[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bei Alternate die "Gainward 4090 Phantom GS" ergattert, Bezahlbestätigung erhalten, Bestellbestätigung von Alternate und nun steht in meinem Konto unter Bestellungen: "Der Auftrag kann aktuell nicht bearbeitet werden, da einer oder mehrere Artikel nicht lieferbar sind."
Soll ich warten und sehen was passiert? Hat jemand Erfahrungen damit? Die zwei die in diesem Thread dieselbe Meldung hatten haben sich nichtmehr gemeldet, ob sie die Karte erhalten hatten oder stornieren mussten.
Danke für die Aushilfe!
Hab aktuell keine mehr, aber lässt sich ja immer wieder fangen so lang sie nicht ausverkauft ist.
Welche Karte möchtest du denn haben?
Eine Gainward Phantom mit oder ohne GS wäre top. Ist die einzige die gerade noch so ins Gehäuse passt von der Länge usw.
Wäre wirklich super!
Ich versuchs derweil über die Verfügbarkeitslinks - bin aber bisher zu langsam gewesen...
Karte ist eindeutig DEFEKT. Gigabyte hats klar gesagt und Alternate hat bestätigt das sau VIELE 4090 diese Schaden haben. Also die Serie ist für den ARSCH und das betrifft durch die BANK alle Hersteller.
aber es haben doch nicht alle Hersteller die gleichen Lüfter, oder?
Sind beide noch da, also suchs dir aus und lass es mich wissen. Gern auch direkt via PN.
Wie sucht man denn richtig nach ner Karte? Gibt es da wieder einen Bot hier?
schau mal hier:
Da würd ich aber noch bis Ende des Monats warten und gleich das gewinkelte bestellen, dann is das Problem mit dem biegen schonmal ausm weg.
Was genau für Lüfterprobleme? ^^
Gibt nen Thread dazu. Die Lüfter haben ein leichtes "Sägen", was man vor allem bei niedrigen rpm hört. Also im Idle die Lüfter auf 30% schalten, dann hört man es. Haben die Gainwards und Palits denke ich alle, zumindest derzeit. Dafür Fiepen sie nicht
das gewinkelte könnte bei den customs aber nicht passen da die anschlusste versenkt sind. maximal aufm kopf da man ja 2 versionen anbieten wird. dann wird das kabel aber über die backplate geführt
Nein haben Sie auch nicht, die Lüfter meiner Zotac Karte sind zum beispiel deutlich größer als bei der Asus oder Gigabyte Karte, deswegen ist die auch nochmal ein Stück breiter. Ich hab überhaupt keine Probleme mit den Lüftern oder Spulen...
Jo die ursprünglich am 12.10 bestellte Gigabyte 4090 Master meiner Freundin wurde noch immer nicht von NBB versendet.
Nach den Posts hier bin ich aber auch gar nimmer so scharf drauf... :(
Nen Storno traut man sich iwie auch nicht weil man sich ja insgeheim darauf gefreut hat und man sie ja sonst nirgends findet :/
Auf YT taucht sie auch nicht auf (außer der Bauer)
Du hast die bananekarte bekommen die hier jemand hatte? Mf.....
Müsste eine andere Karte sein, als die von dem anderen User hier aus dem Thread. Es sei denn jemand hat die Schrauben am Kühler auf oder zu gedreht. Denn die Position ist auf beiden Bildern eine andere.
Mich hat beim Einbau mit dem Adapter auch gewundert, dass es überhaupt kein haptisches Feedback gab, ob der Adapter jetzt richtig sitzt oder nicht.
NVIDIA hätte einfach vor Monaten schon die Hersteller dazu bringen müssen, gescheite ATX 3.0 Netzteile auf den Markt zu bringen - dann wäre das Problem weniger groß. So aber gibt es einfach keine und der Groß an Kunden ist gezwungen, Adapter zu nutzen.
Ah, haptisches Feedback. Die Bezeichnung fiel mir nicht ein. Genau so ist es.
Hatte echt Bock auf die Gainward GS aber nach dem Lüfterproblem von meiner Liste gestrichen :(
Ist es nun ein Fehler oder nicht... Fakt ist, wäre für mich wie hier gehört nicht hinnehmbar.
Update: Hat sich erledigt. In dieser Minute sind welche bei ldlc auf Lager gegangen. Die liefern auch nach DE - zusammen dann 1942 inkl. Versand. Falls noch wer eine braucht - schlagt zu!
Haha, ja dann hoffen und warten wir beide mal. Hatte da vorige Woche schon eine PNY bestellt die als "lieferbar innerhalb 7 Tage" gekennzeichnet war und heute Mittag eine Gainward. Die PNY wurde am nächsten Tag als "kein Lieferdatum bekannt" gekennzeichnet. Fairerweise wurde für die PNY PayPal aber nicht belastet. Für die Gainward wurde PayPal sofort belastet, dass lässt mich hoffen, dass sie wirklich ein größeres Kontingent hatten und liefern können.
Schön langsam nervt es echt; versuche seit 12.10. eine Karte zu einem fairen Preis zu bekommen.........und hier wird gejammert: die Karte fiept, diese hat zu laute Lüfter........
Einige bestellen sich 5 Karten und suchen sich die Beste aus....... Ich versteh schon, 2000 € sind viel Geld und da erwartet man Qualität, aber was manche hier betreiben ist "Cherry picking" in Reinstform
Warum sind die Karten nun im Asusshop teurer geworden ? 100€ ... :cautious:
nun sind sie wieder Günstiger geworden ( die Strix von 2500 Euro wieder auf 2377 Euro ) ... wie gesagt normales verhalten vom Asus Shop .. geht rauf und wieder runter und wieder rauf und wieder runter und war auch schon 2020 so .. warum die das so machen kein plan.
Jetzt muss es die Strix nur auch mal in solchen Mengen geben wie die TUF oder die Gigabyte Gaming oder die Zotac Trinity von den Karten kommen pro Tag ja viele aber die Strix hat sich seit mehr als 1 Woche sehr rar gemacht in Deutschland.
Für alle die die Meldung "Der Auftrag kann aktuell nicht bearbeitet werden, da einer oder mehrere Artikel nicht lieferbar sind" bei Alternate bekamen:
Gerade die Antwort vom Support erhalten (per Twitter):
und gleich nach meiner Anfrage änderte sich auch der Status bei Alternate:
Ich liebe Alternate!
Also hoffen und einfach warten.
Was haltet ihr von meinem Anschluss?
Sicher oder problematisch?
Ähnliche Themen
Antworten
7K
Aufrufe
477K
