[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Media Markt hat ja noch mit die Fairsten Preise ... aber das Captcha dort macht einen ja Wahnsinnig. In den Warenkorb packen -> Captcha, Warenkorb aufrufen -> Captcha, Bezahlen -> Captcha, Fehler beim Bezahlen, Artikel nicht mehr vorrätig -> Captcha. Wieder in den Warenkorb legen -> Captcha Captcha Captcha.
Captcha kommt nur, wenn man es einmal übertrieben hat mit F5, und als Bot erkannt wurde. Dann kommt es regelmäßig.
Ich habe auf MediaMarkt und Saturn noch nie die F5 benutzt. Sobald ich hier den Link sehe, gehe ich drauf und hänge direkt im Captcha. In der Zwischenzeit lasse ich den Shop auch komplett in Ruhe ... merkwürdig
Ich konnte vorgestern fast normal bestellen. Während des Vorgangs ist die Karte aus dem Warenkorb verschwunden (kurzer Schock) dann mit meinem eigenen Mediamarkt Konto aktualisiert und dann war die wieder drin und wird morgen geliefert mit Versandbestätigung. Total aufreibend und schon zuviel für meine schwachen RTX Nerven😂. Ich hoffe das alles passt. Beste Grüße fürs Wochenende und alles.
5950x
4090 TUF OC
Geschlossenes Gehäuse.
Ab 260 will er nicht mehr.
Ich hatte auch + 250 Mhz. War aber in Games nicht stable. Bin jetzt auf +195Mhz bei 0,965V. Ob es stable ist stellt sich nach ein paar gaming sessions raus. Aber von OC kann ich nur abraten. Die Effizienz geht voll flöten und alles wird unnötig heiß und laut.
5950x
4090 TUF OC
Ich kann DIch aber toppen :-)
okay danke dir. Ja hatte bisher nur 3d Mark. Hab gestern leider erstmal die Custom umbauen müssen und co. War leider noch nicht viel Zeit zum Zocken.
Aber ich check das mal gegen das Wochenende.
Da ich den Überblick verloren habe ob das gut oder schlecht ist :d? Weißt du da schon eine Einordnung zu deiner?
Markus
Würdet ihr ne Zotac kaufen und dann den Bykski Block dafür nehmen oder lieber warten bis mal eine FE für 2200 auf Ebay kommt, weil es dafür nen EK oder Heatkiller Block gibt ?
Die Lüfter und Lüfterkurve könnte bei der Zotac besser sein, aber das spielt für dich ja keine Rolle. Die Spulen sind bei meiner zwar nicht immer komplett lautlos, aber sehr leise und selbst bei offenem Gehäuse und ~50cm abstand fast nie wahrnehmbar.
Daher Ja, wenn ich eine Karte mit WaKü block kühlen will, dann würde ich die Zotac auf jeden fall in Betracht ziehen und nehmen, falls verfügbar.
Ja denke auch die Kombi Bykski Block + Zotac AMP ist das beste was momentan unter Wasser möglich ist bezüglich Phasen Auslegung und Spulenqualität/Geräusche.
Aber auch der Bykski Block scheint noch nicht fertig zu sein mein Liefertermin wurde wieder verschoben von 7.11 auf 11.11 heute auf 17.11
Markus
Ich würde ssagen 9/10. Einige können wohl bis 3100Mhz gehen. Bei mir ist bei 3060 Schluss. Ist mir aber total Latte.
Ich denke die tun sich da alles nicht. Der Unterscied liegt wohl bei maximal 2%.
Eventuell bestell ich heute die TUF NON OC und werde die OC verkaufen.
Dann habe ich nochmal 200 Euro rausgeholt.
Puh jetzt bin ich mal gespannt bei MM. Cookies löschen beruhigt auch den Captcha Meister. Zumindest wurde die Zahlung akzeptiert, aber noch keine Bestätigung da
k ne so wichtig ist mir das auch nicht :) Danke dir.
Ja würd auch fast vermuten, dass sich die nicht viel nehmen OC oder nicht. OC ist nur der Name für mehr bezahlt :d
Aber die Non OC für 1950 kommt ja nicht mehr :(. bzw. bis jetzt
5950x
4090 TUF OC
4090 TUF kein Geld für OC Version :fresse2:
Das habe ich glaube ich aber auch dem guten RAM zu verdanken :poop:
Ich habe das Gefühl den Scalpern geht allmählich die Puste aus. Schöne künstliche Verknappung… ich denke die gierigen Mäuler sind größtenteils gestopft.
Die Gaming X Trio für 2400 auf Scalperuniverse. Da kann man doch direkt auf ebay Kleinanzeigen was kaufen und ist günstiger dran. Das ist einfach peinlich...
Also die FE's gehen bei EK noch gut weg. Hatte alle auf der Merkliste. Jeden Tag verschwinden da immer welche, Hätte gestern auch fast zugeschlagen. Aber da war jemand 2 minuten schneller als ich. Hatte zu lang gezögert da nicht klar ist ob bei einem defekt die Garantie greift wenn man nicht auf der REchnung steht. Da kommt es dann wohl auf den Händler an... Nvidia gibt keine Gewährleistung bei Gebrauchtkäufen.
Springt bei euch auch die GPU core voltage beim port royal auch immer zw. 1060mv und 1100 mv hin und her? Power bzw. Temp limit ist laut logs nicht erreicht..
Eigentlich zu Teuer, aber die non-OC Variante ist ja extrem selten (für einen anständigen Preis). Hier habe ich wenigstens die Sicherheit, das genügend Wasserblöcke erhältlich sein werden ... und Asus ist da ja noch relativ Kulant was den wechsel des Kühlers angeht.
Ich denke Anfang kommender Woche werden sich die Preise Richtung UVP -langsam- einpendeln bzw. Stück für Stück runter korrigieren.
Man muss kein Genie sein um zu erkennen, dass viele 4090 in den Lagern der gängigen Händler stehen und künstlich der Preis oben gehalten wird.
Undervolting wird bei Ada nicht empfohlen:
Undervolting wird bei Ada empfohlen:
Ja. Aber nur von ihm:
Habe dazu gestern ein Video gemacht.
hier meine Endgültigen Ergebnisse.
Kannst du vielleicht kurz erklären, weshalb er unrecht hat? Ich möchte mir dafür jetzt kein 25 Minuten Video anschauen.
Selbst Der8auer empfiehlt eher das PT runterzuschrauben, anstatt zu UV'en.
Sollte beim UV'en nicht die Leistung steigen? Die Temperatur der Karte sinkt und der Headroom zum PT wird ebenfalls größer, da der Verbrauch sinkt. Somit sollte die Karte doch eigentlich höher boosten, aber du verlierst in deinem Test Leistung.
Ähnliche Themen
Antworten
6K
Aufrufe
409K
