[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Open RGB geht, zumindest für die normalen LEDs. ich habe noch eine AiO mit Display und die geht nur über Armory Crate. Habe Open RGB dann wieder runtergeschmissen und nutze einfach Armory Crate für alles. Habe auch ehrlich gesagt 0 Probleme damit und die Systemauslastung durch die Dienste ist auf einem High End Rechner auch nicht der Rede wert. Zwischen 0-1%.
Was mir jetzt noch zur Asus 4090 LC aufgefallen ist, dass die wahrscheinlich nur ein 450 Watt Bios hat, denn Asus gibt eine Netzteil Empfehlung für 850 Watt raus und nicht wie bei der normalen Strix mit 1000 Watt:
Obwohl die normale Strix auch nur offiziell mit einer TDP von 450 Watt angeben wird, was meint ihr dazu, wie wird das bei der LC sein?
Ja das wird schon reichen. :)
Hallo Community, ich verbaue die Tage eine 4090 und habe aktuell ein ziemlich neues Bequiet Straight Power 11verbaut. https://www.mindfactory.de/product_...raight-Power-11-Modular-80--Gold_1223022.html
Denkt ihr das reicht oder lieber was neues?
Restliches System.
Asus Strix B650E
AMD 7800X3D
1x Samsung 980 2TB M.2 PCIE4.0
NZXT 240 Wakü
PS: Es soll nichts übertaktet werden. :giggle:
Bei der Gold Version kann es auch sein das es zu wenig ist. Mein straight Power 11 850w hat bei der 3090 und dem 5950x abunzu ausgeschaltet. Aber ist wohl nicht die Regel :)
Wenn es eine 4090 mit einer TDP von 450 Watt ist sollte das aber klappen.
Eine von beiden wird es wohl werden. Frage ist ob sich die 200€ mehr lohnen für die Asus Karte. :unsure:
Die Tuf könnte man bis 600 Watt verbrauchen lassen, die Palit liegt bei 450 Watt mit dem original Bios.
Bei Palit verwirkst du außerdem den Garantie-Anspruch mit dem Umbau auf Wakü.
Ich möchte nix umbauen und Garantie haben beide karten 3 Jahre was ich auch ganz gut finde, 2 jahre bei fast 2000€ finde ich eher naja aber das ist meine persöhnliche meinung. :giggle:
Der Service von Palit ist noch bescheidener als der von Asus, und das will schon was heißen.
Nach zwei Jahren verweigern Händler für diesen Hersteller häufig auch die Garantie-Abwickelung.
So lang du das Teil nur zwei Jahre nutzen möchtest geht es vielleicht noch.
Vermutlich wird es auch ein OC Bios mit Target 500W und Limit 600W geben.
Gut dein Wort in Gottes Ohr! ;)
Habe bei ARLT eine bestellt zu 2.199 denn die Preise scheinen nach oben zu gehen für die LC zumindest zum Start jetzt:
Kennt jemand eine Vergleichstest zu den Zotacs untereinander?
Also die 4090 vs. 4090 OC und der AMP?
Leistung vs. Leistungsaufnahme, Lautstärke,usw?
Wie sind eure Erfahrungen mit den Zotac Karten?
Hat sich bestätigt. Siehe hier.
Hat wirklich niemand eine 4090 im Dual Monitor Betrieb ? Gehen bei euch die Lüfter auf dem Desktop aus, wenn man nicht zockt ?
bei der PNY gehen die aus, trotz dual monitor ... unter 20 Watt Verbrauch bei UWQHD + FullHD Display
Es gibt leider nur wenig Bilder zur neuen TUF OG…
Hat aber ganz schön abgespeckt die Karte.
Die Sparvariante brauchen die mir aber nicht andrehen falls meine TUF OC mal ein Garantiefall werden sollte^^
Interessant ist. dass die neue TUF auch nur noch mit 850 Watt Netzteil Empfehlung angeben ist statt zuvor mit 1000 Watt, ob die auch kein 600 Watt Bios mehr hat?
Gibt's eigentlich mal was neues wegen einer möglichen 4090ti oder titan? Wegen dem wichtigem Kühler... Würde mich mal interessieren was nvidia da rum zaubert...
Wäre mir neu, dass eine 1000W Empfehlung drauf stand. Auf den beiden Asus Seiten zur TUF OC & non OC stehen auch 850W. Schwer abzuleiten, ob sie weiterhin ein 600W Bios hat.
Das recycelte 3090 Ti sollte sicherlich in der Lage sein 600W bereitzustellen. :unsure:
Hab gedacht, dass nur der Kühler kleiner ist, bei der OG. Aber das komplette PCB ist anders und deutlich länger :unsure:
Sind auch weniger Phasen . Vielleicht auch ein geringeres PL .
Zum testen was Chip und Speicher packt durchaus interessant . Die abgespeckte TUF würde ich selber nicht kaufen wollen .
Ähnliche Themen
Antworten
6K
Aufrufe
392K
