lordberti
Experte
- AMD Ryzen 9 9950X3D (SP 120)
- ASUS ROG CROSSHAIR X670E EXTREME (Bios 3102)
- PHANTEKS Glacier One 360 T30 Gen2
- Corsair CMP64GX5M2B6000Z30 (6200 MT/s)
- ASUS ROG Astral GeForce RTX 5090 OC Edition
- LG OLED42C27LA
- WD SN850XBlack
- Phanteks NV7
- Seasonic PRIME TX-1600 ATX 3.1 Noctua Edition
- Windows 11 Pro Voll.
ASUS Pressemeldung: AEMP III Unterstützung für die Neuen Kingston 64GB DDR5 CUDIMM Module wenn 256 GB Installiert sind
edgeup.asus.com
Zudem:
AEMP III Unterstützung mit 256 GB für die ASUS Z890 Boards mit neuem Beta Bios 1401, jetzt auch über die jeweilige Produktseite des jeweiligen Mainboards.
rog.asus.com
ASUS AEMP and AEMP III give you a seamless experience with the new Kingston 64GB DDR5 memory modules - Edge Up
AEMP III makes sure that you can easily get Kingston's new 64GB DDR5 modules up and running -- and it provides a healthy speed boost, too.
Zudem:
1401 Beta Version
2025/01/10
Support up to 5600MT/s when running the maximum memory capacity of 256GB. The exclusive ""AEMP III"" option will appear when four Kingston RAM DDR5 6400MT/s 64GB CUDIMMs are installed.
ROG MAXIMUS Z890 HERO | ROG Maximus | Gaming motherboards|ROG - Republic of Gamers|ROG Global
The ROG Maximus Z890 Hero is ready for Advanced AI PCs. It makes builds soar with 22+1+2+2 power stages, hyper speed DDR5 support and the latest PCIe® 5.0 conne
