[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab mich jetzt "glaube" ich entschieden. Jetzt noch eine letzte Frage :d
Nehme ich die GameRock Active und flashe das GameRock OC Bios drauf (10€ unterschied)
Oder nehme ich direkt die GameRock OC :d
Gibt es sonst noch günstige Karten die ein dualbios haben ?
(Hat die KFA2 auch dual BIOS ?🤔)
Gamerock oc oder non oc ist völlig egal. Die non oc hat eben nur das Kabel mit 3 Anschlüssen, also max. 450W dabei. Wenn du eh ein direktes Kabel nutzt vom NT ist das zu vernachlässigen.
beste Grüße
Dankeschön für eure Hilfe.
Hab´s jetzt geschafft zu bestellen (GameRock + Alphacool Wasserblock) =)
Bin jetzt schon aufgeregt.
Berichte mal ob du noch die alte Rev bekommen hast oder schon die neuen auf den Gamerocks ist.
Beste Grüße
Werde ich machen,
was ist der Unterschied dabei ? Die 1.1V oder 1.07V ?
Du kannst am Ende über den Arschbrenner den Takt einstellen, den du willst. Du Chips sind bei den OC Modellen nicht selektiert, nur Marketing.
wäre ja nur interessant wenn man es bei den Taktraten belässt und dadurch ohne den "Arschbrenner" auskommt.
Richtig. Alte Rev. bekommt 1,1V max und die neue 1,07V max. Wenn die neue Rev wirst du auch kein Bios von Techpower auf die nonOC bekommen, da dort noch alle von der alten Rev sind.
Beste Grüße
Jupp Jupp, die Verpackung ist beinahe übertrieben massiv. Bei mir waren es 7,2 inkl. äußerem Karton
Da bringt die Strix inkl. allen Schichten nur 4,5kg auf die Waage.
Ich hätte ja eher erstmal eine Karte bestellt und geguckt wie hart das Ding fiept bevor ich nen waküblock ordere
Natürlich testet man die Karte vorher auf Herz und Nieren =)
Wenn alles passt und man auch zufrieden ist (2 Wochen Umtausch) kann man auch n anderen Block installieren.
m.M.n. aber ob andere es genauso machen...
Hitman 3 mit RT haut ja ganz schön rein. Die Karte zieht @4K Ultra mindestens 470W und liefert dabei 90FPS aufwärts. Mit PT auf 60% sind es dann noch 320W, der Takt sinkt auf bis zu 2000MHz. Dabei werden dann noch 70+ FPS geliefert.
Die Reflexionen sind schon großartig, in Dubai kommt man aus dem Grinsen nicht mehr raus und streichelt seine 4090 ganz lieb. Ansonsten ist die Grafik eher mau. Gerade die Vegetation sieht eher nach 2012 aus oder so.
Edit: Mit PT auf 120% und 200MHz dazu knackt man die 500W ganz easy.
Da wäre UV dann besser, weil er dann nicht die maximal mögliche Spannung die irgendwie ins PT passt draufpackt, dann kommt man auch mit dem Takt wieder höher, also für den Fall, dass man wirklich Stromsparen will und es nicht nur "mal schnell" ausprobieren wollte :>
Da wäre UV dann besser, weil er dann nicht die maximal mögliche Spannung die irgendwie ins PT passt draufpackt, dann kommt man auch mit dem Takt wieder höher.
Also ich lasse die Karte @ stock laufen, wollte nur mal kurz testen, wie der Verbrauch sinkt. Ich denke aber auch, UV wäre bei 24/7 Betrieb gesünder. Nur soll die Karte halt "saufen" was sie braucht. Ich arbeite da nur mit FPS Limits.
Was schon witzig ist: Bei 470W+ und ca 90 bis 100 FPS fiept die Karte absolut Null in Hitman 3. Während sie in RDR2 bei ca 350 bis 400W und etwa gleichen FPS gut zu hören ist. Das versteh einer.
Edit: Er sagt, man solle lieber nicht undervolten, da der Video Clock und Effective Clock trotzdem sinken, obwohl der GPU Clock gleich bleibt (ab 1:30).
  • Danke
Reaktionen: hwk
Ja der Effective Clock is je nach Auslastung vom eingestellten Takt so 50 Mhz weg, aber ist immernoch besser als Kopf voraus mit 1.1V (oder 1.07V) ins 60 oder 70% Power Target zu rennen und dann 2000 MHz anliegen zu haben :d
Vergesst doch die schei... Takt-Domänen und schaut, wie viel FPS ihr für wie viel Watt bekommt!
Dauerhaft 600W zu nutzen, wohl ehr nicht aber für OC versuche wäre es interessant. OC beim Zocken bringt eh nicht mehr viel.
Die Palit und die KFA2 haben aber nur ein kleineres Powerlimit.
Ob es sinn macht, mehr auszugeben und z.b. auf eine TUF zu gehen ? :unsure:
Hast du diese auch mit einem WaKü Block versehen? Bei den Blöcken ist leider immer nur die SG Variante gelistet.
Zudem habe ich irgendwo im HWLuxx gelesen, das jemand einen Alphacool Block auf die ST? Variante geschnallt hat und 1 bis 2 VRM nur halb
bedeckt waren.
Ich hab die SG Variante, wüsste nicht was für die ST spricht
Meine Zotac RTX 4090 Trinity ist gestern gekommen. Was ein Klopper. Die 3070 Gaming X Trio ist schon fett. Dachte ich.
Die Leistung ist zweifelsohne brachial. Das letzte mal, dass ich so geflashed war müsste 2015 gewesen sein als ich meine 1. SSD eingebaut habe.
Habe noch die erste Revision mit dem AD102-300 Chip.
Der 12VHPWR Anschluss ist auf gut deutsch gesagt beschissen. Ich hab die ganze Zeit das Gefühl der sitzt nicht richtig oder löst sich sobald ich irgendwas im PC mache (was natürlich kaum vorkommt, aber ihr wisst schon).
Naja, wenigstens muss ich nicht diese Ausgeburt von Adapter nutzen da mein Netzteil ein MSI A850G PCIE5 ist.
Lüfter sind auch eher mittel. Für so ein Produkt sollte jede Customkarte 1A Lüfter mitbringe. Werde daher die Lösung aus einem anderen Thread nehmen. Sehr geil das es sowas gibt.
Ja, das ging mir genau so, musste echt zweimal hinschauen wie gut das alles lief plötzlich.
Falls jemand Hitman 3 und eine Zotac, PNY oder andere 450W Limit Karte hat, könnt ihr mal 4k mit RT laufen lassen und sagen wie viel sich die Karte zieht? Gerne auch den Benchmark laufen lassen und Werte posten.
Naja da ist ja auch ein Wasserblock montiert. Wenn du den Kühler runter nimmst sieht das schon anders aus :d
NV Lovelace - war wohl nix mit ITX. :sneaky:
Brauch ein ITX Case mit gutem Air Flow in das ich aber trotzdem 280+360 Radi bekomme, zur Not auch noch 280 + 280. o_O
@IronAge
Vielleicht wäre der Stil von Optimum Tech etwas für dich? Ist natürlich übelst zusammengepackt, aber das musst du natürlich selbst entscheiden. Ich persönlich würde das nur mit einem MORA tolerieren.
Ähnliche Themen
