***Sapphire PURE PI-A9RX480*** - ATI Xpress200 Sammelthread
$ilver
Banned
Als erstes mal etwas zu den ATI Chipsets
<table class="resulttable" border="1" cellpadding="5" cellspacing="0"> <tbody><tr><th colspan="2">Sapphire PURE Innovation PI-A9RX480</th></tr><tr><th>Processor</th><td>AMD Athlon64 / FX Socket 939</td></tr><tr><th>FSB</th><td>800 MHz / 1000+ MHz</td></tr><tr><th>Chipset</th><td>ATI RADEON XPRESS 200 (RX480 + SB450)</td></tr><tr><th>Memory</th><td>4x 184 Pin DDR, Dual Channel DDR266/333/400, up to 4 GB</td></tr><tr><th>BIOS</th><td>AwardBios</td></tr><tr><th>Slots</th><td>1x PCI-E x16
2x PCI-E x1
2x PCI</td></tr><tr><th>HDD Connectivity</th><td>2x ATA-133
4x SATA, 2x SATA-II</td></tr><tr><th>Networking</th><td>10/100/1000 Mbps - Marvell 88E852 via PCI-Express</td></tr><tr><th>Ports</th><td>8x USB 2.0 (4 on Back Panel)
2x IEEE1394 (1 on Back Panel)</td></tr><tr><th>Audio</th><td>8 Channel Realtek ALC880 Audio, SPDIF</td></tr><tr><th>Form Factor</th><td>ATX 305 x 244mm</td></tr></tbody> </table>
Infos direkt von Sapphire
Chipset
  • ATI RX480 x SB450 Chipset
Processor
  • Support for AMD K8 Processor in Socket939 package
  • Support Hypertransport Interface bus
VRM (Voltage Regulator Modules) on Board
  • Flexible motherboard design with on board VRM, easy to upgrade with future AMD K8 processors
  • 0.800V to 1.55V in 25 mV steps
System Memory
  • A total of four 184-pin DDR RAM sockets
  • DIMM size support from 64MB to 2GB
  • Suppot of dual channel 128-bit wide memory interface
  • Support of 266/333/400 DDR RAM memory type
System BIOS
  • PnP, APM, ATAPI and Windows 2000/XP
  • Full support of ACPI & DMI
  • Auto detects and supports LBA harddisks with capacities over 160GB
  • Easy to upgrade BIOS
Plug and Play
  • Supports Plug and Play specification 1.1
  • Plug and Play for Windows 2000 and XP
  • Fully assignable PCI interrupts
Onboard I/O
  • Onboard two PCI fast IDE ports supporting up to four ATA, ATA2, Ultra ATA33/66/100/133 IDE HDDs, CD-Roms, ZIP drives and LS-120 drives as boot drive
  • One floppy port supports two FDD of 360KB, 720KB, 1.2MB, 1.44MB and 2.88MB capacity
  • Eight USB ports (four ports via two headers)
  • PS/2 keyboard connector
  • PS/2 mouse connector
  • One front panel sound connector
Extended USB Support
  • Includes 2 OHCI host controllers, increasing the number of external ports to eight
  • Includes 1 OHCI USB2.0 host ontroller that supports all eight ports (Bandwidth shared between eight ports)
  • This motherboard supports USB 2.0 feature only on Windows 2000 (with SP4 or above) and XP (with SP1 or above) OS.
Onboard Marvell 88E8052 PCI Express Gigabit LAN
  • Full compliance with IEEE 802.3u 100 Base-T specifications and IEEE 802.3X Full Duplex Flow Control
  • Supports 10 Mb/s, 100 Mb/s and 1000 Mb/s operation
  • Supports Wake-On-LAN function and remote wake-up
PCI Express x16 Graphics Interface
  • One 16-lane (x16 port) PCI Express port intended for external graphics
  • Full compliant to the PCI Express Base Specification Revision 11.0a
  • The base PCI Express frequency of this interface is 4 GB/s
  • PCI Express supports an enhanced addressing mechanism
  • An optional ADD2 card can utilize PCI Express Graphics x16 connection
PCI Express x1 Ports
  • Two 1-lane (x1 port) PCI Express port intended for external graphics
  • Fully compliant to the PCI Express Base Specification revision 1.0a
  • Two virtual channel support for full unsynchronized data transfers
  • Supports full 2.5 Gb/s bandwidth in each direction per x1 lane
Power Management
  • Supports SMM, APM and ACPI
  • Break switch for instant suspend/resume on system operations
  • Energy star "Green PC" compliant
  • Hardware monitoring circuit is supported, provide voltage, fan speed etc. monitoring
  • Wake-On-LAN (WOL) support
  • Supports Suspend-To-RAM (STR)
Onboard ALC880 7.1 audio
  • Integrated Realtek ALC880 controller
  • Fully Sound and Sound Blaster compatible
  • Full-Duplex 4 24-bit two-channel DACs and 3 stereo 20-bit ADCs
  • PnP and APM 1.2 support
  • Windows 2000/XP drivers ready
  • Line-In, Line-out, Mic-in, SPDIF-in, SPDIF-out
  • Supports ALC880 codec for eight channel sound output
Onboard IEEE1394
  • Compliant with IEEE1394 OHCI specifications v1.0 and v1.1
  • Integrated 400Mb 2-port PHY
Onboard Serial ATA Host Controller
  • Independant DMA operation on four ports
  • Data transfer rates of 150 MB/s
  • RAID 0/1 feature support
Onboard Serial ATA-II Host Controller
  • Data transfer rates of 300 MB/s
Expansion Slots
  • 1 PCI Express x16 slot
  • 2 PCI Express x1 slots
  • 2 PCI bus master slots - ver. 2.2 compliant
Bilder
Hat auch wieder Power/Reset direkt auf dem Board
So ziemlich jeder Chip , den man Aktiv/Passiv/Wakü Technisch kühlen kann hat Mounting Holes in der Nähe :bigok:
Infos/Pics by techpowerup.com und anandtech ;)
Das Board sieht ja mal hammer aus, viel besser als das Fatal1ty find ich.
ma gucken, die Voltages stimmen auch :), nur mal abwarten wie so die Performance ist.
ne Überlegung isses auf jeden Fall
schau dir das Review von Techpowerup an .. überall schneller als das DFI .. vorallem @ SupI 1M .. 0,5secs schneller :drool:
Für das Board braucht man ja ein Plexi-Case!
Sonst sieht man ja den schönen Rücken nicht! ;)
Schaut aber mal sehr interessant aus, mal sehen wie es sich dann in der Praxis schlägt.
bin auf das board auch mal gespannt, will nämlich auf jedenfall nen crossfire fähiges mb
der hat ja nicht die ULi-SB wenn ichs richtig sehe - mal schaun ob die dann konkurenzfähig ist, weil die ULi hat in dem anandtech preview einiges gezeigt..
Alter heftig sieht das geil aus :hail::hail::hail: *sabber*
da is die 3nasen halterung
@Kaiser: weil HIER alle Infos gesammelt sind
Da könnt ich schwach werden die optik ist ja wohl :love:
wenn jetzt noch die performance stimmt :hail:
ich sag zu performance nur eins .. bei gleichem takt teilweise schon nen großen tacken schneller als das DFI
man muss sagen bei dfi sind alle alpha timings beim vergleich auf auto.
Das board hat KEIN hardware monitoring und wird 160 - 170 eur kosten ... also viel zu teuer. Bios ist überhaupt noch nicht ausgereift... atm gehen nur 1.55V vcore ...
und 3.3 und 12v auf den löchern neben der cpu ... 1a =)
preis leistung is grottig, board is ganz ok ... aber dfi wird king bleiben.
hardwaremonitoring ?
d.h. keine temps,etc auslesbar @ win oder was willste mir damit sagen ?
das wäre nen grober schnetzer und würde das board zu 100% uninteressant machen
KEINE CPU TEMP... weder im BIOS noch im Windows ;)
NOTabschaltung sollte durch cpuvrm gehn, aber es hat nichts mit der cpu temperatur zu tun... überhaupt garnichts ;)
http://www.techpowerup.com/reviews/Sapphire/Gruper/images/b_monitoring.jpg
und wenn man das bild anschaut bekommt man zuviel....
bzw http://www.techpowerup.com/reviews/Sapphire/Gruper/images/33v.jpg
Hallo lesen steht oben
Power Management
Power Management
cpu temp fehlt trotzdem ;)
vielleicht bei den beta biosen... beim final wirds ziemlich sicher da sein, da das board nur den wert der diode vom A64 lesen muss... und dass ist net wirklich schwer...
nein eben nicht. ist hardwaresache, und das haben die enginees verpeilt ;) ich hab da so meine quellen =) also wenns das board geben wird kommech auch an beta bios zeugs etc ran ...
t-bone schrieb:
sehe ich das richtig, das an den befestigungslöchern jeweils 12V und 3V anliegen???
wie gehtn sowas? Das is doch gefährlich oder nich?
genau so ist das ;)
sehr schade .. kannste mir sagen ob das mobo @tpu review nen vorserienmodell oder schon feddich war ?
sample halt ... denke vorserie, aber cpu temp kommt nicht. das mit der spannung an den löchern soll gefixt werden.
