[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also für 2000€ erwarte ich was anderes als eine verbogene Grafikkarte, aber ich bin vermutlich auch zu Oldschool.:wink:
Zudem ist im CB Forum eine Zotac 4090 mit angeblichem metallischen Lüftergeräuschen. Guess what? Das ist coil whine. Also sind die Zotacs auch nicht gefeit.
Habe mir das Buildzoid Video zu dem 12VHPWR angeschaut und was er sagt ist einleuchtend. Das Kabel von BeQuiet ist auch erst nach ca. 3.5cm abgebunden, sodass, sollte man es biegen, die Biegung dadurch etwas abgemildert wird. Da hat also BeQuiet ganz gut mitgedacht. Mal sehen, wieviele User von dem Problem nichts wissen und denen die Karte nach mehrmaligem umbauen und verbiegen etc. abraucht. Gerade, wenn das Case zu klein ist, wie z.B. bei ITX.
Obs von den Lüftern kommt lässt sich ja leicht prüfen wenn man diese einmal kurz auf 0 setzt um zu schauen ob es dann weg ist.
Meine Zotac Amp macht zumindest keine Spulengeräusche.
Betreffs der Black-Screens im Idle, so sieht das im Zuverlässigkeitsverlauf aus.
Dies ist nun allerdings seit 3 Tagen auch nicht mehr aufgetreten, also schwer zu reproduzieren. In der Zwischenzeit hatte ich allerdings auch Windows geupdatet (auf 22H2).
Ja generell ein schlechtes Design wenn etwas so sensibel ist und so schnell zu anwenderfehlern führen kann. Da tut sich Nvidia ja leicht wenn das einfach unter falsche Benutzung abgetan wird. Könnte man auch übertriebengesagt ein Kabel ohne Isolierung entwickeln und wenn sich Kabel im Einbau berühren sagt man stumpf Einbaufehler. Naja ich habe die alten PCIE Stecker schon sowas von verbogen und habe ähnliche Wattzahlen durch nur 2x PCIE an der 3090 durchgejagt ohne das was abgeraucht ist trotz extremer Biegung also fast doppelte der speizifizierten Watt. Da ist es schon traurig das ein Stecker der 600 Watt speizifiziert ist bei wahrscheinlich unter 500 Watt schon aufgibt wenn man nicht 100% den richtigen Winkel trifft. Besonders auch das ein seitliches verlegen des Kabels nicht toleriert wird ist auch eine ziemlich dicke einschränkung etwas seitlich kommt man ja immer schnell raus. Naja mal sehen wievielen das passiert und ob es wirklich ein Problem ist oder Einzelfälle. Meine Wärmebildkamera ist aufjedenfall erstmal auf dem Stecker :d
Schon gruselig, was man hier alles zu lesen bekommt. Early Adopter sein ist manchmal ein qualvoller Weg^^
Passt eigentlich prima zu meinem Thema:
Würde nämlich gerne hier nochmal ein Meinungsbild von euch einholen.
Habe vor zwei Wochen bei MF eine 4090 GameRock bestellen können, die dann seitens MF nicht mehr lieferbar war. Kulanterweise bot mir MF an, die OC Variante zur non OC UVP zu bekommen. Die kam dann letzte Woche an.
Die Karte ist wirklich super. Kein Spulenfiepen, kein Rasseln, kühler als meine alte 3080Ti, nur doppelt so schnell.
Aaaber:
Yep, habe eine Banana GameRock erwischt 🍌
Habe jetzt MF mit dem Bild angeschrieben. Die meinten, dass ich denen die Karte zurückschicken soll, die sie dann überprüfen und testen wollen, um dann zu entscheiden.
Wenn ich hier jedoch mitlese, neige ich gerade dazu, die Karte zu behalten😅
Was meinen die Gentlemen und Ladys dieser Runde?
Ich bin megagespannt wie MF diese Karten testen will, bzw. auf was wollen sie die Karte überhaupt testen? Optisch überprüfen reicht doch um zu sehen, dass hier was nicht stimmt :fresse:
Der beiliegende Adapter hat mir direkt Bauchschmerzen gemacht. Mit dem Adapter von BeQuiet habe ich ein wesentlich besseres Gefühl.
Beim Anschließen fühlte es sich aber trotzdem ziemlich kacke an. Gab irgendwie überhaupt kein klares Zeichen beim Reinstecken, dass es auch komplett drinne steckt. Kein klicken oder sonst was. Habe extra mehr Kraft angewendet und genau geschaut um sicher zu sein, dass der Stecker richtig sitzt.
Genau das war auch mein Gedanke beim Lesen der Mail. Vor allem läuft sie ja auch einwandfrei.
Überlege gerade, ob es nicht Sinn macht nochmal MF anzubieten, dass sie mir einfach eine schriftliche Zusicherung geben, dass im Falle eines Defekts die Garantie greifen wird.
Ist ein richtiges atx 3.0 16 pin Kabel von den neuen atx3.0 Netzteilen anders vom.aufbau her und das problem ist damit aus der welt?
Du hast die bananekarte bekommen die hier jemand hatte? Mf.....
waren Spulenfiepen oder Lüfterprobleme bei der 3090Ti auch ein Thema?
Also ich habe bei meiner Suprim X keines, habe nach den ganzen Diskussionen darüber mal das Case aufgemacht und bei Load das Ohr drangehalten. Nix zu hören! Werde, sollte ich sie verkaufen, wenn eine 4090 gefunden wird, ein Video als Verkaufsargument beifügen :).
Ich geh davon aus, dass das nicht nur eine Karte hat. Die Biegung ist ja in der Verlängerung vom Kühler. Da wenn auf so einen Stapel mal was anderes ungut draufgestellt wurde, dann gibts da ein paar Karten davon.
Gab es hier nicht noch eine GameRock, die jedoch noch mehr gekrümmt war und das an beiden Enden? Daher hat sich bei mir auch der Begriff Bananen-Karte eingebrannt.
Das ist entweder eine Hommage an die aerodynamische Formgebung des NSU RO 80, oder eben die spezielle "Anti Sag Bend".
Das Problem ist tatsächlich, dass wenn du in 4 Wochen einen Defekt dran hast, sie dich dran aufhängen. Ausserdem schaut es shice aus und du darfst nicht vergessen was du für das Ding auf den Tisch legen musstest. Klar, mit genug Alkohol schaut das optisch wieder gerade aus, aber was soll ich sagen? Tu es wech...
Könnten die 4090 Besitzer mal in Ihren "eventvwr.msc" ausführen und schauen ob ihr auch solche Meldungen habt vom Typ 4101 und 0? Wäre interessant zu wissen.
Also außer den mir bekannten Treiber Resets durch OC/bzw. zu niedrige Spannung, hab ich keine im Event Log
Mich hat beim Einbau mit dem Adapter auch gewundert, dass es überhaupt kein haptisches Feedback gab, ob der Adapter jetzt richtig sitzt oder nicht.
NVIDIA hätte einfach vor Monaten schon die Hersteller dazu bringen müssen, gescheite ATX 3.0 Netzteile auf den Markt zu bringen - dann wäre das Problem weniger groß. So aber gibt es einfach keine und der Groß an Kunden ist gezwungen, Adapter zu nutzen.
Schade das seasonic da nichts macht....
Kann ich dir nicht 100% beantworten aber ich denke nicht, das "richtige" Kabel hat ja nur 2 Pins mehr die das NT und GPU miteinander kommunizieren lassen.
Ein ATX3.0 Kabel wird ja nichts ändern da das Problem ja der Stecker ansich ist. Oder eher im Gegenteil das Problem wird noch größer weil dann hat man den kritischen Stecker an 2 Stellen und nicht nur an einer!
Aus Technischer Sicht frag ich mich wie das überhaupt sinn macht der Stecker hat kleinere Kontakte bekommen und soll damit nun das doppelte an Watt Übertragen wie die alte Generation. 2x PCIE darf nur 300 Watt und hat aber die selbe Anzahl an Steckkontakte nur in einer größeren Dimension.
Klar man kann nun mit Material und Klemmkraft noch was reissen aber das Material wird nicht groß anders sein also bleibt nur die Klemmkraft und dann ist man bei dem Problem das wenn es nur mal was schräg reingedrückt wurde oder zu oft rein und raus ist die Klemmkraft dahin und dann geht das ganze nicht mehr.
Ähnliche Themen
Antworten
7K
Aufrufe
477K
