[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mir gefällt die Karte aber die Frage ist ob die wirklich besser performed... Auch interessant, er sagt Tests am 12. Oktober... nVidia sind schon Hunde :poop:
Besser Performed ist mal die frage. Ich kann dir aber sagen das due Qualität einer Strix hervorragend ist. Ich hatte wie bereits erwähnt eine Inno IChill X4 3090 , Eine Zotac 3080TI und danach ne Strix 3080TI. Allein vom Aufbau , allein von den Verbauten Komponenten macht die Strix einen hervorragenden eindruck und auch Job. Ich habe die Asus Strix 3080TI jetzt seid August 2021^und die Karte ist weder abgestürzt, oder hat sonstoge fehler gezeigt. Seid einbau/Umbau läuft die Karte wie ein Schweizer Uhrwerk. Und nein ich bin kein Asus FanBoy , ich sage nur das man merkt das die Karte HOCHWERTIG ist. Und ja diese Gen seh ich das auch bissle anders, da die Monströsen Kühler eh abkommen, seh ich diese Gen nicht ein 400-500€ mehrwert auszulegen. Wo ich drauf achten werde ist die verarbeitung, und ich glaub da bin ich bei der FE nicht falsch was das betrifft. Aber wir werden sehen. vieleicht wird es aber asuch ne Supreme X i dont know aktuell :)
Ich gehe mittlerweile auch davon aus, gab es nicht die Tage irgend ne Info, 3Ghz 509 Watt @ Air?
Es gab nen Twitter Bild von ner Supreme X die 506 genuckelt hatte. JEtzt wissen wir zumindest das es kein Fake war/ist weil ich fest der Überzeugung bin das die HighEnd karten sich genau in diesem Segment bewegen werden.
Was mich wundert ist, dass die MSI Gaming Trio die einzige Karte ist, die nur einen 3 fach Stecker hat und nicht wie die FE 4. für mich wäre es eigentlich die beste Karte gewesen. Sehe ich das richtig, dass sie mit diesem Adapter maximal 450W ziehen kann?
Naja Qualität ist eben nicht alles und die erste Strix die ich hatte, bei der war der Frame verzogen und die LED Leiste verkratzt. Die Zweite ist dahingehend perfekt aber die Performance des Kühlers war leider nie entsprechend der möglichen TDP ausgelegt. Ich würde zum aktuellen Zeitpunkt auf jeden Fall nicht die 400€ mehr zur FE bezahlen. Das war bei der 3090 noch nicht soweit auseinander (ca. 100€)!
die Zotac Trinity ohne OC hat auch nur einen Adapter auf 3x 8Pin:
Von daher gehe ich davon aus, das solche Karten nicht nur nicht mehr als 450W können, weil nur so ein Adapter beiliegt. Sie werden auch nicht mehr als 450W dürfen, weil es so in der FW der Karte hinterlegt ist.
Ja Karte bei denen nur ein 3xPin dabei liegt ist der Ofen aus. Da kann nicht mehr drüber als die 450W , und da wird wie bereits @Dampfkanes gesagt haben das Bios bei 450W liegen
Wobei 3x150W + 75W vom Slot wären wir ja eigentlich bei 525W
Verstehe auch nicht wieso die Strix 400€ mehr kosten soll, der Kühler ist (losgelöst von der eventuellen Kühlleistung) mit Sicherheit minderwertiger/günstiger als der FE Kühler. Man lässt sich einfach nur den Namen bezahlen :) Aber das betrifft ja alle AIB Karten, eigentlich müssten alle maximal bei den FE Preisen liegen.
Wie wars eigentlich beim Release der 3090 (ti), waren die üblichen Seiten down? Gab es Seiten mit eingerichteten Warteschlangen?
Niemand tut so, macht trotzdem keinen Sinn ;)
@gwltbsn bei 3090 ging nix, alles direkt ausverkauft, 3090TI ohne Probleme
Zusammenfassung:
- Nvidia hatte mit dem 8nm Prozess angefangen zu kalkulieren und den Partnern gesagt, dass die 4090 ca. 600-900W brauchen wird um die angepeilte Leistung zu erreichen
- Daraufhin haben die Boardpartner schon die Kühler geplant und gebaut (Der Prozess kann bis zu 1 Jahr dauern)
- Nun hat man aber gemerkt, dass durch den 5nm Prozess, dass die Karte wesentlich weniger Strom braucht und die Leistung gut ist
- Nun hat man aber schon die Kühler gebaut mit geplanten 600-900W zu kühlen, aber müssen nur 450W kühlen. Dadurch die super großen Kühler jetzt
- Die Temperaturen sollen dadurch natürlich richtig tichtig gut sein und die Karte sehr leise
Ich frage mich, ob in Zukunft die Partner kleinere Kühler bauen werden für die Karte. Dann haben wir Cooling V1 und V2 :d
Auch wenn ich mich wiederhole, aber das Thema von Igor find ich gerade echt extrem Spannend. Und da werden VIELE sich Wundern was für ne Perfomante Karte wir kriegen und die "NUR" 450W nuckelt. Geiler scheiß echt.
Ist die Frage ob der FE-Kühler den Die ebenfalls wie bei der 3090 in den 60ern halten kann, oder ob der Kühler tatsächlich diesmal unterdimensioniert ist, da er ja nicht mitgewachsen ist wie die der Customs aber mehr Powertarget hat
Bin auch gespannt, aber der 4090 FE Kühler ist deutlich dicker & die Lüfter größer als 3090/ti
Die Daten haben wir schon > https://videocardz.com/newz/nvidia-...-running-2850-mhz-gpu-clock-at-stock-settings
4K mit RT Native sollten so bei 60-62 Grad am Ende sein. MAX natürlich.
Es ist klar, dass 4090 Airkarten die fast gleiche Kühlleistung haben werden wie Hybrid Karten :) Spart euch den Platz im Gehäuse und holt keine Hybrid. Wenn nur Wakü
Wenn der Yield gut ist, hätte man auch mehr als die 16.384 Shader einsetzen können:rolleyes2:
Das ist möglicherweise nicht so einfach, das Design des Chips dauert viel länger als das Kühlerrdesign normalerweise, da gibt es viel mehr Vorlauf einzuplanen.
Ob der Yield gut wird, weiß man zudem erst einige Zeit nachdem die Massenproduktion wirklich gestartet ist und dann kannst Du nichts mehr ändern, es liegen viele Monate dazwischen. Das ist auch der Grund warum die Chips oft einfach künstlich per Lasercut beschnitten werden je nach Testergebnis, weil es viel einfacher, schneller und billiger ist, als alles gleich passgenau zu fertigen. So kann dann je nach Qualität und Testergebnis im Werk dann basieend auf den Anforderungen das passende Produkt gefertigt werden. Aber erhöhen kannst Du da nix mehr in dem Stadium.
Das ja dann voll die Krücke :) Ich dachte Nativ wär hier die 59,9FPS in 4k :)
Fürchte dass wir uns noch auf deutlich höhere Preise einstellen können, das Beispiel von galaxus hat gezeigt wo die Reise hin geht. /:
Ähnliche Themen
Antworten
7K
Aufrufe
488K
