[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Designfehler bleibt Designfehler. Gelber Stecker ist zwar von Vorteil, aber es kann ja nicht sein, dass die Kable bei der kleinsten horizontalen Bewegung aus dem Port flutschen...trotz eingerastetem Clip.
Ich finde eher um die Ports sollte zumindest oben und seitlich rum ne Führung hin die verhindert, dass man den Stecker in irgendeine Richtung horizontal und vertikal verwackeln kann. Einfach nur gerade rein und raus, ohne Spiel in eine andere Richtung.
In Sachen Abstand zur Backplate könnte es mit dem Wireview wohl eher zu Inkompatibilitäten kommen als wie mit dem CableMod-Adapter:
Kannst du mal den Abstand messen zwischen den beiden Ports, würde gerne wissen wie hoch die Backplate maximal abstehen darf.
Denke gerade bei Karten mit Wasserblöcken könnte es hier häufiger Probleme geben, weil die Backplates meist dicker sind in der Höhe als die originalen Backplates und oftmals auch weiter abstehen vom PCB
Wähhz .. meine Tuf gibt auf.
Geht nach 10 Sekunden Last aus. Manchmal auch nach längerer Zeit am Desktop. Mit dem Disconnet Geräusch von Windows.
Rote Lampe am Stromanschluss geht Flackernd an.
Rechner läuft weiter, kann ich mit Blind Alt F4 Return runterfahren.
Ausbauen, Wakü runter, RMA. Hab ich ja gar keinen Bock drauf. Und das nach gerade mal 8 Monaten Betrieb.
meine karte läuft schön bei 50-70% load mit niederigem pt. schonmodus :fresse:
Mal eine Frage, kann es sein das ein 4090 normal unter Win läuft und immer dann wenn Anwendungen wie Spiele oder 3DMark gestartet wird,
nach kurzer Zeit der PC einfriert? Manchmal kehrt er zurück auf die Win Oberfläche, meistens kann man ihn nur ausschalten. Die Karte lief ohne
Probleme und von jetzt auf nachher dieses Problem.
Ich habe Win 11 komplett neu drauf und nur den aktuellen Nvidia Treiber. Sonst läuft nichts auf dem Rechner. Speichertest erfolgreich keine
Fehlermeldungen etc.
Bin sehr gespannt wie das bei der Marke ablaufen wird.
Drücke dir die Daumen das es reibungslos von statten geht.
Also muss sagen, dass die Kühlung durch die 360er AIO der Gigabyte Waterforce sehr gut funktioniert, hier 2 Stunden Gaming mit OC:
Da kann man doch nicht meckern, oder was meint ihr?
Ich musste Ende Februar / Anfang März eine RMA für ne 4090 TUF (gekauft im Asus Onlineshop) starten, die ich auf Wakü umgebaut hatte.
Nach Eingang der Karte laut DHL Tracking ist dann direkt 1-2 Tage später der Kaufpreis erstattet worden.
Wurde so abgewickelt, da mir keine Austauschkarte zur Verfügung gestellt werden konnte.
"Gerne bieten wir Ihnen an dieses zur Prüfung zurückzunehmen. Prozessbedingt können wir Ihnen, sofern der Schaden von der Garantie abgedeckt wird, nur eine Erstattung anbieten."
komisch aber wenn du den kaufpreis bekommst ist das natürlich gar nicht so übel. andere karte geholt, mehr geld über^^
@Holzmann
Also entweder lässt Du Dein System nach dem Zocken noch ne halbe Ewigkeit ideln, bevor Du die Screenshots von GPU-Z erstellst oder Du hattest während des Zockens keine konstante Auslastung. :unsure:
So hab ich es mit meiner Zotac gemacht und 400€ zurückbekommen 😂
@Holzmann
Besonders zu sehen sind die 2 kurzen Peaks auf 3000Mhz, da kam ja nie und nimmer genügend Wärme an um etwas runterkühlen zu lassen.
Wollte nur die Temps mal zeigen, GPUZ lief im Hintergrund, ja der screen ist mit Verzögerung entstanden, so dass die Auslastung jetzt wenig Bezug hat.
Hätte ich auch nichts dagegen . 2250€ zurück und dann ne FE zur UVP gekauft :d
Bisher zumindest on Air ist meine TUF OC noch in einem guten Zustand . OC Fähigkeit letztens noch getestet . Sowohl GPU und Speicher gleich geblieben .
Dann hat der Screenshot genau null Aussagekraft, da du den Avg zeigst bei den Werten die relevant sind und Max bei denen die dir gefallen.
@Nastya
Что тут смешного 🤔
Может быть будет правда так! 😆🤭
так тебе и надо :sneaky:
Hast ja gesehen was dabei rauskam ))
On-topic: hat jemand kürzlich eine Gigabyte 4090 Gaming OC gekauft und ein neueres BIOS as die auf Techpowerup? Würde gerne wissen, ob es auch mit neueren Chargen noch Probleme mit der Lüftersteuerung gibt.
Genau, Frauenhandel usw 🤣
Ich habe eine Gigabyte 4090 Gaming OC! Habe aber das normale BIOS drauf und habe keine Lüfterprobleme... Aber danke für den Hinweis, wusste nichts vom neueren BIOS 🤔
Derzeit auf silent und es gefällt mir sehr gut in Kombi mit Undervolting.
Das sind doch Werte, die mit Luftkühler locker erreicht werden können? Für ne Wasserkühlung finde ich das nicht gut. Aber gut, ist ne AIO, keine echte Wasserkühlung.
Aber nicht nahezu lautlos.
Ausserdem möchte ich den Luftkühler sehen, der über 2 Stunden knapp 600 Watt abführt mit den Temps ;)
Meinst du es gibt Probleme mit dem RMA? Offiziell gibts ja keine Garantie auf Kühlerwechsel.
Gibts bei Gigabyte und Nvidia auch nicht, und trotzdem machen sie keine Probleme. Kommt halt immer drauf an wie Du arbeitest denke ich.
Sieht man das der Lüfter runter war, oder sieht man es nicht.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
