[Sammelthread] Intel Core 2 Duo "Wolfdale" 45nm | OC-Thread & Liste (7)
So, 5100Mhz sind im Kasten:wink: mit 1,416 Vc.:love:
Morgen geht es an die 5200Mhz. :wink:
Ich hätte nicht gedacht das ich das stabiel bekomme. Bilder kommen Morgen für die Liste.
Wird die Liste noch gepflegt?:motz:
Was ist denn in deiner SIG Laing HArdwareluxx edition??
[FONT=&quot]ASUS P5Q DLX Template :[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]JumperFree Configuration Settings[/FONT][FONT=&quot]
AI Overclock tuner: Manual
CPU Ratio Setting: 9[/FONT]
[FONT=&quot]FSB Strap to North Bridge: 333
FSB Frequency: 500
PCI-E Frequency: 100
DRAM Frequency: 1002[/FONT]
[FONT=&quot]DRAM CLK Skew on Channel A1: Manual [/FONT]
[FONT=&quot]DRAM CLK Skew on Channel A2: Manual[/FONT]
[FONT=&quot]DRAM CLK Skew on Channel B1: Manual[/FONT]
[FONT=&quot]DRAM CLK Skew on Channel B2: Manual
DRAM Timing Control: 5-5-5-18-60[/FONT]
[FONT=&quot]DRAM Static Read Controll: Dis[/FONT]
[FONT=&quot]DRAM READ TRAINING: Dis[/FONT]
[FONT=&quot]MEM OC CHARGER: Dis[/FONT]
[FONT=&quot]AI CLOCK TWISTER: lighter[/FONT]
[FONT=&quot]AI TRANSACTION BOOSTER: AUTO[/FONT]
[FONT=&quot]
CPU Voltage: (real 1,208)
CPU GTL Voltage Reference (0/2): 0,63 (also standart)[/FONT]
[FONT=&quot]CPU GTL Voltage Reference (1/3): 0,67 (auch)
CPU PLL Voltage: 1,52
FSB Termination Voltage: 1,2
DRAM Voltage: 2,1 (real)
NB Voltage: 1,3v
NB GTL Reference: 0,55 (ging bisher am besten)
SBridge Voltage: AUTO[/FONT]
[FONT=&quot]PCIE SATA Voltage: AUTO[/FONT]
[FONT=&quot]Load Line Calibration: Enabled[/FONT]
[FONT=&quot]CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled[/FONT]
[FONT=&quot]CPU Clock Skew : Normal[/FONT]
[FONT=&quot]NB Clock Skew : Normal
Advance CPU Settings
CPU Ratio Setting: Manual
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled[/FONT]
[FONT=&quot]Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
[/FONT][FONT=&quot][/FONT]
CPU GTL Voltage Reference (1/3): 0,67 (auch) = Beide Mal auf 63
CPU PLL Voltage: 1,52 = Für 500FSB definitiv auf 1,6V !!!
FSB Termination Voltage: 1,2 = auf 1,12V (wie du schon sagtest)
PCIE SATA Voltage: AUTO = Beides auf die kleinste stufe einstellen !!!
Probier mal diese settings und dann evtl. mit nem 400 Nb Strap !
Na ich lasse jetzt erstmal ne weile prime laufen, bis die "k" durch sind, bei denen es bisher haperte, und dann teste ich mal! Aber glaube nicht das er wieder bootet wegen den VTT!
Strap soll laut Perl_Freak nicht bei 400 Stabil zu bekommen sein, er hatte das board auch! Es startet auch garnicht bei 400 bei mir!
Deswegen sagte ich ja,probier mit 400 ansonsten nimm 300 !
Bei mir lief es z.b. nur mit 400 :hmm:
Oder ein Tip am rande,wenn du net undervolten willst,hau es in den MP und besorg dir das DK P45 Plus ;)
Hab ich auch mit dem PC vom kollegen gemacht (schreibe gerade damit) läuft richtig gut das board und das mit Beta Bios :drool:
ja echt zum kotzen!
Was kommt nach 384k?
In der logdatei steht, 384 Passed, und dann ist ende! Also müsste ich ja das testen was danach kommt oder? Dann muss ich nicht immer von vorne anfangen oder?
Hab es gerade durchlaufen gesehen, nach 384K kommt 24K, also hapert es an Vcore
Wie ist das beim DK P45 PLus zeigt es auch mehr an als anliegt unter windows?
Hab ich noch net getestet,mache ich morgen da ich heute schon was getrunken habe und nix put machen möchte :d
Aber für dich wär das eh nix da du ja undervolten willst !
Ging nicht wie ich mir dachte! nun die vtt wieder auf 1,2 und es geht weiter das testen! Schon seltsam!
Wieso das ist doch am geilsten ;) Angetrunken kann man am besten ocen weil man sich nicht aufregt wenns nicht geht;)
Ja nee is klar,ich fummel mit dem DMM im gehäuse run und dann komm ich noch an irgend ein teil wo ich ne drann kommen soll und mein Arbeitskollege dem der Rechner gehört hängt mich an den Eiern auf :fresse:
E8400 OC-Problem
Hallo zusammen,
bin neu hier also bitte nicht verschreien wenn die Frage schon gestellt wurde:hail:!
Also zuerst mein Sys vielleicht:
C2D E8400
Asus P5E
Asus GTX280
4 X 1 GB Corsair XMS2 6400
Tagan PipeRock 500 Watt
So nun zu meinem Problem:
Ich bekomme den "Kleinen Schei..." einfach nicht stabil bei 4Ghz laufen!
Momentan läuft er bei einem VCore von 1,29V Stabil mit FSB 415/ 3.73Ghz!
Acu finde ich die Temps schon etwas hoch, hab nen Mugen drauf und hat bei Leerlauf schon gute 45° C! Für was sind denn die GLT-teiler im Bios gut?
Ich hab eigentlich durchweg im Bios dem FSB und der NB 0,2V mehrgegeben, aber wie gesagt der will nedd Stabil laufen mit Prime!
Für guten Rat bin ich jederzeit dankbar!!
MfG Bandit480
wie kann das sein das die 1,12 nicht wollen? Bin echt ahnungslos und kapier das nicht!
@ Kr0n05
Probier es aus ;)
@Prof.66
Gibts bei dir sowas wie GTL's ???
was sagen deine restlichen settings ???
Aber 10V auf der 12V schiene scheinen mir etwas zu wenig obwohl du ein gutes NT hast !
habe schon das 1201 drauf (usb), mal sehen, bin ich mal gespannt!^^ Wenns dann auf anhieb funzt mit der VTT dann wäre ich neuen Mutes!
Ja ich weis aber everest liest das falsch aus würde ich sagen, da ich im Bios eigentlich über den 12V bin zumindest zeigt es mir das an,
GTL´s gibts ja aber wie gesagt ich hab da nicht wirklich den Plan davon, restlichen settings stehen eigentlich alle auf Auto bis eben die timings und die Spannung (1.9V) vom Speicher.
Dann solltest du dich mal ans testen der Spannungen machen und sie einstellen ;)
evtl. mal in einem sammelthread für dein board nachfragen !?!?
Im Bios kann man bloß nicht die Spannungen sehen die im Load anliegen.
Das ist richtig, aber wie gesagt in Load modus ist ja alles Top sobald ich aber wieder im Idle bin bekomm ich Blue Screen.
Und die Spannung ändert sich nicht laut everest egal ob Idle oder Load
