[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich würde auch erst mal abwarten intel muss sich erst mal beweisen mit chiplett wie gut das fehler frei funktioniert oder obs problem gibt und wie die leistung ist bei amd ist halt klar was komt aber ich nehm dann das was stärker ist effizienter ist mir eh egal.
Und selbst wenn nicht, die Teile kosten nicht die Welt. Muss ja nicht dieses ASUS-Teil sein...
So eine reicht dicke aus und kommt bei mir selbst zum Einsatz:
Amazon-Link
Die hätten noch für paar Cent eine verschiebbare Hülse verbauen/dazulegen sollen (ähnlich einer Teleskopstange), damit man die Gewindestange nicht sehen muss
Hast Du schon Deine Gas- bzw. Ölheizung rausgerissen, eine Wärmepumpe und ein E-Auto gekauft? Ansonsten werden wir demnächst überschwemmt oder ausgedörrt, je nach dem, was gerade passt.
"Hal Harvey" sei "Dank"
Fanboy und auch noch stolz drauf, i like it 👌
Jeder sollte seinen eigenen Scheiß ownen 🤘
mein letzter Intel ein Pentium MMX
Core 2 Duo^^
Plant noch wer seine TUF/Strix auf Wasser umzubauen?
Überlege, ob das vor RTX5000 noch lohnt^^
Selbst dann wenn AMD in den Benchmarks vorne liegt und effizienter ist?
Würde amd nicht mal kaufen wenns doppelt so schnell wie Intel wär, ist für mich einfach eine Müllfirma, alleine der Move dass sie heuer keine High End GPU bringen weil sie zu blöd sind NVidia auch nur Ansatzweise nahezukommen ist einfach peinlich
Und du denkst, Intel ist als "Umweltsau" auf dem richtigen Weg? :d
Die sollten mal an der Performance pro Watt arbeiten. Da hat AMD die Nase weit vorne... ;)
Nein Intel ist auf nem falschen Weg, weil sie die konkurrenz unterschätzt und geschlafen haben jahrelang, ich mag sie als Firma dennoch lieber als AMD. Am Besten wäre wenn Nvidia auch noch in den CPU Markt einsteigt und blau und rot zeigt wies geht
Intel konnte AMD dank Hohen Takt und gutem Speichercontroller immer auf augenhöhe halten aber jetzt mit einer neuen Fertigung müssen sie was liefern weil die 12/13/14 waren ein Super CPU´s haben halt nur gesoffen wie ein loch aber wer Hohen Takt will muss immer 1 tod sterben
Und die Wahrheit ist halt auch das AMD nur beim X3D effizient, weil sie kein höheren Takt fahren könne weil die cpu bei mehr Spannung schnell stirbt und der 3D Chance schlecht wärme leitet wenn die könnten würden die das auch mit viel mehr Takt fahren weil was ist aktuell schon 5GHZ und Amd interessiert sich ein scheiß führ die Umwelt außer man glaubt an Weihnachtsman. Soll nicht heißen das Amds cpu grad nicht sehr gut sind.
Wenn man mal AMDs/Intels high end Desktop cpu vergleicht beim mir hat 7950x 280watt bei 95C° Tjmax also ins Temperatur Limit mein 13900ks war ca. 335watt 100c° Tjmax da ist, wenn man hoch rechnet Amd nicht viel effizienter, sondern setzt früher ein temp Stopp und Amd lässt sich schlechter kühlen. Und AMD hat bei mir ca. 40000 Punkte vs. Intel 43000 also ca führ gleiche Leistung wäre der Verbrauch ca. gleich so sehe ich das und wär besten Takt oder Leistung haben (Roh Leistung) der braucht halt Strom geht ja auch nicht immer nur um Gaming.
Immerhin hast du schonmal 2 zusätzliche Satzzeichen für @NamaNatranius dagelassen :bigok:
Mein letzter AMD war ein X2 6400 🙈
haste noch? am besten in OVP :asthanos: ??
Willst Du loswerden? :p
meine TUF hat schon einen Wasserkühler, aber die beiden Strix und die Heatkiller liegen hier, aber ich finde die Luftkühler so gut, dass ich eigentlich den Umbau schon die ganze Zeit vor mir her schiebe.
Meistens wäre der Grund für den Umbau wirklich nur die Größe des Kühlers.
Wenn ich mir die geforderte CPU Leistung bei den Unreal Engine 5 Titeln so anschaue, ist es im Prinzip bums welche CPU da reingeschraubt wird.
Mein 13600K benötigt bei Hellblade 2, an die ~40 Watt avg. Dafür hat die 4090 in 4K ordentlich zu tun.
Wird Zeit das die 5090 kommt :)
Hellblade 2 sieht aber auch zum niederknien geil aus und hört sich (mit Kopfhörern!) absolut fantastisch an. 🤩
Musste aber noch per ini Eintrag paar Sachen wie Chromatische Aberration, schwarze Balken oben und unten und den Film Grain entfernen.
Kostet zwar paar FPS, insbesondere die verschwundenen Balken aber bin mit FG und DLSS Q trotzdem selten unter 110FPS unterwegs in 4K@Max 👍
Fand das Game auch ohne FG echt smooth mit Controller. Waren ja meistens 70-80 FPS.
Hab ja dann Hellblade 1 nochmal gezockt und das sind Welten zwischen UE4 und UE5 was Frametimes Shaderladen und so angeht.
Also bisher bin ich von der UE5 Enginge begeistert. Bei UE4 gehts dann mit DX 11 halbwegs brauchbar ,aber DX12 ist schrecklich auch mit anderen Games wie Hogwarts oder so.
Hab dann Hellblade 1 sogar lieber in DX11 gezockt , weil DX12 war einfach schrecklich von Ruckler etc.
Hab dann lieber auf Raytracing verzichtet.
Ja habe extra vorher auch noch Hellblade 1 gezockt, da hat es echt immer wieder geruckelt… Hellblade 2 hat bisher nach 5 Stunden nicht ein einziges mal gezuckt.
@MS1988
Aber Spiel mal das UE5 Game Immortals of Aveum (aktuell im Game Pass), dass ruckelt und zuckelt an jeder Ecke… furchtbar. 🤮
ansonsten macht Nvidia nun endlich das was man bei AMD schon lange kann..
Verstehe ich nicht. Ein Tool, mit dem man die Software rausfahren lassen kann, was an OC geht, hat nVidia doch schon vor Ewigkeiten (Release Turing oder kurz danach) zur Verfügung gestellt. Sie haben halt keine GUI dazu geliefert und es wurde dann als OC Scanner unteranderem beim MSI Afterburner oder eVGA Precision X eingebaut. Das was da im Hintergrund genutzt wird, kam aber schon immer von nVidia. Beim Curve Editor das gleiche. Da greifen Afterburner und Co auch nur auf Schnittstellen zu, die nVidia in den Treiber eingebaut hat.
Die einzige Neuerung ist es also, das nVidia nun einen Teil davon direkt über eine eigene GUI zugängig macht.
Ähnliche Themen
