[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich warte bis ich es bei meinen Arbeitgeber für 1650€ bekomme, dann ist es fair!
Also 1950€ und der Persorabatt:)
Nach den Testergebnissen bin ich davon überzeugt, dass die Nachfrage gigantisch sein wird.
Frage, weil ich wahrscheinlich über nem guten Homie, der beim Saturn arbeitet, die Karte auf Perso kaufen werde. Genau wie die 3080Ti damals. Bekam ich auch unter UVP😅
Oh nein, bitte kein Ampere-ReTrauma
Na wo sind die armen Seelen die glaubt haben die 4090 hätte die vierfache Leistung der 3090 TI :ROFLMAO:
Ich wurde noch belächelt als ich sagte das es nur 30 - 40 % wie immer ist, sehe nichts von vierfach. DLSS3 auch noch nicht ausgereift zumal ich sowieso davon nichts halte. Viel Spaß als Beta-Tester für 2500 € ich steige in 2 Jahren auf die beste 4090 für 1000 € um.
Irgendwas hast du da nicht ganz richtig verstanden. 30-40% waren das vielleicht bei deiner 3090 Ti zum Vorgänger und nun lachst über die 4090 die wesentlich mehr drauflegt? :unsure:
Der Leistungssprung ist so hoch wie kaum zuvor. Die 3090 Ti wird deutlich geschlagen und wirkt fast nur noch wie Mittelklasse in den Benches.
Wenn dir 2 Jahre warten 1k wert sind, bitte. Viel Spaß beim Warten! :)
Wenn China Richtung Taiwan marschiert kriegt holzmann nen herzinfarkt
Ich sehe das mit großer Gelassenheit, habe ja bei e-tec vorbestellt. :d
Also ich hab die Kommentare und so mal grob überflogen und hab jetzt keinen Stimmungswandel feststellen können. Leute sagen nach wie vor "Leistung top, aber 2000€ ohne mich".
Sehe ich ähnlich. Das die Karten morgen ausverkauft sein werden, liegt halt primär an den Scalpern. 2 Wochen kann man ja retour schicken. Dann wird sich das alles normalisieren ..
Als ob Du zwei Jahre warten wirst. Wer das glaubt wird selig. :d
Also wenn ich mir die Test so der FE anschaue, frag ich mich echt wo die daseinsberechtigung einer Strix / Supreme / Aourus noch herkommen soll :)
Also mein einer PC 1080p und der andere 1440p im ersten werkelt eine 7700K und im zweiten ein 10700K - in meinem ersten PC eine 2080ti und und meinem zweiten eine 3090. Ich stelle fest, upgrade bei entsprechenden CPU/Graka kombinationen völlig sinnfrei.
Scheiss aufs Geld mitnehmen kannst du eh nichts...😆 Hauptsache FPS!😄
Die Karte ist doch gut geworden.
Selbst mit einem TBP von 450 Watt kommt man gut zurrecht .
Schade natürlich wieder , dass die Ref. Platinen schlechtere Spannungsversorgung haben als die FE , aber die selbe UVP.
Tuen einem irgendwie die Boardpartner bisschen leid.
- Welche Spiele spiele ich momentan und plane ich zu spielen?
- Bekomme ich momentan genug FPS, um das Spiel zu genießen in deiner maximalen möglichen Auflösung?
- Unterstützt dein Monitor mehr HZ, um die höheren FPS überhaupt korrekt darstellen zu können oder müsstest du einen neuen Monitor dazu kaufen?
- Ist dein Gehäuse groß genug oder musst du ein neues kaufen? Hast du genug Platz neben Lüfter und Pumpe?
Alles mit Ja beantwortet? Check dein Bankkonto oder überlege ernsthaft, ob sich eine Grafikkarte lohnt um eine Finanzierung zu starten.
Alles mit Nein beantwortet?
- Hast du genug Geld und willst einfach nur das “haben” Gefühl? > Kauf es dir
- Brauchst du es für die Arbeit und kannst es dir leisten? > Kauf es dir
- Kauf es einfach nicht
:ROFLMAO:
Können doch bessere bauen? Kühler und 2x 120 Lüfter drauf und Abfahrt. Rgb Kühler gedönz brauch ich nicht.
Tuen sie ja auch , aber geht dann auch bei 2300€ los .
Nvidia kann halt für sich selber am günstigsten produzieren.
Und wo ist die Chance auf eine FE nun besser? NBB oder Nvidia direkt... 🤔🤔🤔 Glaub ich versuchs erst mal direkt bei Nvidia.
Ich muss eh auf meine Reaktionszeit vertrauen mit Webcode oder Botspielchen kenn ich mich nicht aus. 😂
Du wirst sicher von Nvidia direkt zu NBB weitergeleitet, die vertreiben auch exklussiv aktuell alle FE Karten.
Da werden sicher auch Mitarbeiter genötigt, die in der Kaffeebohnen-Abteilung für Vollautomaten arbeiten und kurz vor der Rente sind :d
Kurz - bei MM/SAT sieht es vielleicht nicht so gut für uns aus... :fresse:
Dieses Jahr wirds gar nicht einfach, gefühlt 80% der Karten passen nicht in mein Gehäuse. Gott segne uns mit Verfügbarkeit.
Ähnliche Themen
