[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Jetzt gehts ab :ROFLMAO: Shitstorm incoming, Nvidia
Ist das das Ursprungsvideo von der Reparaturfirma?
Dann ists ja schon gar nicht mehr aktuell bzw. aufgeklärt. Siehe hier:
Vielleicht vorher mal auf YT gehen und gucken wann das Video von Northridge gepostet wurde. Es ist aktueller
und ist die Antwort auf dein Video vom heiligen Steve.
Northridge Video vom 21.5
GN vom 20.5
Über 200 defekte Karten ist schon einiges
Habe ich das richtig verstanden, die Karten, die er bekommt hatten alle den Cable Mod Adapter drauf? Und er ist Partner von Cable Mod? Kann mich natürlich verhört haben. Oder waren da auch NVidia Adapter oder native PSU 12hvpwr Kabel dabei?
Nein, etwas anders. J2C (auch Cablemod Partner) berichtet, dass Cablemod eine Garantie anbietet (keine Ahnung ob nur USA oder vielleicht auch Weltweit), also wenn eine 4090 mit deren Adapter verschmilzt, kauft Cablemod die Karte auf zum originalen Kaufpreis des Users, lässt diese dann bei Northridge reparieren und bringt diese wieder in Umlauf.
Cablemod hat wohl bisher 8 Karten zu Northridge gesendet (Nachfrage von GN an Cablemod).
Northridge selbst hat in dem Video angegeben, dass er einen massiven Anstieg von 4090 Reperaturen wegen verbrannten Steckern in der letzten Zeit verzeichnet. Anscheinend auch Karten mit Cablemod Adaptern die zu 100% drinnen stecken.
Dazu kommt noch, dass das Kokeln laut J2C immer im Stecker der Karte stattfindet und nicht an den Kabeln die in den Cablemod Adapter reingehen. Ebenso wundert er sich, dass das Problem zB. nicht bei der 3090Ti besteht, obwohl die Karte auch gerne 500W zieht. Es scheint ein 4090 Problem zu sein, da wohl keine 4080 und 4070 betroffen sind. Also anscheinend die hohe Anzahl an Watts die durch den Stecker an der Karte laufen.
Cablemod sagte auf Anfrage von J2C, wieso jetzt wieder diese verschmolzenen Stecker auftauchen, dass das Problem weiterhin bestanden hat, auch nach dem Video von GN und nie verschwunden war.
GN vermutet laut Northridge, die User könnten mit den originalen Adaptern oder PSU-Kabeln schmelzende Stecker verursacht haben und dann den Cablemod Adapter in den Stecker reingepresst haben, was ich doch etwas bei den Haaren herbeigezogen empfinde.
Also GN besteht weiterhin auf dem Standpunkt der User sei schuld, J2C und Northridge sind der Meinung das Problem bestehe bei Nvidia, weil A. So ein fehleranfälliges Produkt auf den Markt zu bringen kann man nicht auf den User schieben und B. scheint es ein Problem direkt an der Karte zu sein, da nicht die Kabel am Netzteil oder auch vor dem Cablemod Adapter kokeln, sondern immer direkt an der Karte.
GN versucht natürlich seine Aussage zu den Steckern zu verteidigen und Nvidia war vorher fein raus, waren ja alles die User schuld laut GN.
In den Kommentaren unter dem Northridge Video ist häufig zu lesen, man würde GN nicht wirklich vertrauen, weil zu nah an der Industrie (Nvidia) dran. Ebenso ließt man häufiger, das User Jahrzehnte GPUs benutzen bzw. PC bauen und es nie Probleme gab mit den 8-Pin/6-Pin Steckern und nun sollen alle User Plötzlich zu blöde sein die Stecker richtig einzustecken.
Mich würde interessieren bei wie viel Watts die ganzen defekten Karten betrieben wurden. Hier im Forum scheinen die meisten ja ihre Karten im UV zu betreiben, also irgendwas zwischen 250W bis 350W und man würde auch hier ab und zu was lesen von verschmorten Steckern... wahrscheinlich weltweit aber ich denke die meisten betreiben ihre Karten nicht bei 600W (sind ja real eher was um die 500W - 550W) sondern im UV.
Natürlich kann man die Karte kaufen, in den PC stecken und dann entweder ohne UV in Stock-Mode betreiben wo sie dann gerne 500W zieht oder sogar noch nen OC drauf bis Anschlag, wo die Karte dann noch mehr Watts zieht.
Eine Lösung des Problems wäre dann alle Karten mit nem Bios Update auf max. 450W zu limitieren. Bei neuen Karten kann man das dann sofort machen. Mit Karten die bereits im Umlauf sind, ist das dann so ne Sache.
So und ich bin ebenfalls betroffen, kein Scheiß, habe nen Cablemod Adapter und bekomme diesen nicht mehr aus der Karte raus. Wollte das gerade überprüfen, Kabel aus dem Cablemod Adapter bekomme ich raus, Adapter aus Karte ist fest.
Das kann doch wohl nicht wahr sein.
Sehe auch den Fehler bei Nvidia, aber die werden das eh nie zugeben.
Ja nvidia meinte die User sind schuld und können nicht richtig einstecken:) bzw biegen des adapters wäre unzulässig obwohl enge radien in cases normal sind :) naja warten wir mal ab.
Mich würde interessieren bei wie viel Watts die ganzen defekten Betrieben wurden. Hier im Forum scheinen die meisten ja ihre Karten im UV zu betreiben, also irgendwas zwischen 250W bis 350W und man würde auch hier ab und zu was lesen von verschmorten Steckern... wahrscheinlich weltweit aber ich denke die meisten betreiben ihre Karten nicht bei 600W (sind ja real eher was um die 500W - 550W) sondern im UV.
Mach uns keine Sorgen ich hab auch n cablemod Adapter:)
Ich kriege ihn nicht raus, bombenfest. Der steckt zu 100% auf Anschlag drinnen, keine Lücke zwischen den Steckern zu sehen. Alter Schwede was ein Bullshit.
Kurzes Video mit Versuch den Adapter rauszuziehen:
Das Knacken kommt vom Adapter, wenn ich da noch mehr dran ziehen würde, würde entweder der Adapter zerbrechen oder ich würde den Connector vom Board reißen.
Da kanns unterschiedliche Gründe geben.
Z.b. könnte es sein, dass die 3090 Ti-Karten deutlich seltener gekauft worden sind als die 4090er.
Stecker/Buchse der 3090Ti mögen vielleicht von Außen betrachtet so aussehen, als wäre es das gleiche wie bei der 4090. Eventuell hat man für die 4090 die Toleranzen zwischen Buchse und Pin mehr in Richtung Presspassung gewählt um den Übergangswiderstand zu reduzieren.
Durch diese Erhöhung der Anpresskraft steigt nun aber auch der Kraftbedarf zum Einstecken und schon steigen die Chancen, das ein User, der sich nicht dafür interessiert, ob die Verriegerlung eingerastet ist oder nicht, den Stecker nicht weit genug einsteckt.
12 Kontakte bedeuten halt auch eine nochmal höhere notwendige Kraft als nur 8 Kontakte.
Ich kann mir leider nicht alle Videos etc anschauen. Kann mir bitte kurz jemand sagen, liegt es an den CableMod Adaptern? Ich nutze auch so einen Adapter und möchte keine Probleme bekommen.
Was ein Mist heut zu Tage. 2K€ GPU und man muss sich Sorgen machen. 500€ CPU und auch da können Probleme enstehen. Wahnsinn :/
Man weiß es aktuell noch nicht. Ich kann nur soviel dazu sagen:
Das Kabel was im Cablemod Adapter steckt, war vorher direkt an der Karte, aber mit massiver Biegung und ich hatte keine Probleme.
Hab dann den Adapter geholt wegen Entlastung am Connector und jetzt sind Karte und Adapter verschmolzen.
Jeder der so nen Adapter hat sollte jetzt schleunigst checken ob er das Problem ebenso hat.
Meine Karte läuft seit Tag 1 mit Galax 666W Bios, Seasonic Kabel, alles paletti. Irgendwelche Adapter / Stecker von 3. Anbietern verwenden und den Fehler bei Nvidia suchen, yay :fresse:
Keine Panik, glaube nicht das da so einfach was verschmolzen ist.
Kenne das von diversen PCIE Steckern, musste da auch schon Stecker abschneiden weil es sich nicht lösen lies.
Ist eher ein Zeichen das alle Kontakte perfekt halten. Im Unterschied dazu gibt es auch Verbindungen die sind derart locker das man sich fragt ob da überhaupt Steckverbindungen drinnen sind.
Was das Video eigentlich aussagt ist das es nicht sein kann das dem User der Schwarze Peter in die Schuhe geschoben wird. Sind eben diverse Faktoren die dazu führen können das es hier zu Problemen kommen kann.
Mit der nötigen Sorgfalt und dem Wissen was man möglichst vermeiden sollte dürfte da nichts passieren..
Ja bei wem soll der Fehler denn sonst liegen. Der Cablemod Adapter ist nix anderes als dein Seasonic Kabel. Entweder das Problem besteht bei Cablemod oder bei Nvidia. Besonders weil der Adapter zu 100% drinnen steckt und auch noch eingeklipst ist.
Was wäre denn bitte, wenn du nen TV kaufst und dann kriegst du das HDMI Kabel nicht mehr entfernt, weil es im HDMI-Port verschmolzen ist, aber trotzdem funktioniert. Ist das dann dein Vergehen oder wie? Wohl eher liegt das Problem beim TV-Hersteller oder HDMI-Kabel-Hersteller.
Und Cablemod ist jetzt kein günstig-günstig Chinaramschhersteller.
Dazu wird die Karte im UV betrieben, also 350W maximal und hat nicht einmal mehr als 350W gesehen nachdem der Adapter eingebaut wurde.
Weil Du ihn nicht ab bekommst, bist Du Dir sicher, das da etwas verschmolzen ist?
Und das soll passiert sein, ohne das es sich überhaupt bemerkbar gemacht hätte (Geruch z.B.)?
Der ist zu 100% verschmolzen. Weil da bewegt sich innerhalb des Steckers absolut nichts. Wenn ich das Kabel vom Adapter ziehe merkt man ein minimales Spiel und kann den Stecker ziehen.
Habs gerade nochmal versucht, die Klammer mit nem Plastiktool soweit angehoben das sie frei liegt und dann versucht den Adapter parallel zur Kante abzuziehen mit ein wenig Bewegung nach links und rechts, da bewegt sich nix. Dieses leichte Spiel zwischen Stecker und Connector fehlt völlig. Das ist so fest miteinander verbunden, das sich rein garnix irgendwie bewegt.
Nein gerochen habe ich nix, auch wenn ich mit der Nase nah ran gehe ist nichts zu riechen.
Da reicht ja auch nur eine Mindesttemperatur um das Plastik (vielleicht auch nur kurzfristig) etwas zu verflüssigen und beim Erkalten sind die dann ausreichend miteinander verbunden... und das riecht man ja nicht unbedingt.
Naja, zumindest funktioniert die Karte, daher mache ich mir was das angeht keine großen Sorgen. Aber zwecks Weiterverkauf irgendwann ist das ziemlich bescheiden. ich habe Cablemod mal angeschrieben inkl Fotos und Video. Bei Reddit wurde zumindest der Eindruck erweckt, das Cablemod die Karte irgendwie tauscht. Alternative wäre sich nen Connector zu besorgen und die Karte reparieren zu lassen
Du möchtest die Karte so weiter nutzen?
Davon kann nur abgeraten werden.
Cablemod Mitarbeiter bei Reddit:
We've sold tens of thousands of these already and the RMA rate is 0.0001% - nothing to worry about with our products, even if something did go wrong, we would fully take care of it. That's the CableMod way, just like we're taking care of this user with a new GPU.
Ich warte mal ab was Cablemod schreibt.
Die Karte läuft seit über 2 Monaten mit dem Adapter daher mache ich mir da keine Sorgen. Da sind schon etliche Stunden und Tage 350W durchgelaufen.
Überlege mir gerade ein Laser-Thermometer zu bestellen um zumindest mal zu gucken was der Connector unter Last so macht.
Und dran rum reißen werde ich sicherlich nicht, gerade weil ich abwarte wie Cablemod sich verhält. Falls die Tauschen oder Ersetzen können die sich um ihren Stecker kümmern.
Passiert laut Cablemod auch mit Corsair Kabeln
Und soll anscheinend an den SensPins liegen.
Panik is back! 😱
Wir werden alle sterben, schon wieder 😈
Bin gechillt, habe auch den Cablemod Adapter drauf, gestern 2h lang Metro Exodus mit 500W durchgeballert, alles cool in da house. Heute gehts weiter, froi mich schon wieder auf DLDSR 2,25x +DLSS alles maxxed. Da bleibt keine Kapazität um an einen Kack Adapter zu denken. (y)
Thread hier war eh fast tot, jetzt kommt wieder leben hier rein, Angst und Terror bringt die Menschen (Schneeflocken) zusammen 🤣
Ist die Frage ob man sich verängstigen lässt. Für mich als betroffenen erstmal blöd, aber ich warte erstmal ab. Mir gehts eher darum, dass die Karte mit nem Adapter der sich nicht mehr entfernen lässt auch somit nicht so gut weiterverkaufen lässt.
So, habe ne Antwort von CableMod bekommen. Man hat eine Rückerstattung des Adapters beantragt und ich soll erstmal ne RMA-Anfrage beim Hersteller starten. Gut, hab jetzt also mal ne Support-Anfrage bei Zotac gestartet, gehe aber davon aus, dass die sich weigern werden. Falls das eintritt, werde ich mich nochmal an Cablemod wenden.
Mir ist aber aufgefallen, dass der Adapter bei 350W extrem heiß wird, so heiß, dass ich meine Finger kaum draufhalten kann.
Ist das bei euch auch so?
Hier wurde zumindest geschrieben es sei "normal", aber ich finde das eigentlich ne Nummer zu heiß:
Ähnliche Themen
Antworten
7K
Aufrufe
490K
