. Wenn man drauf zahlt, kommt es recht zügig.
Falls jemand da bestellt, mit dem Code NEXT10 gibts 10% Rabatt.
Hoffe die haben sauber gearbeitet beim Stecker, aber bis jetzt waren die Kabel immer top.
So nochmal zum FE Drop von heute. Das Ding ging ne halbe Stunde später in den Versand. Auffällig zu meinem Versuch am 12.10.22, dass die Artikelnummer (A 996979) eine andere (A 997429) ist. Könnte sich also sehr wohl um einen Rückläufer handeln zumal sonst keiner irgendwas gesehen bzw. gehört hat.
Heut war ein FE drop? Ist der Bot kaputt?
Von Cablemod gibt's noch nichts für be quiet oder...hab mal das Original Kabel bei Caseking bestellt, mit unbestimmten Lieferdatum. Sonst gibt's ja keins soweit. Bei Modify wollte ich nicht extra bestellen. Bin am überlegen ob ich nicht gleich ein neues Netzteil kaufe. Da musst echt überlegen wie man die Zeit überbrückt mit dem Wish-Adapter von Nvidia. Fand die Infos von Igor echt gut und ein Witz von Nvidia, die ner 2k Graka nen 99 Cent Adapter beilegen. Kein Bock auf Real Life RTX mit RauchRTX und SchmorRTX. Das mindeste von Nvidia wäre ein kostenloser Austausch.
Klingt jetzt verrückt. Aber wenn du mit Hirn an die Sache rangehst, dann wirst du weder noch haben. Es ist nicht nur der Adapter das Problem. Der User vor dem PC ist auch mit verantwortlich was er draus macht :) Beispiel extrem biegen / knicken usw.
Fast jeder, der ne 4090 reinknallt, wird dies halbwegs anständig erledigen aber JEDER (auch Du und alle mit dem 4 Zack nach den Infos) wird immer mal wieder etwas argwöhnisch ins Case blicken bis diese Sache erledigt ist. Dann ists auch wieder gut und alles läuft normal weiter.
nein. Siehst du auch auf vielen Fotos hier das viele eben drücken und knicken bis zum geht nicht mehr damit die Karte ins viel zu kleine Gehäuse passt. Fotos gibts massig.
aber JEDER (auch Du und alle mit dem 4 Zack nach den Infos) werden immer mal wieder etwas argwöhnisch ins Case blicken bis diese Sache erledigt ist.
nein, mein Gehäuse ist verschlossen. Ich werde das nicht wieder öffnen. Andere eventuell schon. Ich mache mir da aber generell keine Gedanken, da meine Karte unter 300W benötigt und mein Gehäuse groß genug ist.
Tut es jetzt auch schon, wenn man wie gesagt mit etwas vernunft an die Sache rangeht. Das sagt übrigens auch der hoch gelobte Igor in seinem Video. Das durchaus auch der User vor dem PC dafür sorgen kann, da es gar nicht erst zu problemen kommt.
Das kann doch nach allem, was bisher bekannt ist, nicht Dein Ernst sein.:shake:
Schade das manche nicht weit genug schauen können. Natürlich ist das mein Ernst und das bleibt er sogar. Ist doch auch logisch das der User vor dem PC nicht unschuldig ist. Alleine wenn man schon sieht das das Kabel an der Gehäusewand eingeklemmt ist und somit deutlich weiter gebogen und geknickt wird als normalerweise. Wenn das nicht so wäre, wäre auch das Grundproblem kleiner.
An dem Adapter selbst ändert das nichts, aber man kann durchaus umgehen das es zu Problemen kommt und beeinflussen wie schnell es zu Problemen kommt. Echt schade, das manche das einfach nicht sehen sondern sich strickt ihn ihrer Blase "Nvidia ist schuld weil der Adapter kacke ist" verstecken. Unverständlich.
Lustig an der Sache ist, das ihr ein stinknormales Stromkabel von z.b. einem Mehrfachstecker niemals so biegen würdet wie ihr es mit dem Kabel der GPU tut. Warum wohl ? Gesunder Menschenverstand eventuell ?
Na da bin ich ja mal gespannt gestern bei MF bestellt... gammelt leider noch immer bei DHL in Bremen rum mit dem Hinweis, hoher Krankenstand, alles kann länger dauern :(
Ebenso😂 trotz allem wirft mein gesunder Menschenverstand nen Blick ins Case bis das Thema mit nem anderen Adapter oder dem be quiet Kabel abgeschlossen ist. Dein Kommentar klingt leider so als ob wir nicht mehr ganz bei Trost wären...sorry dafür. Es kann halt random jeden treffen, das ist der Stand. Natürlich hat die Mehrheit Glück aber es ist echt bescheiden für den Einzelnen.
BTT, bin auch am überlegen den 13700k anzuschaffen um das CPU Limit etwas zu erhöhen. Schon heftig wie schnell die 4090 dem 12700k die Grenzen aufzeigt (z.B. in Assetto Corsa Competitione mit Triplescreen).
Ähnliche Themen
