[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Naja durch meinen Beruf schaffe ich es nicht, am Mittag am Handy/Pc zu sein und da gehen mir viele Drops durch die Finger :(. Einen kleinen Aufschlag für ein gutes Produkt, welches ich dann sicher habe, tut mir nicht weh :) aber ich bin mit MF irgendwie noch unsicher :/!
Scharwenzelst doch schon regelrecht um die 4090 Modelle wie die Schlange um das Karnickel. :d
Erlöse uns und tauche hier in diesem Thread mit ein, in dem Du Deinen Bestellstatus, Statusupdates der Sendungsverfolgung, Bilder von der gelieferten Karte und schlussendlich Benchmarkergebnisse postest.
Wie/Womit kann ich eigentlich das BIOS der Asus TUF updaten?
Kann ich eigentlich den 4. Anschluss an dem 16-Pin Adapterkabel mit dem PCI-E 6+2 Kabel, welches sich am Ende zu zwei 6+2 Anschlüsse aufsplittet anschließen, oder sollte ich da lieber ein 4. direktes Kabel zum Netzteil benutzen?
Sorry, falls die Frage schon gestellt wurde, habe es bei der Suche nicht gefunden.
Ist die Anleitung noch die gleiche fürs Flashen?
Anleitung
7. Enter drücken
10. PC neu starten
Die Chipgüte variiert ja Extreme bei der 4090.
Ich hatte jetzt bereits 3 Strix eine TUF und 2 Suprim X und ne weitere Strix ist unterwegs gerade bei der Strix hab ich jetzt 2 Modelle die keine 3GHz gepackt haben und eine die Default 2985 MHz in ihrer Default Curve bei 1,1Volt drin hat und geht auf über 3.1GHz die andere geht nur bis 2970MHz und Default bei 1,1Volt gerade mal 2805Mhz. Die TUF liegt iwo dazwischen und die Suprime lagen beide bei ~2900 in der Curve.
Da reden wir von über 180MHz von einer Strix zur anderen …
Wie sehen denn eure Default Curves im Afterburner aus bei 1,1Volt?
Hier bei default Curve ist bei mir 2775 MHZ @1,1 V .
Stock 1,05V 2700 MHZ
Finde es übel wie groß die differenzen der einzelnen Karten sind.
Ihr habt es nicht verstanden. Je mehr gekauft wird, desto höher gehen die Preise. Das ist ein automatisches System in den Shops.
Wird nach einer gewissen Zeit ein verteuerter Artikel nicht verkauft, geht der Preis automatisch wieder runter.
Edit: Alles wird sich in den kommenden 1-2 Monaten entspannen...aber solange will ich nicht auf meine FE warten. :d
Du Fuchs :d
Gute 180 gingen schon raus, so schlecht läuft das nicht für MF. Sind halt mal über 32000€ mehr Einnahmen als Mediamarkt mit seinem Preis.
Glaub aber die Preise waren vorher nicht so hoch bei den den Karten. Sprich die haben 180 mit günstigeren Preisen abgesetzt.
ja 2249€ hatten die letzten Donnerstag bei MF gekostet
Gibt es da kein Programm von Asus zum updaten des BIOS? Ich will kein anderes BIOS von anderen Karten auf die TUF flashen.
Ich muss ehrlich zugeben, dass ich die flash Prozedur auch nicht selber beherrsche oder traue durch zu führen, ich muss dann immer jmd. freundlich fragen, der mir dabei hilft, iwi bekomme ich das nicht hin, obwohl es eigentlich recht einfach scheint .....
Ich hab am 4. Adapter Anschluss den 2. Anschluss vom 3. PCIe Kabel, weil ich nur 3 Frei hab, läuft unter Vollast ohne UV etc auch Problemlos am 850 W Seasonic Netzteil, auch mit 133% Powertarget :d, aber eigentlich könnte ich es bei meinen Settings auch locker weglassen.... da reichen idR sogar 2 x 150W.
Der Preis wäre für mich kein Problem, habe bei der 3090Ti auch einen Aufschlag bei nbb bezahlt aber wenn man so die Bewertungen bei trustpilot anschaut, sträuben sich einem die Haar :(.
Edit: Ich lasse es lieber und warte auf einen Drop bei einem anderen Shop!
Hast du nicht schon eine 4090 oder verwechsele ich gerade was? :)
Leider noch nicht, in den Shops wo ich gern eine kaufen würde, waren alle immer innerhalb kurzer Zeit ausverkauft. Mit MF tue ich mich noch etwas schwer, habe gern vor Ort Service, wie bei Alternate!
Edit: Meine 2 BeQuiet Kabel sind aber eben angekommen :).
Bei meiner alten Palit 3080 musste ich mir einfach nur ein Programm von deren Seite runterladen und ausführen. Ich dachte, dass ist bei Asus bzw. überall genauso. OK Egal.
Das liegt wohl daran, dass NVIDIA jede GPU immer näher am ermittelten maximalen Potential jedes einzelnen Chips laufen lässt.
Das ist ja ein allgemeiner Trend bei allen grossen CPU/GPU Herstellern. Da will niemand mehr 'Leistung auf der Strasse liegenlassen'.
Deswegen lohnt sich ja auch manuelles OC immer weniger, weil die Sichherheitsabstände immer kleiner werden, die man 'für frei' nutzen kann.
Jetzt kann man hauptsächlich mit mehr Stromeinsatz noch ein paar % Leistung rausholen oder undervolten und relativ viel Strom sparen, bei geringfügig reduzierter Leistung.
Wird im Video ja gesagt, trotzdem ist es unakzeptabel, dass der VRAM so heiß wird und bei anderen Herstellern zwischen 60-70 Grad liegt. Im Sommer kann man dann je nach Raumtemperatur nochmal einige Grad draufrechnen. Für mich ein absolutes K.O. Kriterium bei der Auswahl der Karte, was ich so von der Liquid X nicht erwartet hätte, sollten andere User, welche die Karte besitzen, die Temperaturen bestätigen.
Hab meine Suprim Liquid X jetzt nicht mit AIDA gequält, nur ein paar Durchgänge Superposition 4k. Bei 3015 MHz und 125% PL lag die max. GPU Temperatur bei 61 Grad, Hotspot bei 62 Grad max und die Memory Junction Temp bei 74 Grad max.
Hier im Thread wird echt zu viel Müll gepostet.
Wer kann mir die TUF OC BIOSe hochladen?
Gerne beide, aber primär Quiet.
Wollte dir gerade das TUF OC Bios speichern , aber kommt leider eine Fehlermeldung :(
Mal eine Frage dazu. Kommt es nicht auf das BIOS der Karte an wie sich die Default Curve verhält? Ich habe z.B. eine TUF non OC. Die ist doch von Haus aus niedriger getaktet. Steht bei 1,1V bei 1745 MHz, macht aber auch +315 MHz mit und boostet dann bis 3060 MHz bei 1,1V.
Das BIOS gibt Möglichkeiten vor aber welche genutzt werden kommt vom Chip..
Ja ist auch kein Thema eigentlich , aber finde es misst , wenn Asus eine TUF und eine TUF OC bringt und man kauft sich die OC wie ich (gut habe nichts andere bekommen)
und man bekommt einen Chip der nicht besser ist als die non OC.
Ähnliche Themen
Antworten
7K
Aufrufe
472K
