[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
des wegen hab ich ja damals u.a. das ud5h genommen, weils ja kein via-ports hat
Aber Klar ... ist nicht offiziell!!! Benutzung auf eigene Gefahr !!!
Gigabyte gibt sich trotz mehrfachen Nachfragen sehr bedeckt dazu.
Sämtliche Anfragen in diversen Foren werden kurioser Weise immer ganz schnell von Gigabyte geschlossen.
Keine Ahnung warum ???
Aber egal, ich habe nun mein Bios selbst modifiziert mit UBU 1.69.16
Garantie hab ich ja sowieso nicht mehr und schiefgehen kann ja nix, da das Board ein DualBios hat.
so, nun schaut mal
For Sandy Bridge....cpu206A7_plat12_ver0000002D_2018-02-07
For Ivy Bridge........cpu306A9_plat12_ver0000001F_2018-02-07
For Haswell-E........cpu306F2_plat6F_ver0000003C_2018-01-19
For Broadwell........cpu40671_plat22_ver0000001D_2018-01-21
For Broadwell-E.....cpu406F1_platEF_ver0B00002A_2018-01-19
For Skylake...........cpu506E3_plat36_ver000000C2_2017-11-16
For KabyLake.........cpu906E9_plat2A_ver00000084_2018-01-21
For Coffee Lake.....cpu906EA_plat22_ver00000084_2018-01-21
For Coffee Lake-S..cpu906EB_plat02_ver00000084_2018-01-21
Quelle
Original Bios F16J (Z77X-UD5H)
modifiziertes Bios F16J
Anleitungen gibt's im TT-Forum
bevor ich da wieder stundenlang lesen muss, könntest du mir bitte bitte bitte eine version fürs ud3h/ivybridge basteln :hail::hail::hail:
brauchst nix lesen, einfach Ubu runterladen, starten, Biosfile laden, aktualisieren und speichern. so und dann nue noch flashen ... fertig
@Misda T woher bekommt man das MMTool? find da keine download. Gerne auch per PN.
Würde ein Bios für das Z77X-D3H machen.
Hab jetzt doch ein MMTool gefunden bekomme dann aber folgende Meldung.
Scanning BIOS... Please wait...
Define BIOS platform - AMI Aptio 4
The input image is not Aptio V.
Hab ich jetzt das falsche MMtool?
versuch's mal damit:
MMTool Aptio 5.02.0024
noch mehr Tools findet ihr hier ;)
Ich kann mich bei Gigabyte nicht mal richtig registrieren. Sie schicken mir keine E-mail zum abschließen der Registrierung. (Nö, keine Spam-adresse, sondern meine normale E-mail-Adresse bei der telekom). Seit 2 Wochen, keine Antwort. So kann ich keine Fragen stellen, die ich zu meinem Mainboard habe. Ich kann u. a. unter Windows 10Pro immer noch nicht das vdeck starten, obwohl ich das aktuellste Bios (F16b) drauf habe. Ich habe sämtliche Audio-Treiber von Via bereits durch, auch den, den Gigabyte auf ihrer Support-Seite anbietet. Immer dasselbe Problem. Echt zum Kotzen.
Oh, ich sehe gerade. Ich bin im falschem Sammelthread. Kann mich bitte jemand mal verschieben?
Das Forum kannst du vergessen. Seit ca. 3 Jahren wollen sie es umstellen und nun ist es einfach zu
Hat sich in letzter Zeit hier mal einer aus dem Gigabyte-Forum, z. B. "JZ" zum Neustart des Gigabyte-Forums geäußert? Angeblich stellen sie gerade (gefühlt schon etliche Monate) um.
jetzt geht erstmal gar nix mehr - mal sehen ob sie überhaupt wieder online gehen
JZ z.B. ist ganz weg von Gigabyte - aber schon fast 2 Jahre
Und die anderen (mich eingeschlossen) haben sich schon verabschiedet - den einzigsten den ich noch von den "alten guten Zeiten" kenne und der noch aktiv ist, ist Stasio vom TT-Forum
Es gibt aber noch echten Gigabyte-Support hier und das geht sauschnell!
Was hat das bitte mit Support zu tun, wenn jede Anfrage mit dem Textbaustein:
...für weitere Fragen kontaktieren Sie uns unter der deutschen Festnetznummer 040**** und mit der "1" Technischen Support. …
beantwortet werden.
Warum wird dort dann nicht auf das eigene Support-Forum verwiesen ?
Schon seltsam, oder nicht ?
ich hoffe ich bin hier richtig, denn ich habe ein Z77X-UP5 TH Mainboard. Folgendes Problem: ich hatte bisher einen 3570K eingebaut, der lief @4,5 GhZ über Jahre absolut stabil, war geköpft & geschliffen und daher auch kühl. Jetzt habe ich mir einen 3770K gegönnt und wollte natürlich gleich mal schauen, wie gut sich der i7 übertakten lässt. Bis 4,4 GhZ ist alles in Ordnung (abgesehen von der sehr hohen VID, habe wohl ein schlechtes Exemplar erwischt) aber sobald ich den Multi auf 45 Stelle, tut sich gar nichts mehr, das Board versucht 3x zu booten und zeigt beim UEFI dann die Meldung, dass wohl einige Einstellungen nicht gepasst haben.
Ich habe eigentlich genug Erfahrung in Sachen OC, habe auch extra nochmal die Anleitungen hier gelesen und habe alles befolgt: bis auf wenige Ausnahmen wie VCore und LLC alle Werte auf Default und schrittweise nach oben tasten. Mir kommt so vor, als würde das Board mit dem 45er Multi beim 3770K nicht klarkommen - an zu wenig Spannung kann es nicht liegen, Netzteil ist auch stark genug. Wie gesagt - bis 44er Multi läuft alles super, leider braucht der i7 schon bei 4400 MhZ über 1,3V - habe dann mal 1,35V und sogar 1,375V versucht - dennoch kommt 3x bootfail und ich muss wieder auf 44 zurück.
Heute habe ich den Prozessor in mein Backup Board, ein ASUS P8Z77-V, eingebaut - dort habe ich ebenfalls die meisten Werte auf Default gestellt, VCore und LLC erhöht, Multi auf 45 und siehe da - es läuft! Der i7 braucht zwar leider sehr viel Spannung, aber es läuft.
Woran kann es liegen, dass der 3570K mit dem 45er Multi problemlos läuft, der 3770K aber nicht? Würde es "nur" an einer schlechten CPU liegen, warum läuft er dann mit dem 45er Multi auf dem ASUS Board? Kann es sein, dass das Gigabyte Board beim 3770K irgendwie einen Multi "Limiter" hat?
Bin für jede/n Ratschlag/Tipp/Hinweis/Anregung dankbar!
Grüße
es liegt am Board bzw. Bios, Gigabyte ist diesbezüglich für OC nicht besonders geeignet - vom Support mal ganz zu schweigen
Asus und Asrock ist hier viel viel besser, auch was die älteren Sockel angeht
Dass das Board Probleme mit dem BIOS hat, habe ich leider auch schon feststellen müssen. Mit der F12 Version werden die OC Einstellungen nicht mal gespeichert/übernommen - zumindest wars beim 3570K so. Beim 3770K dürften die Einstellungen jetzt gespeichert werden, hilft mir mit dem Multi 45 auch nicht viel. Deshalb war die F12 Version auch nur auf dem Backup BIOS drauf, als Main BIOS musste ich wegen den Bugs vom F12 die ältere F11 verwenden. Habe die Sache mit dem 45 Multi sowohl mit F11 als auch F12 versucht - leider kein Erfolg.
Und dabei dachte ich, dass das UP5 TH eines der besten OC Boards für Ivy Bridge CPUs wäre, zumindest von den VRMs her. Trotzdem verstehe ich nicht, wieso das Board mit dem 3570K und dem 45 Multi funktioniert, den Dienst beim 3770K und 45er Multi aber verweigert. Ärgerlich die Sache. Ich werde den 3770K trotzdem wieder verkaufen, der hat nämlich schon beim Standardtakt von 3,5 GhZ eine VID von fast 1,2V (!) - das muss überhaupt eines der schlechtesten Exemplare vom 3770K sein - in vielen Threads wurden Exemplare mit einer VID von 1,1V als Krücken bezeichnet...
probier's halt mal mit dem Bios F12j-mod9
GA-Z77X-UP5TH BIOS F12j mod9
Modified with :
Intel Legacy RAID ROM 11.6.0.1702 to 13.1.0.2030
Intel UEFI SataDriver 11.6.0.1702 to 13.1.0.2030
Marvell 88SE91xx SATA RAID 1.0.0.0027 to 1.0.1.0025
Intel Boot Agent PXE 1.3.81 to 1.5.48
Intel EFI UNDI 4.9.00 to 6.0.24
Intel PCI Accelerated SVGA 2137 PC 14.34 to 2170
Sandy GOPdriver 2.0.1023 to 2.0.1024
Ivy GOPdriver 3.0.1023 to 3.0.1027
CPU MicroCode Pack (with Sandy 6A728 and Ivy 6A919)
ME Firmware 8.1.30.1350 to 8.1.51.1471
Modified splash logo 2
Quelle
- - - Updated - - -
@SlotkuehlerXXL
"Trolle" und sonstige A... auf meiner Ignorier-Liste:
RiMaBo - SaKuLification - Pirate85 - C0d3ma5t3r SK11 - Dozer3000 - alffrommars - daurum - tomCAT2008 - JZ_ - pedi - mickeySM - Sirnoea - MihawkLFC - H5N1 Virus - Equilibrium - ******* - Kommando
Vielen Dank für die Blumen !!!
Danke für den Tipp! Habe das gemoddete BIOS statt dem normalen F12 eingespielt, hat auch funktioniert, PC bootet normal etc. Mit Multi 44 läufts, aber sobald ich auf 45 stelle = kein Booten mehr und am Mainboard erscheint der Fehlercode 79 - laut Handbuch ist das "CSM initialization is started" - keine Ahnung was genau das bedeutet. Mit dem normalen F12 BIOS erschien beim 45er Multi meist der Fehlercode 72 (PCH devices initialization), manchmal auch 79. Die ganze Sache kommt mir sehr komisch vor, ich denke nicht, dass hier ein Spannungsproblem vorliegt - viel mehr glaube ich (auch wenn es unlogisch klingt), dass das Board dem 3770K einfach keine höheren Multis als 44 erlaubt.
Ich habe auch in anderen Foren gesucht und bin auf diesen Beitrag gestoßen. Dort hatte ein User ein ähnliches Problem, sein 3770K ging nicht über einen 41er Multi hinaus:
The latest BIOS generations comes with a "lock" in the CPU multiplier. You need to look for "Advance CPU settings" or something similar and change the "max multiplier" to one above 46
Dort ging es zwar um ein Asus Z77 Mainboard, aber kann es sein, dass es auch bei GB so einen "lock" gibt? Ich habe überall im BIOS nach einer ähnlichen Einstellung gesucht, wo man einen maximalen Multiplikator einstellen könnte, aber leider nichts gefunden.
Würde gerne wissen welches Problem hier vorliegt, denn von der Logik her ergibt das überhaupt keinen Sinn.
Mit dem 3570K funktioniert der 45er Multi - also dürfte das Board wohl auch 45er Multis unterstützen.
Mit dem 3770K geht maximal 44er Multi - Verdacht: es liegt am Prozessor --> stimmt nicht, da die CPU beim P8Z77-V mit 45er Multi läuft.
Wenn ich wüsste, dass es an der CPU liegt, würde ich mir einfach einen anderen 3770K holen...
mein sandy lief damals auch auf 4,8 und 4,9ghz stable. bis ich auf die dumme Idee kam, auf ivybridge upzugraden. temps nicht besser, Stromverbrauch auch kaum, cpu geht nur bis Multi 45 (selbst das auch nicht so richtig stable).
das bios an sich ist auch ein rätsel. es läuft stabil, dann ändere ich zb die usb-Einstellungen und auf einmal zickt es rum.
hab jetzt zum glück mein gemoddetes bios mit erp-fix wiedergefunden
Gigabyte ist der größte Müll - nun ist ja auch noch das GB-Forum für immer und ewig zu, über die Hotlines hängt man ewig in der Warteschleife bis man rausgeworfen wird ... kurz um, Gigabyte ist (leider) nicht mehr das, was es mal war
Echt schade ... aber Asrock hat richtig klasse Boards und super Support. Ich möchte da nur mal JZ nennen. Echt Klasse der Mann. RESPEKT !!!
Kurzes Update: Habe mir tatsächlich einen anderen 3770K geholt und siehe da, der 45er Multi funktioniert plötzlich! ABER: Mit dem neuen 3770K funktioniert das XMP Profil von meinen 2x8 GB G SKILL ARES 2400 Riegeln nicht mehr - sobald ich das XMP Profil einstelle oder den 24er Multi beim RAM manuell einstelle = bootfail. Der maximale Speichertakt liegt jetzt bei 22, also 2200 MHz statt 2400. Habe dann mal den Prozessor im Standardtakt von 3,5 GHz gelassen, aber selbst hier verweigert das System den 24er RAM Multi. Getestet sowohl mit der F11 als auch der gemoddeten F12j BIOS Version, leider ohne Erfolg.
Seltsamerweise hat es mit dem vorigen 3770K noch normal mit dem 2400er XMP Profil funktioniert, auch bei 4400 MHz CPU Takt.
Schon kurios die Geschichte: der eine 3770K hört bei 44x Multi auf, akzeptiert aber einen 2400er Speichertakt. Der neue 3770K akzeptiert den 45 Multi, hört aber bei einem 2200er Speichertakt auf.
Hat jemand eine Idee woran das liegen könnte?
