[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
Danke für den Sammler. Hier mal meine Beiträge zur Taichi Kompatibilitätsliste:
CPU-Kühler: Cryorig R1 Ultimate | | kompatibel | keine Einschränkungen
RAM: Corsair Vengeance LPX 32GB CMK32GX4M4A2400 | 4 x 8GB | DR | kompatibel | keine Einschränkungen, BIOS P2.20 XMP-Profil aktiviert@2400 14-16-16-31
@darkpope: ich habe ein paar Ergänzungen beim RAM gemacht
Dankeschön, Tipfehler sollten raus sein und Ram & Kühler nachgetragen. Ich werde erst heute Abend mal wieder reinschaun können. Ansonsten, wenn jemand noch was hat, immer her damit. Mein Board ist noch im Trockenaufbau ohne BS, ich komme wohl erst am Wochenende dazu. Dann gibt es von mir auch ein paar Neueigkeiten.
Habe deinen Thread in der Sammelthread und AM4 Übersicht verlinkt :wink:
Danke für den Sammler:
Hier mein RAM für die Liste:
G-Skill Trident-Z16GB, DDR4-3200, CL16-16-16-36 2N (F4-3200C16D-16GTZ) | 4 x 8GB | DR | SuLux | kompatibel | Bios 2.30 @1,35V 2666 CL14-14-14-34 1T
G-Skill Trident-Z16GB, DDR4-3200, CL16-16-16-36 2N (F4-3200C16D-16GTZ) | 4 x 8GB | DR | SuLux | kompatibel | Bios 2.30 @1,35V 2933 CL14-14-14-34 1T ( BLCK 110x36,5 )
Vielleicht wäre es sinnvoll, zumindest bei den Corsair Speichern auch die Version anzugeben - da gibt es unterschiedliche Bestückungen, die teilweise nicht richtig laufen.
Ja, das wäre vielleicht sinnvoll. Meine sind Samsung V4.24.
Danke für die Infos, hab ich alles nachgetragen. Mich würde noch interesserieren, welche CPUs ihr verbaut habt, und ob die @Stock / Default oder doch übertaktet laufen.
Apropos, der Asus Prime x370 Sammelthread hat eine schöne Übersicht über die Spannungswerte innerhalb der CPU.
Also bei mir ist es ein R7 1700, läuft für 24/7 auf 3,9 GHz mit 1,35V und LLC Stufe 3 im Bios eingestellt. Maximal kann ich für Singlecorebenchmarks mit 1,5V bis zu 4,15 GHz erreichen, allerdings ohne SMT und mit 6 deaktivierten Kernen^^
Hat jemand von euch P-States konfiguriert? Ich hatte bisher noch keine Zeit da rumzuspielen, würde mich aber mal interessieren, ich mag es nicht wenn die CPU permanent mit 3,9 GHz rumgurkt.
Mein 1600X läuft mit P-States auf 4GHz. Hab nur P-STATE 0 konfiguriert. Taktet schön runter.
von die Handy
Weiß jemand ob die G.Skill Trident Z RGB DDR4-3866 DIMM CL18 Dual Kit als Vollbestückung auf mindestens 3000mhz laufen werden beim Fatal1ty X370 Professional Gaming ?
Sind 4x 8GB Riegel.
Gesendet von meinem SM-G935F mit Tapatalk
Diese RAMs hab ich bei mir auf dem Taichi getestet - alle sind kompatibel ohne Rumgefummel bei den Einstellungen - nur XML geladen
Corsair Vengeance LPX 3000(CMK16GX4M2B3000C15) Version 5.30 | 2 x 8 GB | SR | Kullberg | kompatibel | @2933 CL16 | läuft erst seit BIOS 2.2, hat Hynix Chips
Corsair Vengeance LPX 3200(CMK16GX4M2B3200C16) Version 5.39 | 2 x 8 GB | SR | Kullberg | kompatibel | @3200 CL16 | läuft erst seit BIOS 2.2, hat Hynix Chips
Crucial Ballistix Tactical 2666 (BLT2C8G4D26AFTA) | 2 x 8 GB | DR | Kullberg | kompatibel | @2666 CL16 | keine Einschränkungen
Die Nächsten haben kein XML - die laufen auf 2400 ohne dass man im BIOS was einstellen muss
Kingston ValueRAM DIMM 16GB 2400 ECC (KVR24E17D8/16) | 2 x 16 GB | DR | Kullberg | kompatibel | @2400 | 2 Einzel-Module, ECC funktioniert, OC bis 2666 möglich
Crucial VLP 2400 ECC (CT2K16G4XFD824A) | 2 x 16 GB | DR | Kullberg | kompatibel | @2400 | ECC funktioniert, OC bis 2933 möglich
p.s. CPU ist ein Ryzen 7 1800X ohne OC
Probiers doch einfach aus? :d Ich bezweifle dass du sie bei anderen Boards höher bekommst als auf dem Board. Selbst wenn machen die paar MHz keinen Unterschied wenn man nicht gerade ein permanentes CPU Limit erzwingt, wäre allerdings beim Gaming schon eine Art Armutszeugnis wenn man es nicht schafft die Grafikkarte ins Limit zu pushen ;)
Probieren werde ich erst in 14 Tagen, denn muss vorher den FX verkaufen.
Wie wird bei euren Taichi denn die VCore ausgelesen? Ich hab jetzt bei 3 Tools, vier verschiedene Spannungen.
A-Tuning zeigt unter OC die selbe Spannung an, die ich im UEFI eingestellt habe: 1,225V. Unter Systeminfo sind es 1,216V
Ryzen Master zeigt 1,1875V an. Wobei da hab ich mich nicht mit beschäftigt. Wird da die momentane Spannung angezeigt oder nur ein Default-Wert?
CPU-Z zeigt 2,432V an, was genau dem doppelten Wert aus der Systeminfo von A-Tuning entspricht. Das sieht für mich nach einem Fehler aus. Das selbe zeigt auch HWMonitor.
Außerdem noch eine allgemeine Frage:
Beim Tachi lässt sich ja kein einzelner Wert für den Multi einstellen. Ich gehe davon aus, dass wenn ich die Frequenz im UEFI fix einstelle, der Multi geändert wird und der Basistakt unangetastet bleibt?
Ich frage deshalb, weil CPU-Z das ganze wie von mir gedacht anzeigt, im A-Tuning Tool jedoch die APU/PCIe Frequenz (die dem Basistakt entspricht?) bei 160Mhz steht was mir sehr hoch vorkommt...
Sorry für die Einsteigerfrage aber mein letzte Prozessor den ich ein wenig übertaktet hatte war ein Athlon X2 64 :fresse:
Huhu, bei mir auf dem Gaming Professional laufen die
G.Skill Trident Z RGB DIMM Kit 16GB, DDR4-3600, CL16-16-16-36 (F4-3600C16D-16GTZR)
sowohl unter Bios-Version 2.20 als auch 2.30 einwandfrei mit 3264MHz (CL16) @1.35V :)
Der Heatkiller Rev3.0 mit AM4 Umrüstkit macht auch keine Probleme und passt perfekt!
@Tanatos
Danke für die Bestätigung, dann werden auch meine laufen, da die ja sich nicht unterscheiden groß.
Aber hattest du nicht nach 4x8GB gefragt? Ich hab nur das 16GB Kit mit 2x8GB^^
Mein Kit ist auch 2x8 GB nur das ich zwei da hab.
Natürlich hoffe ich auf Vollbestückung, aber es freut mich trotzdem das die überhaupt drauf gut laufen. Falls mein Plan nicht 100%ig funktioniert verkauf ich einfach ein Set.
Ich hoffe mal, dass ich alle Beteiligten beim Nachpflegen erwischt habe, danke schon mal für eure Mühen. Falls nicht, schreibt mir kurz.
Meinen R5 habe ich erstaml auf 3700 gebracht (ohne Mühen) und beim Speicher die Timings auf CL14 gesetzt. Kann es sein, dass die Tacticals nicht per se auf 2933 laufen, da kein passendes XML-Profil exisitiert?
Danke mal vorweg an darkpope für die Erstellung des Sammlers! :coolblue:
Ich habe seit BIOS 2.10 eigentlich kleinere Probleme mit meinem Prof.Gaming! Werde aber später noch einiges dazu schreiben.
Ich habe meinen 1800er jetzt mal default laufen um diverse Problemchen abzuchecken.
Ich konnte meinen Ram mit dem 2.00 Bios noch auf 3200 laufen lassen, allerdings mit wirklich schlechten Timings. Seit 2.10
zickt das Brett irgendwie ein bisserl rum. Momentan scheinen zumindest die 2666 stable zu sein.
Falls das ein Retail Kit ist, dann versuch es noch mal mit einer aktuelleren Version von Thaiphoon. Bei den G.SKILL Kits sollten IC Hersteller und IC Typ eigentlich korrekt im SPD hinterlegt sein.
(würde mich über einen SPD Dump + Screen für [Sammelthread] HARDWARELUXX SPD Datenbank DDR4 IC Liste freuen)
Kann es sein das man bei der alten FX Plattform die Chips garnicht mit Thaiphoon auslesen kann?
Diese Informationen im SPD zu hinterlegen ist erst bei DDR4 so richtig in Mode gekommen.
Alles klar.
Hatte schon gedacht das es am Mainboard liegt.
