[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Genau das habe ich auch bei mir 93 %
Supreme X mein Netzteil ist ein HX 1500i
Lg
Ihr müsst den Treiber via DDU deinstallieren und dann neuinstallieren. Igor hat das in seinem aktuellen Video angesprochen.
Würde nicht viel Hoffnung auf nen LG 27er OLED. Klar der wird kommen, aber sicher ohne Garantie gegen Einbrennen, wie es sie beim AW QD-OLED gibt.
Dachte eigentlich, so oft wie die Bot Benachrichtigungen kommen, hätte es sich langsam mit der schlechten Verfügbarkeit.
Aber wenn das immer nur einzelne Karten sind.
Lg
Ich habe auch mit Msi Hotline telefoniert und er meint, das sind Software Geschichten wie Afterburner und gpu z da die Grafikkarten noch sehr neu sind. Ich sollte mir diesbezüglich keine Sorgen machen, weil die Leistung angegeben wird.
Lg
Das hab ich schon getan, hat bei mir aber nicht geholfen.
Lg
Schick mir mal den Link von dem Video
Wenn ich in Afterburner links neben dem abspeichern drauf klicke, dann sind es 100 % wenn ich einen Neustart des PCs mach hab ich wieder 93 %. Sobald man das Programm irgendwann verlässt, hat man wieder 93 % power Limit
Lg
Hast du denn auch die neueste Afterburner Beta drauf? Das Powerlimit wird definitiv korrekt von 100%-115% angezeigt bei der MSI.
OK
Sofern am NT alles richtig angeschlossen ist, würde ich wie oben steht den Treiber mal mit DDU entfernen und dann neu, bei mir war das allerdings nicht nötig ....
"rentiert" es sich knapp 300 mehr für ne suprim auszugeben, wenn man die karte ohnehin uv will?
ich werd die karte nur zum benchen mal schön oc´n aber 24/7 läuft sie dann gleich wie meine 3080ti im öko modus...
A Plague Tale : Requiem ist das erste Game das ich mit der 4090 inkl. DLSS3 getestet hab, echt heftig was da an Frames rauskommt wenn man dieses zusätzliche Zwischenbildberechnung anschaltet :oops:
Interessanter Effekt: Mein Monitor macht 144 Hz, weswegen ich die max. FPS in der NVIDIA System Steuerung auf 144 FPS limitiert habe.
Bei Plague Tale ist mir direkt aufgefallen dass die FPS über die 144 FPS hinausschießen, das Limit funktioniert ansonsten in allen anderen Games aber eigentlich recht zuverlässig.
Eben bin ich darauf gekommen woran das liegt: Der Treiber erkennt das zusätzlich berechnete Frame nicht und limitiert bei 288 FPS.
Man muss die Systemsteuerung also auf max 72 FPS setzen, dann werden bei Plague die Frames im Game auch auf 144FPS limitiert.
Wow, der tipp ist geil :-) Und ich dachte Framelimiter funktionieren nicht. Haben alle Youtuber gesagt :-) Hut ab.
Der für dich relevante Part sollte ab Minute 13 anfangen.
hey Nvidia, warum hast du der 4090 so viel Power spendiert? Angst vor AMDs Navi31? -)
Die RT Leistung zu verdoppeln reicht aber nicht, um an die 4090 ranzukommen. Damit hat man Ampere, aber hinkt immer noch eine Gen. hinterher.
Allerdings hast Du dann auch den Frame-Lag von 72 FPS.
Mag sich bei 72 FPS noch irgendwie ausgehen, aber darunter fühlt es sich echt komisch an, weil Du den LAG von wenigen FPS hast, aber auf dem Monitor viele FPS erscheinen.
HX1200 corsair
hol mir mal so ein neues kabel.. dual bios is auch p mode extra nochmal geschaut
Strix an BQ Straight 850 mit 4x8 adapter problemlos 120%.
Probier mal GPU tweak 3 aus…Achtung: nicht mehr als 120% einstellen (600W) sonst übernimmt er es nicht und springt auf 100% zurück…AB geht nur (korrekterweise) bis 120%.
Toll wenn das eigene Programm nicht vernünftig funktioniert :-)
Evtl. zeigt der RivaTuner Statistics die Frames auch einfach noch falsch an? Weil wie du schon sagst fühlen sich die künstlich gepushten 144 FPS irgendwie nicht danach an :poop:
Oh man das klingt alles nach nem großen Fake. Tearing, Inputlag, schwammige frames, kann ja nur noch besser werden...
Hoffe ich kann es bald selber testen :(
Hat irgendjemand heute mal eine Bestellung für eine 4090 bei Mediamarkt/Saturn durchbekommen? Macht echt keinen Spaß mehr 🙃
Jupp, habe heute Nachmittag (16 Uhr oder etwas später) eine TUF OC bekommen. War wirklich merkwürdig. Ich habe wieder wie vor 2 Jahren einen Merkzettel angelegt und in dem wurde die Verfügbarkeit grün. Man konnte sie aber noch nicht in den Warenkorb legen. Ich habe mich dann erstmal bei PayPal angemeldet etc. und ein paar gefühlte Minuten später ging es dann. Hab dann alles per Hand in den Warenkorb geklickt und normal durchbestellt. Wenn sie nicht noch storniert wird, wars das.
Edit: war 16:20 Uhr und der Status ist "deine Bestellung wurde versandt", also ja ich bin raus.
Ähnliche Themen
Antworten
7K
Aufrufe
477K
