[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bei mir wären es 4 Std. Fahrt, mit leeren Händen zurück kommen wäre echt💩
Zur Abholung bestellen … du bekommst dann eine Abholbestätigung. Also keine Sorge umsonst fährst da nicht hin… aber bei 4h macht’s keinen Sinn. Express Versand erhöht die Chancen ;-)
Hat schon jemand Stray gezockt?
4K und alles auf max. Auflösungsmaßstab auf 200% fordert die 3090 mehr als Cybepunk77 :fresse2:
@yilem76 Yep, ich. Deswegen habe ich das mit der 200% ganz schnell wieder gelassen, 4k reichte auch so schon :d
Wie läuftn das bei Alternate wenn man bestellt hat bei großem Andrang und per Express bestellt - Bestellung ist durch wenn man Versandbestätigung hat? Oder weiß man das vorher?
Alternate : Dort werden Express Bestellungen Priorisiert sagt die Erfahrung also vor allen anderen die bestellt hatten kommen erst die Express Bestellungen dran, ich glaube gelesen zu haben das sie es mal ändern wollten aber Scalpernate bleibt scalpernate.
So war es beim Ampere launch.
Meinungen zu Gainward? Die Karte würde sich optisch gut bei mir machen...
Das blöde an Alternate ist das ich nur wenige km davon entfernt wohne und früher bin ich an Release Tagen Losgefahren und habe unterwegs bestellt und gleich abgeholt, aber früher waren die Aufschläge nicht so krass wie heute.
Der Garantie-Service ist :poop: bei dem Hersteller, genau so wie bei Palit, also nichts für länger als ein Jahr.
Du kannst es natürlich drauf ankommen lassen, aber bei mir kommen weder Gainward noch Palit in die engere Auswahl für eine Karte die ich länger halten will.
Da bin ich mal gespannt. Chrom statt Nickel, 50% dichtere Kühlfinnen und die neue Paste/Pads klingen vielversprechen.
Du meinst jetzt den Alphacool oder ?
Ich kann über die Gar nicht meckern .
Ein Alphacool auf der Red Devil verbaut und einen auf der 3080Ti FE einzig für den Speicher bin ich bei der FE auf Alphacool APEX SOFT 11W/mK ausgewichen für den GDDR6X .
Die Kühler haben bei Igor hervorragend abgeschlossen ich glaub Biski und EK hingen immer hinter her bei der Kühlleistung.
Nur Aquacomputer war da Top und der Watercool !
Ich muss aber auch sagen Alphacool hat bei mir ein Stein im Brett weil ich da vo ca.18 Jahren das erste mal dort vor Ort in Braunschweig eine Wasserkühlung zusammengestellt habe .
Es war ein Klasse Erlebnisse und seit je her versuche ich Alphacool Produkte auch vor zu ziehen oder Aquacomputer und Watercool .
Es gab aber in den Anfängen der GPU Kühler von Alphacool nicht Gute Kühler teils waren die Spannungs Wandler noch Passiv gekühlt beim Block usw. aber die Zeiten sind längst Vergangenheit.
Gerade auch die PL ist großartig.
Gruss
warum hat alphacool immer diese dichtungsgummis MITTEN IM BLOCK
Meint ihr einer der kabelhersteller ist so schlau und macht ein Kabel wo der 16 Pin abgewinkelt ist sodass die Karten doch in mehr cases passen? Denke mit so nem Kabel könnte man sich diese Gen ein goldenes Näschen verdienen
Ist eher die Frage ob es den Stecker abgewinkelt gibt. Habe bisher noch nicht häufig (wenn überhaupt) Molex MicroFit Stecker mit Winkel gesehen.
Kann ja nicht so schwer zu produzieren sein oder?
Ist wahrscheinlich längst bekannt, könnte man aber in Post #1 verlinken
Kabel umsonst, für alle mit Seasonic-NT, das in den letzten 12 Monaten gekauft wurde
Frage mich ob man es dann auch kaufen kann, habe mein Seasonic NT etwas länger als ein Jahr -.-
Alternate war in der Anfangszeit vom Ampere was das Verkaufsverhalten abgeht, sagen wir mal sehr speziell.
Während Online und bei telefonischer Anfrage eine bestimmte Karte nicht vorrätig war, konnte man diese zeitgleich zur Abholung bei Barzahlung bestellen.
Die Auftragsbestätigung kam noch am gleichen Tag und der sehr zeitnahe Abholungszeitraum (waren es 3 Werktage?) wurden einem mitgeteilt.
So kam ich ungefähr vergleichbar schnell zu meiner 3080, als hätte ich diese vorrätig per Versand bestellt.
Der Tipp kam damals hier aus dem Forum.
Ähnliche Themen
Antworten
7K
Aufrufe
488K
