[Sammelthread] MSI Big Bang XPower II MS-7737 (X79)
MSI Big Bang XPower II (MS-7737)
LGA2011 / Intel X79
Produktlink: MSI Big Bang Xpower II | MSI Microsite
Preisvergleich: MSI Big Bang XPower II (gelistet ab 360,- Euro, Stand 12.01.2012)​
Spezifikationen & Ausstattung
  • Processor Support
    • LGA 2011 Socket
    • Second Generation Core i7 Models
  • Chipset
    • Intel X79, PLX PEX8608, ASMedia ASM1480
  • Memory Support
    • 8x DDR3 DIMM, bis zu 128GB
    • DDR3-1066 / 1333 / 1600 / 1866 (OC) / 2133 (OC) / 2400 (OC)
    • XMP Profiles
    • Quad Channel
  • Networking
    • Intel 82579V GbE LAN (10/100/1000)
    • Intel 82574L GbE LAN (10/100/1000)
  • IEEE 1394 (Firewire)
    • VIA VT6315N
    • 1x IEEE 1394 extern (Backpanel)
    • 1x IEEE 1394 intern
  • Audio
    • Creative Soundblaster X-Fi MB2 (Realtek ALC892 ALC898)
    • 8 Channel HD Audio & Jack Sensing
    • EAX Advanced HD 5.0
    • THX TruStudio Pro
  • SATA
    • 4x SATA-II (SATA3~6, Intel X79)
    • 2x SATA-III (SATA1~2, Intel X79)
    • 4x SATA-III (SATA7~10, ASMedia 1061)
    • RAID
      • Intel Matrix Storage Technology (SATA1~6)
      • Modes: AHCI, RAID 0 / 1 / 5 / 10 (Intel X79)
  • USB 3.0
    • 1x USB 3.0 intern (NEC D720200)
    • 4x USB 3.0 extern (NEC D720200)
  • Multi-BIOS II
    • 2+1 Chips (1x socketed), graphical UEFI (Click BIOS II)
    • Windows Interface
  • Form Factor
    • XL-ATX
    • 345mm x 264mm ( L x W )
Connectors & Buttons
  • Back panel
    • 1x PS/2 Keyboard / Mouse
    • Clear CMOS Button
    • 1x Coaxial S/PDIF-Out
    • 1x Optical S/PDIF-Out
    • 1x IEEE 1394
    • 4x USB 3.0
    • 6x USB 2.0
    • 2x RJ45
    • 6x Audio
  • On-Board
    • 3x USB 2.0 Pin Header
    • USB 3.0 Pin Header
    • IEEE 1394 Pin Header
    • Chassis Intrusion
    • S/PDIF-Out (3pin)
    • Front Panel Audio
    • Debug LED
    • Voice Genie connector (optional)
    • MultiConnect Panel connector (optional)
    • Power button
    • Reset button
    • OC Genie button
    • Multi BIOS button
    • Base clock buttons
    • Over-Voltage Switch
    • Voltage Check Point Set
    • 4x PCI-E CeaseFire Switches
    • 1x Multi-BIOS Button
    • 1x OC Genie Button
    • 1x Reset Button
    • 1x Power Button
Mainboard - schematisch
Backpanel
Features (Links werden nachgetragen)
  • Nvidia 4-Way SLI (Anbindung: 16+8+8+8 PCIe 3.0 Lanes, Quelle: Preisvergleich)
  • AMD Quad CrossfireX (Anbindung: 16+8+8+8 PCIe 3.0 Lanes, Quelle: Preisvergleich)
  • MSI APS (Active Phase Switching)
  • MSI Winki 3 (Quick Boot OS, feat. Browser, Messenger, Office, Backup...)
  • MSI OC Dashboard
  • MSI OC Genie II (CPU & Memory)
  • MSI V-Switch (Overvoltage Switch)
  • MSI PCIe CeaseFire Switch (PEG Control, Disable/Enable)
  • MSI Super Charger (bis zu 1.5A, iPhone, iPad, Smartphones, auch in S1/3/4/5)
  • MSI Superpipe (8mm Heatpipe)
  • MSI Control Center II (feat. Instant OC)
  • MSI Military Class II (Microsite)
    • getestet nach MIL-STD-810G
      1) Temperature Shock Test – MIL-STD-810G Method 503.5
      2) Humidity Test - MIL-STD-810G Method 507.5
      3) Vibration Test - MIL-STD-810G Method 514.6
      4) Low Pressure test - MIL-STD-810G Method 500.5
      5) High Temperature Test - MIL-STD-810G Method 501.5
      6) Low Temperature Test - MIL-STD-810G Method 502.5
      7) Shock Test - MIL-STD-810G Method 516.6
    • Next-Gen DrMOS
      • Renesas 20655 Driver Mosfets
      • 22x Phasen für CPU
      • maximale Belastbarkeit ~ 770 Watt
    • Super Ferrite Chokes (SFC)
    • Tantalum Hi-C Caps (CPU, Memory, PCH)
    • Aluminium Solid Caps (restliches Board)
  • Phase LED (for CPU, Memory, PCH, VTT, SA)
Lieferumfang & Zubehör
  • Mainboard
  • Datenträger Treiber & Utilities
  • Handbuch (PDF-Download)
  • Software Application Users Guide
  • Quick Installation Guide
  • Quick Reference Guide
  • 6x SATA cables
  • I/O Shield
  • V-Check Probes
  • USB3 Slotblende, Front-USB3 Adapter
  • eSATA Dual Slotblende (mit 2x eSATA Stromkabel)
  • 3x SLI-Bridges (ein mal extra lang)
  • CrossFireX Brücke
  • M-Connector
  • MSI X79 Overclocking Guide
Click BIOS / UEFI (Updates, Einstellungen, Bilder)
Updates: MSI Downloads
BETA Thread @ MSI-Forum: BETA-UEFI/BIOS-Versionen [E7737IMS.1xx-Releases]
Verfügbare Spannungseinstellungen:
  • CPU Core Voltage
  • System Agent Voltage (SA)
  • CPU I/O Voltage
  • CPU PLL Voltage
  • DDR CH_A/B Voltage
  • DDR CH_C/D Voltage
  • DDR CH_A CA Vref Voltage
  • DDR CH_B CA Vref Voltage
  • DDR CH_C CA Vref Voltage
  • DDR CH_D CA Vref Voltage
  • DDR CH_A DQ Vref Voltage
  • DDR CH_B DQ Vref Voltage
  • DDR CH_C DQ Vref Voltage
  • DDR CH_D DQ Vref Voltage
  • PCH 1.1 Voltage
  • PCH 1.5 Voltage
Optik
Reviews, News, Links
Kompatibilitätslisten
1) CPU-Kühler
  • Corsair H100 (Review: Vortez)
  • Noctua NH-D14 SE2011 (User: Dragon667)
  • Phanteks PH-TC14PE (User: DragonClaVV)
  • Wakühler: MSI XpowerII XSPC WaterBlock Set (14541) @ Aquatuning
  • INKOMPATIBEL Prolimatech Armageddon (User: Dragon667 - kolidiert mit Kühlkörpern)
  • INKOMPATIBEL Zalman CNPS 12X (User: Mac78 - kolidiert mit Kühlkörpern)
2) Arbeitsspeicher
  • 16GB G.Skill RipJawsZ DDR3-2133 CL9 Quad Kit (F3-17000CL9Q-16GBZH) (Review: Guru3d)
  • 16GB Corsair Vengeance Black DDR3-1866 CL9 Quad Kit (CMZ16GX3M4X1866C9) (Review: Hardware Heaven)
  • 16GB Corsair Vengeance Red DDR3-1866 CL9 Quad Kit (CMZ16GX3M4X1866C9R) (Review: Vortez)
  • 16GB G.Skill Sniper DDR3-1866 CL9 Quad Kit (F3-14900CL9Q-16GBSR) (Review: Overclockers)
  • 16GB G.Skill RipJaws-X DDR3-1866 CL9 Quad Kit (F3-14900CL9Q-16GBXL) (User: J1nX3rS)
  • 16GB G.Skill Ares DDR3-1600 CL9 Quad Kit (F3-1600C9Q-16GAO) (User: ElitePilot)
  • 8GB Corsair Vengeance LP weiß DDR3L-1600 CL9 Dual Kit (CML8GX3M2A1600C9W) (User: J1nX3rS)
3) Gehäuse (weitere Vorschläge willkommen!)
  • AeroCool Strike-X ST
  • Aerocool XPredator (User: Dragon667)
  • Antec Eleven Hundred
  • Antec P280
  • Akasa VenomToxic (AK-TOX-01BK)
  • BitFenix Shinobi XL
  • Cooler Master Cosmos II (RC-1200-KKN1)
  • Coolermaster HAF X (RC-942-KKN1)
  • Cooler Master CM Storm Trooper (SGC-5000-KKN1-GP)
  • Cubitek HPTX-Tank
  • Cubitek XL-Tank
  • HEC 98 R9BB
  • Mountain Mods Ascension*7
  • Nox Hummer USB 3.0
  • NZXT Switch 810
  • Lian Li PC-A77F
  • Lian Li PC-P80(R/N)
  • Lian Li PC-V2120
  • Lian Li PC-X500FX TYR
  • Lian Li PC-X1000 TYR
  • Lian Li PC-X2000F TYR
  • Lian Li PC-Z70
  • Silverstone Temjin SST-TJ07 (User: J1nX3rS)
  • Silverstone Temjin SST-TJ11B-W
  • Xilence Interceptor
  • Xilence Interceptor Pro
  • Xigmatek Elysium
Update: 08/2011 (aus dem Sammelthread / User-Review vom Big Bang Marshal)
Achtung: Alle Angaben ohne Gewähr.
Anhang A) Die möglichen Konfigurationen der PCIe Lanes
Aus dem Handbuch:
Nach Verwendung (Anbindung von oben nach unten):
Dieser Thread ist noch in Bearbeitung. Berichtigungen sowie Ergänzungen (jeweils unter Angabe der Quelle) und eure Unterstützung bei der Pflege dieses Threads ist ausdrücklich erwünscht. Danke & Gruß, emi
Es reicht einer.
Der zweite Anschluss kommt erst bei extrem-Benching zum tragen. Damit meine ich SubZero..
Das NT ist gut, kannst Du so lassen.
hab mir jetzt mal kurzer Hand noch den Adapter zugelegt und werde den 4Pin auch anschließen, damit er auch mal eine Aufgabe bekommt :d... Wird eh nächsten Monat son 1200W BeQuiet herkommen, da ich ja noch ein wenig was vorhabe (4 Grakas)... Aber danke dir Dozer3000!!!
Hab die Beiträge mal in den Sammelthread zum XPowerII verschoben :wink:
BIOS 1.1 - 2012-02-01 --> Download
1) Update CPU Micro Code for Sandy Bridge C1/C2 CPU
2) Update M-Flash module
3) Improved memory compatibility
4) Fix CPU ratio after disable Hyper-Threading
Hat schon einer Erfahrungen mit Wasserkühlern für dieses Board gemacht ? Für die Spawa muss man sich ja eins anfertigen lassen. Habe zumindest noch keinen Kühler gesehen, der lang genug ist. Bei der SB könnte theoretisch ja der fürs Asus P9X79 passen. Sieht zumindest optisch so aus.
Hab mir das "kleine" ;) zugelegt.
Zur kompatibilität: Es passt auch in ein Aerocool XPredator Gehäuse. Der Noctua NH-D14 SE2011 CPU kühler passt drauf. (Selbst mit installierten Seitenlüftern des XPredator.)
Natürlich passt ein Noctua NH-D14 drauf, was hast du denn erwartet? ;)
Ich wollte eigentlich einen Prolimatech Armageddon drauf bauen, der passt aber leider nicht.
Passt der nicht aufs Board wegen der Mainboardkühler oder weil es in deinem Gehäuse zu eng wird?
Denn auf dem Board haben bisher alle Kühler gepasst die ich getestet habe.
Wegen der Mainboardkühler, der Kühler unter dem Sokel kommt in konflikt mit den Heatpipes. Die fächern beim Armageddon sehr weit auseinander.
Ok, gut zu wissen falls jemand diesen Kühler verbauen wollte. ;)
@Dragon667: Danke für den Hinweis. Kühler und Gehäuse-Liste geupdated :wink:
Hey Leute,
in Aida64 wird ja auch die AUX Temperatur ausgelesen. Die klettert bei mir je nach Anwendung auf über 100°C . Gerade nachdem ich das erste relativ kurze Level aus Serious Sam 3 gespielt habe hatte sie sogar 126°C.
Sowohl Aida als auch Open Hardwaremonitor zeigen die selbe Temp an als gehe ich davon aus das es kein Auslesefehler ist.
Gehe ich recht in der Annahme das es sich dabei um die Spannungswandler handelt? Ist die Temperatur nicht ein wenig arg hoch?
@DraonClaVV
Ich hab grade mal mit prime 95 getestet. Hardwaremonitor zeigt nach ~10 Minuten bei mir 60°C für Temperatur #1 an. (Das dürfte ja wohl die sein die du meinst) CPU @ 3800 Mhz; RAM @2133 Mhz.
Ich nutze Open Hardwaremonitor da ist es die temperatur 2.
Cpu ist ein 3930k C2.
Nur mal so nebenbei. Was hast du für eine Spannung auf deiner CPU anliegen? Meine setzt 1.304-1.312 bei Standardtakt. Ich hab momentan das Gefühl das da irgendwas nicht stimmt. Werde nachher nochmal ein CMOS Reset machen auch wenn ich das schon am Anfang nach dem Biosupdate gemacht habe.
Ich hab auch einen 3930k C2 und das Bios ist 1.3.
Bei last habe ich laut Open Hardwaremonitor bei Temperatur #2 ~50°C.
Die CPU VCore liegt bei last bei 1.280 V. (Hab an den CPU-Werten bis jetzt noch nicht geschraubt.)
Moinmoin,
kleines Update meinerseits:
Die Hohe Temp scheint von den Grafikkarten zu kommen was ich mir beinahe schon gedacht habe. Die Karten haben keinen Referenzkühler und verteilen daher die Warme Luft zu großen Teilen im Case(Welches jedoch mit massig Lüftern ausgestattet ist) Die untere Karte steckt im 5er und der Kühler liegt auch auf dem Magazin auf.
Wenn beide Karten arbeiten gehen sie beide auf 75+ Grad hoch und werden unerträglich laut. Oben genannte Temperaturen werden relativ schnell erreicht.
Gleiches Spiel, jedoch im Treiber auf EinzelGPU gestellt. 1 Std gespielt und die einzelne Karte erreicht 70-71 Grad und ist schön leise. Untere Karte entsprechend inaktiv. Aux Temperatur nach 1 Std 68°
Ich bekomme jetzt die Tage einen neuen CPU Kühler und werde wenn ich diesen einbaue mal noch etwas rumtesten und die Karten etwas anders stecken in der Hoffnung die Temperatur zu besseren.
Also ich habe gerade ne Rückmeldung von Marc (Liquid Extasy) bekommen.
Da ja für das XPower II keine Wakü existieren, würde er die anfertigen. In den nächsten 6 Wochen hat er zwar keine Zeit, aber danach werde ich mal vorbei fahren und bissl was absprechen.
Wollte nur mal Bescheid geben. Vielleicht möchte ja der ein oder andere auch nen Wakü für das Board. Könnt ja mal Bescheid geben. Ggf. gibts ja auch bissl Rabatt dann.
Grüße!
Ich würde mich auch schwer für so einen Kühler interessieren!
Edit:
Ich hab in de Kompatibilitätsliste gelesen das das Board auch in ein 650D reinpassen soll? Das X79 ist 4cm läger als das X58 Xpower. Kann vielleicht jemand mit einem X58 Big Bang-XPower und einem 650D schauen ob da ernsthaft noch soviel Luft ist?
Wollte mir eigentlich das Shinobi XL Kaufen, aber das wurde schon wieder um eine Woche verschoben.
So, nu darf ich mir selbst ein Bild vom Xpower II machen. Liegt gerade vor mir. :cool:
Optisch echt nen feines Board. Habe direkt mal ein paar Kühler probiert. Fü die Spawa passt echt kein einziger Kühler. Der ist einfach zu ... mächtig. Für die Südbrücke gibt es zwar ein paar, aber leider keinen, der bis unter die CPU geht, um auch die beiden Kondensatoren + die beiden (ich schätze, es sind auch) Spawa zu kühlen.
Nun muss ich das Board aber erstmal austauschen. Als ich es heute ausgepackt hab, ist mir die rechte obere Ecke aufgefallen.
Ich könnte echt heulen. :wall:
@Wums
Ich hatte zwar den Vorgänger, aber leider nicht das Gehäuse. Aber es passt locker ins TJ07. :d
Ich war das nicht. Das Board kam schon so bei mir an.
Ob es noch geht, weiß ich nicht. Hab es noch nicht in Betrieb gehabt. Will es direkt Montag zur Post geben und tauschen.
Heyo,
der Phanteks PH-TC14PE passt aufs Board. Problemlose Montage keine Kollision und das sogar mit 3 Lüftern. Der dritte ist der selbe wie im Lieferumfang: PH-F140TS
Mache die Tage noch ein Bild sobald ich hier mal ne ordentliche Kamera kriege und nicht mein 10 jahre altes handy...
Danke, hab ihn eingetragen.
@Dragon667: Ich kann dir leider nicht sagen, warum das 1.3er BIOS von MSI zurückgezogen wurde. Vermutlich gab es damit noch Probleme?
Übrigens, da das Silverstone TJ07 noch nicht in der Liste ist ... da passt das Board auch rein. :)
Der Corsair Vengeance Low Profile weiß DIMM Kit 8GB PC3L-12800U CL9-9-9-24 (DDR3L-1600) (CML8GX3M2A1600C9W) läuft auch einwandfrei. Hab auch schon 9-10-10-28 mit 1866 @1,5V getestet. Mehr kann ich erst testen, wenn ich das neue Board habe.
Die G.Skill RipJaws-X DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-14900CL9Q-16GBXL) laufen auch auf Standardtakt.
Danke für den Hinweis, alles eingetragen :wink
Mann könnte auch sich bei MipsComputer mal melden,die fertigen auch WaKü für solche exoten.Bei dem faxconn BloodRage hatten die es gemacht,ob sie es auch hier bei diesen hier machen weiß ich nicht.Werd mal da anrufen und euch bescheit sagen.
