[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Na ja - Vorteil: kein Stecker in der GPU / Nachteil: gleicher Stecker im Mainboard -> dann wieder Vorteil: Mainboard ist nicht so teuer, wenn es abfackelt :ROFLMAO:
Am Mainboard ist aber mehr Platz für den Stecker und man tauscht es auch nicht so häufig. Ich sehe das schon als Vorteil. Vielleicht bieten Case Hersteller einen konkreten Kabel Kanal oder derlei.
Dass BTF Standard wird (was zu begrüßen wäre) kann ich mir nicht vorstellen. Da müsste sich w wenigstens noch ein Hersteller anschließen. Werde mit aber mit Arrow Lake so ein Board holen. Kann ja sein dass die Asus Karten nächstes Mal wieder "normal" Fiepen, wer weiß. Und dann ist es schon ziemlich cool, so ganz ohne Kabel an der Graka.
Also mein BeQuiet 16pin 90° kabel kam eben an und das sind WELTEN!!!!!! gegenüber dem MODDIY Kabel von der Qualität
Das Bequiet hat super steife kabel nix wabbelt mehr wie bei dem MODDIY und der Anschluß viel Robuster und wenn man den Anschluss leicht bewegt dann begwegen sich keine Kabel gegenüber dem MODDIY sieht man richtig wie die kabel sich bewegen und so kommt es vlt auch dann das die pins leicht rausrutschen und nicht mehr fest sitzen
Jein - kommt auf das Case an ;-)
Bei den neuen Corsairs stimme ich Dir zu
Naja zum Thema kommt aufs Case an ist zu sagen dass zu enge Platzverhältnisse sicherlich der Hauptgrund für diese Problematik ist. Da werden Kabel gebogen oder Adapter gekauft, weil jeder meint so ein schönes SFF System wie die Techtuber bauen zu müssen. Oder nicht bereit ist seinen Midi Tower abzulösen. Ne 4090 gehört aber nun mal in ein großes Gehäuse, auch wenn das viele nicht wahr haben wollen. Ne Garage muss auch breiter sein als die Karre damit man noch raus und rein kommt.
Ob ich es noch erleben darf, dass man 4K/HDR/RT-Gaming @120fps in ein USFF (~1Liter) packen kann? :)
Meine kleine Mini-Tiny-Sammlung, die ich heute komplettiert hab :fresse:
Es passen zumindest Low-Profile-Karten rein
Das wäre ja immer noch fast 8-12 Monate vor dem Release…
Wusste noch gar nicht das es von seiten Nvidia einen bestätigten Release zeit raum gibt dachte die machen das so wie die führ richtig halten. Wusste nicht das die sich schon an gerüchten orientieren. aber vieleicht hab ich auch was offiezeles übelessen. Ich wart dann mal ab :popcorn:
Wenn es nur der Stecker ist der in der Fassung schmilzt, sollte kein anderer Schaden entstehen. Man muss eben dann das "Weibchen" auf der Karte erneuern lassen (oder ist es doch das Männchen, denn die Pins sind ja auf der Kartenseite?). Zumindest war das bisher bei allen mir bekannten Karten so.
Die neue „Pico-Strix“ :ROFLMAO:
Nachricht gelöscht
Das Ding auf der Karte ist eigentlich wenn man es genau nimmt der Stecker ja :)
In der modernen Zeit darf sich der Stecker und die Buchse als das definieren, was es sein will :d
Der weibliche Stecker und die männliche Buchse :fresse:
puh... "alles fitti im feinrippschlüppi?" ich krieg den spruch nimmer weg, danke für die buchse^^ xD
8-12 Monate? Die kommt doch safe heuer noch im Oktober, so wie immer halt
Safe ist gar nichts. Das entscheidet der Hersteller. Die Wahrscheinlichkeit eines „pünktlichen“ Release ist aber nicht gering, da die Fertigung von solchen High-End-Chips nicht mal eben neu gestaltet werden kann. Was ist aber, wenn NVidia schon länger mit einer Verschiebung plant? Es gibt keine Konkurrenz und aufgrund des KI-Booms gibt es auch andere Felder die bespielt werden wollen. Andererseits muss man das eine ja nicht lassen, wenn man das andere hochfahren will. Denn NVidia hat ja keine Fertigung, sondern beauftragt. Mal schauen, ob sie genügend Slots für eine Marktverfügbarkeit von neuen Chips halten.
Ich persönlich tippe aber auf Anfang 2025.
Soviel Arbeit in ein Gehäuse und dann mit dem 14900k den Kühlkreislauf grillen :)
Der verbrät ein Drittel von einer 4090?
Puh, ein Schelm wer denkt das es Leute geben soll die mit einem PC noch mehr machen als nur CyberPunk zu spielen...
Und ggü. dem 7800X3D kann der 14900K seine Wärme immerhin an den Kühlkreislauf weitergeben, die X3D laufen mit egal was für eine Kühlung immer am Temp Limit (Bauartbedingt)
Ähnliche Themen
Antworten
6K
Aufrufe
392K
