Frage zum MEG Z490 Unify Beta Bios
Guten Tag,
Meine deutsch ist schlect. So I will use english.
Does anyone have any beta bios for the MSI z490 Ace for Intel Gen 11? Also curious if there is a beta bios available for the z490i Unify (the itx board).
Thanks in advance!
Link to BETA Bios for MSI Z490i Unify
Ich frage mal an,
kann aber bis morgen dauern, bis ich eine Antwort habe.
@MSIToWi
Ich wurde nach dem Beta Bios für das MEG Z490 Godlike gefragt. Habt ihr da auch schon was?
Link zum BETA Bios für das MEG Z490 Godlike.
Vielen Dank, habs weitergegeben!
Latency is worse on beta bios for z490 godlike. I can also no longer get 102blck to work with prior ram timings:
1.07 bios
1.8 beta bios:
Have to say I am disappointed having seen the response and results ASUS is getting compared to this so far =[
1.07 bios
1.8 beta bios:
Feel free to get in touch with MSI support and share your results and findings.
We will take a look into it then.
Please use the support system on the MSI website.
Hello again,
I want to try if there is a newer beta BIOS than this (E7C75IMS.A72) for MSI MPG Z490 GAMING PLUS
There is no newer BETA bios available.
Can you share the old microcode and new microcode ram latency ?
Hey there. I don't have access to a bios that would have old microcode while utilizing the new microcode's ram latency.
I honestly don't even know if that is a thing, as I don't have any real coding knowledge.
You may checkout the MSI website, if there is a newer BETA bios available, I have none on hand.
