[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe die letzten Seiten gerade einmal überflogen und wollte einmal wissen, wie man sich für die priorisierte Bestellungsmöglichkeit der FE anmelden kann. Kannst Du mir da eventuell weiterhelfen?
Ich habe mir eben gerade mal GeForce Experience heruntergeladen und mich angemeldet (nutze diese Software sonst nie...), aber finde irgendwie nichts. Auf der NV-Website habe ich Benachrichtigungen zur 4090 auch aktiviert. Bisher kam nichts...
Lustig, dass jetzt auf einmal die verpönte Experience Software installiert wird. :d
Ist es da gebe ich dir recht und das sind für mich echt komische Menschen die sowas ausnutzen. Aber die preise sind gefallen oder ? am anfang habe ich so um die 3K+ gesehen.
Einfach nicht kaufen. Der hat bestellt und will innerhalb von 2 Wochen die Karten verkaufen, da die sonst zurückgehen.
Glaubt ihr dass man die FE nur mehr über dieses neue Programm über Invite kaufen kann oder wird es auch noch reguläre Drops geben? Ich habe aktuell keine GPU verbaut und somit keine Möglichkeit geforce experience zu installieren, wäre schon krass unfair wenn man da dann komplett aussen vor, ich war immer NV User
Moin,
kurze Frage.
Suprim x angeschlossen an einem Dark Power pro 1000W über zwei Kabel die in den beigelegten Adapter gehen (4x8pin). Angeschlossen an Pcie1 und 3 mit v3 und v4.
Der Afterburner sagt mir beim PT max 108%...
Ist das richtig so? BIOS steht auf Gaming.
Danke für die Hilfe...
Macht euch nicht verrückt, natürlich wird es drops geben! Wäre auch sehr blöd von NVIDIA und NBB
Interessant. Ich habe hier nur zwei Beispiele, Kumpel mit Strix oc und ich mit TUF non-oc. Die Karten laufen beide gleich. Knapp über 3 Ghz aber auch unter Last stabil mit 1.1v.
Wo EVGA jetzt weg ist, gibt es sicher einen Markt für diese "Kingpin" Karten. Galax wird da bestimmt eine HOF bringen, aber die sind ja bisher hier noch nicht so etabliert am Markt. Könnte ich mir also schon vorstellen das ASUS was bringt. Dann aber bitte auch ein Modell in Kooperation mit deutschen Wakü-Herstellern wie Watercool oder Aqua-Computer. *träum*
Besser in Kombination mit EKWB, die machen bessere Waterblocks für GPUs
Ist so korrekt
Wie bekommt man Drops mit? Hab leider keine Instagram, twitter, fb nur Discord. Die Fe würde ins Gehäuse meines Bruder passen.
denke in Discord oder Telegramm gruppen wird sowas gepostet. Ich selbst bin bei Part Alert (DISCORD), da kommen Benachrichtigungen aber "NOCH" nicht für 4090.
Aber das wird kommen
Moin,
kurze Frage.
Passt. Gaming BIOS sind 480W die Ausgangsbasis. 108% entsprechen dann 520W, dem Maximum der Suprim.
THX @BHouse
War immer bei 450W...
Bei meiner Suprim hatte ich im Afterburner je nach eingestelltem BIOS entweder 108% oder 113% Power Limit. Wir hatten die Diskussion vor zwei Tagen hier im Forum, das eine Bios geht von 450 Watt als Standard aus, das andere von 480W. Da in beiden Fällen das Limit 520W darstellt, passt das so :)
WoW
Die Gainward Problematik scheint echt wie Igor vermutet lediglich an Resonanzen zwischen den Lüftern zu liegen, anders kann ich es mir nicht erklären.
Im Silent BIOS ist das Geräusch bei mir wirklich nur kurz beim Hochfahren zu hören und wenn das BIOS geladen ist, ist die Karte absolut ruhig. Im Idle natürlich 0rpm aber auch beim anlaufen dann wenn man zockt etc. Ist nichts zu hören. Funktioniert aber nur mit der Standard Lüfterkurve. Sobald man im Afterburner was eigenes einstellt, hat man dieses Brummen wieder, auch im Silent BIOS.
Kann also echt sehr gut sein, dass es dafür lediglich ein BIOS Update braucht.
Wenn ich also auf S stelle muss ich den PC Neustarten ? oder werden die Bios einstellungen der Karte sofort geladen ?
Ein Neustart muss sein.
Hwmonitor zeigt mit ein max Verbrauch von etwas über 550watt an. Ist das dann ein auslese Fehler?
Guten Morgen!
Meine Gainward befindet sich in der Zustellung und ich habe jetzt schon mal den Rechner vorbereitet wobei sich noch eine Netzteil Frage ergeben hat:
Ich habe aktuell das Sharkoon Silent Storm 850W Netzteil. Das Netzteil hat PCI-E Anschlüsse nativ und es liegen zwei 6+2 Doppelstecker Kabel mit dabei, also insgesamt 4x 8 Pin. Jetzt habe ich hier gelesen, dass man auf keinen Fall Doppelstecker verwenden soll, aber an dem Netzteil habe ich keine andere Möglichkeit. Meint ihr das ist problematisch? Ich betreibe seit 2 Jahren eine 3090 auf vollen 350W mit einem Doppelstecker, angeschlossen an einer Buchse am Netzteil. Ich vermute also mal, 2 Doppelstecker würden dann auch gehen? Zumal ich das PL eh auf 80% stellen werde.
Hi, hat da bei dir geklappt mit dem Sharkoon Silent Storm und der RTX 4090? hab die 4090 suprim x und auch das 850 von sharkoon. Hatte schon mal den support angeschrieben aber bislang kein Antwort. Hab mich noch nicht getraut die karte anzuschließen.
:d Naja und beim freundlichen scalper neben an
Ähnliche Themen
Antworten
6K
Aufrufe
392K
