[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So ich hab mich hier mal registriert um evtl mehr infos zu geben.
Ich bin die Person mit dem ersten Fall. Falls fragen da sind fragt
Ist nur die Karte und Adapter jetzt defekt oder hat’s auch andere Komponenten erwischt ?
Neues Gigabyte Bios für Gaming OC: Lüfter brauchen 4% mehr Fanspeed um stabil zu laufen.
Also auf dem Bild hängt der eine Strang aber schon ziemlich stark geknickt weg
Dank der "empfohlenen Biegeradien" hat man praktisch einen Freifahrtschein und kann jedem Betroffenen erstmal pauschal unterstellen, dass erst er/sie selbst dran Schuld ist. Diese 4er-Peitsche lässt sich nun mal sch*** verlegen und in irgendeine Richtung muss das Ding am Ende gebogen werden. Mittlerweile wird die kleinste Biegung, der kleinste Knick als "ziemlich stark geknickt" bezeichnet... Irgendwo ist das einfach nur noch lächerlich, dass man einen Steckertyp hat, wo die Kabel absolut perfekt verlegt werden müssen, weil man ja sonst fahrlässig handelt.
Ich will das mit der Beachtung der Biegeradien gar nicht verharmlosen oder so. Schließlich hatte ich selbst Negativ-Beispiele direkt im Freundes-/Bekanntenkreis. Auch hier im Forum oder auf Google finden sich etliche Bilder, wo die Leute den Stecker/ Adapter ziemlich stark biegen, von den ITX-Systemen mal ganz zu schweigen. Wenn man das jetzt mit dem oberen Foto vergleicht, ist das Kabel/ der Adapter noch relativ entspannt verlegt. Da sind selbst die ganzen Bilder auf Google weitaus schlimmer.
Meine Maxime: Always change a running system :d
Was ist denn da jetzt mal Sache bei der Geschichte mit dem durchgeschmorten 12VHPWR 🔌??
Habt ihr bei euch auch mal drauf geachtet wie die Temperatur am Stecker ist(ohne sich einen Stromschlag abzuholen)? Gab es sonst noch jemanden mit sonstigen Auffälligkeiten, die in die Richtung gehen?
Oder ist das alles nur ein dummer Zufall gewesen bei demjenigen 🤔
Das ist doch perfektes Futter für Romans Kanal. Vielleicht kann er da Licht ins dunkel bringen. Denke aber Steve wird sicher auch schauen
die lüfter sind vielleicht bei 100% ok, aber stell die mal auf den geringsten wert 30%. son brummen/sägen ist nicht normal für lüfter die mit 1000rpm laufen
Gemacht was du verlangtest. Ich habe soetwas nicht. Ich bezweilfe nicht, dass es stimmt, was du sagst, daher war ich so besorgt bevor ich die Karte erhielt und ich würde das sehr gerne feststellen innerhalb meiner Rückgabefrist.
Aber ich kann kein Brummen feststellen bei 30%, 20% oder 10%.
Immerhin laufen 99%+ ohne Probleme.
Ich will niemandem auf den Schlips treten, gehe aber schon davon aus, dass da einige dabei sein werden, die da was überdehnt haben oder sonstwie nicht aufgepasst und das vermutlich nicht einmal wissen. Zugeben wird das kaum einer im Nachgang.
Welches Vertical Mount empfiehlt ihr?
Schaut auf allen Bilder richtig schlecht aus
soll ich jetzt mein netzteil aufs gehäuse legen, damit das kabel gerade von oben kommt bei vertikal verbauter karte? der stecker ist einfach nur müll
Ähnliche Themen
