Hier bitte alles rein zum Thema Grafikkarten Upgrades, Mod-Biose etc bei Clevo Barbones
...Startbeitrag wird natürlich noch ausgebaut!
HIGH-END-DTR(Desktop CPU)
# 17,3" Clevo P570WMx (Release Q4/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
release
changes
2013/03/09
1. EC firmware 1.02.05 for both P570WM and P570WM3.
2. Solve “sometimes system enters CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update BIOS to 1.02.08 or later version.
4. Please refer to the content of readme_EC.txt to update firmware.
2013/03/09
1. System BIOS 1.02.08 for P570WM3 only.
2. Solve “sometimes system enter CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update EC firmware to version 1.02.05 or later.
4. Please refer to the content of readme.txt to update BIOS.
2013/03/09
1. System BIOS 1.02.08 for P570WM only.
2013/01/19
1. System BIOS 1.02.06 for P570WM3 only.
2. Solve “in Windows 8 UEFI the position of S4 resume logo is incorrect” issue.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM3_W8FW.zip
to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme.txt to update firmware.
2013/01/19
1. System BIOS 1.02.06 for P570WM only.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM_W8FW.zip
2013/01/19
1. EC firmware for both P570WM and P570WM3.
2. Support AMD HD7970M VGA card.
3. If your machine's BIOS or EC version is not 1.02.xx than it is necessary to download P570WM_W8FW.zip
or P570WM3_W8FW.zip (depends on model) to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme_EC.txt to update firmware.
2012/12/15
1. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01 for P570WM3 only.
2. Support Windows 8.
3. It is necessary to update EC firmware first, system BIOS is the second, VBIOS is the last one.
4. Please read the file readme_1st.txt to update firmware correctly, the wrong order will cause
system hangs or no screen symptom.
2012/12/15
1. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01, GTX670MX VBIOS 80.04.67.00.06 for P570WM only.
2012/12/07
1. System BIOS 1.00.02 for P570WM3 only.
2. Solve "sometimes LAN can't work properly" issue.
3. Please follow the instruction of readme.txt to update firmware.
2012/12/07
1. System BIOS 1.00.02 for P570WM only.
1. VBIOS for nVIDIA Quadro 5010M VGA card.
2. Solve "sometimes screen flickers" issue.
3. Run update.bat in pure DOS environment to update VBIOS.
2011/09/23
1. EC firmware 1.00.08.
2. Modify fan table.
3. Run update.bat in pure DOS environment to update EC firmware.
2011/07/08
1. System BIOS 1.00.12.
2. Update RAID ROM to 10.5.0.1034.
2011/06/10
1. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support GTX580 VGA card.
3. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
2011/05/20
1. System BIOS 1.00.10.
2. Support nVIDIA Quadro 5010M VGA card.
2011/03/25
1. System BIOS 1.00.09.
2. Support V4.x M/B.
2011/03/11
1. AMD HD6970M VBIOS BR39257.008.
2. Solve DVI to D-sub function doesn’t work issue.
3. If there is only one VGA card inside, please run One_card.bat.
4. Run master.bat to flash VBIOS of master VGA card, Run slave.bat to flash VBIOS of slave VGA card.
2011/02/25
1. System BIOS 1.00.08 and EC firmware 1.00.06.
2. Support AMD Mobility Radeon HD 6970M VGA card.
2010/11/05
1. System BIOS 1.00.05 and EC firmware 1.00.03.
2. Support nVIDIA Quadro FX3800M VGA card.
2010/10/15
1. System BIOS 1.00.04 and EC firmware 1.00.02.
2. Support new version M/B.
1. System BIOS 1.00.09 and EC firmware 1.00.04.
2. Support nVIDIA GTX 480M VGA card.
2010/03/30
1. System BIOS 1.00.06.
2. Support nVIDIA Quadro FX3700M VGA card.
2010/01/22
1. System BIOS 1.00.05.
2. Add “Turbo Boost Enable/Disable” item.
2009/10/16
1. System BIOS 1.00.03.
2. Support Windows 7.
2009/07/24
nVIDIA GTX 280M VBIOS 62.92.91.00.01.
2009/07/24
1. System BIOS 1.00.02 and EC firmware 1.00.02.
2. Update RAID OPROM.
3. Solve “sometimes system has no display after resuming from Standby mode” issue.
4. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
1. KBC/EC firmware for VISTA keyboard only.
2. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
3. It is necessary to upgrade BIOS to 1.00.22 or later.
2008/12/12
1. KBC/EC firmware for Windows XP keyboard only.
2008/12/12
1. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
2. It is necessary to update H8 firmware to 1.00.13/13N or later.
2008/10/20
2. When system working temperature reaches fan on point but the system can’t receive normal
fan speed information, it will alarm for one minute then shut down.
2008/10/20
1. KBC/EC firmware for XP keyboard only.
2008/10/14
Support Q9550 CPU.
2008/09/10
Support nVIDIA NB9x series VGA.
2008/07/22
Support 9800M GT VGA card.
2008/06/12
2. Solve "sometimes system can't boot up" issue.
2008/06/12
2008/05/20
Solve “system sometimes can’t boot up after installing PCI-Express card” issue.
2008/04/30
2. Solve "sometimes system can't identify hard drive" issue.
2008/04/30
2008/03/21
Support both partnet board and daughter board.
2008/03/12
Solve "in Windows press Fn+F7 causes system beeps" issue.
2008/03/12
2. Solve VGA temperature probe inaccuracy issue.
2008/03/12
2008/01/21
Solve “install total 2GB memory will cause VISTA hangs up after resuming from standby mode” issue.
2007/12/18
2. Support nVIDIA GeForce 8800M GTX (BIOS and hardware need to support).
2007/12/18
Support nVIDIA GeForce 8800M GTX (KBC/EC firmware and hardware need to support).
2007/11/19
Solve “external USB keyboard doesn’t work during POST and CMOS setup” issue.
2007/10/29
2. Add VGA card fan monitor function.
3. Solve "sometimes system can't boot up" issue.
2007/10/29
2007/10/29
1. Solve "system stops on POST when the ODD is unavailable" issue.
2. Solve "sometimes system S3 resume doesn't work by Q6700 CPU + RAID enable" issue.
2007/08/23
1. Solve “system can’t recognize nVIDIA GeForce 8700M GT VGA card” issue.
2. Add VGA card information item in CMOS.
3. Solve “VISTA show incorrect CPU speed” issue.
2007/07/16
1. Solve "4GB system RAM + single VGA card cause system hangs up on POST" issue.
2. Solve "single VGA + AHCI mode enable cause system can't boot up from HDD/USB dongle" issue.
3. Solve "system hangs up on POST if the Blu-ray or HD-DVD is installed" issue.
1. System BIOS 1.02.08 for P370EM3 only.
2. Update ME to 8.1.0.1248.
3. Please refer to the content of readme.txt to update firmware.
2013/01/26
1. System BIOS 1.02.08 for P370EM only.
2. Support eDP panel.
2013/01/26
1. K5000M VGA card VBIOS 80.04.67.00.07 for P370EM only.
2. Solve “POST screen flickers” issue.
3. Please refer to the contect of readme_nVBIOS.txt to update firmware.
2013/01/26
1. GTX670MX VGA card VBIOS 80.04.67.00.06 for P370EM only.
2012/12/15
1. EC firmware 1.02.09 for both P370EM and P370EM3.
2. Solve sometime can’t pass production line test program issue.
3. It is necessary to follow the instruction of readme_EC.txt to update firmware.
2012/11/24
1. EC firmware 1.02.08 for both P370EM and P370EM3.
2. Support Windows 7 and Windows 8.
2012/11/24
1. System BIOS 1.02.06 for P370EM only.
3. Because 1.02.xx version BIOS can't work with 1.00.xx version EC, so it is necessary to make sure
the EC firmware of machine is 1.02.xx, if the EC firmware of machine is 1.00.xx then the system will
not boot up after update 1.02.xx system BIOS.
4. It is necessary to follow the instruction of readme.txt to update system BIOS.
2012/11/24
1. System BIOS 1.02.06 for P370EM3 only.
2012/10/12
1. EC firmware 1.00.06 for P370EM only.
2. Solve “sometimes system shows zero battery capacity” issue.
3. Run ecflash.bat in pure DOS environment to update firmware.
2012/09/28
1. System BIOS 1.00.02.
2. Solve GTX670MX VGA card can't be identified issue.
3. Please follow the instruction of readme_BIOS.txt to update firmware.
1. System BIOS 1.01.04.
2. Solve "system can't identify GTX670M VGA" issue.
3. Run flash.bat in pure DOS environment to update BIOS.
2011/11/18
1. EC firmware 1.00.05.
2. Modify the timing of LED initiation.
2011/11/04
1. System BIOS 1.01.03.
2. Support UEFI.
3. Run update.bat in pure DOS environment to update system BIOS.
2011/10/21
1. System BIOS 1.01.02 and EC firmware 1.00.04.
2. Update CPU micro code.
3. Modify fan table.
2011/10/07
1. EC firmware 1.00.03.
2. Modify Touch Sensor LED initial control.
LINKS:
# 18,4" Clevo X8100 (Release Q1/2010) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
release
changes
2011/02/25
1. System BIOS 1.00.14.
2. Correct the VGA card model name in CMOS setup.
2010/10/22
1. System BIOS 1.00.13.
2. Solve “GTX 460M SLI can’t work properly” issue.
2010/09/10
2. Modify nVIDIA VGA fan table.
2010/07/15
2. Support ATI HD5870 VGA.
2010/05/07
1. System BIOS 1.00.07 and EC firmware 1.00.04.
2. Solve "system can't identigy i7 940XM CPU correctly" issue.
2010/04/15
2. Solve “some RAM modules cause no display after system resumes” issue.
2010/03/30
1. System BIOS 1.02.17 for P170EM only.
2. Solve “in UEFI mode can’t display CMOS setup screen when the external display is connected to machine” issue.
2013/02/09
1. System BIOS 1.02.16 for P170EM only.
2. Solve “Fn+F7 can’t work properly in Non-UEFI OS” issue.
2012/10/30
1. System BIOS 1.02.14 for P170EM only.
2012/10/30
1. EC firmware 1.02.12 for P170EM only.
3. It is necessary to follow the instruction of readme.txt to update firmware.
2012/10/12
1. EC firmware 1.00.10 for P170EM only.
2. Solve "power USB port charge function can't work" issue.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmwa
2012/09/28
1. EC firmware 1.00.09 for P170EM only.
2. Support both old and new matrix keyboards.
3. Follow the instruction of readme_EC.txt to update firmware.
2012/08/31
1. System BIOS 1.00.10 for P170EM only.
2. Solve sometimes system stops on POST issue.
3. If the BIOS version of machine is 1.00.03 or early, please update to 1.00.04 before executing next step.
4. Refer to the instruction of readme.txt to update BIOS + ME firmware.
5. To downgrade BIOS will cause system can't boot up if the BIOS of machine is version 1.00.07 or later.
2012/08/24
1. EC firmware 1.00.08 for P170EM only.
2. Add new keyboard matrix.
3. Please refer to the instruction of readme_EC.txt to update firmware.
2012/07/27
1. System BIOS 1.00.07 for P170EM only.
2. Solve “sometimes no display after system resumes from S4” issue.
2012/07/11
1. EC firmware 1.00.06 for P170EM.
3. Please follow the instruction of file readme_EC.txt to update firmware.
2012/06/15
1. System BIOS 1.00.05 for P17xEM only.
2. Solve "system can't identify GTX680M VGA" issue.
3. Update Intel Sandy Bridge Processor microcode.
4. Run update.bat in pure DOS environment to start procedure.
2012/06/08
1. EC firmware 1.00.05 for P17xEM only.
3. Please read file "Update SOP.txt" to update firmware.
2012/05/11
1. System BIOS 1.00.04 and EC firmware 1.00.04 for P170EM only.
2. It is necessary to refer to readme.txt to update firmware.
3. Update ME to 1441.
4. Update PXE ROM to 2.46.
5. Enable Intel CPU VT function support.
1. EC firmware 1.00.09 for both P170HM and P170HM3.
2. Solve “sometimes get incorrect CPU thermal information” issue.
2011/10/28
2. Run update.bat in pure DOS environment to update VBIOS.
2011/09/16
3. Run flash.bat in pure DOS environment to update EC firmware.
2011/09/09
1. System BIOS 1.01.10 for P170HM only.
2011/09/09
1. System BIOS 1.01.05 for P17xHM3 only.
2011/08/11
1. System BIOS 1.01.03 for P17xHM3 only.
2011/08/05
1. System BIOS for P170HMxx only (except P170HM3).
2011/06/10
1. System BIOS 1.01.07 for P170HM only.
2. Update Intel RAID ROM to 10.5.0.1034.
2011/05/27
1. System BIOS 1.01.02 for P170HM3 only.
2. The BIOS password will not be cleared after BIOS update.
2011/05/06
1. System BIOS 1.01.06 for P170HM only.
2. Add new VGA card identification.
2011/04/22
2. Solve “enter S4/S5 in DC mode, the Wake on LAN function can’t work after plugging in AC power” issue.
2011/03/18
2. Solve “sometimes system VGA SMBus detection can’t work properly” issue.
2011/02/25
1. System BIOS 1.01.02 for P170HM only.
2. Support Intel B3 version chipset.
2011/01/14
1. System BIOS 1.00.02 and EC firmware 1.00.02 for P170HM only.
2. Solve “sometimes system spends several seconds to boot up” issue.
3. Run step1.bat to update system BIOS, run step2.bat to update EC firmware.
1. EC firmware 1.00.02.
2. Solve "sometimes EC reports incorrect EC version to BIOS" issue.
# 17,3" Clevo W870CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
release
changes
2012/03/03
ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/11/26
1. EC firmware 1.00.14 for W87xCU only.
2. Solve "sometimes system can't identify i7-940XM CPU" issue.
2010/10/22
1. EC firmware 1.00.11 for W87xCU only.
2. Solve “under clone mode the GTX 460M/470M VGA cause screen flashes symptom after pressing Silent key” issue.
2010/10/08
1. System BIOS 1.00.18 for W87xCU only.
2. Solve the audio issue of BIOS 1.00.17.
2010/09/20
1. System BIOS 1.00.17 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 470M VGA card" issue.
2010/09/17
1. System BIOS 1.00.15 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 460M VGA card" issue.
2010/08/20
1. System BIOS 1.00.14 for W87xCU only.
2. Update Intel CPU micro code table.
2010/06/18
1. System BIOS 1.00.13 for W87xCU only.
2. Solve “HDMI audio has no function with nVIDIA GTS 360M” issue.
2010/05/21
VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/04/30
1. System BIOS 1.00.12 for W87xCU only.
2. Solve “the CMOS setup screen shows incorrect ATI VBIOS version” issue.
2010/02/25
1. Sysem BIOS 1.00.10 and EC firmware 1.00.10 for W87xCU only.
2. Base on V4.1 and later version main board to support Arrandale CPU.
2009/12/11
1. System BIOS 1.00.05 for W87xCU only.
2. Solve system can't show 4GB system memory issue
1. System BIOS 1.02.17 for P150EM only.
2013/03/15
1. System BIOS 1.02.17 for P151EM1 only.
2013/01/19
1. System BIOS 1.02.16 for P150EM only.
2. Update VBIOS to 2143.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017).
2013/01/19
1. System BIOS 1.02.16 for P151EM1 only.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017.
2012/10/30
1. EC firmware 1.02.11 for P151EM1 only.
2012/10/30
1. System BIOS 1.02.14 for P151EM1 only.
2012/10/30
1. EC firmware 1.02.11 for P150EM only.
2012/10/30
1. System BIOS 1.02.14 for P150EM only.
2012/10/12
1. EC firmware 1.00.09 for P150EM only.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmware.
2012/09/28
1. EC firmware 1.00.08 for P150EM only.
2012/09/07
1. System BIOS 1.00.10 for P151EM1 only.
2012/09/07
1. System BIOS 1.00.10 for P150EM only.
2012/08/31
1. EC firmware 1.00.07 for P151EM1 only.
2. Support new keyboard matrix.
3. Please follow the instruction of readme_EC.txt to update firmware.
2012/08/24
1. EC firmware 1.00.07 for P150EM only.
2012/07/12
1. EC firmware 1.00.05 for P150EM only.
2. Modify VGA fan table.
3. Please follow the instruction of readme_EC.txt to update EC firmware.
2012/06/29
1. System BIOS 1.00.05 and EC 1.00.05 for P151EM1 only.
2. Update CPU microcode.
4. Please refer to readme_EC.txt before EC firmware update.
5. Run step1.bat in pure DOS environment to update EC firmware, run Step2.bat to update system BIOS.
2012/06/15
1. System BIOS 1.00.05 for P150EM only.
3. Update Intel Sandy Bridge Processors microcode.
2012/05/11
1. System BIOS 1.00.04 and EC firmware 1.00.04 for P151EM1 only.
2012/05/04
1. System BIOS 1.00.04 and EC firmware 1.00.04 for P150EM only.
1. EC firmware 1.00.13.
2011/10/28
2. Solve “sometimes screen flickers” issue.
2011/09/16
1. EC firmware 1.00.12.
2011/09/09
1. System BIOS 1.01.14.
2. Solve “CMOS Boot Sequence can’t show some USB3.0 devices” issue.
3. Run update.bat in pure DOS evironment to update system BIOS.
2011/08/05
1. System BIOS 1.01.12.
2011/07/15
1. EC firmware 1.00.11.
2011/07/01
1. EC firmware 1.00.10.
2. Support ATI HD6990M VGA card.
2011/05/06
1. System BIOS 1.01.11 and EC firmware 1.00.07.
2. Support nVIDIA GTX560M VGA.
2011/04/22
(need to update LAN driver to 6.0.26.6 or later)
2011/03/25
1. System BIOS 1.01.06 and EC firmware 1.00.04.
2. Solve F2 and F7 keys no function issue.
3. Modify DMI data.
2011/02/25
2011/01/14
1. System BIOS 1.00.03 and EC firmware 1.00.02.
1. EC firmware 1.00.11 for W86xCU/-3D only.
2010/9/20
1. System BIOS 1.00.18 for W86xCU and W86xCU-3D only.
2010/9/17
1. System BIOS 1.00.16 for W86xCU and W86xCU-3D only.
2010/8/6
1. System BIOS 1.00.15 for W86xCU/W86xCU-3D only.
2. Add Intel K0 stepping CPU micro code.
2010/6/11
1. System BIOS 1.00.14 for W86xCU only.
2. Solve "HDMI audio no function witn nVIDIA GTS 360M VGA card" issue.
2010/5/21
2010/4/30
1. System BIOS 1.00.13 for W86xCU only.
2010/2/25
1. Sysem BIOS 1.00.11 and EC firmware 1.00.10 for W86xCU only.
2009/12/11
1. System BIOS for W86xCU only.
2. Solve system can't show 4GB system memory issue.
Volle 2 Jahre Garantie auf die Karte, klingt ja recht gut
Edit:
Tag 8 wo mein 170hm bei goldenstar/clevo ist - auf Rückfrage, was mit meinem Book ist und wann ich mit einem Rückversand rechnen kann bei goldenstar => keine Antwort seit 28 Stunden, von hawkforce gestern antwort bekommen, dass noch keine Informationen vorliegen und das Gerät auch noch nicht bei Ihnen ist.
Schade - sowas nervt und ich benötige das Ding mal wieder um etwas arbeiten zu können.
Frage daher => hat jemand ähnliche Erfahrungen mit RMA bei Goldenstar/Clevo gemacht?
Das Gerät ist Dienstag letzte Woche bei goldenster eingegangen - geht ja nicht um mein Paket sondern die auskunftsfreudigkeit des Schuppens.
Als Kunde erwarte ich bei einem Garantiefall nach gewisser zeit eben eine Auskunft, was kaputt ist und wann ich mit einem Abschluss des rma rechnen kann - naja nun weiß ich wieso du bei Dell mehr zahlst, der Service ist grandios, clevo liegt im mittel mit Panasonic - die brauchen auch ewig und ohne Rückfrage weißt nicht, wie es mit der Bearbeitung aussieht ;-)
"...noch nicht bei IHNEN ist..." = hawkforce, nicht goldenstar. schreib deutlicher! ;-)
rma meines nb hat insgesamt fast 4 wochen gedauert. ich hock aber auch in wien und habe es via hf dazwischen abgewickelt. ich glaube, es war knapp 1 woche bei clevo. bin aber nicht mehr sicher. laut hf lassen die das Gerät länger laufen nach Reparatur, damit die sehen, ob es passt. lasttests und so. ruf goldenstar an, was damit ist. oder sie haben es schlichtweg übersehen bis jetzt.
Ich finde meine Ausdrucksweise ist verständlich, steht ja im Satz das es bei Goldenstar ist seit 8 Tagen ;-)
Hawkforce hatte ich zuerst kontaktiert zwecks einer zwischeninfo, da hatte man keine Info seitens Goldenstar vorliegen, als auch kein Gerät erhalten, weil ich es auch über Hawkforce abgeleiert habe zum prüfen. Daraufhin habe ich selber Goldenstar kontaktiert.
Habe nun seitens Hawkforce heute morgen eine Email bekommen, dass das Gerät auf dem weg zu ihnen ist. Und das auch Hawkforce nicht klar ist, wieso goldenstar keine Info weitergegeben hat. Na dann warte ich mal auf die Kiste ;-)
Hallo
Habe momentan wieder ein kleines Problem mit meinem P170HM (XMG P701)
Ich benutze momentan Windows 8. Hotkey-Treiber von der XMG-Seite wurde installiert.
Die FN+... Hotkeys funktionieren auch einwandfrei. Lediglich die Helligkeit meines Displays lässt sich nicht mehr Regeln.
Weder unter Windows in den Optionen, noch per Hotkey Treiber die "Balken" werden angezeigt und der Regler wechselt von 0 auf 100 aber die Helligkeit des Displays reagiert nicht.
Bei niedrigem Akku kann der Laptop seltsamerweise die Helligkeit verringern Manuel lässt sich aber auch dann nichts einstellen.
Hat jemand einen Lösungsansatz für mich?
Gruss vorny
ich hatte nach 2 Tagen win8 beim 370em genau dasselbe Problem. deinstallieren und erneutes installieren der Anwendung brachte nix... auf win8 gepfiffen und wieder win7 drauf, das 8er kann nix besser ausser schneller booten.
---------- Post added at 22:34 ---------- Previous post was at 22:29 ----------
Ich Nutze Win 8 jetzt schon sehr Lange und möchte nicht wieder auf Win 7 zurück. Was mich irritiert ist einfach das sämtliche Einstellung der Hotkey Tasten einwandfrei funktionieren. Außer halt die Helligkeit dazu kommt das diese im Windows auch nicht mehr Manuel regalbar ist.
naja 600 Euro für eine Notebook Karte ist halt recht happig wie ich finde ;-) Solange die aktuellen Spiele recht gut laufen, werde ich nicht unbedingt wechseln - mal schauen wie es in der zweiten Jahreshälfte aussieht.
im 2. Halbjahr gibts schon die neuen gpu/cpu Generationen. magst nicht lieber bei einem neuen book zuschlagen? meine bastelkarte willst nicht? hab dir mal eine pn geschickt. ..
Gesendet von meinem GT-I9300 mit der Hardwareluxx App
Hallo
Gruss vorny
@all: Der Folien-Mod - damit das Book Kühler und leiser wird... Jaja, die GPU mache ich am Wochenende nochmal neu ;-)
Von Oben:
CPU:
GPU:
Was habe ich benutzt?
• Tesa Aluminium Tape für 7,99 Euro aus dem OBI
Was bringt es?
• In Game und Benchmark durch den verbesserten Luftstrom ca. 5 - 7 Grad niedrigere Temperaturen, da die Luft nun durch die Heatsinkenden gepustet und nicht seitlich im Gehäuse verteilt wird. Desweiteren ist das HM nun im Office Betrieb angenehm leise.
Würdest du es nochmal machen?
Bei jedem Barebone das die Möglichkeit dazu bietet - effektiv und günstig.
UPDATE:
Habs am WE nicht geschafft die GPU nochmal neu zu machen, werde aber sowieso die CPU neu machen müssen, sobald mein 2760QM eingetroffen ist - mache dann beide nochmal frisch, ggf. nochmal neue WLP und dann schauen wir mal. Im April kommt dann eine Next-Gen GPU rein vom Schlag 7970M oder 680M - lieber wäre mir die NVIDIA; hatte seit Jahren keine mehr und die Eigenschaften der Karte sind einfach etwas performanter - zudem kein vBios rumspielen notwendig, es reicht eine Karte für das EM-Model, damit das Ding out-of-the-box funktioniert.
Benchmarks habe ich bereits dokumentiert für die aktuelle Konfig
Heute ist mein Intel 2760QM eingetroffen, habe ich gerade verbaut und status quo damit erstmal bei Sysprofile aktualisiert, mache noch geschwind ein paar 3D Mark benches, dann hätte ich alle 3 Stadien des Books dokumentiert.
Zwecks dem Umbau, ich schau mal wie ich Lust habe mit der Kamera - aber geplant ist ein kleines Tut, wie wo was eben.
Update:
Noch keine Neuigkeiten seitens Notebookguru/Barebone bekommen, es hiess die Karte soll gestern auf die Reise gegen per NN; aber eine Antwort auf meine Rückfrage ob das auch passiert ist, steht noch aus.
Update 2:
GPU ging grad erst per NN auf den weg, hoffe das Ding kommt morgen - dann kann ich am Wochenende umbauen ;-)
@F1r3: du wirst es nicht bereuen, ich habe die 7970m seit letztem Jahr Oktober in meinem 170HM. Da geht aber noch mehr, habe mit meiner bei 3DMark11 Performance ca. 7200punkte und im 3DMark 13 ca. 5080Punkte. Karte läuft auf 1000/1560MHz aber noch mit einem 2670QM, der 2860QM ist unterwegs
Bekomme eine Austausch 7970m asap - meine hat schmauchspuren am platinenrand - solange bleibt der clevo erstmal inaktiv und ich kann das Tut nicht schreiben - narf
Update:
Neue Karte wurde um 14 Uhr mit dem passenden VBios gemoddet und befindet sich seit 14.45 Uhr auf dem weg zu mir. Mit viel glück ist das gute Stück morgen bei mir
Update 2:
Die AustauschKarte ist defekt - Stehe in Verhandlung wie es nun weitergeht.
Ja das dies alles nicht so wirklich funktioniert beim P570WM hab ich teilweise auch schon festgestellt und im Sammeltopic angesprochen ... kann ich beim besten Willen nicht nachvollziehen, wenn man sich vor Augen hält, das sich dies Gerät ca 1 Jahr verspätet hatte!
Update: Seit dem Wochnende keinerlei Reaktion auf meine E-Mails bekommen.. So sieht leider kein guter Service aus.. Sitze also nun auf einer Schmauchspurenkarte mit 2D Bildfehlerchen und einer bei 3D abstürzenden 7970M fest. Hätte ich bloss die 6970M drinne gelassen..
Nur um das nochmal zu verstehen: Du hattest eine 7970M gekauft und auch bekommen. Diese funktioniert auch einwandfrei aber hat "Schmauchspuren (???) am Platinenrand" (Edit: und 2D Bildfehler). Dann wurde dir eine zweite Karte geschickt, welche nun aber auch nicht funktioniert (3D Abstürtze)?! Hast du die zweite nicht im Austausch bekommen für die erste oder hast du beide bezahlt?!
