Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]foobar2000 v2.25 preview 2025-07-26 wurde veröffentlicht
Amended WavPack in Matroska interaction with Verifier.
Added advanced preferences toggle for alternate multi-value MP4 tag storage - more compatible with specific apps but less compatible with others. Old versions of foobar2000 read both schemes.
Fixed a bug that made exotic FLAC configurations unplayable if muxed into Ogg/Matroska/MP4.
Fixed failure to resume internet radio streams after specific patterns of connection issues.
Made Verifier detect multichapter files with FLAC-style audio MD5, now prompts to scan as whole.
Improved interaction between Verifier and built-in FFmpeg decoders; more errors get reported.
2025-06-13:
Fixed ID3 tags in AAC radio stream causing playback to stop.
Fixed "wrong URL format" error trying to list SMB server root folder without slash after hostname.
Windows: Improved screen reader behavior in Verify Integrity results dialog.
Made "Edit Chapters" show progress dialog when manipulating files, avoid unresponsive UI when rewriting large MP4.
Tweaked MP4 tag padding to rewrite large files less.
2025-06-06:
Amended prebuffering code, no longer outputs very large chunks, which caused some DSPs to behave erratically.
Fixed regression from the last build causing very short music files not to be played.
Mac: Fixed erratic behavior of Properties dialog on multi line tags with Windows style line endings.
2025-06-05:
Playback prebuffering logic update, should fix stuttering with high-res internet radio streams.
Windows: Slightly updated Album List search box, made delay setting take immediate effect; previous behavior required reopening Album List to take effect.
Re-enabled decoding of xHE-AAC thru alternate decoders, as FFmpeg decoder is still buggy. This means aac_at decoding on Mac OS.
Mac: Cleaned up external FFmpeg decoder preferences.
Media Library made properly keep track of enabled decoders list; made remember which decoder was used for each file, so only affected files will be reloaded after uninstalling or disabling of specific decoder.
Media Library added 'clean flag' to know if a rescan of specific folder actually completed; fixes upgrading from foobar2000 v1.x with no scan-on-startup folders becoming empty.
FFmpeg updated to current git master, fixed more xHE-AAC decoding bugs.
Windows: Made internal cover art reading routines respect embedded color profiles.
Windows: Fixed failure to negotiate playback format on some exotic audio devices.
2025-05-22:
Fixed playing track info possibly becoming out of sync when using seekbar near track switch.
Windows: Fixed initial directory not being set correctly in folder picker regression.
2025-05-20:
FFmpeg 7.1 updated to 7.1.1, fixed xHE-AAC bugs.
Windows: Fixed wrong default folder in Quick Convert in portable installs.
2025-05-19:
Mac: Fixed keyboard shortcuts page glitches.
Mac: Handle forward delete key in properties, playlist, etc.
Windows: Fixed "save all playlists" crash.
Windows: Various bug fixes in dark mode listview substitution code.
Windows: New VC runtime.
Windows: Made converter properly resolve redirected relative paths.
2025-05-14:
Made live playback info manipulation match behaviors of old foobar2000 versions better, should fix Internet radio issues.
Windows: Removed dotted lines from various treeviews, refreshed Album List tree looks.
Windows: Fixed bad import of relative library paths when upgrading from portable install of old version.
Windows: More verbose output on "open containing folder" errors.
2025-05-12:
Fixed unintended capture of ctrl+shift+left/right by tab containers.
Internet radio album art lookup regression fix.
Amended handling of dynamic info (live bitrate etc), the behavior in previous build was causing OpenMPT visualization to malfunction.
Monkey's Audio updated to 11.10.
2025-05-09:
Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
- Other foobar2000 instances on your local network, with UPnP remote control feature active, will be listed as output devices.
- foobar2000-to-foobar2000 playback shows tags with album covers on the other end, using Ogg FLAC as stream container.
FFmpeg updated to 7.1, added native support for xHE-AAC decoding.
Media Library can natively index FTP/WebDAV/SMB network shares.
Added preferences page for network share credentials so you don't have to place them in URLs anymore.
Made editing DSP settings momentarily lower output latency to make DSPs appear more responsive.
Portable install: Changed the way relative paths are handled, so cached tags are no longer forgotten after relaunching from a different path.
Allowed = character in tag field names. Will be converted to _ in formats that don't allow =.
Installer is now hi-DPI friendly.
Rewritten Ogg FLAC tag handling, properly implemented embedded album art.
Made system file dialogs invoked out-of-process, to avoid stability issues.
2025-06-16:
2025-06-13:
2025-06-06:
2025-06-05:
2025-05-22:
2025-05-20:
2025-05-19:
2025-05-14:
2025-05-12:
2025-05-09:
Restored ability to list HTTP folders via "Add Location".
Fixed saved network credentials not being used for HTTP/WebDAV resources.
SMB bugs fixed.
2025-06-18:
Enabled RF64 writing in Converter.
2025-06-16:
2025-06-13:
2025-06-06:
2025-06-05:
2025-05-22:
2025-05-20:
2025-05-19:
2025-05-14:
2025-05-12:
2025-05-09:
Fixed a problem with yesterday's HTTP bug fix that broke adding whole local folders, by drag&drop etc.
2025-06-22:
SMB bugs fixed.
2025-06-18:
2025-06-16:
2025-06-13:
2025-06-06:
2025-06-05:
2025-05-22:
2025-05-20:
2025-05-19:
2025-05-14:
2025-05-12:
2025-05-09:
Mac: Visualizations - fixed falling peaks for blank bars not being drawn.
Cleaned up various inconsistent behaviors of filesystem API, correct read-ahead option is once again used for SMB.
Reverted 2024 change breaking titles in local M3U playlists referencing internet radio M3U.
Fixed extreme memory usage of visualizations with specific file types.
Made title formatting date functions not throw C++ exceptions when fed input they can't process.
Improved handling of AAC radio streams that have both ID3 tags and icy metadata.
2025-06-23:
2025-06-22:
SMB bugs fixed.
2025-06-18:
2025-06-16:
2025-06-13:
2025-06-06:
2025-06-05:
2025-05-22:
2025-05-20:
2025-05-19:
2025-05-14:
2025-05-12:
2025-05-09:
Fixed disappearing internet radio covers for specific Ogg streams.
2025-06-27:
2025-06-23:
2025-06-22:
SMB bugs fixed.
2025-06-18:
2025-06-16:
2025-06-13:
2025-06-06:
2025-06-05:
2025-05-22:
2025-05-20:
2025-05-19:
2025-05-14:
2025-05-12:
2025-05-09:
2025-06-27:
2025-06-23:
2025-06-22:
SMB bugs fixed.
2025-06-18:
2025-06-16:
2025-06-13:
2025-06-06:
2025-06-05:
2025-05-22:
2025-05-20:
2025-05-19:
2025-05-14:
2025-05-12:
2025-05-09:
2025-06-27:
2025-06-23:
2025-06-22:
SMB bugs fixed.
2025-06-18:
2025-06-16:
2025-06-13:
2025-06-06:
2025-06-05:
2025-05-22:
2025-05-20:
2025-05-19:
2025-05-14:
2025-05-12:
2025-05-09:
