[Sammelthread] ASUS ROG Maximus XI Apex & Gene - Das Mini APEX! (Z390)
[Sammelthread] ASUS ROG Maximus XI Gene (90MB10E0-M0EAY0)
--- Produktseite | PDF-Handbuch | Support-Downloads | Preisvergleich | HWBOT ---
The Gene is back with the Maximus XI family, this time with a twist. Multi-GPU configurations are becoming rarer as NVIDIA and AMD focus on single-card performance, and GPU coolers are growing beyond two slots to improve performance and reduce noise. The old Gene’s dual-GPU focus doesn’t reflect the kinds of systems gamers and enthusiasts are building, so the new model refocuses to aggressively pursue higher performance and support additional storage. It has already made its mark on the hardware leaderboards by claiming 11 global first place scores and eight world records, including the fastest CPU frequency at 7613.19MHz and the highest memory clock at 5566MHz.
Spezifikationen
attachment.php
attachment.php
attachment.php
CPUBuild in Intel® 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® Processors
Supports Intel® Turbo Boost Technology 2.0
* Refer to ASUS Deutschland
for CPU support list
ChipsetBuild in Intel® Z390
MemorySocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors
2 x DIMM, Max. 64GB, DDR4 4700(O.C)/4600(O.C)/4500(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400(O.C.)/2133(O.C.) MHz Non-ECC, Un-buffered Memory *
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
for the Memory QVL (Qualified Vendors Lists).
* Double Capcity DRAM support depends oh the DRAM models
GraphicIntegrated Graphics Processor- Intel® UHD Graphics support
- Supports HDMI 1.4b with max. resolution 4096 x 2160 @ 30 Hz
Expansion SlotsSocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors
1 x PCIe 3.0 x16
Intel® Z390 Chipset
1 x PCIe 3.0 x4
StorageSocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors :
2 x ROG DIMM.2 Module support(CPU_DIMM.2), with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)
Intel® Z390 Chipset :
2 x M.2 Socket 3, with M Key, type 2242/2260/2280 storage devices support (x4 PCIE mode)
4 x SATA 6Gb/s port(s),
Support Raid 0, 1, 5, 10
Intel® Optane™ Memory Ready
LANIntel® I219V, 1 x Gigabit LAN Controller(s)
Anti-surge LANGuard
ROG GameFirst Technology
Wireless Data NetworkIntel® Wireless-AC 9560
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Supports MU-MIMO
Supports channel bandwidth: HT20/HT40/HT80/HT160. Up to 1.73Gbps transfer speed
BluetoothBluetooth® 5.0
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output 113 dB SNR recording input
Audio Feature :
- SupremeFX Shielding™ Technology
- Gold-plated jacks
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB PortsIntel® Z390 Chipset :
1 x USB 3.1 Gen 2 front panel connector port(s)
4 x USB 3.1 Gen 2 port(s) (3 x Type-A+1 x Type-C)
8 x USB 3.1 Gen 1 port(s) (2 at mid-board)
6 x USB 2.0 port(s)
ROG Exclusive FeaturesROG CPU-Z
ROG CloneDrive
Pre-mounted I/O Shield
Slow Mode
CMOS button
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- MicroFine Alloy Chokes
- 10K Black Metallic Capacitors
Mem TweakIt
Double Power :
- Dual 8 -pin CPU
USB BIOS Flashback
ROG Exclusive Software
- RAMCache III
- GameFirst V
- Sonic Radar III
Special FeaturesAI Overclocking
ASUS 5X Protection III :
- ASUS SafeSlot Core: Fortified PCIe Slot prevents damage
- ASUS LANGuard: Protects against LAN surges, lightning strikes and static-electricity discharges!
Gamer's Guardian:
- SafeSlot
ASUS Optimem II:
- Optimem (Improved DDR4 stability)
- Improved DDR4 Stability
ASUS Exclusive Features :
- MemOK! II
- Pre-mounted I/O Shield
- ASUS NODE : hardware control interface
- BIOS Flashback Button
- Clear CMOS Button
- Reset Button
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 4
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
AURA: RGB Lighting Control
Armoury Crate
Operating System SupportWindows® 10 64-bit
Back I/O Ports1 x PS/2 keyboard/mouse combo port(s)
1 x HDMI
1 x LAN (RJ45) port(s)
3 x USB 3.1 Gen 2 (red)Type-A,
1 x USB 3.1 Gen 2 (red)Type-C
6 x USB 3.1 Gen 1 (blue)
2 x USB 2.0
1 x Clear CMOS button(s)
1 x Wi-Fi antenna port(s)
BIOS1 x 128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 6.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information.
ManageabilityWfM2.0, DMI3.0, WOL by PME, PXE
Support DiscOverwolf
1-year Anti-Virus software
Daemon Tools Software
WinRAR
Form FactormATX Form Factor
9.6 inch x 8.9 inch ( 24.4 cm x 22.6 cm )
Backpanel:
attachment.php
Special Features
1) Double-capacity DIMM support (DC DIMM)
Maximus XI Gene features a unique memory-trace design that supports up to 32GB per slot for a total memory capacity of 64GB. With double-capacity UDIMM modules, Maximus XI Gene delivers four-DIMM memory capacity in a compact, dual-DIMM design.
--> [Sammelthread] Double Capacity DIMM DDR4 (DC DIMM)
2) Overclocker's toolkit
1) MEMOK! II - DRAM Auto Training Switch
2) QLED - 4 LEDs to show current boot status.
3) LN2 Mode - Jumper to enable special options and functions for liquid-nitrogen (LN2) overclocking.
4) Pause Switch - Activate to pause the system and fine-tune OC parameters mid-benchmark.
5) Slow Mode Switch - Instantly reduces the CPU ratio to 8X to bypass finicky benchmark passages.
6) ReTry Button - One press instantly initiates a hard reset.
7) Safe Boot Button - Instantly reset the PC and boot directly in to a safe mode.
8) ProbeIt - Check the voltage via integrated measurement points.
BIOS
Reguläre Releases (Support Downloads - BIOS Shortcut)
  • 1502 (2020/04/29, Improved system stability)
  • 1401 (2019/12/11, Improve Memory-OC rules & Intel Optane H10 compatibility, fixed Tjmax for i9-9900KS)
  • 1302 (2019/09/11, Improve system stability)
  • 1105 (2019/06/20, Improved DRAM compatibility & system performance & storage device comp, Updated ME to v12.0.39 & microcode for Security)
  • 1005 (2019/04/25, Enhanced security. Improved SSD & DRAM compatibility, Updated RAID driver)
  • 0905 (2019/04/11, Enhanced Security)
  • 0903 (2019/03/22, Microcode Update)
  • 0805 (2019/01/02, Supported JEDEC Standard DDR4 32GB memory, Updated RST driver & ME FW, Improve system performance & DRAM stability)
  • 0702 (2018/12/18, Improved system stability and performance, updated RST Driver)
  • 0602 (2018/10/31, Updated Microcode, improved DRAM stability, fixed USB issue)
  • 0506 (2018/09/29, First Release BIOS)
Bilder ( ASUS Maximus XI Gene BIOS walkthrough. - YouTube )
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
  • 0021 (OC BIOS, New Sammy A2 Profiles, need to be logged in @ HWBOT Forums to download)
  • 0050 (OC BIOS, allows BCLK change with OC PANEL)
  • 0093 (OC BIOS, allow higher voltages without LN2 mode, need to be logged in @ HWBOT Forums to download)
  • 0057 (3rd OC BIOS, improves a2 dimms overclocking)
  • 0044 (2nd OC BIOS, some memory related fixes vs 0084)
  • 0084 (1st OC BIOS for short-traced DIMMs such as G.Skill RGB or Galax based A2-pcb)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
  • Hersteller Modell @ Preisvergleich | Quelle | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller Modell @ Preisvergleich | Quelle | inkompatibel | Grund/Foto(s)
  • --> Bitte helft mit sammeln!
2) RAM
ASUS Memory QVL (PDF).
attachment.php
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
  • RAM OC MemOK per SChalter auf dem Board deaktiiveren beim RAM OC
  • ASMedia USB 3(.1) Treiber in das Windows 7 Image integrieren oder P/S2 Tastatur verwenden und die Treiber von einer angeschlossenen Festplatte installieren. Alternativ einen PCIe USB Controller verwenden, der nativ unterstützt wird.
4) FAQ - Frequently Asked Questions
  • Q: Wie exakt wird die Vcore per Software ausgelesen?
  • A: Elmor hat dies so erklärt:
    Elmor schrieb:
    A note on voltage reporting on the Maximus XI-series, and voltage measurements in general. Like on Crosshair VII Hero, we've improved the SIO voltage readings for better accuracy. The CPU Core Voltage is now reading very close to the voltage the CPU is getting. Applied voltages and load-line levels are comparable to before, but not the software voltage readings.
    When measuring voltages on a motherboard and large currents are involved, it's important to use accurate measurement points due to resistance/impedance present on the board. The power plane for example can be modeled as a resistor connected in series between the VRM output and the target device, together with Ohm's law, U = R*I. The larger the current, the larger the voltage drop. If you measure the voltage at the VRM output, for example at the inductor, you'll see a large difference compared to the voltage measured at the CPU socket MLCC. What we're interested in is what voltage the CPU die is actually getting after passing through the output filter, power plane, socket and package.
    The Super I/O controller is used by BIOS/AiSuite/CPU-Z/HWInfo/AIDA64 for reading most voltages, temperatures and fan speeds. Its single-ended ADC inputs measure the input voltage referenced to the local SIO ground. With increased VRM output currents, this reading will be more and more inaccurate. We've added a circuit for measuring the differential CPU-die sense and converting it to a single-ended signal to the SIO. The CPU-die sense is accessible through two dedicated pins on the CPU, and are routed to the supply and ground on the CPU die itself. It's typically used by the CPU VRM controller for output voltage control.
    Something to look out for is when you're seeing a voltage reported during load which is much higher than what you've set. It would require a negative load-line which is just not supported on any controller as far as I know. At 0 mOhm load-line, you get exactly what you set (Level 8 on M11).
    The resulting difference can be seen in the graph below.
    Prime95 26.6 12K FFTs
    Manual Mode Voltage = Voltage set in BIOS
    CPU-die Sense = DMM measurement of the CPU die-sense pins, "true" CPU Core Voltage
    Socket MLCC = DMM measurement of the capacitors at the back of the socket
    SIO (traditional) = Software reading with standard SIO voltage sense circuit
    SIO (Maximus XI Hero) = Software reading with the improved SIO voltage sense circuit
  • Q: Das Bluetooth funktionert mit den ASUS Treibern nicht. Gibt es dafür eine Lösung?
  • A: Mit den original Intel Treibern v20.70.0.4 gibt es laut Low keine Probleme (Download).
  • Q: Meine Tastatur wird beim Systemstart nicht rechtzeitig initialisiert. Wie komme ich ins UEFI?
  • A: Die einfachste Möglichkeit ist es, wie im Handbuch beschrieben die Reset Taste dafür zu verwenden. Wer keine Taste mehr dafür an seinem Gehäuse hat, kann auch den Onboard Button verwenden. Für wen weder das Eine noch das Andere in Frage kommt, der kann alternativ auch einen Start ins UEFI mit dem Power Button erzwingen (siehe Handbuch Seite 3-2 "Entering BIOS Setup after POST").
  • Q: Wie sind die einzelnen M.2 Steckplätze genau angebunden?
  • A: Die beiden auf dem DIMM.2 Modul, teilen sich PCIe Lanes von der CPU mit dem PEG. Wenn das DIMM.2 verwendet wird, reduziert sich dessen Anbindung auf x8. Die beiden Steckpätze auf dem MAinboard selbst sind mit PCIe Lanes vom Chipsatz angebunden. Man hat also die frei Wahl, was einem wichtiger ist (Storage/GPU-Performance).
  • Q: Was ist der Unterschied zwischen XMP-1 und XMP2? Mein Kit sollte eigentlich gar kein zweites XMP besitzen.
  • A: ASUS hat den Z390 Modellen eine Funktion spendiert, die statt dem originalen XMP des RAM-Hertellers (XMP-2), von ASUS optmierte Einstellungen verwendet (XMP-1). In der Regel ist XMP-1 zu bevorzugen und etwas performanter, im Fall von Performance- oder Stabilitätsproblemen, empfiehlt es sich aber auf XMP-2 auszuweichen.
    Silent Scone@ASUS schrieb:
    On Z390, there is now the option to use the DIMM profile which is XMP II. These settings are not validated, so mileage will vary depending on the kit and CPU.
    XMP I - Board optimised timings
    XMP II - Default XMP timings
    Often, XMP II timings will be slightly looser depending on the memory kit. If you check within the UEFI or memtweakit, you'll see a difference in memory subsets.
  • Q: Wie stelle ich die RTL/IOL richtig ein?
  • A: Dazu hat swdtechnik eine Anleitung im Coffee Lake RAM OC Thread gepostet:
    Nun wegen RTL`s und IO-L`s und wie man steuern bzw. beeinflussen kann:
    wir gehen ins Bios und setzen MRC Fast Boot auf [Disabled]
    (wenn Modulen B-Die A2 sind dann zusätzlich noch Trace Centering auf [Enabled])
    dann MCH Full Check auf [Enabled]
    dazu noch Round Trip Latency auf [Enabled]
    noch müssen wir folgende Settings unbedingt auf diese Werte setzen :
    DRAM RTL INIT value [x Wert]
    DRAM RTL (CHA DIMM0 Rank0) [Auto]
    DRAM RTL (CHA DIMM0 Rank1) [Auto]
    DRAM RTL (CHA DIMM1 Rank0) [Auto]
    DRAM RTL (CHA DIMM1 Rank1) [Auto]
    DRAM RTL (CHB DIMM0 Rank0) [Auto]
    DRAM RTL (CHB DIMM0 Rank1) [Auto]
    DRAM RTL (CHB DIMM1 Rank0) [Auto]
    DRAM RTL (CHB DIMM1 Rank1) [Auto]
    DRAM IOL (CHA DIMM0 Rank0) [Auto]
    DRAM IOL (CHA DIMM0 Rank1) [Auto]
    DRAM IOL (CHA DIMM1 Rank0) [Auto]
    DRAM IOL (CHA DIMM1 Rank1) [Auto]
    DRAM IOL (CHB DIMM0 Rank0) [Auto]
    DRAM IOL (CHB DIMM0 Rank1) [Auto]
    DRAM IOL (CHB DIMM1 Rank0) [Auto]
    DRAM IOL (CHB DIMM1 Rank1) [Auto]
    CHA IO_Latency_offset [21]
    CHB IO_Latency_offset [21]
    CHA RFR delay [14]
    CHB RFR delay [14]
    den DRAM RTL INIT value [x Wert] rechnen wir mit : (euer tCAS x 2) + IO-L bzw. 4 + IOL Offset bzw. 21 + 10
    Jetzt wo alles eingestellt, speichern und Neustarten!
    Wenn bootet wieder ins Bios und NUR DRAM RTL INIT value auf eine Zahl runter setzen, speichern und Neustarten!
    Und nun so weiter wiederholen mit DRAM RTL INIT value Senkung bis nicht mehr bootet.
    Nun haben wir irgendwann Punkt erreicht wo es nicht mehr bootet, dann Power Knopf 5 Sek. lang halten
    Rechner geht dann aus.
    Wieder Start Knopf drücken, mit F1 ins Bios landen und DRAM RTL INIT value auf den letzten funktionierenden Wert setzen, speichern und Neustarten und ins Windows booten lassen.
    So, sind wir im Windows,
    Starten nun und ASRock Timing Configurator Programm und schauen auf unsere IO-L´s an!
    Die werden im Idealfall gleich sein 7-7 oder 6-6 also, wenn nicht (was am meisten der Fall ist) zbsp. 7-6 oder 6-7 oder 7-13 oder 11-7 oder was auch immer,
    dann alles was wir nun brauchen ist nur auf unser Channel A or Channel B, schauen bei dem IOL Wert falsch ist.
    Beispiel:
    euer letzte ermittelte bootfähige DRAM RTL INIT value Wert ist 68 <---- nur für Beispiel genommene Zahl <---
    dabei hat es folgende RTL/IO-L Kombo bei euer DRAM RTL INIT value 68 trainiert
    62-63-6-7
    aber wir wollen natürlich unsere Werte auf 62-63-6-6 haben
    dann alles was wir nun brauchen ist:
    ins Bios gehen und unser CHB IO_Latency_offset auf von 21 auf [22] setzen weil genau da unser IO-L nicht stimmt! , speichern und Neustarten.
    Nun wird es 62-63-6-6 sein.
    Wollen wir mal unser RTL/IO-L Werte beispielweise auf 62-63-5-5 haben
    dann gehen wir ins Bios und erhöhen unser DRAM RTL INIT value Wert um eins höher UND NOCH beide CHA IO_Latency_offset / CHB IO_Latency_offset auch um eins höher., nun speichern und Neustarten.
    Schon wird es dann 62-63-5-5 sein!
    Falls jemand noch Fragen hat, einfach melden ;)
    P.S. - Was aber komisch oder ein Bug von ASRock Timing Configurator Tool ist - manch mal werden die Änderungen von CH IO_Latency_offset im ASRock Timing Configurator Tool nicht angezeigt (oder es ist nur bei mir so das ASRock Tool spinnt), das Asus MemTweakIt dagegen zeigt die Änderungen immer korrekt an (im Reiter "Timings 4" zusehen).
  • --> Deine Frage hier!
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
[Sammelthread] ASUS ROG Maximus XI Apex (90MB0XV0-M0EAY0)
Reviews
  • 0021 (OC BIOS, New Sammy A2 Profiles)
  • 0093 (OC BIOS, allows higher voltages without LN2 switch)
  • 0033 (early OC BIOS)
Dancops ApeXI Guide (Samsung 8Gbit B-Die SR/A2): ROG Maximus XI APEX - NEW BIOS PROFILES small guide @ HWBOT Community Forums
M11G_01.jpg M11G_02.jpg M11G_03.jpg M11G_3D.jpg M11G_2D.jpg M11G_BP.jpg M11G_BP2.jpg M11G_3D500.jpg M11G_2D2.jpg M11G_2D500.jpg M11G_3D2.jpg ASUS ROG Maximus XI Gene QVL.png
RAM OC ist nix für kleine Kinder. Nee, mal im Ernst entweder das 4133er 16GB Kit ist richtig mies oder du hast einen groben Schnitzer bei der Konfiguration.
Am besten XMP mal ganz weg lassen und dann auf dem Gene sich durchkämpfen.
Im Coffee Lake RAM OC Thread wird dir geholfen!
Entweder einfach mal die Settings dort abklopfen, Mode 2 setzen oder wenn das schon nach böhmischen Dörfern klingt, schicke ich dir paar Bios Screenshots.
Auf dem Board aber zu er mal die Memory Okay Funktion ausschalten... und VDimm auf 1,45v setzen und unter tweaker paradise die eventual VDimm auf 1,485v oder 1,5v.
IO=1,28 und SA=1,3v
Dann sind schon mal ein paar Eckpfeiler fest...
Wie hängt denn der Bios Fehler 23 zusammen? Hatte eben ein Absturz aufgrund zu hohe CPU Temperatur(vermutlich VPP755 abgestürzt/kabelwackler). Seitdem bekomme ich bei +3600MHz Fehler 23 mit Bios 0805. Bei der Aktion ging auch meine Soundkarte hops ;(
23 heißt nur das er den Ram nicht trainiert bekommt. Würde einfach mal einen Bios reset machen und einmal alles neu einstellen.
Nur weil die CPU einmal zu warm wird, sollte ja nicht direkt was essig sein. Nicht das es deinen IMC erwischt hat oO.
Hat funktioniert :). IMC und CPU gehen so schnell nicht kaputt. Ist ja nicht meine erste VPP755 (3.). Hatte nach dem re-install von Windows vergessen die Aquasuite Alarme anzuschalten.
Frage an die ASUS XI User.
Ich bin gerade dabei die Boot Zeit etwas zu optimieren.
Welche Startzeiten habt ihr?
Am einfachsten vielleicht, indem ihr im Tastmanager die letzte Bootzeit nachguckt?!
Danke schon mal vorab.
Da Wheity im ASUS Support Unterforum ein entsprechendes Angebot gemacht hat, wollen wir das 2x16GB Problem der neueren BIOS Versionen beim Gene mal gemeinsam angehen?
Damit das Ganze gesittet abläuft und möglichst zielführend ist, bräuchte von euch folgende Infos:
1) Welche Kits sind betroffen/wurden getestet? Hier wären vor allem Modelle interessant, welche sich auch auf der QVL befinden (CMK32GX4M2F4000C19, F4-4000C19D-32GTZSW, F4-4000C19D-32GTZKK).
2) Wie äußert sich das Problem genau? Möglichst detaillierte Beschreibungen des Verhaltens beim POST (mit XMP/manuellem OC, ggf mit Video auf YT).
3) Welches ist die letzte nicht betroffene BIOS Version? Vermutlich ja 0602, es wäre in dem Zusammenhang aber gut, wenn auch noch mal jemand 0702 prüfen könnte.
4) Mit welchen BIOS Versionen wurde das Problem von euch verifiziert? Hier sind vermutlich vor allem die letzten drei Releases für den Support interessant.
( 5) Zur Sicherheit weil die Frage vermutlich kommen wird: Mit welchen Prozessor Modellen und welcher Kühlung wurde getestet? )
Ich werde die Informationen dann kompilieren, einen entsprechenden Thread im Support Sub erstellen und diesen auch hier verlinken.
Jetzt erst gesehen.
Gskill F4-3200C15D-32GTZ läuft auf 4000mhz stabil mit Bios 0602 0702 0805 auf dem Gene XI. Ab 0903 klappt es nicht mehr mit dem OC. Die genaue Fehlermeldung habe ich mir nicht notiert. Grundsätzlich laufen keine 2x16gb auf mehr als ~3733mhz bei niemandem. Jedenfalls habe ich im Netz keinen Screenshot mit zb. Bios 1302 finden können, der 2x16gb mit 4000-4200mhz betreiben kann. Einmal hat der Rechner mit 4000Mhz CL19 gebootet.
Das andere Problem ist der 23 Fehler beim Warmstart, der hin und wieder vorkommt, wenn man die IOLs und RTLs manuell aus den trainierten Werten einfach manuell einträgt.
Dem kann ich mich in etwa anschließen. Hab allerdings das Bios 0805 nie verwendet. Ab 0903 ist aber Müll, was 2x16GB in hohen Taktraten und Timings angeht.
XMP kann ich immer laden und booten, hab dafür aber auch teure 2x16GB 4000C19 Riegel, egal mit welchem Bios. Will ich dann höher Takten oder Timings verändern, muss ich 0602 oder 0702 verwenden. Sonst endet es im klassischen 23 oder 55. Hatte aber auch schon 00 was überhaupt keinen Sinn ergibt.
Fehlerbild ist eigentlich immer das selbe, dass er mit den neuen BIOS ab 0903 überhaupt nicht mal mehr die Primären Timings trainiert bekommt. Einfaches Beispiel setze ich bei Bios 0602, 4000-16-17-34 ohne weitere Anpassungen Rest Auto bootet er sofort, ab 0903 bootet nicht mal 3900-16-17-34, 4000MHz ganz zu schweigen.
Problem mit dem Warmstart kann ich ebenfalls bestätigen, wie Low beschreibt. Des weiteren haben hier viele das Problem, dass RTL/IO Auto trainiert booten. Wenn diese, genau die gleichen Auto trainierten Werte nun Fixed eingetragen werden, -> 23 kein Boot mehr möglich
Das Thema 23 hatten wir im RAM Thread die Tage schon besprochen.
Rauwman hatte dazu geschrieben:
Das Problem hatte ich auch..... aber im Startbeitrag steht was von swdtechnik.
Geh davon aus er trainiert zbsp 63-65-6-7 daraus machst du dann 64-65-7-7. Sollte er stattdessen 63-65-7-6 machen, machste 63-66-7-7. Danach lief es bei mir.
Half bei mir zumindest bisher.
Und Bootzeit bis ins Windows ist jetzt super mit 8.5 Sek.
Fastboot in Bios und Windows ist wegen der Fehler deaktiviert. Aber auch MCH Fastboot beim Speicher ist aus.
XMP kann ich immer laden und booten, hab dafür aber auch teure 2x16GB 4000C19 Riegel, egal mit welchem Bios. Will ich dann höher Takten oder Timings verändern, muss ich 0602 oder 0702 verwenden. Sonst endet es im klassischen 23 oder 55. Hatte aber auch schon 00 was überhaupt keinen Sinn ergibt. Fehlerbild ist eigentlich immer das selbe, dass er mit den neuen BIOS ab 0903 überhaupt nicht mal mehr die Primären Timings trainiert bekommt. Einfaches Beispiel setze ich bei Bios 0602, 4000-16-17-34 ohne weitere Anpassungen Rest Auto bootet er sofort, ab 0903 bootet nicht mal 3900-16-17-34, 4000MHz ganz zu schweigen.
Danke für euer Feedback. Dann werde ich das wohl mal angehen. Ein 2x16GB Kit um das zu verfizieren ist schon auf dem Weg.
Weiteres Feedback und Ergänzungen sind willkommen und bitte gebt auch immer das Modell eures Speichers mit an (weil der ASUS Support 110% danach fragen wird).
Moin, also das ist mein Speicher F4-4000C19D-32GTZSW
Steht auch auf der aktuellen QVL Liste von ASUS drauf
Und 2x16GB kostet nerven :shot:
Ok gut, dann ist es schon mal ein anderes als bei mir. Die Royals sollten auch A2 PCB haben, so dass wir auch das abhaken können.
Naja, alles noch ganz entspannt im Vergleich zu RAM-OC auf AMD Plattformen ;)
Ach bei den neuen 5000Mhz XMP und ab gehts :d
Sicher das die Royals das selbe Board haben?
Wieso das selbe, deine SW sind doch sicherlich A1?
Also können wir das Problem für beide PCBs belegen.
Keine Ahnung welches pcb die haben. Vermutlich aber ja
So mein 4000er Royals sind da und auch schon verbaut. Hab im Moment allerdings noch das 0093 drauf. Werde die Riegel damit vor dem Update noch schnell auf OC testen und ein paar Screenshots erstellen.
Sehr cool, Spannung steigt :bigok:
Was würdet ihr sagen bei dem "XI Gene" bis wie viel Ohm Kopfhörer kann man die Soundkarte benutzen ohne das man auf ein externen Verstärker/Dac greifen muss/sollte ?
Das ist eine sehr relative Frage, Frage ist eher, was du vom Sound erwartest. Ich kann auch meinen Beyer T1 600Ohm an mein iPhone hängen, geht aber ist nicht cool.
So kurzer erster Test vor dem Feierabend:
0093 Optimized Defaults + XMP-II, Tweak AUTO, DDR4-4133 17-18-18-37 360 1.4V Rest AUTO
G.Skill F4-4000C19D-32GTRS @ DDR4-4133 17-18-18-37 2T 360 XMP II MemTweak AUTO 0093 32M AidaMEM .png
Mach morgen dann weiter mit 0602 und einer aktuellen BIOS Version.
Eigentlich sollte da ein DT 990 250 Ohm oder ein 600er falls es sinn macht für fps shooter und musik/filme, da war halt die frage ob 250 oder 600..onboard sound oder sowas wie FiiO E10K Olympus 2
Hey zusammen,
welches ist denn für das APEX XI das beste Bios wenn's um Ram OC bei 2x16GB Bdie Riegeln geht?
Danke & LG
Hehe... genau darüber wird die ganze Zeit diskutiert.
Für das Gene gibt es ja das 0602, für das Apex wäre mir aber kein "identisches" Bios bekannt..?
LG
Perfekt, danke!
Ist aber ein BETA, das passt dennoch, oder?
LG
0802 ist eine Beta. Mein Apex läuft auf 0805 auf 2x16GB 4000MHZ. Könnte Beta und Release Version zeit. Der Zeitstempel von Asus kann aber nicht stimmen.
Version 0805
22.02.2019
Version 0401
11.01.2019
Version 0802 Beta Version
10.01.2019
Gibt es eine Möglichkeit die LED Start/Reset vom Board irgendwie auszuschalten? Ich würde das Gehäuse gerne auf den Tisch stellen.
Danke, das meine läuft nun mit dem 0802 auch auf 2x16GB 4000MHZ, das ging mit dem aktuellen Bios so garnicht..
Viel auf Stabilität hab ich aber noch nicht getestet..
LG
Die aktuellen kannst du einfach vergessen, mit 2x16GB. Egal ob Gene oder Apex. Werden aber als die besten 2x16GB Boards von allen verkauft, nur mit alten Bios Versionen Hust
Jungs bald kommt was (exakt für 2x16Gb Memory), wird laut Asus Antwort grad getestet.
