[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das geht eventuell über die ASUS Software Armory Crate.
Den Rotz voller Rootkits und Malware würde ich aber nicht installieren :fresse:
Aber nicht übers Bios.
Armoury Crate ist die Pest. Wenn man trotzdem sein Setup vom Regenbodenlook befreien möchte, sollte man sich das folgendes Opensource-Projekt angucken, um sein System sauber zu halten. Nutze ich seit Ewigkeiten.
Immer, wenn ich es starten ist das power Limit bei 93 % ist es zur Zeit normal. Hat das auch Ware..?
Ist zur Zeit die aktuellste Version
Lg
Lg
SuprimX?
An der Stelle zeigt er das, passiert mit 3 Steckern ist dann aber auch das Limit.
Ganz aktuelles Beispiel "Super People", selbst mit DLSS kann ich nicht immer 160 FPS halten - klar ich könnte ein paar Settings runtergehen aber... :)
Forza Horizon 5 (jetzt kein richtiger MP Titel) droppt auch häufig unter 160 Frames, man merkt die Slowdowns
Wer braucht 160 FPS+ in 'nem Rennspiel? 120 FPS reichen doch völlig aus.
Gerade getestet. Geht nicht.
SuprimX?
Ja supreme x habe aber den Adapter dran. 4 Stecker
Vorsichtig mit solchen Tipps!!
In MP Games kann man für solche Software gebannt werden.
IgorsLabs Mitarbeiter wurde wegen einer RGB Software in Tarkov und PUBG gebannt.
Igor hat dann ein Video dazu gemacht.
Fazit:
Software muss gegen einen Preis von Anti-Cheat-Entwicklern freigekauft werden.
User sind dem hilflos ausgesetzt.
Danke für den Tipp. Ist mir nie aufgefallen, da ich ja nicht zocke. Die Software muss jedoch gar nicht laufen - nicht mal als Dienst sondern kann die Config direkt auf's Device schreiben. Da ich aber noch keine 4090 hier habe kann ich die Funktion da nicht bestätigen.
PCIe 4.0 Riser würde ich aus eigener Erfahrung nur die von Linkup nehmen.
Das hatte ich auch mal mit nem Lian-Li riser, es kann helfen die Grafikkarte neu einzustecken in den Slot. Kann aber natürlich auch ein Defekt sein.
Danke, das hats gebracht... sind nun 16 Lanes :)
das das Riser schon sehr gequetscht ist, mach dem das was?
Ja ich musste lian li nehmen, das Bracket für das o11 gibts ja nicht einzeln
Gestern kam endlich meine ZOTAC GAMING GeForce RTX 4090 AMP Extreme AIRO von Alternate für 2274 Taler und sie passt in mein bequiet Pure Base 500 wie Arsch auf Eimer, da sind noch locker 2cm Platz.:LOL:
Fummelig anzubringen war das RGB Kabel, welches leider auch noch teilweise rot ist...muss noch geändert werden. Genauso wie das unsägliche Adapterkabel, aber Computeruniverse hat es noch nicht verschickt.
Ich habe bisher alles auf Standard laufen lassen und die Karte ist total hübschig:love:, meiner Meinung nach zumindest.:banana:
Die größte Angst war das Spulenfiepeno_O, aber ich höre im Gegensatz zu meiner 3090FE, die jetzt bei meiner Frau verbaut ist, kein Spulenfiepen, auch in Menüs von 400+fps nichts, Spiele getestet habe ich bisher allerdings nur Elden Ring, Deathloop, Two Point Hospital, alles 4k @144hz, oder ohne vsync bis 180-200fps, mehr testen ging noch nicht weil aus unserer eh schon lahmen 100Mbit Leitung kommen maximal 75 heraus...:rolleyes2: , falls da noch ein Spulenfiepen kommt mach ich ein Update.
Lüfter sind angenehm, drehen aber unnötig hoch im Verhältnis zur Temperatur, das werde ich anpassen...muss ja nicht nur auf 55-63grad laufen bei 1300u/min. Mit UV und angepasster Lüfterkurve bekomm ich das so leise wie ich das möchte, das die Lüfter so bei maximal 1000 u/min laufen.
Fazit:
Du musst nur nach dem Start die Software öffnen dann wieder schließen. Deinen Farben passen dann.
Sitzt die Figur da jetzt nur fürs Foto oder wirklich dauerhaft?
Was ist denn die KFA2 GeForce RTX 4090 SG 1-Click OC für eine Karte? Von der habe ich ja noch gar nichts mitbekommen...
Das ist der Persocom Chi von Chobits, einem Anime den ich damals mit meiner Frau gesehen habe, als wir uns kennenlernten und ja seitdem sitzt Chi immer mit im Rechner.
Ich hoffe sie kann sich an das schlanke neue Kabel korrekt anlehnen. :LOL:
Ähnliche Themen
Antworten
6K
Aufrufe
392K
