[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Aufgerissen/aufgeschnitten?
Ich musste die Tüte aufschneiden. Lässt sich auch nicht zerstörungsfrei öffnen
k.A. ob hier eine Folie drum war, aber so war es bei mir und einigen Anderen hier...
Welche Spiele (außer Cyperpunk) können derzeit etwas mit DLSS 3 anfangen?
Morgen kommt Plague Tale Requiem. Sieht vielversprechend aus und der erste Teil war super. Kommt mit DLSS 3 und Raytracing UND ist ab Tag 1 im Xbox Gamepass mit drin. Sollte man sich mit ner 4090 vor allem mal anschauen.
Bei den Unboxingvideos weiss man nie, ob sie im Vorfeld nicht schon die Folien (außen und die Klebefolie an der Karte) entfernt haben. Deswegen mein Video oben, wo beides dran ist. Der Flyer im Video fehlt bei mir übrigens auch, womit die Sache klar sein dürfte, v.a. wegen dem Kabel. Ätzend.
Hier ist auch keine Folie drum...
Lustig - auf der Rückseite des schwarzen Schaumstoffdeckels steht bei mir auch irgendwas auf italienisch, wenn ich mich nicht irre :d
Cyberpunk kann noch nichts mit DLSS 3 anfangen, der norwendige Patch ist noch nicht draußen. Es sei denn er kam zufällig heute ;)
Lade gerade schon runter und mit viel Glück ist die GameRock auch spätestens übermorgen da (y)
Da die alten Invites abgelaufen sind seit 18 Uhr, hat jemand neue Invites erhalten über GE?
Hatte ich gesehen, daher mein Fokus auf das Adapterkabel. Eigentlich lächerlich, ja, aber es ist einfach mies das nicht als Rückläufer zu deklarieren. Ich hab Neuware gekauft, jetzt irgendeine suspekte Karte.
Kann nicht sein, da hats der selbe super duper leaker doch schon bestätigt...
Denke das wird der Grund sein der Strategie Änderung: Selbstzerstörung im Labor :-) Klick
Wenn ich zb. Cyberpunk 2077 1440P mit DLSS spiele. Habe ich zb. 70FPS. GPU Auslastung 85% und CPU 8%. FPS Cap 118. Warum macht die GPU dann keine 118.
Weil eine CPU nicht zu 100% ausgelastet sein muss um zu limitieren. Das ist etwa im Jahr 2005 gestorben und muss sich nur noch rumsprechen^^
Schalte mal auf FHD zurück. Die FPS müssten an sich gleich bleiben, nur die Auslastung der Graka dürfte sich verringern. Das ist ein Zeichen für ein CPU-Limit.
An sich reicht auch die GPU-Auslastung. Immer wenn Du weniger als 95% Auslastung hast, hängst Du im CPU-Limit oder hast einen anderen Limiter gesetzt.
Nebenbei: Hast Du Win11 und das H22-Update (oder wie das heißt?). Das zerschießt die CPU-Metrik von einigen Beobachtungs-Tools, weil MS irgendwas geändert hat. Wahrscheinlich ist der 8% Wert einfach nur Banane ausgelesen, was natürlich nix daran ändert, das eine GPU-Auslastung unter 95% eigentlich immer auf ein CPU-Limit hinweist.
Wo kann ich einen Wasserkühler für die Suprim vorbestellen ?
Hi Leute
Meine MSI Suprim X Liquid ist heute auch mal eingetrudelt. Gekauft am Tag nach offiziellem Release. Zu meiner Überraschung war der Karton weder eingeschweisst oder versiegelt, noch war eine Schutzfolie am Gehäuse der Karte.
Ich würde von euch gern wissen, ob das Adapterkabel eingeschweisst ist oder nicht.
Cheers
Meine Suprim X wurde in einem großen Karton aus Pappe von MSI geliefert.
Karton der Grafikkarte: nicht versiegelt und auch keine Folie drum
Zubehör: nicht versiegelt. Adapter Stecker war einseitig offen
Grafikkarte: Foliert am Kühler+Backplate
Wenn du Day1 gekauft hast wird das garantiert kein Rückläufer sein.
So bisschen PCars 3 gespielt, das lief (aus einem mir nicht begfreiflichen Grund) mit der 3090 nicht flüssig oder unter 30 fps was gerade in einem Rennspiel nicht gut ist. Jetzt war ich so weit ich das gesehen habe nie unter 60, meist bei 120 (Limit vom Monitor) 4k max.
Und fakt ist die Karte braucht einen Wasserkühler, zumindest in meinem Gehäuse. Gehäuse ist inzwischen geschlossen und ich hatte 74°C bei der Karte.
Meine Suprim war auch „offen“, aber Schutzfolie auf dem Kühler.
hier habt bestimmt keine rückläufer bekommen. Meine Suprim X war auch der Karton Offen, rest eingepackt, folie auf Lüfter, Backplate und Suprim Schriftzug
Das Zitat ist überhaupt nicht von mir :confused: Schau mal, wohin der Link führt (was ich wirklich geschrieben hab) ;)
Stammt von @*$Ben$* ;)
Wieso war das ein Problem, wurden Dir die Lüfter zu laut? Meine Suprim bleibt selbst bei Vollast im Bench und Max OC in meinem Gehäuse in der Regel unter 70°C. Lüfter habe ich dabei nicht wirklich wahrgenommen. Beim Zocken ist sie meist >10°C kühler. Ich persönlich sehe daher keine Notwendigkeit für einen Wasserkühler bei meiner.
Von den FE Besitzern. Was habt ihr in Time Spy Extreme auf den Core geben können?
Bei meiner ist wohl bei +150 MHz Schicht im Schacht (PL +133%, vCore +100%) -> Entspricht ca. 3000-3015MHz
Yeah, meine TUF wurde versandt :banana:
Zu laut nicht, aber ich finde 74°C einfach nicht gut.
ne aber wenn bereits ein mo-ra incl AGB und softtubes da liegen, wär es natürlich blöd es nicht zu nutzen :) Meine Geht auf jedenfall wiedfer Unter Wasser, wenn der Block da ist incl Test erfolgreich sind
Ähnliche Themen
