[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ich hab mich jetzt doch schon entschieden das neue bequiet zu verwende nach Igors Video.
Hab das Kabel auch schon gestern bestellt hoffe die können bald liefern.... solange stelle ich das benchen lieber mal ein, man möge es mir verzeihen. :d
Versteh ich, immerhin ist das Kabel erst seid heute gefährlich. Die ganzen Benches bisher waren ungefährlich. Du machst das schon richtig :)
Defekte Airbags werden auch erst dann gefährlich wenn sie zum Einsatz kommen also bei einem crash. Autos werden trotzdem zurückgerufen obwohl noch nix passiert ist.
Die benches sind auch micht der Auslöser
Habe wohl grad ein glückliches Händchen für gute Chips. Gestern die 13700K Perle, jetzt eine gute 4090...
full hd? :d
ah im verkaufsthread hast 1440p geschrieben :)
Ist das hier Werbung für deinen Verkaufsthread? Darf ich fragen wieso du sie direkt verkaufst?
also meine gainward von alternate war neu ovp, gerade eben angekommen
nix b ware
Kurzes Update zu meiner Inno3D iCHill - mehr wird schwieriger bei 450 Watt:
+ 210 GPU / +1660 Speicher
Morgen / Samstag kommt der Wasserkühler und dann geht es an den Umbau. Ich muss dann mal sehen, wie ich das Siegel auf der Rückseite "entfernen" kann, ohne es kaputt zu machen. Habt Ihr nen Tipp?
Der ist schon kaputt wenn den anschaust. Das ist so ein ich geh in 100 Teile kaputt Aufkleber. Hatte es damals mit der 3090 versucht. Eine Schrauber an der backplate gelöst war der schon broken.
jupp der wird beim wiederaufbringen definiv von einem neuen zu unterscheiden sein. bete einfach dass mit der karte nix passiert
Der neue Grafikkartentreiber ist ja raus gibst Verbesserung Verschlechterung…?
Lg
Da zieh selbst ich, cHio First of his Name, Großmeister des bottings, mein Hut. Windforce für 1950 gekauft, 1h nichtssagende Tests gefahren und für 350€ mehr weiter verkaufen. :ROFLMAO: Stundenlohn kann sich sehen lassen. (y)
Und Du unterstellst mir keine Ahnung zu haben? Wie viel Offset man geben muss, hängt neben Temp/Spannung vor allem davon ab, wie die Boostclocks im BIOS eingestellt sind. Default taktet die Karte 2730, weil das im BIOS so konfiguriert ist. Mit einem Offset von 283, lande ich bei 3000.
also bisher kein Spulenfiepen bei 4090 Zotac?
Was hat denn der default Takt mit dem Overclock zu tun? Gigabyte haut auf seine Karten ein Standard Bios, in dem die Boost Tables alle gleich sind.
Was die Karte kann, hat mit dem Auslieferungszustand nichts zu tun.
Ähnliche Themen
