[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Spielt am Ende nur ne Rolle wenn man Benchmark Rekorde jagen will... m.M.n.
Ja ich habe verschiedene settings und mein mid-low everyday gaming rock stable setting hat VL. 5-10% weniger FPS aber die Hälfte Watt und DB und Hitze...
Also ich kann mir nicht helfen. Ich habe gerade mal paar Benches gefahren und war 100% Last und high FPS. Konnte null Spulenfiepen hören. Trotz Fenster zu und direkt mit Ohr an der GPU.
Hier hat doch irgendwer schon den ALC Kühler auf die I-chill gepackt. Wie sieht es da mit den Temps aus ? Wie ist das Delta . Was machen die VRam Temps .
Einfach mal aus Neugier.
Ein paar Bilder von Reddit gibt es hier: https://www.reddit.com/r/watercooli...0_alphacool_block_micro_review_making_it_fit/
Die Pads auf dem Ram scheinen sehr dünn zu sein, vielleicht 1mm. Ich denke das verspricht gute Temperaturen. Auch sonst finde ich den Block prima. Aber ist ja immer auch Geschmackssache.
Hab jetzt mal noch meine neueste Suprim X und TUF OC schnell auf den Benchtable gepackt bezüglich schnellem Check auf Spulenfiepen. Einfach Totalausfall was MSI und ASUS da produziert, unter der Berücksichtigung was die anderen Hersteller bieten.
Meine Spulenfiepen Liste aller Karten die ich bisher getestet habe (Von gut nach schlecht sortiert mit Sample Size):
1. KFA2 GeForce RTX 4090 SG 1-Click OC (1) ->>>> Kein bzw. sehr sehr leises Spulenfiepen. Nicht hörbar aus 50cm Entfernung.
2. Gigabyte 4090 Gaming OC (1) ->>>> Spulenfiepen hörbar aber leise. Aus geschlossenem Gehäuse nicht hörbar
3. ZOTAC 4090 Trinity OC (1) ->>>> Spulenfiepen hörbar aber OK. Nicht störend aus geschlossenem Gehäuse.
4. ASUS TUF Gaming GeForce RTX 4090 OC (2) ->>>> Spulenfiepen deutlich hörbar.
5. ASUS TUF Gaming GeForce RTX 4090 (1) ->>>> Spulenfiepen deutlich hörbar.
6. MSI GeForce RTX 4090 SUPRIM X (2) ->>>> Spulenfiepen sehr deutlich hörbar und nervig ab bereits 80FPS.
7. MSI GeForce RTX 4090 TRIO X (1) ->>>> Spulenfiepen sehr deutlich hörbar und nervig ab bereits 80FPS.
8. ASUS ROG Strix GeForce RTX 4090 (1) ->>>> Spulenfiepen abartig laut. Man hat das Gefühl die Karte geht gleich kaputt.
Die "günstigeren" Hersteller (3 Karten) waren bei mir trotz der geringeren Samplesize in Sachen Spulenfiepen allesamt deutlich besser als ASUS (4 Karten) oder MSI (3 Karten).
Insbesondere von MSI bin ich enttäusch wegen der irreführenden Werbung mit leisen Spulen. Sowohl Suprim X (2) als auch Trio X (1) waren super nervig.
Trotzdem: Die Suprim X ist von allen Karten die ich da hatte in Sachen Qualität/Verarbeitung/Haptik mit abstand am besten, wirklich extrem edel. Hätte die gerne behalten aber so einfach nicht hinnehmbar für mich.
P.S. Wie immer: Spulenfiepen ist eine subjektive Sache. Nicht jede Person hört es, nicht jede Person stört es. Ich brauche kein: "aber aber aber meine Suprim oder ASUS ist aber leise". Jede Karte ist zudem ein individuelles Stück. Man kann meine Erfahrung hier höchstens als Tendenz betrachten.
Ah drückt ihr die Preise auf ebay so extrem^^?
habs mit 1000€ + versucht, zahlt keiner für ne 3080ti.
unter welchen bedingungen hast du die getestet bzw beurteilt?
vollast denke ich mal auch bei 80fps?
Aber nicht für 300€ Aufpreis…
Bei 50€ würde auch keiner meckern.
die aufpreise sind ja bei der strix nicht zu sehen
das sind diese alibikarten damit man auf dem papier was zur uvp anbieten kann. anders kann ich mir diesen move nicht erklären
Scheiss egal alle 4 Modelle haben das selbe PCB . Das hat Inno3d hier im Forum bestätigt und bei ALC steht auch das alle vier Varianten mit dem Kühler kompatibel sind .
ist keine i-chil ist eine Inno3d X3 OC.
@cHio bewertest du die spulen allgemein oder nur fiepen? "rasseln" würde mich eher interessieren
Benutzte den Begriff Spulenfiepen eher als allgemeinen Oberbegriff. Es gab sowohl rasseln als auch fiepen unterschiedlich ausgeprägt.
Hauptsächlich Volllast aber auch Teillast. Hab auch mit Undervolt und Power Target rumgespielt. Hat das ganze aber nicht entscheidend verändert. Erst wenn man Richtung 50% Power target geht.
Übrigens, um auch mal das Netzteil Thema endgültig vom Tisch zu bekommen. Ich hab 2 Benchtables und 1 geschlossenen PC mit unterschiedlicher Hardware Konfig. Netzteile stehen mir folgende zur Verfügung:
Dark Power 12 1000W
Dark Power Pro 12 1500W
ROG THOR 1600T
Seasonic Prime TX-1000
Corsair AX Series AX1600i
Egal welches Netzteil oder System, es macht kein unterschied.
Das mit dem Spulenfiepen macht mir bei der Suprim X etwas Sorge und bei der TUF die hohen VRAM Temperaturen. Andere Alternativen gibt es für mich eigentlich derzeit nicht.
ich war derjenige der den ALC Block auf der karte hat.
Zu Deiner Beruhigung: Auch die FE macht ab und an Geräusche. Allerdings kein Spulenfiepen. Manchmal, wenn die Karte einige Zeit lang in Betrieb war und dann abkühlt, gibt es wie eine Art Schleifgeräusch, vllt. 3-4 mal. Das geht dann wieder weg. Laut NVIDIA "normal". Liegt vermutlich an den Lüftern, die mehr oder minder frei "liegen" und wenn sich das Metall des X-Frames durch die Hitze ausdehnt und dann zusammenzieht, damit in Berührung kommt. Aber das ist nur eine Vermutung von mir.
Das mit dem Spulenfiepen macht mit bei der Suprim X etwas Sorge und bei der TUF die hohen VRAM Temperaturen. Andere Alternativen gibt es für mich eigentlich derzeit nicht.
Ja ärgerlich … von Asus kommt ja vielleicht noch was …
Bin auch unsicher welche ich behalte ;-)
Für kurzzeitiges OC ist es uninteressant. Dachte an Richtwerte für dauerhaften EInsatz in jeglichen Lebenslagen ohne Abstürze.
schau dir das video von Roman an :) PT ist das einfachste mittel dafür
pt auf 70-75% runter. 5-7% weniger leistung, aber 80-100w weniger verbrauch
Und wie verhalten sich so die Lüftergeräusche bei den Modellen? Welche sind leise bzw unangenehm laut (Ausm Gehäuse heraus)
Also sollte ich nächste Woche Dienstag keine FE von NBB bekommen, werde ich mal Ausschau nach der KFA2 halten, die sollte bei mir ins NR200P passen und auch noch genug Platz für den PCI-E Stecker haben.
Mit 74mm dicke ist gerade so genug Platz, wenn ich die Slimlüfter rausnehme. Auch 336mm Länge sollte gerade so reinpassen.
Nur die Höhe von 138mm, welche fast dieselbe ist wie die Founders mit 137mm, macht mir halt zu schaffen, da ja der PCI-E Stecker noch rein muss...Der Cablemod 90° Stecker ist definitv ein muss. :d
Cooler Master gibt "nur" 156mm Höhe an...da wird vermutlich keine einzelne 4090 passen...selbst mit Waküblock, weil die alle so hoch sind. (Der Stromstecker muss da ja noch dazwischen).
Wenns nicht passt, muss so oder so ein neues Gehäuse her...ich tendiere zum AP201. Ein Youtuber hat ne Strix reingekriegt und ein NH-D15 würde reinpassen...zudem passen auch mATX und ATX Netzteil.
Edit: Kommt halt darauf an mit was gerechnet wird, ob mit oder ohne PCI-E Slot, ob mit oder ohne Slotblende...mein Gehäuse ist 18,5cm breit von Panel zu Panel. Mainboard und Panel zusammen sind ca 2-2,5cm dick.
Wären also noch rund 16cm Platz MIT PCI-Slot, aber ohne Slot-Blende und mit PCI-E Stromstecker...
Habe ich mir auch angesehen... die MSI Suprim soll nur 12,3cm hoch sein... Techpowerup gibt aber 14,2cm an und MSI gibt auch 14,2cm an... irgendwas läuft da schief bei PCGH... :d Haben die nur den Kühler vermessen, aber nicht den PCI-E Slot?
Wäre also eine der kleisnten Karten...wäre die nicht eine der dicksten -.-... mit 78mm passt die nicht mehr rein. Und nicht zu vergessen ein Kreischer :d
Hab auch zwei Desktop PCs (Seasonic TX-1000 und 850) und nen Benchtable mit 650W BQ NT hier, wenn eine Karte gefiept hat, dann hat sie immer mit allen NT gefiept. Konnte das persönlich auch nie nachstellen dass andere NTs irgendetwas an der Sachlage ändern.
Denke das ist irgendein Urban Myth, den irgendjemand mal erzählt hat und den seither alle gebetsmühlenartig nachplappern ohne es selbst getestet zu haben.
Scheinbar geht's doch:
Ähnliche Themen
Antworten
7K
Aufrufe
471K
