[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Selbst wenn wir von 10.000 Karten ausgehen, dann sind das 0,03%. Und 10K sind definitiv zu tief gegriffen wenn Shops stellenweise mehr als 600 Karten bekommen haben.
Und jetzt? Groß angelegte Rückrufaktionen passieren wegen Einzelfällen, wenn sich diese intern beim Hersteller nachstellen lassen. Das reicht schon völlig aus.
Wir reden hier aber nicht über einen banalen Kondensator der Platzt oder ein SMD Bauteil welches kurz durchbrennt und gut ist. Wir reden über einen Steckerkopf der Durchbrennt die resultierende Gefahr ist höher.
Und wenn ich mich recht erinnere lief der PC bei denen dokumentieren Fällen weiter und hat sich nicht abgeschaltet. Aktuell ist die Lage noch nicht wirklich überschaubar - aber ich hätte als RTX 4090 Besitzer Angst das System unter Last z.B. Rendering ohne Beisein laufen zu lassen!
3. Jeder mit etwas Hirn weis das man Stromkabel nie eng verlegt. Solche Brandstellen sieht man bei normalen Mehrfachsteckern auch öfter wenn diese zu stark gebogen sind.
4. Manche glauben scheinbar das alles in ihr extrem kleines Gehäuse passen muss und lassen sich am Ende sogar dafür feiern das Sie mit Kabelbindern und co. doch noch die Kabel verlegt bekommen haben. Anders wäre das
Völlig realitätsfern. Ich behaupte, nahezu alle Käufer quetschen das Teil in ihr bestehendes Gehäuse, Deckel drauf und gut ist. Die meisten verkauften Gehäuse bieten schlicht nicht den Platz. Das ist auch Nvidia bekannt. Niemand, absolut niemand ausser vielleicht drei oder vier Supernerds beschäftigten sich mit der Frage, wie gross der Biegeradius, der Abstand zum Stecker 35 mm oder besser 37 mm sein sollte und was genau der beste Winkel zum Biegen ist, um das Haus nicht abzufackeln. Darum muss sich der Hersteller kümmern. Und wenn es nur vom Fachmann gemacht werden darf, dann ist das Mindeste dies auch klar zu kommunizieren oder den Krempel eben nur B2B anzubieten. Der Adapter ist Müll, das sieht auch ein Blinder. Nvidia hat sich entschieden das Risiko einzugehen, mit der Brechstange zu miniaturisieren. Ich hoffe, es bleibt bei Sachschäden. Und ich hoffe, sie werden verklagt :)
Ja, wenn festgestellt wurde, dass ein grundsätzliches Problem existiert, aber an dem Punkt sind wir doch noch gar nicht und dafür sind 3 Fälle auch zu wenig, um das von außen bewerten zu können.
Die 3 Fälle können bisher auch einfach nur Einzelfälle sein, aber einige rennen schon durch die Foren und halten die Nvidiakarten für gefährlich.
So ne kleine Platine zum aufstecken schön verpackt mit 4x8 Pin und 12+4 VHPWR wäre doch super gewesen, statt dieser Kabelpeitsche :d
Aber keine Ahnung wie Kompakt man das hinbekommt, und ist natürlich teurer.
All diese Dinge sind nur ein kleiner Teil dessen was nicht berücksichtigt wird. Und man sollte auch noch sehen wie viele Karten bisher eigentlich verkauft wurden und wie viele Fälle es gibt. Es wäre einfach schön wenn man etwas auf dem Boden bleibt.
Und wie siehst du das wenn deine Karte betroffen wäre?
Renderst ein Video wo du außer Haus bist und kommst wieder und findest ne verqualmte Wohnung vor,im Worstcase hat dir die Feuerwehr schon die Tür eingetreten.
Dann bleibt noch die Frage der Versicherung ob solche Geräte ohne Aufsicht betrieben werden dürfen,Stichwort Obhutspflicht.
Der Stecker ist jetzt keine meisterliche Ingenieurskunst aber ich finde das Ganze wird etwas overhyped. Ich sehe das Problem eher in einer mangelhaften Kabelqualität inkl. unsachmäßiger Behandlung und weniger an nVidia selbst. Kann mir sehr gut vorstellen, dass bei der Qualität des Kabels durch billige China Herstellung einfach teilweise geschlampt worden ist. In ordentlicher Qualität wird das wahrscheinlich keine Probleme machen.
@owned139 Klar können dies Einzelfälle sein aber legen wir die Fakten doch mal auf den Tisch:
- 1 Monat vor Release wird das Problem bekannt
- Nvidia sagt betroffen waren Kabel anderer Hersteller in der Entwicklungsphase die Problem sind behoben
- Die Karten erscheinen mit einer Vielzahl von Hinweisen wie das Kabel gebogen werden darf blablabla etc.
- Hersteller limitieren die Garantie auf 30 Steckzyklen etc.
- Die ersten Karten brennen bei Kunden durch
Allein schon die diversen Warnhinweise und Vorschriften für den Umgang mit den Adapter sind für mich ein klares Zeichen das es hier ein Problem gibt.
Nvidia hätte nur soetwas hier beilegen müssen und alle Problem wären gelöst. Geringe Bauhöhe "Ausnudelgefahr" der Terminals geringer:
@cHio ES LIEGT NICHT AM KABEL!!! ES LIEGT AM MANGELDEN KONTAKT DER TERMINALS
Während der Entwicklung traten Fehler auf, und?
Das ist ganz normal.
Du darfst Kabel generell nicht zu stark biegen, da ansonsten Kabelbrüche entstehen.
Das betrifft genau so die alten 6-8Pin Stecker, aber naja.
Bei dreien bisher und bei allen anderen nicht. Ich habe meine TUF jetzt auch seit 2 Wochen im Einsatz und das Kabel ist immer noch tadellos. Die meisten in diesem Thread haben eine 4090 und kein einziger Stecker ist durchgeschmort.
Den Fakt ignorierst du bewusst. Für dich ist der Fall klar: Alle Stecker sind potentiell gefährlich, aber diese Aussage basiert eben nicht auf Fakten. Du hast weder Insiderwissen, noch gibt es die Fehelrquote von < 0,03% her.
Habt ihr die Beobachtungen der PCI-SIG überhaupt gesehen? Es sind nicht nur die Steckköpfe am Steckerport zur GPU verschmort, sondern auch direkt am NT-Eingang. Das ist also mitnichten nur der doofe Adapter von Nvidia GPU-seitig.
Vom Prinzip hätten Sie den Stecker, Kabel, Litzen, Terminal (keine Ahnung; bin kein Fachmann) mit Epoxi eingießen können dann wär das Thema auch keins. Falls das möglich ist. Aber würde mich wundern wenn so ein kleiner Schritt nicht hätte eingefügt werden können in den Produktionsprozess.
Weil das Ding erst durch Stress zum problem wird somit passiert bei denen, wo auf dem Kabel weniger stress wirkt, erstmal nix denke ich
Und die Möglichkeiten sind sehr vielfältig wie das Kabel falsch belastet werden kann.
Verstehe ich nicht. Die Stecker sind nunmal "potentiell gefährlich". Sind alle abgeraucht? Nein. Das sagt auch niemand.
Wenn Du mit einem Risiko im Promillebereich leben kannst, Dir z.B. nachts während dem Rendern die Bude abzufackeln - kudos to you.
Wenn Du mit einem Risiko im Promillebereich leben kannst...
Nein, aber genau deine zweite Aussage ist der Knackpunkt. 3 von x tausend Karten sind defekt und du tust so, als könnte das bei jedem passieren.
Das ist aber nur der Fall, wenn der Stecker grundsätzlich Fehlerhaft ist und genau das wissen wir nicht. Bei 3 Fällen kann man jedenfalls noch nicht von einem grundsätzlichen Problem sprechen.
Das New World Thema wurde damals auch medial aufgebauscht und es wurde von Igor und co. behauptet, dass auch AMD und andere Karten betroffen waren.
EVGA hat 2 dutzend Karten weltweit ausgetauscht und danach hat man von der Problematik nie wieder gehört. War also nur ne Nebelkerze.
Man darf nicht das Kabel vom Netzteilhersteller verwenden, sondern wird gezwungen, den ollen Adapter zu verwenden.
Wo ist dann der Sinn vom 12vhpwr 🫣
interessant finden ich diese Passage:
So Nvidia honestly didn't know about the issue. However, the chipmaker does warn against using third-party adapters, such as the Cablemod and the upcoming Seasonic one, which will void your warranty.
Warten wir doch erstmal ab, was Nvidia oder die Boardpartner dazu dann offiziell bekanntgeben. Hier wird so viel gemutmaßt und am Ende weiß es Keiner wirklich.
Ich denke, dass wenn es ein grundlegendes Problem wäre, wären schon mehr User davon betroffen. Außerdem kann ich es nur wiederholen, ich hatte den neuen Adapter für 6-7 Monate an meiner 3090Ti ohne Probleme und es gab auch bisher sonst keine mir bekannten Fälle, mit dem Adapter und den 3090 Tis. Also alle mal durchatmen!
Ziemlich gewagte Aussage, wenn schon die PCI-SIG auch direkt am Netzteil verschmorte Pins bei Tests ausmachen konnte.
Woher weißt du denn davon ab, dass das nicht bei jedem passieren kann? Hier geht's nicht darum, dass es definitiv passieren wird. Aber dass ein potentielles Risiko besteht, reicht ja schon aus. Und "Kabelbrand" ist definitiv alles andere als lustig...
Seh ich genauso. Die 90° Stecker werden eine viel besser Stabilität bringen. Auch find ich kann man mehr Stabilität am Stecker selbst herstellen. Einfach nur das Kabel rein mit einer Klammer naja ,.... Ich denke da gibts schon viel bessere Lösungen und die werden auch kommen.
Nur,.... :) die 20 cent mehr Gewinn hat man doch als Firma, wie überall wenn man erstmal nach Spezifikation geht.
Naja, beim Herstellen der Grafikkarte spart man Platz auf dem PCB.
Als nVidia würde ich auch erstmal sowas öffentlich sagen. Du hast ja keine Ahnung was es da alles für Adapter und Netzteilkabel gibt. Sie beziehen sich nur auf das was sie auch vertreten müssen.
Ja, während der Entwicklung. Es ist normal, dass während der Entwicklung Probleme auftreten. Nvidia behauptet, dass das Problem nicht mehr existiert. Siehe: https://www.hardwareluxx.de/communi...rktplatz-handeln-sperre.1323338/post-29515265
Weiß ich nicht, aber deswegen halte ich mich auch zurück und renne nicht durch die Foren um Panik zu verbreiten.
Mal ne ganz blöde Frage:
Lässt sich dieses Schmor-Problem nicht einfach mit einem nativen ATX 3.0 PSU "umgehen"? Die haben ja den 12VHPWR von Haus aus drin. Keine 4x8-pin auf 1x16-pin Adapter etc.
Oder verstehe ich hier grundlegend was nicht? 😅
Es gibt auch schmor Probleme mit 8-Pins z.b., die sind aber gaaanz selten und bei weitem nicht so schlimm. Ob natives ATX 3.0 oder nicht, es schon reicht wenn man einen PCI-E 5.0 Adapter nutzt.
Ich sehe die Probleme IM Nvidia Adapter 16-Pin Stecker selbst.
Mal eine Frage.
Wenn ich Afterburner starte, dann steht bei mir 90% Powertarget.
Bedeutet das, dass die Karte nur mit 90% Leistung arbeitet?
Und wenn ja, wieso steht die automatisch nur auf 90%?
ja
sie darf nur 90% der 450w verbrauchen, solange sie nicht voll ausgelastet ist am Anschlag, hast du keine Leistungseinbußen
keine ahnung
Nein, die Warnung der PCI-SIG stammt erst aus dem September. Da ist nichts mehr mit Entwicklung. Warum Nvidia sagt, dass das Problem/die Probleme gefixt sind, weiß ich nicht. Kann nur Nvidia intern beantworten.
Da reichen auch schon zwei bekannte Fälle aus, um diese Behauptung in Frage zu stellen.
Fall jemand gerade einen neuen Prozzi sucht für seine 4090 und noch AM4 hat:
Innerhalb von ein paar Tagen von 467€ auf 366€ gefallen, 101€ weniger ist schon extrem krass. Wow 🤩
Edit: Der Niedrigste Preis liegt sogar bei 348€!: 🙏🙏🙏
Viel zu teuer ;)
/OT
Ähnliche Themen
