[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die Frage ist auch was passiert wenn man in dem Moment wo das passiert nich im Raum ist und vielleicht so 10 min auf dem Klo ist oder in der Küche ?
Das kann dann sicher auch schnell mal mehr als nur die Karte und der Adapter werden der da dann Kokelt oder vielleicht sogar brennt
so easy wie das einige hier abtun sollte man die ganze sache jedenfalls nicht das is schon ne Nummer was da grad passiert
Und der nächste Fall : ( mit unserm Luxxer von vorhin wären das nun 5 Fälle in 2 Wochen .. zumindest von dennen wir bisher wissen )
Wichtige Frage und hat Nvidia wirklich übertrieben,-
man muss ja nicht immer alles fokusieren und "Erster" sein
Kann es sein das NVidia deshalb die Produktion der 4090 enorm drosselt und sich besinnt
und dem Ganzen ein Ende bereitet.
PS:
Mann kann nur auf AMD hoffen da jene 2x 8Pin, oder max. 3x 8Pin verbauen
und dass die Leistungsaufnahme bei unter 300 Watt, max. 350 Watt bleibt!
Dem Forumskollegen Viel Glück
und dass alles geklärt werden kann und die Garantie Greift!
Nein .. wenn dann kommt der Absolute Produktionsstop wenn es um die Sicherheit geht aber der is nich angekündigt .. und auch das mit der Drosselung is bisher nur ein Gerücht und kein Fakt
somit sollte man das auch noch als Gerücht behandeln und nicht als fakt... auch war niemals die rede von "enorm drosseln" sondern nur "drosseln"
Bisher is nur bekannt das Nvidia selbst sich mit den Nutzern bei dennen das passiert ist meldet und die neuen Fälle begutachten will
Es bleibt spannend.... 2018 : Space Invader Artefakte , 2020 : Cap Problem , 2022 : schmelzende und brennende Power Adapter ( wobei hoffentlich niemand zu schaden kommt ) , 2024 : ???
nun bin ich sogar froh das ich noch keine 4090 Strix abbekommen hab und geh erstmal in Wartestellung bis das geklärt ist und schaue mir an was von AMD am 3.11 angekündigt wird.
Wollen wir mal hoffen , dass es lediglich an manche Adaptern liegt . Finde sieht eh schon kriminell aus das Dinge . Daher froh ein natives von Corsair zu haben .
Kann es nur nicht verstehen . Gab microfit 3.0 und dann bei der 3090 TI den 12+4 Adapter .
Hmm.. Vielleicht wären 450 Watt max + 8 pin Kabel besser gewesen..
5090 dann mit kleineren Leistungsprung dafür wieder 8 pin
Tja ich hätte auch nie gedacht, dass ich eher eine Palit behalte als eine MSI. Aber das Fiepen bei der MSI war echt nicht mehr ertragbar. Und Geld gespart habe ich auch :ROFLMAO:
Hatte vorher eine Palit 2080Ti, auch da war Spulenfappen kein Thema, sogar 2100MHz hat sie unter Wasser gem8. Weiß immer noch ned wieso so massiv zu Asus und MSI gegriffen wird. oO
Prestige, aussehen und meist einer der besten Luftkühler.. Aber eigentlich nicht den Aufpreis wert.. Hatte früher auch mal Strixxen aber jetzt ist der Preisunterschied zur FE viel zu groß geworden.
Bei der 3090 war ja mal 1663€ die UVP im Asus Webshop. Dann haben die iwann den Preis stark angehoben
Bei der nächsten Gen gibt es dann gratis Feuerlöscher dazu :ROFLMAO:
AMD weiß schon warum sie diesen Müll Connector nicht auf die 7000er Karten packen
Unter Wasser sehen alle Grakas gleich aus. Schon für die früheren Aufpreise bekam man einen Block für die GPU, die dann unter Wasser moar MHz gem8 hat als ne Graka mit "dem besten Luftkühler".
Für die heutigen Aufpreise bekommt man eine ganze Wakü. (y)
Offensichtlich gibt es auch noch eine Tendenz dazu, dass ausgerechnet die Modelle der unattraktiven Hersteller (Palit, Inno3d, Zokack?...) eher kein Spulenfappen haben.
Konsequenz daraus? Strix und Suprims sind morgen wieder in Milisekunden ausverkauft. :o
Hab Coolblue für alle 4090 hinzugefügt, nicht nur die zwei Karten. Keine Ahnung ob da noch mehr reinkommen oder nicht - kannst du ja vllt. besser sagen, wenn du den Shop schon länger beobachtest.
Ich hatte nur durch Zufall die beiden Karten entdeckt - Preis ist ja gut. Ob noch andere Karten kommen, weiß ich nicht.
Ansonsten kann ich nichts negatives sagen - schnelle Lieferung und bisher noch keine Probleme gehabt.
Fuck, meine 4090 TUF ist gerade beim Warzone 2 zocken abgeraucht. Es stinkt alles verschmort und die Sicherung ist geflogen.
irgendwie kann ich dir das nicht abnehmen, sorry.
Du gehst ruhig schlafen nach dem Vorfall?! Ohne einziges Foto zu machen?
Ich glaube generell an das Gute im Menschen aber hier glaube ich dir leider nicht - sorry!
Täuscht mich das, oder trifft es hauptsächlich die TUF ?
Die TUF wird mit am meisten verkauft, daher... Und je breiter die Karte desto eher wird das Kabel doll geknickt. Die bequiet!-Kabel haben keine Versteifung/Sleeve, die sind auch gut dabei bei der Schmorquote.
Asus und MSI deshalb, weil bei Wakü-Umbau die Garantie nicht erlischt.
P.S.: Mist, mir bleibt wohl nur ohne Seitenfenster und warten bis es offizielle 90°-Kabel gibt. Gebogen ist der Adapter schon, hoffe das Zurückbiegen macht es nicht schlimmer.
Nvidia will nur die Garantie nicht übernehmen, wenn ein anderer Adapter Schuld ist. Das Problem ist ja immer der Stecker. Entsprechend wäre bei Schäden dann der genannte Steckerhersteller Schuld. Wobei der bei 2000-2500€ Schaden wohl erstmal nen Gutachter dazuholen will und man dann erstmal ne Weile auf dem Schaden sitzt bis sich das geklärt hat. (Wahrscheinlich kann man aber relativ günstig nen neuen Stecker bei ner Reparatur drauflöten lassen)
Kenne nur paar Geschichten von zbs. Corsair AIOs, bei denen man dann den ganzen Rechner einsenden durfte und ewig warten. (Meine teilweise 1-2 Monate)
Ist aber unwahrscheinlich, dass es dann abgelehnt wird. Außer zbs. Cablemod stellt fest, dass der Stecker nicht ab 35cm sondern schon ab 30cm gebogen wurde. (Der Gebrauchshinweis muss dann aber auch dem Produkt beiliegen)
Die Kabelhersteller verkaufen ihr Zeug wohl auch so teuer, um solche Fälle abzudecken.
Naja nächste Gen baut Nvidia dann nen Tempsensor in die Buchs ein und im Zweifel gibt es Notabschaltungen :p Würde mich nicht wundern, es wurde ja auch bei den 6/8 Pins nen hoher Aufwand für die perfekte Lastverteilung betrieben.
Na das ließt sich ja schon wieder alles herzallerliebst hier... :rolleyes2:
Mein Beileid @tomm73
Drück Dir die Daumen, dass es nicht ganz so schlimm ist und nur der Adapter und dessen Plastikstecker betroffen ist.
Halt uns mal bitte auf dem Laufenden, gern in nem eigenen Thread dafür.
Der 16pin Stecker ist so klein, die Karte wird wohl hin sein. Hoffe asus hilft hier aus.
Evga scheint irgendwie einige Dinge virausgesehen zu haben könnte man meinen.
Werde heute abend mal meinen Adapter genau begutachten.
Hoffentlich ist der 90 grad Adapter von cablemod in ausreichender Zahl verfügbar......
Ich frag mich auch wie er Warzone 2 gespielt hat, Release ist erst am 16.11. aber wahrscheinlich einfach vertippt 😁
Achja jetzt weiß ich zumindest wieso ich MSI dankbar bin für ihr 520W Bios :)
Ähnliche Themen
