[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Von nbb bitte auch:)
  • Danke
Reaktionen: SH
Ja Karte bei denen nur ein 3xPin dabei liegt ist der Ofen aus. Da kann nicht mehr drüber als die 450W , und da wird wie bereits @Dampfkanes gesagt haben das Bios bei 450W liegen
Wobei 3x150W + 75W vom Slot wären wir ja eigentlich bei 525W
Da flasht man einfach das Oc Bios drauf und steckt den 4x8 Pin an und schon gehen auch die auf 600 Watt+
Seltsam ist nur, warum Nvidia über die Leistung so ein Geheimnis macht! Für den Hype wäre es doch viel besser gewesen, wenn die Tests nun released worden wären und man genug Zeit hat, den Hype aufzubauen!
Die Nummer wird dann viele Grakas zum Tot verhelfen.,
Bestimmt nicht, die oc modelle davon haben ja auch die 4x8 Pin, an einer gaming trio ist nix anders als an der Gaming X Trio ausser dass die eine Karte ein Bios mit mehr Boost und TDP hat. So gesehen ist das reines Marketing
Es geht ja das Gerücht, daß die Tests und Review am Vortag des Releases erscheinen dürfen. Das reicht immer noch für den Hype und das sich dann alle am 12.10. auf den Shop Pages knubbeln können ;)
Vielleicht gibt es aber auch keinen Hype wie manche ihn erwarten. Die LuXXer hier haben da meiner Erfahrung oft eine andere Wahrnehmung als der Rest der Welt ;) Die meisten sonst werden ja eher Richtung 4080 und darunter gehen, und die 4080 kommt ja erst im November, der Rest noch später. Für die Interessenten einer 4090 braucht man keinen weiteren Vorlauf, einen Tag, eine Woche macht da keinen Unterschied. Ich würde sogar eher sagen, der Hype wird eher größer gerade weil es noch nichts gesichertes gibt. nVidia ist da ja in guter Gesellschaft.
Ich würde mir NIE zutrauen nen Biosflash zu machen wo bei der Karte "NUR" nen 3Pin stecker wär. Um dann ein Bios mit 600W drauf zu brutzeln. Never Ever, war auch bei der 30er Gen ned anders. Ich kenn keinen der nen Bios einer 3x8Pin auf ner 2x8Pin geflasht hat. Da gebräbst die KArte ja direkt.
Zusammenfassung:
- Nvidia hatte mit dem 8nm Prozess angefangen zu kalkulieren und den Partnern gesagt, dass die 4090 ca. 600-900W brauchen wird um die angepeilte Leistung zu erreichen
- Daraufhin haben die Boardpartner schon die Kühler geplant und gebaut (Der Prozess kann bis zu 1 Jahr dauern)
- Nun hat man aber gemerkt, dass durch den 5nm Prozess, dass die Karte wesentlich weniger Strom braucht und die Leistung gut ist
- Nun hat man aber schon die Kühler gebaut mit geplanten 600-900W zu kühlen, aber müssen nur 450W kühlen. Dadurch die super großen Kühler jetzt
- Die Temperaturen sollen dadurch natürlich richtig tichtig gut sein und die Karte sehr leise
Ich frage mich, ob in Zukunft die Partner kleinere Kühler bauen werden für die Karte. Dann haben wir Cooling V1 und V2 :d
Was der da wieder für einen Käse zusammenspekuliert. Er hat schon bei den letzten 2 Gens viel Mist verzapft. Verstehe nicht, dass ihn überhaupt jemand ernst nimmt.
Ada wird schon seit Jahren in 5nm (4nm) geplant, ein AD102 wäre in 8nm technisch gar nicht möglich. AD102 würde mehr als deutlich das Flächenlimit überschreiten in 8 nm und wäre damit ~1600 mm² groß. Das ist nicht herstellbar.
Man kann den Prozess nicht einfach über Nacht wechseln ohne ein komplettes Redesign des Chips. Die Leckströme sind anders, die kritischen Pfade werden anders, das Verhalten der Transistoren wird anders etc. Bestehenden Chip einfach schrumpfen ist so nicht drin. So ein Schwachsinn. Der Fertigungsprozess ist sehr früh in der Designphase gesetzt. Die 4 nm stehen sicherlich seit 2,5-3 Jahren fest. Boards und Kühler werden in einem Bruchteil der Zeit designt.
Und wann kommuniziert das restriktive Nvidia sowas dann abschließend ggü. seinen Partnern, damit ja bloß nichts von denen nach außen dringt?
Und der letzte Anschnitt zu N31, was ein Unsinn. xD
Vor allem widerspricht er damit quasi allem was er früher immer erzählt hat. Ohne eine definierte Vorlaufzeit (und die ist sicher nicht nur ein paar Wochen) kann man keine Chips produzieren, somit muss die Entscheidung für den Chiphersteller definitiv vor dem Kühlerdesign getroffen werden.
Igor reimt sich seit Jahren irgend ein Blödsinn aus den Gerüchten zusammen und verkauft es dann als echte "Leaks" von ihm. Der hat kaum brauchbare Quellen. Am besten finde ich ja da seine PCB "Leaks", sorry aber das würde jeder 10 Jähriger noch hinbekommen...
Hm ich weiß nicht, es kann auch sein, dass die Zahlen auf dem Papier dann in Real nicht so hoch ausfallen, wie manche denken. Mich z.B. interessiert DLSS 3.0 überhaupt nicht, da ich alles in nativer Auflösung spiele und mir da die Leistung wichtig ist. Aber mal abwarten :)!
NBB wird wieder die FE Karten vertreiben, die 4090 FE wurde heute morgen hinzugefügt
Kann man bei NBB seine Kreditkartendaten hinterlegen oder müssen die im Bestellprozess eingetippt werden?
Wenn man zu lange hier im Forum unterwegs ist, bekommt man ja noch das Gefühl die Karten wären gefragt.
Ohne Miner werden sich in ganz Deutschland wohl nicht mal 50 Käufer Abnehmer finden zu Release.
Wirkt aber nach viel, wenn hier 7-8 Leute schreiben, sie wollen eine RTX 4090 sofort kaufen. :)
Ich gehe von einer überraschend guten Verfügbarkeit aus.
Ähnliche Themen
