[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bevor ihr eure Handelsabsichten hier postet, lest noch mal den Threadtitel.
Grade hat es einen User erwischt.
Hier ist nicht der Marktplatz.
Handel gehört in den Marktplatz, nicht in diesen Thread, nicht in PNs.
Mir fällt seit der 4090 extrem auf, dass es bei vielen Spielen wichtig ist, nicht ins CPU-Limit zu rennen. Bei A Plaque Tale Reqiuem und Cyberpunk fühlt es sich trotz VRR einfach nicht smooth an, wenn die GPU nicht voll ausgelastet ist. Dreht man die Kamera sieht man leichtes bis starkes Geruckel. Bei A Plaque Tale ist das je nach Szene besonders schlimm. Bei Uncharted scheint ein CPU-limit egal zu sein, dass sieht immer smooth aus.
Außerdem ist ein CPU-Limit auch Gift für VRR auf einem OLED, weil es frametime-Ausreißer begünstigt was wiederum VRR-flickering verstärken kann. Die 4090 ist echt keine Karte für alles unter 4K in meinen Augen.
Ich frag mich aber obs vielleicht auch an meiner CPU liegt. Ob Intel in solch CPU-limitierenden Szenarien bessere Frametimes hat?
Fps limiter rein und zwar unterhalb deiner Limits. Problem gelöst
Macht die cpu im min nurr 110, machte du dein fps cap bei 105 und gut ist.
Kein Mensch zockt mit uncapped fps😅
Dieses Ruckeln bei Plague wenn man die Kamera langsam bewegt liegt am Spiel. Sieht man auch im GPU Limit und die Frametimes von der Hardware sind absolut stabil.
Zumindest nicht mehr NACH der EVGA und NewWorld Tragödie 🤩
Ich persönlich finde CPU Limit in Spielen eigentlich eine gute Sache. Denn es sagt mir das ich noch Reserven auf der GPU Seite habe, die ich für Bildqualität nutzen kann. (DL)DSR, noch höhere Details und zack bin ich wieder im GPU Limit und meine Karte ist ausgelastet. Wenn das nicht geht, dann notfalls Frame Limiter knapp unterhalb der Max FPS welche die CPU noch schafft, das sollte das Ruckeln eliminieren. Meiner ist eh so eingestellt, daß maximal knapp 120 fps ausgegeben werden, mehr kann mein OLED eh nicht.
Natürlich versuche ich aber eine ausreichend starke CPU an den Start zu bringen, aber immer ist das leider nicht möglich. Mit dem neuen Intel der glaube gestern vorgestellt wurde solltest Du aber nochmal etwas besser rauskommen als mit dem aktuellen AMD Portfolio falls das für Dich wichtig ist.
So...habe heute mal ausführlich die Palit Gamerock OC und die MSI Gaming Trio X getestet.
Ergebnis: Jede Karte hat ihre Macken...
Die Gamerock hat die Lüfterprobleme (leichtes rattern) und die Trio X hat super lautes Spulenfiepen (auch bei FPS unter 100).
Letzten Endes wird die Gamerock bleiben(Leichtes Spulenfiepen ab 150fps). Das Spulenfiepen der Trio ist einfach lauter.
Die Trio taktet zwar etwas höher, jedoch macht dies im Alltag kaum was aus und vor allem ist mir das keine 200€ Aufpreis wert.
Komischerweise konnte ich mit dem neuen 12VHPWR Adapter Cable bei der Palit das Power-Limit nicht mehr erhöhen (Ging nicht über 100%).Sobald ich auf den Adapter der Palit zurück gewechselt habe ging es wieder auf 111%.
Bei der Trio X konnte ich mit dem 12VHPWR Adapter das Powerlimit auf 106% erhöhen.
Habe ein BeQuiet Straight Power 11.
Der Kühler ist eher mittelmäßig performant, FEs fiepen/rattern wie sau (schon immer, da minderwertige Spulen), lüfter eiern oder machen komische unerwünschte geräusche (hatte ich schon bei einigen 3090, geräusche machen alle, hört nur kaum einer), garantiebedingungen (keine wakü erlaubt) und es gibt viel größere karten, mit besseren Temps.
die FE taugt nur, wenn man keinen platz hat. verstehe sonst nicht warum man die haben will. scheinbar leben hier viele nutzer im tiny house. gibt viele bessere karten sonst
das invite system von nvidia ist zwar besser als die auslosung von grafikkartenteurer.de aber warum man da einfach eine karte zum kauf vorgeschlagen kriegt, ohne danach gefragt zu haben, weiß ich jetzt nicht
Musst dir hier keine Argumente aus den Fingern saugen. Wir wissen du willst einfach nur scalpen :ROFLMAO:
Die RTX 4090 von Zotac und Inno3D scheinen nicht so begehrt zu sein, die sind seit gestern Mittag auf NBB verfügbar und auf Lager. Aber ich bin schon überrascht, wie viele User doch mal so eben eine Grafikkarte zwischen 2.000 und 2.500,00 kaufen, das Geld scheint bei vielen doch noch recht locker zu sitzen. 🤔
Andererseits finde ich die Stückzahlen, welche die Händler von RTX 4090 bekommen, einfach nur lächerlich. Wenn da mal kein System und Absicht dahinter steckt, um die Grafikkarte interessant zu halten.
So sehe ich das auch die Stückzahl ist schon gegeben bestimmt.
Lg
So Kabel ist da, aber ist sehr steif :LOL: Muss ich definitiv noch biegen. Hab bestimmt nur 4 cm bis zum Seitenteil Spielraum..
Die Surpreme sollte morgen kommen...
Gefühlt höre ich bei msi immer nur „hat extremes spuhlenfiepen“ da hab ich nächte woche ja garkeine lust mehr meine bei NBB abzuholen xD
Machen die faxen wenn ich es abhole und wieder zurückgebe wenn es auch extemes spuhlenfiepen hat?
Höre immer nur negatives über NBB. Aber hab extra auf abholen und vor ort zahlen gemacht um es mir nochmal zu überlegen.
Abholen bedeutet kein fag. Dann musst du auf Kulanz hoffen
  • Danke
Reaktionen: bRv
Hmm dann lass ich es lieber bzw. Muss es mir mal überlegen. Will eigentlich eh die strix xD
Nicht das die dann faxen machen dann etc. Hätte ich es mir dann lieber mal schicken lassen 🙄
Richtig, so erkennt man einen guten Chip!
Im idle die Curve öffnen und gucken, was die Karte bei 1.05v liefert.
1.1 würde ich nicht nehmen, da es nicht Default ist.
Meine hat bei 1.05v nur 2700 MHz.
Bin schon etwas enttäuscht 😢
Habe 2850 bei 1.05 und 2910 bei 1.1 mit meiner TUF OC, cool.
Nunja die FE Kühler sind deshalb ein wenig wärmer, WEIL die kleiner sind. :d Das ist halt Vor und Nachteil zugleich. Aber zumindest hat der FE Kühler keine direkten Schwächen wie die TUF mit dem etwas schlecht gekühltem VRAM.
Wenn Wasser ausläuft oder du machst beim umbauen mist, greift eh KEINE Gerantie. Egal ob sie den Umbau erlaubt.
FE fiepen ist wie bei allen anderen Karten individuell. Ich hatte 2 RTX 3000er FEs. Eine fiepete nur beim kaltstart und ging dann innerhalb von wenigen Minuten weg und die andere fiepte zwar ne Zeit lang, aber das ging dan von alleine weg. Und was man hier im Forum so ließt, so scheint es, das viele andere AIB Karten schlimmer fiepen.
Warum ICH eine FE will? Weil mein Gehäuse zu klein ist für beinahe alle andere Karten. Nur 2 Karten passen so weit ich weiß rein, aber bei denen passt der PCI-E Stecker dann nicht mehr, wenn das Gehäuse zu ist :d
"Extremes Spulenfiepen" ist eine individuelle Wahrnehmung und kein technischer Fakt hier. Meine MSI hat natürlich auch etwas Spulenfiepen, aber keines das mich im Alltag auch nur irgendwie ansatzweise stören würde. Und eine Strix kann genau so "extremes Spulenfiepen" haben. So oder so wirst Du um ausprobieren und persönliches Bewerten nicht drumherum kommen.
  • Danke
Reaktionen: bRv
Ja okay, das hilft. Meiner Erfahrung nach bekommt man bei vielen Spielen das beste Ergebnis, wenn die GPU immer gut ausgelastet ist und die CPU möglichst wenig zu tun hat.
Habe jetzt auch bemerkt, dass die Performance glitchy werden kann, wenn man Auflösungen, DLSS usw. mehrmals ändert. Auf einmal hatte ich dann jede Sekunden frametime hiccups. Musste dann das Spiel nochmal komplett neu starten.
Wenn man keine frame generation nutzt, habe ich auch bemerkt, das Reflex für Kameraruckeln sorgt. Deaktiviert man das, sieht das viel smoother aus.
du spielst bei nem 144hz vrr monitor eh mit 142fps limiter sofern cpu und gpu diese erreichen. dann hast du 1a glatte frametimes.
sobald eine komponente das nicht schafft, fps cap unterhalb des limits und auch dann sind die frametimes tippi toppi.
mache das schon seit jahren in jedem game. funzt immer gleich :d
Ja war der fehler auf meiner seite weil ich auf abholen gemacht habe. Jetzt wenn ich es abhole und die ist extrem die karte und ich es zurückgeben will das NBB da faxen macht oder so.
Aber ja hast recht muss man schauen dann wie sie ist und ob es störend ist. Letzendlich haben sie alle das spuhlenfiepen, mal mehr und mal weniger.
Na ja - komischerweise wurde alles verkauft.
Vielleicht ist ja der einer oder andere froh - aber klar lasse ich es zukünftig
Ne passt schon, sorry du hattest es ja gut gemeint, mich kotzen diese Preiserhöhungen einfach nur so an dass der Mist jetzt schon wieder so krass ist wie letzte Gen
Ähnliche Themen
Antworten
6K
Aufrufe
392K
