[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
die Hersteller müssen doch keine Adapter bei legen das machen sie eigenständig und freiwillig
und was glaubst du warum sie das machen?
weil die karte sonst eine totgeburt wäre weil es keine netzteile gibt, die den anschluss haben.
also wirklich freiwillig ist das sicher nicht.
Na wenn alles schon vorhanden ist, cool. Glaube ich zwar nicht ansatzweise, aber hey, ich will dir deine Illusionen gar nicht rauben.
Schönen Abend dir noch 🙏
Geht eher um Fakten als um Glauben … Fakt ist man braucht zum aktuellen Zeitpunkt kein ATX 3.0!
Und wenn man es dann braucht dann wird es auch von den Bekannten guten Herstellern verfügbar sein ;-)
Und ja, jeder kann selbst entscheiden ob er jetzt an seiner Grafikkarte ein vernünftiges Netzteil anschließt oder eben seine 750 Watt Gurke die er vor 3 Jahren gekauft hat als ATX 2.4 rauskam.
Jetzt kannst du gerne wieder den Beitrag so lange editieren das ein ganz anderes Bild entsteht.
Aber wenn du dann fertig bist dir auch nen schönen Abend.
Hast Du die Möglichkeit einen Thermosensor nahe an den Kabeln anzuklemmen?
Ich schätze mal direkt an den Kabeln wird es ca. 20° C heißer sein. Ist zwar immer noch nicht brandgefährlich, aber mit der Zeit verändert sich die isolierende Umgebung.
Nein, möchte da auch ran. Ich gebe mich mal mit den 59,3°C zufrieden. Es ist ja nicht Dauerzustand bei 545W 1h lang zu spielen.
Da der Stecker nach dem Test nicht zum Flammenwerfer wurde, gehe ich davon aus, dass ich in Zukunft auch nicht abgefackelt werde. Die Lasten werden in der Praxis sicher niedriger sein. (y)
nur 1 std zocken?
wird da jemand alt^^
Ich ballere schon mal länger. (y), Aber ich erwarte nicht in diesem Zeitraum, dass für 1h 545W konstant anliegen werden. :o
Wie läuft denn das jetzt wieder bei Proshop? Wollte mir die Demo-Inno mal kommen lassen. Schlechtestmögliche Karte aber immerhin preislich gut und es gibt Waterblocks. Steht auf Lagernd aber kann nicht bestellt werden.
Warum?
Hier im HWluxx Test hat die Karte ziemlich gut abgeschnitten
Thja, gutes Beispiel wie man es nicht machen soll :fresse2:
Ich habe den Bequiet Adapter zwar noch nicht in der Hand gehabt aber die Biegung bei dir fängt direkt am Stecker an. Genau das gilt es zu vermeiden. Die Adern aus dem Stecker sollen über eine gewisse Strecke, 3,5cm wird von Cablemod genannt, gerade herauskommen bevor der eigentliche Biegeradius beginnt.
Hm, okay, ich habe das noch etwas entschärft und einen etwas größeren Bogen gemacht, viel mehr ginge aber nicht weil dann kommt das Seitenfenster und ich will da jetzt auch nicht viel rumrödeln.
Mal den Treiber neu installieren über den abgesicherten Modus. Hilft oft. Nicht vergessen den das "Neuinstallation" unter erweitert zu aktivieren.
Hab ich alles probiert. Hab jetzt sogar das Windows neu installiert. Es ist praktisch so, sobald ich den Treiber installiert habe, kann ich nicht mehr fehlerfrei ins Windows booten. Hab ja heute Nachmittag geschrieben, dass es jedes 2. mal beim Booten ist, mittlerweile muss ich 3,4,5 mal booten um überhaupt ins Windows zu kommen. Bin schön langsam ratlos. Treiber kann ich auch nur den 522.25 installieren bei den älteren meckert er dass die nicht zum Windows kompatibel sind. Konnte aber mit meiner 3080 ohne Probleme ältere installieren da der 522.25 ja Probleme in Cyberpunkt macht hab ich nen älteren drauf gespielt mit der gleichen Windows Version.
War Amazon Business Prime 2539Euro im Privaten war sie nicht gelistet :-(
Guten Preis ausgehandelt :ROFLMAO:
Und das hier...
Genau einfach den Thermosensor anlöten, das gibt die besten Werte :ROFLMAO:
Jeder mit ein wenig Grundlagen weiß aber das über die Kabelisolierung Aufgerund der geringen Oberfläche und co. keine hohen Wärmeströme übertragen werden können und darum ist die Temperaturdifferenz zwischen Kupferlitze und der Kabelummantelung nicht nennenswert. Aber Du lötest vermutlich alle deine Temperatursensoren direkt ans Kabel.... Aber vielleicht glaubst Du auch man könnte eine ~ 1 mm dicke Ummantelung als Rohrdämmung verwenden, bringt bestimmt was.
PC Hardware ist ausgeschlossen.
+ die Rabatte wurde nach oben korrigiert.
Test falls man die PC Hardware doch aufnehmen würde um zuvor die 19% aufschlagen zu können ^^
Hat die Gigabyte 4090 Aorus Master inen Defekt? Die Karte gibt es einfach niiiirgends!
Ebay leer, Idealo leer, Geizhals leer, YT bis auf Roman und ggf 2 andere auch leer. Noch nicht mal die Scalper haben die in die Hände bekommen...
Auf ebay Kleinanzeigen gibt es sogar Suchen nach der Karte....
Was ist denn da los?
500 Personen interessieren sich für das Produkt... Jo
So habe noch das Corsair 7000D direkt bei Corsair bestellt, da es überall sonst ausverkauft ist. Habe mir ein paar Bilder angeschaut, wo die 4090 mehr als genug Platz hat, damit das Kabel nicht biegt. Es soll sogar nicht mal das Seitenfenster berühren, d.h. da ist dann schon Mal die Gefahr minimiert. Wenn die 4090 morgen kommen sollte, schaffe ich es aber leider erst am Samstag alles umzubauen. Hoffentlich klappt alles, wie ich es mir vorgestellt habe :).
@ralle_h
Vielleicht kannst Du die beiden Links mit aufnehmen? Heute früh gab es wieder kurzzeitig Karten :-). Ich baue mir meine Frostbite selbst.
Ich werds mir mal anschauen. Viele Karten scheint der Shop aber nicht zu haben?
Die Zotac hat gefühlt kaum Spulenfiepen bzw mit geschlossenem Gehäuse merkt man asolut nichts, jedoch rumpeln die Lüfter bzw Motoren der Lüfter ziemlich heftig sobald die Lüfter anfangen zu drehen. Hatte die Hoffnung das ich eine "gute" Karte erhalte wie manch ein anderer hier im Forum, leider ohne Erfolg... keine Ahnung was von beidem schlimmer ist.
Die Lüfter bei der Zotac sind bissel nervig, werde da wohl einfach 3 120mm Lüfter drauf bauen und dann passt das.
Hab mir das 7000x bei Mindfactory mit 2-4 Tagen Lieferdauer bestellt, bin gespannt ob das eingehalten wird.
Bietet halt echt ausreichend Platz und die Karte kann auch vertikal montiert werden (Slotblende + Kabel ist wohl inklusive, allerdings nur PCIe 3.0 Riser) ohne, dass selbst ne 4090 direkt vor der Scheibe klebt.
Preislich zwar happig, aber platztechnisch hoffe ich da erstmal ein paar Jahre Ruhe zu haben.
Was macht man nicht alles um die Kirmesbeleuchtung im PC noch besser sehen zu können :d
Betreibt wer seine 4090 in einem Corsair 7000d und kann was zum Seitenabstand sagen? Möchte mein geliebtes Evolv X tauschen, da ich mehr Luftdurchzug brauche und auch etwas mehr Platz allgemein.
Hier mein System mit der Suprim X im 7000D (wird Zeit, dass es ein Waküblock gibt :d).
Habe mittlerweile das Kabel von Bequiet verbaut. Gehäuse lässt sich noch ganz gut schließen.
Das habe ich mir im November letzten Jahres auch so gedacht! :d
Kannst du ganz entspannt sein :)
Wenn die Scheibe zu ist ist noch genug Luft dazwischen . Hab da mal mit dem Handy reingeleuchtet . Bin leider auf Nachtschicht sonst hätte ich dir noch ein Bild von der Seite geschickt , aber hatte jetzt das noch auf dem Handy .Ist ein tolles Gehäuse .
Viel Spaß damit .
Viel Spaß damit .
Hehe, bin auch gerade auf der Nachtschicht, sonst hätte ich ebenfalls ein besseres Bild geschickt.
Da sieht man mal was fürn fetter Klopper die Karten sind. Die wenigsten haben so ein großes Case
Ja, musste aber dennoch im System einiges umbauen. Hatte vorher noch Pumpe und AGB im Gehäuse. Damit passte die Karte nicht.
Aber die Tage wird eh AM4 rausgeschmissen und der Raptor zieht ein. :)
Also habe das BeQuiet Kabel auch getestet. Jedoch kann ich, wenn ich das Kabel nutze, das Power Target auf nur maximal 100% stellen. Mit dem 4-Zack-Adapter geht es bis 111% (Palit Gamerock OC).
Hat noch jemand dieses Problem?
Das Netzteil ist ein 1000w Straight Power 11 Gold (laut BeQuiet kompatibel)
Hehe sehr gut :). Mir hat das 7000d besser gefallen, da weniger Glas = weniger Staub wischen und mehr Luftdurchzug. Verbaue ausschließlich Noctua Industrials, daher ist mir das RGB nicht so wichtig :). Will reine Kühlleistung, wobei die 4090 (ähnlich wie die 3090 Ti) sowieso nicht so warm wird, wie meine 3090 davor. Ich weiß nur noch nicht, wie ich das GPU Stromkabel im 7000d verlegen soll. Denke ich lege es von der Rückwand durch den Schacht, welcher für eine SSD am Gehäuseboden gedacht ist, zur GPU. So sollte es am wenigsten knicken. Das Evolv X hat dafür eine Aussparung unter dem GPU Stromanschluss, was sehr praktisch ist.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
