[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das ganze ist doch mit Plastik und Gummi ausgegossen.
Ich habe das starke Gefühl dass das nicht ausreicht.
Das Grauen hat ein Gesicht: NVIDIAs feuriger 12+4 Pin Adapter für die GeForce RTX 4090 analysiert!
Ich auch nicht, aber zumindest besser, als wäre es frei in dem Stecker.
So hat es nach den ersteren Bildern für mich gewirkt.
Kommen denn in absehbarer Zeit noch ein paar ATX 3.0 Netzteile ?
So schlecht wie der Adapter offenbar ist, scheint es ja absolut Sinn zu machen, gleich ein NT mit nativem 16-Pin Stecker zu kaufen, wenn man ohnehin ein neues braucht.
Ich werde die Karte drosseln auf 250 Watt und erst wieder freilassen wenn das cablemod Kabel da ist.
Stell dir mal vor dass man die liegen lassen kann bis es ordentliche Kabel gibt
Kennt sich zufällig jemand mit Crysis Remastered aus? Wollte jetzt mit der 4090 mal schauen, wie das inzwischen so läuft und irgendwie geht meine Bildrate nie über 63 FPS!? Stimmt da was mit der Engine nicht? Egal, ob ich auf den Boden, gen Himmel oder auch im Hauptmenü schaue - die FPS kleben bei 63:
Im originalen Crysis habe ich das nicht, in anderen Games auch nicht. FPS-Limit und V-Sync sind logischerweise nicht aktiv. Kurzes Googlen hat mir auch nicht geholfen.
passend zur TUF ein TUF NT. :fresse:
Haben die auch die Sense pin?
Im Rog forum hatte jemand ein Rog Thor II mit 12vhpwr Anschluss aber noch ohne die 4 Sense pin bekommen.
tjoa...hängst halt im cpu limit, willkommen im club :d
sieht so aus oder?
müssen wir nur hoffen das das ding gute kritiken bekommt..
vll hilft eines der dinge von hier
Und erneut liegst du falsch. Mein Beitrag wurde nie bearbeitet. Sieht man auch direkt am Beitrag. Von dir kommt einfach nichts richtiges. Egal. Du bist erledigt für mich :)
Touché.
Ändert trotzdem nichts daran, dass du nur Stuss von dir gibst. Kann nur hoffen, dass niemand aufgrund deiner hyperintelligenten Verharmlosungen zu Schaden kommt. Sowas geht mir an die Nieren und deswegen ist das auch mein letzter Beitrag im Forum. Viel Spaß noch.
Deine Curve sieht scheiße aus...
Irgendwann / irgendwo wirst du Crashes haben, versprochen!
Nur weil 900mv vielleicht stable sind, heißt das aber definitiv nicht, dass alle Werte zwischen 700 und 900mv stable sind.
Triggern wirst du das, wenn die Karte vor sich rumlümmelt und die Leistung bei 900mv nicht benötigt wird: FPS Limit, DLSS, whatever.
Dann wird es auf die Aufwendung geschoben :popcorn:
pffff dann zeig mal deine Curve bei deinem Kartoffel Chip :d
Meine hat einen 99er Loop Metro Exodus EE Benchmark mit max Settings, DLSS und 5160x2160 durchgehalten, mehr wollte ich jetzt nicht stresstesten nach dem die ersten Stecker durchgeschmorrt sind. :shot:
Und gezockt habe ich schon einiges im 144Hz Limit. Also wir werden sehen. :sneaky:
Danke Dir. Das habe ich geflissentlich ignoriert, weil es sich nur auf Crysis 2 und 3 bezogen hat. ^^
Low Latency Mode auf Ultra im Treiber hat geholfen:
Wollte schon sagen... mit nem 10900K niemals im CPU-Limit in dem Spiel. :d
pffff dann zeig mal deine Curve :d
Es gibt immer wieder Samples die ultra niedrige Spannungen auch auf Halblast mitmachen, auch wenn da nen 200mhz OC druff is. Ich hatte vor der aktuellen FE ne 3080 12Gb Trio, die ohne jemals zu crashen ihr Leben in meinem PC mit 0,775V bei 1860 Mhz auf Luft mitgemacht. Das habe ich vorher bei noch keiner Ampere gesehen, und ich habe sehr viel gebencht.
Ich mache dazu heute ein Video. Die Latenz wird in manchen Games einfach überbewertet. Als es noch kein GSYNC gab konnte auch jeder zufrieden zocken. Es mag bei Esport auf ein paar ms ankommen. Aber nicht bei Plague oder Spiderman. Probiere es selbst einmal aus. Spüren tust DU den Unterschied mit einem Controller nicht. Hatte auch immer blind einen Framelimiter benutzt um unter Vsync zu bleiben. Für Dlss3 habe ich jetzt mal Vsync genutzt. Die beiden genanntenj games fühlen sich genau so an. Nur mit FG jetzt butterweich auf dem Bildschirm. Mehr Details im Video...
Ein Framelimiter bringt doch überhaupt nichts bei DLSS3. Die Latenz ist fast identisch. Da merkt man logischerweise keinen Unterschied. Wenn du Latenz reduzieren willst mit DLSS3, musst du die GraKa so ans Limit bringen, dass sie einfach nicht anders kann als unter Vsync oder Framelimiter (+Vsync) zu bleiben
Mal schauen wie oft das Video hier noch verlinkt wird? :rolleyes2:
Man muss da einige Kerne deaktivieren. Google mal. Vollschrott das remake
Ihr mit euren Millisekunden latenzen. die machen plague oder spiderman echt unspielbar... ^^
also brauch ich nur mein seasonic 3000 fe 12 pin kabel nehmen und für 450watt einfach den 2. von den 4 sense pins erden. sicherer als der adapter mist :ROFLMAO:
Ja Division 2 habe ich auch gebencht aber keine loops, weil ich nicht wüsste wie man die automatisch loopt
875mV 2460Mhz
870mV 2430Mhz
Meinst du das packt sie nicht? Kann ich bei Gelegenheit ja benchen, ist ja nicht das Problem jetzt.
875mV 2460Mhz
870mV 2430Mhz
@***** geht nicht um die Spitzenwerte sondern um das Offset im Spannungsbereich unter deinem maximalen Spannungspunkt. Besser wäre die Anfangskurve steiler laufen zu lassen, dass die Niedrigspannungen kein Offset haben.
->Curve auf
->875 Punkt auf 2460 ziehen.
->alles was dahinter noch ansteigt drunter ziehen
->abspeichern. Damit sind alle Takt-Punkte unter 875mV mit weniger Offset aber dafür größeren Sprüngen zwischeneinander versehen und du hast ne höhere Stabilität bei Halblast.
Aber wie gesagt, es kann auch einfach sein, dass dein Chip auch im Niedrigspannungsbereich sehr gut ist und mit dem Offset schlichtweg klarkommt
Ähnliche Themen
Antworten
7K
Aufrufe
477K
